  4. [gelöst] LG Adapter Problem
11 Beiträge 3 Kommentatoren 980 Aufrufe 3 Beobachtet
    deta
    schrieb am zuletzt editiert von deta
    nach einen System problem, hab ich jetzt das Problem, das der Adapter sich nicht mehr installieren lässt.
    Was ist hier das Problem?
    $ iobroker add lgtv auto --host rock64 --debug
    NPM version: 9.8.1
    Installing iobroker.lgtv@2.1.1... (System call)
    npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutil
    npm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | arm64npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:245047) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.50-current-rockchip64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T11_19_59_385Z-debug-0.log
    npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | arm64npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:245047) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.50-current-rockchip64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T11_19_59_385Z-debug-0.log
    host.rock64 Cannot install iobroker.lgtv@2.1.1: 1
    ERROR: Process exited with code 25
    mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
    • D deta
      NPM version: 9.8.1
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @deta
      https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update ?
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • D deta
        NPM version: 9.8.1
        @deta
        Gib mal die Ausgabe von
        iob diag
        zum Besten.
        • mcm1957M mcm1957
          @deta
          deta
          @mcm57 leider brachte iob fix nichts
            @deta
            iob diag
            zum Besten.
            deta
            Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
            The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
            Just copy and paste the Summary Page, including the ``` characters at start and end.
            It helps us to help you!
            Press any key to continue
            ======== Start marking the full check here =========
            Skript v.2023-10-10
            *** BASE SYSTEM ***
             Static hostname: rock64
                   Icon name: computer
            Operating System: Armbian 23.8.3 bookworm
                      Kernel: Linux 6.1.50-current-rockchip64
                Architecture: arm64
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             13:40:05 up 10 min,  2 users,  load average: 2.66, 3.98, 2.57
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Thu 2023-10-19 13:40:06 UTC
                       Universal time: Thu 2023-10-19 13:40:06 UTC
                             RTC time: Thu 2023-10-19 13:40:06
                            Time zone: Etc/UTC (UTC, +0000)
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            rock
            /home/rock
            rock sudo users iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            4.2G        2.4G        1.3G        6.0M        497M        1.8G
            Swap:           2.1G          0B        2.1G
            Total:          6.3G        2.4G        3.4G
                     3974 M total memory
                     2305 M used memory
                     2202 M active memory
                      232 M inactive memory
                     1282 M free memory
                       43 M buffer memory
                      430 M swap cache
                     1987 M total swap
                        0 M used swap
                     1987 M free swap
            *** FAILED SERVICES ***
              UNIT                              LOAD   ACTIVE SUB    DESCRIPTION
            * mnt-raspi\x2ddatensicherung.mount loaded failed failed /mnt/raspi-datensicherung
            1 loaded units listed.
            *** FILESYSTEM ***
            udev           devtmpfs  1.9G     0  1.9G   0% /dev
            tmpfs          tmpfs     398M  5.7M  392M   2% /run
            /dev/mmcblk0p1 ext4       29G  4.8G   24G  17% /
            tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     2.0G     0  2.0G   0% /tmp
            /dev/zram1     ext4       47M  2.9M   41M   7% /var/log
            tmpfs          tmpfs     398M     0  398M   0% /run/user/1001
            [Thu Oct 19 13:29:35 2023] Kernel command line: root=UUID=3941c09f-f61e-41a9-a178-95c32383f0d6 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=45b7c889-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
            [Thu Oct 19 13:29:39 2023] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
            [Thu Oct 19 13:29:42 2023] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
            [Thu Oct 19 13:29:45 2023] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
            Show mounted filesystems \(real ones only\):
            TARGET         SOURCE                   FSTYPE OPTIONS
            /              /dev/mmcblk0p1           ext4   rw,noatime,errors=remount-ro,commit=600
            |-/var/log.hdd /dev/mmcblk0p1[/var/log] ext4   rw,noatime,errors=remount-ro,commit=600
            `-/var/log     /dev/zram1               ext4   rw,relatime,discard
            /var:
            426M    /var/
            280M    /var/cache
            275M    /var/cache/apt
            204M    /var/cache/apt/archives
            132M    /var/lib
            No journal files were opened due to insufficient permissions.
