  4. NodeJS update nicht möglich...
    5.2k
27 Beiträge 4 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • D Dragon
    ======== Start marking the full check here =========
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer-vm
               Chassis: vm
            Machine ID: 58d2cc2a97184623922200d7fac194bf
               Boot ID: 1e570689b59e42068bd315fb831075dc
        Virtualization: kvm
      Operating System: Debian GNU/Linux 10 (buster)
                Kernel: Linux 4.19.0-25-amd64
          Architecture: x86-64
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     11:30:26 up 48 min,  1 user,  load average: 2.34, 1.83, 1.80
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sat 2023-10-07 11:30:27 CEST
               Universal time: Sat 2023-10-07 09:30:27 UTC
                     RTC time: Sat 2023-10-07 09:30:28
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           8.0G        4.3G        2.8G         16M        831M        3.4G
    Swap:          974M          0B        974M
    Total:         9.0G        4.3G        3.8G
             7978 M total memory
             4303 M used memory
             4382 M active memory
              393 M inactive memory
             2843 M free memory
              120 M buffer memory
              711 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     798M   17M  782M   3% /run
    /dev/sda1      ext4       31G   11G   19G  36% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    tmpfs          tmpfs     798M     0  798M   0% /run/user/1000
    [Sat Oct  7 10:42:00 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Oct  7 10:42:00 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems (real ones only):
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
    `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    /var:
    557M    /var/
    384M    /var/cache
    379M    /var/cache/apt
    318M    /var/cache/apt/archives
    154M    /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    No journal files were opened due to insufficient permissions.
    /opt/iobroker/backups:
    236M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    759M    /opt/iobroker/iobroker-data/files
    255M    /opt/iobroker/iobroker-data/backup-objects
    126M    /opt/iobroker/iobroker-data/files/vis.0
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    59M     /opt/iobroker/iobroker-data/states.jsonl
    30M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 100
            100 /var/lib/dpkg/status
         10.24.0~dfsg-1~deb10u3 500
            500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://deb.debian.org/debian buster/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.11
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   2
    Adapter State
    + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: ioBroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker                                 -  enabled
    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
    + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
    + system.adapter.imap.0                   : imap                  : ioBroker                                 -  enabled
    + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
    + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1890, bind: 192.168.178.3
    + system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
    + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
    + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
      system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
      system.adapter.odl.0                    : odl                   : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 - disabled
    + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.pushsafer.0              : pushsafer             : ioBroker                                 -  enabled
      system.adapter.rickshaw.0               : rickshaw              : ioBroker                                 - disabled
    + system.adapter.samsung.0                : samsung               : ioBroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled
      system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
      system.adapter.schoolfree.1             : schoolfree            : ioBroker                                 -  enabled
    + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
    + system.adapter.signal-cmb.0             : signal-cmb            : ioBroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 192.168.178.3
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker                                 - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : ioBroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.178.222:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "adguard"      : 0.0.8    , installed 0.0.8
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "awtrix-light" : 0.8.0    , installed 0.8.0
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovery"    : 3.1.0    , installed 3.2.0
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "followthesun" : 0.4.2    , installed 0.4.2
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "imap"         : 0.1.1    , installed 0.1.1
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.11 [Updatable]
    Adapter    "kodi"         : 3.0.0    , installed 3.0.0
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "octoprint"    : 4.0.0    , installed 5.0.1
    Adapter    "odl"          : 2.0.5    , installed 2.0.5
    Adapter    "openweathermap": 0.3.9   , installed 0.4.2
    Adapter    "parcel"       : 0.0.27   , installed 0.0.32
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wled"         : 0.6.7    , installed 0.7.0
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.22 [Updatable]
    Objects and States
    Objects:        28000
    States:         27615
    Hit:1 http://deb.debian.org/debian buster InRelease
    Hit:2 http://deb.debian.org/debian buster-updates InRelease
    Hit:3 http://security.debian.org/debian-security buster/updates InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9975       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13815      366/sshd
    tcp        0      0 192.168.178.3:1883      0.0.0.0:*               LISTEN      1000       14959      595/io.sonoff.0
    tcp        0      0 192.168.178.3:1890      0.0.0.0:*               LISTEN      1000       14895      546/io.mqtt.0
    tcp        0      0 192.168.178.3:1891      0.0.0.0:*               LISTEN      1000       14896      546/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       14438      349/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       13909      349/iobroker.js-con
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10531      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       14522      380/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       20165      1647/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       22548      1766/io.socketio.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1000       15254      663/io.nuki-extende
    tcp6       0      0 :::8086                 :::*                    LISTEN      1000       22855      1999/io.ws.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13817      366/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       22716      1958/io.simple-api.
