  2. English
  4. Tapo / Tp-link
    1.6k
    1.5k
Tapo / Tp-link
5 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • B
    B
    Bvelkov
    My tapo L530 smart light bulbs stopped working after I updated their firmware. It was working perfectly fine with 1.1.9 but now on 1.3.0 I can't control any of the states. Any suggestions on how to fix it?
    Tried deleting the adapter and the instances and rebooting everything, nothing helped. Tested with an old light bulb that still has the 1.1.9 worked immediately.
    • B Bvelkov
      arteckA
      arteckA
      arteck
      @bvelkov LOG from Adaper in debug mode maybee..
      B 1 Antwort Letzte Antwort
      • arteckA arteck
        B
        B
        Bvelkov
        @arteck Here's the log from the adapter, hope it helps. iobroker.2023-10-02.log.html
        • B Bvelkov
          Marc BergM
          Marc BergM
          Marc Berg
          @bvelkov
          2023-10-02 11:47:40.013 - error: tapo.0 (8466) 111 Error: connect EHOSTUNREACH 192.168.0.167:80
          2023-10-02 11:47:40.015 - info: tapo.0 (8466) Initialized 8022499C86F638445F8EBA45627EB4851D8C46C5
          2023-10-02 11:47:40.015 - error: tapo.0 (8466) 52 - Get Device Info failed
          2023-10-02 11:47:40.355 - info: tapo.0 (8466) Init device 80234DDA2E0CB8AD97C9CF60AB502FD31E7EABC4 type L530 Series with ip 192.168.0.114
          2023-10-02 11:47:43.594 - error: tapo.0 (8466) 111 Error: connect EHOSTUNREACH 192.168.0.114:80
          Maybe the bulbs got new IP addresses after the update. Can you see the bulbs in the Wi-Fi router?
          • Marc BergM Marc Berg
            @bvelkov
            B
            B
            Bvelkov
            @marc-berg not those two, but they rest that I expect to work are there, I tried deleting the cache file hoping it would get the new device list again, also tried deleting the instance and the adapter, but I think that didn't work. Do you know how I can force the cache delete on this instance?
            1.4m