            /opt/iobroker/backups:
            16M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.1G    /opt/iobroker/iobroker-data/
            531M    /opt/iobroker/iobroker-data/history
            523M    /opt/iobroker/iobroker-data/files
            90M     /opt/iobroker/iobroker-data/files/echarts.admin
            78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            USB-Devices by-id:
            USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_70a5b0635fd9eb119fe1158e6fe9f4d9-if00-port0
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.18.2
            /usr/bin/node           v18.18.2
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            /usr/bin/corepack       0.19.0
            nodejs:
              Installed: 18.18.2-1nodesource1
              Candidate: 18.18.2-1nodesource1
              Version table:
             *** 18.18.2-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                    100 /var/lib/dpkg/status
                 18.18.1-1nodesource1 500
                 18.18.0-1nodesource1 500
                 18.17.1-1nodesource1 500
                 18.17.0-1nodesource1 500
                 18.16.1-1nodesource1 500
                 18.16.0-1nodesource1 500
                 18.15.0-1nodesource1 500
                 18.14.2-1nodesource1 500
                 18.14.1-1nodesource1 500
                 18.14.0-1nodesource1 500
                 18.13.0+dfsg1-1 500
                 18.13.0-1nodesource1 500
                 18.12.0-1nodesource1 500
                 18.11.0-1nodesource1 500
                 18.10.0-1nodesource1 500
                 18.9.1-1nodesource1 500
                 18.9.0-1nodesource1 500
                 18.8.0-1nodesource1 500
                 18.7.0-1nodesource1 500
                 18.6.0-1nodesource1 500
                 18.5.0-1nodesource1 500
                 18.4.0-1nodesource1 500
                 18.3.0-1nodesource1 500
                 18.2.0-1nodesource1 500
                 18.1.0-1nodesource1 500
                 18.0.0-1nodesource1 500
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.14
            admin:          6.10.8
            javascript:     7.1.5
            Adapters from github:   0
            Adapter State
            + system.adapter.admin.0                  : admin                 : rock64                                   -  enabled, port: 8081, bind: 192.168.178.61, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : rock64                                   -  enabled
              system.adapter.alias-manager.0          : alias-manager         : rock64                                   - disabled
              system.adapter.awattar.0                : awattar               : rock64                                   -  enabled
            + system.adapter.backitup.0               : backitup              : rock64                                   -  enabled
            + system.adapter.broadlink2.0             : broadlink2            : rock64                                   -  enabled
              system.adapter.coronavirus-statistics.0 : coronavirus-statistics: rock64                                   -  enabled
              system.adapter.daswetter.0              : daswetter             : rock64                                   -  enabled
            + system.adapter.discovergy.0             : discovergy            : rock64                                   -  enabled
            + system.adapter.discovery.0              : discovery             : rock64                                   -  enabled
            + system.adapter.echarts.0                : echarts               : rock64                                   -  enabled
            + system.adapter.enigma2.0                : enigma2               : rock64                                   -  enabled
              system.adapter.feiertage.0              : feiertage             : rock64                                   -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : rock64                                   -  enabled
            + system.adapter.harmony.0                : harmony               : rock64                                   -  enabled
            + system.adapter.heatingcontrol.0         : heatingcontrol        : rock64                                   -  enabled
            + system.adapter.history.0                : history               : rock64                                   -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : rock64                                   -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : rock64                                   -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : rock64                                   -  enabled, port: 0
              system.adapter.ical.0                   : ical                  : rock64                                   -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : rock64                                   - disabled
              system.adapter.icons-material-png.0     : icons-material-png    : rock64                                   - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rock64                                   - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: rock64                                   - disabled
            + system.adapter.info.0                   : info                  : rock64                                   -  enabled
            + system.adapter.iot.0                    : iot                   : rock64                                   -  enabled
            + system.adapter.javascript.0             : javascript            : rock64                                   -  enabled
              system.adapter.linux-control.0          : linux-control         : rock64                                   - disabled
            + system.adapter.mielecloudservice.0      : mielecloudservice     : rock64                                   -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : rock64                                   -  enabled, port: 1891, bind: 192.168.178.61
              system.adapter.netatmo-crawler.0        : netatmo-crawler       : rock64                                   -  enabled
            + system.adapter.radar2.0                 : radar2                : rock64                                   -  enabled
              system.adapter.scenes.0                 : scenes                : rock64                                   - disabled
              system.adapter.schoolfree.0             : schoolfree            : rock64                                   -  enabled
            + system.adapter.simple-api.0             : simple-api            : rock64                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.socketio.0               : socketio              : rock64                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : rock64                                   -  enabled, port: 1883, bind: 192.168.178.61
              system.adapter.synology.0               : synology              : rock64                                   - disabled, port: 5001
            + system.adapter.tankerkoenig.0           : tankerkoenig          : rock64                                   -  enabled
            + system.adapter.telegram.0               : telegram              : rock64                                   -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : rock64                                   -  enabled