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       16609      779/io.broadlink2.0
    udp        0      0 0.0.0.0:44185           0.0.0.0:*                           1000       15997      779/io.broadlink2.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9979       1/init
    udp        0      0 0.0.0.0:45747           0.0.0.0:*                           1000       16622      779/io.broadlink2.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       21311      1688/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       15037      631/io.chromecast.0
    udp        0      0 192.168.178.3:5353      0.0.0.0:*                           1000       15022      615/io.tr-064.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       21358      1405/io.upnp.0
    udp        0      0 0.0.0.0:42950           0.0.0.0:*                           1000       20750      1405/io.upnp.0
    udp6       0      0 :::111                  :::*                                0          9984       1/init
    2023-10-07 11:30:08.360  - info: host.ioBroker instance system.adapter.ical.0 started with pid 8790
    2023-10-07 11:30:10.464  - info: dwd.0 (8761) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-07 11:30:10.703  - info: javascript.0 (431) script.js.common.Automatisierung.Sonstige.DWD_UWZ_NINA: No change! headline: Amtliche WARNUNG vor WINDBÖEN
    2023-10-07 11:30:11.459  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 11:30:12.606  - info: host.ioBroker instance system.adapter.ical.1 started with pid 8803
    2023-10-07 11:30:12.682  - info: ical.0 (8790) Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
    2023-10-07 11:30:14.049  - info: ical.0 (8790) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.11
    2023-10-07 11:30:15.552  - info: ical.0 (8790) processing URL: Brüderkalender https://calendax
    2023-10-07 11:30:15.609  - info: ical.0 (8790) processing URL: Froebus/Schleibach https://calendar.....
    2023-10-07 11:30:15.767  - info: ical.0 (8790) processing URL: Familie https://calendar.gx
    2023-10-07 11:30:15.961  - info: ical.0 (8790) processing URL: Müllabfuhr https://calendar.gox
    2023-10-07 11:30:16.038  - info: ical.0 (8790) processing URL: Geburtstagskalender https://calendar.goox
    2023-10-07 11:30:16.753  - info: host.ioBroker instance system.adapter.odl.0 started with pid 8822
    2023-10-07 11:30:18.262  - info: ical.0 (8790) processing URL: Privat https://calenxs
    2023-10-07 11:30:18.878  - info: ical.1 (8803) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.11
    2023-10-07 11:30:20.270  - info: ical.0 (8790) processing URL: Dienstplan https://calendaxsic.ics
    2023-10-07 11:30:22.105  - info: ical.1 (8803) processing URL: Müllabfuhr https://cax/basic.ics
    2023-10-07 11:30:23.395  - info: odl.0 (8822) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.odl, node: v18.17.1, js-controller: 5.0.11
    2023-10-07 11:30:27.246  - info: odl.0 (8822) Terminated (NO_ERROR): Without reason
    2023-10-07 11:30:27.712  - info: ical.0 (8790) Terminated (NO_ERROR): Without reason
    2023-10-07 11:30:27.833  - info: ical.1 (8803) Terminated (NO_ERROR): Without reason
    2023-10-07 11:30:28.023  - info: host.ioBroker instance system.adapter.odl.0 terminated with code 0 (NO_ERROR)
    2023-10-07 11:30:28.677  - info: host.ioBroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-10-07 11:30:28.754  - info: host.ioBroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
    2023-10-07 11:31:05.702  - info: host.ioBroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    iob diag has finished.
