  4. BackItUp kann alte Backups nicht löschen
    5.1k
backup fehlerbackup file löschengelöst
9 Beiträge 3 Kommentatoren 1.0k Aufrufe 2 Beobachtet
    theo996
    schrieb am zuletzt editiert von theo996
    |Hardwaresystem:| Pi4 |
    |Arbeitsspeicher:| 8GB |
    |Festplattenart:| SSD |
    |Nodejs-Version:| v18.18.0 |
    |NPM-Version:| 9.8.1 |
    ich habe seit ich mit dem iob node fix Skript mein System auf 18.18.0 bekommen habe, Probleme mit BackItUp (v2.8.1).
    Anfängliche mount-Probleme aufs NAS habe ich nach Neuinstallation von BackItUp ausgeräumt, aber es bleibt das Problem, dass es folgende Fehlermeldung beim Backup gibt: "Backup files not deleted from /opt/iobroker/backups because some errors".
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false}
    [DEBUG] [mount] - noserverino option: true
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //xxx.xxx.xxx.xxx/Backup_ioBroker /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [iobroker] - host.raspberrypi 21065 states saved
    [DEBUG] [iobroker] - host.raspberrypi 24156 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_10_07-12_47_12_backupiobroker.tar.gz
    [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
    [DEBUG] [iobroker] - done
    [DEBUG] [cifs] - used copy path: /Backup_ioBroker
    [DEBUG] [cifs] - done
    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [pushover] - [iobroker] used pushover-Instance: pushover.0
    [DEBUG] [pushover] - done
    [DEBUG] [pushover] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2023_10_07-12_47_12_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de","time":"07. Oktober 2023 um 12:47 Uhr"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2023_10_07-12_47_12_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"07. Oktober 2023 um 12:47 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2023_10_07-12_47_12_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"07. Oktober 2023 um 12:47 Uhr"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":null,"target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//xxx.xxx.xxx.xxx","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"xx:xx:xx:xx:xx:xx","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup_ioBroker","dirMinimal":"sharename/backupDir","user":"iobroker","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    [/s]
    Grüße vom Theo
    • T theo996
      [EXIT] 0
      [/s]
      @theo996
      Warte auf nodejs 18.18.1
      Ich vermute, das hat mit der libuv aus 18.18.0 zu tun.
      https://forum.iobroker.net/topic/68779/tester-gesucht-backup-auf-fritz-nas-node-18-18-0?_=1696680468995
      • Thomas BraunT Online
        @theo996 sagte in BackItUp kann alte Backups nicht löschen:
        Wie sehen die Einstellungen im Adapter denn an Stelle genau aus?
          theo996
          Grüße vom Theo
          • T theo996
            @theo996
            Die 'noserverino'-Option wird eigentlich nur für Fritz.Nas verwendet. Wenn das da bei dir keines ist, dann schalt die aus.
              @theo996
              theo996
              Erledigt, aber das hatte ich auch nur eben mal aktiviert um zu schauen, ob es was ändert... hatte es aber nicht.
              Grüße vom Theo
              • T theo996
                simatecS Offline
                simatecS Offline
                simatec
                @theo996 Es gibt aktuell nur 2 Möglichkeiten…
                Auf Node 18.18.1 warten oder zurück auf 18.17.0 gehen
                • Besuche meine Github Seite
                • HowTo Restore ioBroker
                T 2 Antworten Letzte Antwort
                • simatecS simatec
                  theo996
                  @simatec
                  Ich denke ich werde mich in Geduld üben und auf 18.18.1 warten..
                  Besten Dank für Euer Feedback!
                  Grüße vom Theo
                  • simatecS simatec
                    theo996
                    @simatec
                    18.18.1 aufgespielt und alles ist wieder fein :-)
                    Grüße vom Theo