            + system.adapter.tr-064.0                 : tr-064                : rock64                                   -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : rock64                                   -  enabled
            + system.adapter.tuya.0                   : tuya                  : rock64                                   -  enabled
              system.adapter.tvspielfilm.0            : tvspielfilm           : rock64                                   - disabled
            + system.adapter.upnp.0                   : upnp                  : rock64                                   -  enabled
              system.adapter.vis-bars.0               : vis-bars              : rock64                                   - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : rock64                                   - disabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : rock64                                   - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : rock64                                   - disabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : rock64                                   - disabled
              system.adapter.vis-history.0            : vis-history           : rock64                                   - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : rock64                                   - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : rock64                                   - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : rock64                                   - disabled
              system.adapter.vis-metro.0              : vis-metro             : rock64                                   - disabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : rock64                                   - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : rock64                                   - disabled
              system.adapter.vis-weather.0            : vis-weather           : rock64                                   - disabled
              system.adapter.vis.0                    : vis                   : rock64                                   - disabled
            + system.adapter.web.0                    : web                   : rock64                                   -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
            + system.adapter.wifilight.0              : wifilight             : rock64                                   -  enabled
            + system.adapter.zigbee.0                 : zigbee                : rock64                                   -  enabled, port: /dev/ttyUSB0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): beta
            Installed ioBroker-Instances
            Used repository: beta
            Adapter    "admin"        : 6.10.8   , installed 6.10.8
            Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
            Adapter    "alias-manager": 1.2.6    , installed 1.2.6
            Adapter    "awattar"      : 1.0.6    , installed 1.0.6
            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
            Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
            Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
            Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
            Adapter    "discovery"    : 4.2.0    , installed 4.2.0
            Adapter    "echarts"      : 1.5.4    , installed 1.5.4
            Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
            Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
            Adapter    "fritzdect"    : 2.5.2    , installed 2.5.2
            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
            Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
            Adapter    "history"      : 3.0.0    , installed 3.0.0
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
            Adapter    "ical"         : 1.13.3   , installed 1.13.3
            Adapter    "icons-material-png": 0.1.0, installed 0.1.0
            Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
            Adapter    "info"         : 2.0.0    , installed 2.0.0
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.1.5    , installed 7.1.5
            Controller "js-controller": 5.0.14   , installed 5.0.14
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
            Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "radar2"       : 2.0.8    , installed 2.0.8
            Adapter    "scenes"       : 2.3.9    , installed 2.3.9
            Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
            Adapter    "socketio"     : 6.6.0    , installed 6.6.0
            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
            Adapter    "synology"     : 3.0.1    , installed 3.0.1
            Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
            Adapter    "telegram"     : 2.0.1    , installed 2.0.1
            Adapter    "text2command" : 3.0.2    , installed 3.0.2
            Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
            Adapter    "tuya"         : 3.14.2   , installed 3.14.2
            Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
            Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
            Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
            Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
            Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
            Objects and States
            Objects:        15231
            States:         9695
            Hit:2 http://security.debian.org bookworm-security InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 http://deb.debian.org/debian bookworm-backports InRelease
            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            Hit:6 http://fi.mirror.armbian.de/apt bookworm InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 192.168.178.61:1883     0.0.0.0:*               LISTEN      1000       20510      1519/io.sonoff.0
            tcp        0      0 192.168.178.61:1892     0.0.0.0:*               LISTEN      1000       18821      1501/io.mqtt.0
            tcp        0      0 192.168.178.61:1891     0.0.0.0:*               LISTEN      1000       18820      1501/io.mqtt.0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       11260      897/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       15124      897/iobroker.js-con
            tcp        0      0 192.168.178.61:2010     0.0.0.0:*               LISTEN      1000       17357      1445/io.hm-rpc.0
            tcp        0      0 192.168.178.61:8082     0.0.0.0:*               LISTEN      1000       21458      2206/io.web.0
            tcp        0      0 192.168.178.61:8081     0.0.0.0:*               LISTEN      1000       18524      1338/io.admin.0
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14314      1/init
            tcp        0      0 192.168.178.61:8701     0.0.0.0:*               LISTEN      1000       18726      1468/io.hm-rpc.1
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14971      1009/sshd: /usr/sbi
            tcp6       0      0 :::5201                 :::*                    LISTEN      103        16086      899/iperf3
            tcp6       0      0 :::8084                 :::*                    LISTEN      1000       21400      2029/io.socketio.0
            tcp6       0      0 :::8087                 :::*                    LISTEN      1000       19236      2005/io.simple-api.