    @dragon
    Es gibt keine nodesource.list bei dir.
    Das ist aber dem node-fix-Skript egal, das meldet nur:
    rm: cannot remove '/etc/apt/sources.list.d/nodesource.lis*': No such file or directory
    und legt dann die richtige Datei an und installiert die letzte Version aus dem 18er-Zweig. Gerade getestet.
    Was funktioniert denn bei dir mit dem Skript nicht? Vollständige Ausgaben helfen.
      @dragon
      Dragon
      ioBroker nodejs fixer 2023-10-03
      Recommended nodejs-version is: 18.18.0
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      We found these nodejs versions available for installation:
      nodejs:
        Version table:
      Nothing to do - Your installation is using the correct paths.
      You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
      Press <y> to continue or any other key to quit
      Trying to fix your installation now. Please be patient.
      [sudo] password for iobroker:
      rm: cannot remove '': No such file or directory
      Virtualization: kvm
      Beendet
      iobroker@ioBroker:~$ ^C
      iobroker@ioBroker:~$ ioBroker nodejs fixer 2023-10-03
      -bash: ioBroker: Kommando nicht gefunden.
      iobroker@ioBroker:~$ Recommended nodejs-version is: 18.18.0
      -bash: Recommended: Kommando nicht gefunden.
      iobroker@ioBroker:~$ Checking your installation now. Please be patient!
      -bash: Checking: Kommando nicht gefunden.
      iobroker@ioBroker:~$ Your current setup is:
      -bash: Your: Kommando nicht gefunden.
      iobroker@ioBroker:~$ /usr/bin/nodejs         v18.17.1
      node:internal/modules/cjs/loader:1080
        throw err;
      Error: Cannot find module '/home/iobroker/v18.17.1'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          at Module._load (node:internal/modules/cjs/loader:922:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          at node:internal/main/run_main_module:23:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.17.1
      iobroker@ioBroker:~$ /usr/bin/node           v18.17.1
        throw err;
        requireStack: []
      Node.js v18.17.1
      iobroker@ioBroker:~$ /usr/bin/npm            9.6.7
      Unknown command: "9.6.7"
      To see a list of supported npm commands, run:
        npm help
      iobroker@ioBroker:~$ /usr/bin/npx            9.6.7
      npm ERR! code E404
      npm ERR! 404 Not Found - GET https://registry.npmjs.org/9.6.7 - Not found
      npm ERR! 404
      npm ERR! 404  '9.6.7@*' is not in this registry.
      npm ERR! 404
      npm ERR! 404 Note that you can also install from a
      npm ERR! 404 tarball, folder, http url, or git url.
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-07T09_54_10_069Z-debug-0.log
      iobroker@ioBroker:~$ /usr/bin/corepack       0.18.0
      Unknown Syntax Error: Command not found; did you mean one of:
        0. corepack -h
        1. corepack -v
        2. corepack enable [--install-directory #0] ...
        3. corepack disable [--install-directory #0] ...
        4. corepack hydrate [--activate] <fileName>
        5. corepack prepare [--activate] [--all] [--json] [-o,--output] ...
      While running 0.18.0
      iobroker@ioBroker:~$ We found these nodejs versions available for installation:
      -bash: We: Kommando nicht gefunden.
      iobroker@ioBroker:~$ nodejs:
      -bash: nodejs:: Kommando nicht gefunden.
      iobroker@ioBroker:~$   Installed: 18.17.1-deb-1nodesource1
      -bash: Installed:: Kommando nicht gefunden.
      iobroker@ioBroker:~$   Candidate: 18.17.1-deb-1nodesource1
      -bash: Candidate:: Kommando nicht gefunden.
      iobroker@ioBroker:~$   Version table:
      -bash: Version: Kommando nicht gefunden.