            tcp6       0      0 :::111                  :::*                    LISTEN      0          14315      1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14973      1009/sshd: /usr/sbi
            tcp6       0      0 :::61991                :::*                    LISTEN      1000       19125      1882/io.harmony.0
            udp        0      0 0.0.0.0:36910           0.0.0.0:*                           1000       19987      1738/io.broadlink2.
            udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       18746      1508/io.radar2.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          348        1/init
            udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          16917      971/chronyd
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       21520      1651/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       21521      1651/io.tuya.0
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       19126      1882/io.harmony.0
            udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       19984      1738/io.broadlink2.
            udp        0      0 0.0.0.0:44107           0.0.0.0:*                           1000       39719      1738/io.broadlink2.
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       22546      2192/io.upnp.0
            udp6       0      0 :::111                  :::*                                0          14316      1/init
            udp6       0      0 ::1:323                 :::*                                0          16918      971/chronyd
            udp6       0      0 fe80::81d3:290b:af8:546 :::*                                0          11216      746/NetworkManager
            2023-10-19 13:42:11.898  - debug: mielecloudservice.0 (1494) Received PING message by SSE: {"type":"ping","data":"ping","lastEventId":"","origin":"https://api.mcs3.miele.com"}
            2023-10-19 13:42:13.528  - info: radar2.0 (1508) debug: started #41 l2ping  -c 1 98:b8:bc:ad:31:27
            2023-10-19 13:42:13.634  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"98:7b:f3:4b:cd:5f","btName":"LG HTS(CD:5F)","rssi":-53,"btVendor":"Texas Instruments","by":"noble"}
            2023-10-19 13:42:13.655  - warn: radar2.0 (1508) arp-scan maybe without rights because no data returned!
            2023-10-19 13:42:17.237  - info: radar2.0 (1508) debug: ChangeState ack:true of S20-FE-von-Detlef._lastHere = 2023-10-19@13:42:17
            2023-10-19 13:42:17.570  - info: radar2.0 (1508) debug: started #42 l2ping  -c 1 18:70:3b:37:12:8c
            2023-10-19 13:42:21.609  - info: radar2.0 (1508) debug: started #43 l2ping  -c 1 c8:8d:4d:ea:19:ec
            2023-10-19 13:42:21.675  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"7c:a0:e6:35:fc:7f","btName":"N/A","rssi":-68,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:21.680  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"68:61:24:bf:5c:b1","btName":"N/A","rssi":-69,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:25.658  - info: radar2.0 (1508) debug: started #44 l2ping  -c 1 34:fe:77:10:87:4e
            2023-10-19 13:42:28.860  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"de:83:ec:e2:00:e5","btName":"N/A","rssi":-68,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:29.223  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"f9:dd:b2:07:54:32","btName":"N/A","rssi":-81,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:29.759  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"40:5c:b1:9e:57:45","btName":"N/A","rssi":-80,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:29.860  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"5f:9a:49:49:19:46","btName":"N/A","rssi":-69,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:29.868  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"c4:f8:75:12:c9:e4","btName":"N/A","rssi":-70,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:30.068  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"70:ff:92:55:6f:e1","btName":"N/A","rssi":-82,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:30.864  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"de:83:ec:e2:00:e5","btName":"N/A","rssi":-67,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:31.100  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"48:93:fe:a7:8d:67","btName":"N/A","rssi":-81,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:31.223  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"f9:dd:b2:07:54:32","btName":"N/A","rssi":-77,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:31.908  - debug: mielecloudservice.0 (1494) Received PING message by SSE: {"type":"ping","data":"ping","lastEventId":"","origin":"https://api.mcs3.miele.com"}
            2023-10-19 13:42:31.930  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"c4:f8:75:12:c9:e4","btName":"N/A","rssi":-69,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:32.874  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"de:83:ec:e2:00:e5","btName":"N/A","rssi":-67,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:33.228  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"f9:dd:b2:07:54:32","btName":"N/A","rssi":-77,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:33.935  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"c4:f8:75:12:c9:e4","btName":"N/A","rssi":-72,"btVendor":"N/A","by":"noble"}
            2023-10-19 13:42:34.413  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"e6:b0:3d:a1:3e:21","btName":"N/A","rssi":-80,"btVendor":"N/A","by":"noble"}
            iob diag has finished.
            Press any key for a summary
            Copy text starting here:
                                    v.2023-10-10
                   Icon name: computer
                Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               arm64
            Timezone:               Etc/UTC (UTC, +0000)
            User-ID:                1001
            X-Server:               false
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
            Recommended versions are nodejs 18.18.2 and npm 9.8.1
            MEMORY:
            Mem:            4.2G        2.4G        1.2G        6.0M        669M        1.7G
            Swap:           2.1G          0B        2.1G
            Total:          6.3G        2.4G        3.2G
            Active iob-Instances:   35
            ioBroker Core:          js-controller           5.0.14
                                    admin                   6.10.8
            Objects type: jsonl
            States  type: jsonl
            Objects:                15231
            States:                 9695
            Size of iob-Database:
            17M     /opt/iobroker/iobroker-data/objects.jsonl
            6.9M    /opt/iobroker/iobroker-data/states.jsonl
            === Mark text until here for copying ===
            • D deta
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
                            NTP service: active
                        RTC in local TZ: no
              rock
              /home/rock
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           2.1G          0B        2.1G
                       3974 M total memory
                       2305 M used memory
                       1282 M free memory
                         43 M buffer memory
                        430 M swap cache
                       1987 M total swap
                          0 M used swap
                       1987 M free swap
              *** FILESYSTEM ***
              /var:
              426M    /var/
              280M    /var/cache
              275M    /var/cache/apt
              132M    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.10.8
              javascript:     7.1.5
              Adapter State
              + instance is alive
              Objects and States
              Objects:        15231
              States:         9695
              Pending Updates: 0
                                      v.2023-10-10
                     Icon name: computer
                  Architecture: arm64
              Kernel:                 aarch64
              Userland:               arm64
              User-ID:                1001
              X-Server:               false
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
              MEMORY:
              Swap:           2.1G          0B        2.1G
                                      admin                   6.10.8
              Objects type: jsonl
              States  type: jsonl
              Objects:                15231
              States:                 9695
              @deta
              Setz die Zeitzone richtig.
                @deta
                deta
                @thomas-braun sagte in LG Adapter problem:
                @deta
                wo meinst du das?
                • D deta
                  @deta
                  wo meinst du das?
                  @deta
                  In deinem Betriebssystem.
                    @deta
                    deta
                    @thomas-braun danke genau das wars. Grummel.
                    • D deta
                      @deta
                      Die exakte Uhrzeit ist für Computersysteme enorm wichtig, das ist nicht nur 'zur Zierde' da.
                        @deta
                        deta
                        @deta
                        schon klar, hatte ich doch irgendwie übersehen.
                        Jetzt geht das ganze System wieder.
                        Bis auf eine kleinigkeit.
                        Wenn ich auf den Schraubenschlüssel klicke für die Basiseinstellungen, nurdelt er sich bis...
                        kommt nichts.
                        cu Deta