      iobroker@ioBroker:~$  *** 18.17.1-deb-1nodesource1 100
      -bash: iob_diag.log: Kommando nicht gefunden.
      iobroker@ioBroker:~$         100 /var/lib/dpkg/status
      -bash: 100: Kommando nicht gefunden.
      iobroker@ioBroker:~$      10.24.0~dfsg-1~deb10u3 500
      -bash: 10.24.0~dfsg-1~deb10u3: Kommando nicht gefunden.
      iobroker@ioBroker:~$         500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
      -bash: 500: Kommando nicht gefunden.
      iobroker@ioBroker:~$      10.24.0~dfsg-1~deb10u1 500
      -bash: 10.24.0~dfsg-1~deb10u1: Kommando nicht gefunden.
      iobroker@ioBroker:~$         500 http://deb.debian.org/debian buster/main amd64 Packages
      iobroker@ioBroker:~$ Nothing to do - Your installation is using the correct paths.
      -bash: Nothing: Kommando nicht gefunden.
      iobroker@ioBroker:~$ You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
      -bash: You: Kommando nicht gefunden.
      iobroker@ioBroker:~$ Press <y> to continue or any other key to quit
      -bash: y: Datei oder Verzeichnis nicht gefunden
      iobroker@ioBroker:~$ Trying to fix your installation now. Please be patient.
      -bash: Trying: Kommando nicht gefunden.
      iobroker@ioBroker:~$ [sudo] password for iobroker:
      -bash: [sudo]: Kommando nicht gefunden.
      iobroker@ioBroker:~$ rm: cannot remove '': No such file or directory
      -bash: rm:: Kommando nicht gefunden.
      iobroker@ioBroker:~$ rm: cannot remove '/etc/apt/sources.list.d/nodesource.lis*': No such file or directory
      iobroker@ioBroker:~$ Virtualization: kvm
      -bash: Virtualization:: Kommando nicht gefunden.
      iobroker@ioBroker:~$ Beendet
      Thomas BraunT DJMarc75D 3 Antworten Letzte Antwort
      • D Dragon
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        Virtualization: kvm
        Beendet
          throw err;
          requireStack: []
        Node.js v18.17.1
          throw err;
          requireStack: []
        Node.js v18.17.1
          npm help
        npm ERR! code E404
        npm ERR! 404
        npm ERR! 404
          0. corepack -h
          1. corepack -v
        @dragon
        Du kopierst da irgendwie die Ausgabe in die Kommandozeile rein. Logisch kann die mit dem Krempel nix anfangen.
        Nochmal...
        • D Dragon
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          Virtualization: kvm
          Beendet
            throw err;
            requireStack: []
          Node.js v18.17.1
            throw err;
            requireStack: []
          Node.js v18.17.1
            npm help
          npm ERR! code E404
          npm ERR! 404
          npm ERR! 404
            0. corepack -h
            1. corepack -v
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @dragon zusätzlich würde ich einen anderen User anlegen welcher NICHT iobroker heisst
          Lehrling seit 1975 !!!
          • D Dragon
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            Virtualization: kvm
            Beendet
              throw err;
              requireStack: []
            Node.js v18.17.1
              throw err;
              requireStack: []
            Node.js v18.17.1
              npm help
            npm ERR! code E404
            npm ERR! 404
            npm ERR! 404
              0. corepack -h
              1. corepack -v
            @dragon
            Lad das Skript nochmal frisch herunter.
              @dragon
              Dragon
              @thomas-braun Hat jetzt funktioniert!
              • D Dragon
                @dragon
                Es hat mutmaßlich zuerst nicht funktioniert wegen:
                Mit einem anderen username hätte es wohl hingehauen.
                Leg dir also einen User 'dragon' oder sonstwas an und verwende den dann für Abenteuer im System. Gruppen 'adm', 'sudo' und 'iobroker' bei dem neuen User eintragen und das System über 'Debian 11 "Bullseye" auf Debian 12 "Bookworm" heben.
