  4. Roborock - Adapter stürzt ständig ab
    6.8k
30 Beiträge 10 Kommentatoren 4.3k Aufrufe 9 Beobachtet
  • Michael SauerM Offline
    Michael Sauer
    schrieb am zuletzt editiert von Michael Sauer
    habe das Problem das ich den Adapter bisher nicht richtig nutzen kann.
    Mein Saugroboter ist ein S8+. Verbindung wird aufgebaut jedoch stürzt der Adapter im Minuten Takt ab.
    Habe den Adapter auf Debug gestellt:
    roborock.0
    2023-09-28 20:32:33.060	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    roborock.0
    2023-09-28 20:32:33.043	error	adapter disabled
    roborock.0
    2023-09-28 20:32:33.023	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 20:31:50.150	warn	setInterval called, but adapter is shutting down
    roborock.0
    2023-09-28 20:31:44.518	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-28 20:31:44.515	info	terminating
    roborock.0
    2023-09-28 20:31:44.502	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:31:44.502	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-28 20:31:44.500	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:31:44.499	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-28 20:31:32.436	info	MQTT initialized
    roborock.0
    2023-09-28 20:31:27.501	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
    roborock.0
    2023-09-28 20:31:26.946	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 20:30:35.148	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-28 20:30:35.143	info	terminating
    roborock.0
    2023-09-28 20:30:35.127	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:30:35.126	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-28 20:30:35.124	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:30:35.122	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-28 20:30:08.135	info	MQTT initialized
    roborock.0
    2023-09-28 20:30:04.677	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
    roborock.0
    2023-09-28 20:30:04.393	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 20:01:20.818	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-28 20:01:20.815	info	terminating
    roborock.0
    2023-09-28 20:01:20.806	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:01:20.806	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-28 20:01:20.805	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:01:20.804	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-28 20:01:06.531	info	MQTT initialized
    roborock.0
    2023-09-28 20:01:05.376	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
    roborock.0
    2023-09-28 20:01:05.189	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 20:00:24.153	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-28 20:00:24.150	info	terminating
    roborock.0
    2023-09-28 20:00:24.120	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:00:24.119	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-28 20:00:24.118	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:00:24.116	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-28 20:00:08.550	info	MQTT initialized
    roborock.0
    2023-09-28 20:00:03.663	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
    roborock.0
    2023-09-28 20:00:03.375	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 19:59:19.285	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-28 19:59:19.282	info	terminating
    roborock.0
    2023-09-28 19:59:19.274	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 19:59:19.273	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-28 19:59:19.272	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 19:59:19.271	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-28 19:59:07.700	info	MQTT initialized
    roborock.0
    2023-09-28 19:59:05.970	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
    roborock.0
    2023-09-28 19:59:05.760	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 19:58:55.753	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    roborock.0
    2023-09-28 19:58:55.751	info	terminating
    roborock.0
    2023-09-28 19:58:55.746	info	Got terminate signal TERMINATE_YOURSELF
    Jemand eine Idee?
    Thomas BraunT GlasfaserG copystringC 3 Antworten Letzte Antwort
    • Michael SauerM Michael Sauer
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      Jemand eine Idee?
      @michael-sauer sagte in Adapter stürzt ständig ab:
      Jemand eine Idee?
      System auf Stand halten. nodejs@18 und js-controller@5 z. B.
      Michael SauerM 1 Antwort Letzte Antwort
        Jemand eine Idee?
        Michael Sauer
        @thomas-braun Ist ein Argument. Danke
        • GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          Version 0.4.4
          Die Version ist BETA , läuft es auch nicht mit dem Stable !?
          Keine Verbindung !?
          Stelle mal auf DEBUG
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            Jemand eine Idee?
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            @michael-sauer
            kannst du den Thread Titel anpassen auf :
            roborock Adapter stürzt ständig ab
            • GlasfaserG Glasfaser
              Version 0.4.4
              Keine Verbindung !?
              Michael Sauer
              @glasfaser
              Steht auf Debug. System ist aktualisiert:
              roborock.0
              2023-09-29 08:17:46.345	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
              roborock.0
              2023-09-29 08:17:46.334	error	adapter disabled
              roborock.0
              2023-09-29 08:17:46.317	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              roborock.0
              2023-09-29 08:17:10.665	info	terminating
              roborock.0
              2023-09-29 08:17:10.373	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
              roborock.0
              2023-09-29 08:17:10.370	warn	setTimeout called, but adapter is shutting down
              roborock.0
              2023-09-29 08:17:10.369	warn	setTimeout called, but adapter is shutting down
              roborock.0
              2023-09-29 08:17:10.271	warn	setTimeout called, but adapter is shutting down
              roborock.0
              roborock.0
              2023-09-29 08:17:10.185	warn	setTimeout called, but adapter is shutting down
              roborock.0
              2023-09-29 08:17:10.181	warn	Failed to create map. retry
              roborock.0
              2023-09-29 08:17:10.161	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              roborock.0
              2023-09-29 08:17:10.160	info	terminating
              roborock.0
              2023-09-29 08:17:10.146	error	Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-29 08:17:10.146	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
              roborock.0
              2023-09-29 08:17:10.145	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-29 08:17:10.144	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-09-29 08:17:07.454	warn	Failed to execute load_multi_map on robot 5Eo7zrAcFZhjGJqyG5saSx Error: There was an error processing the request with id 3224 error: {"code":-10003,"message":"action locked"}
              roborock.0
              2023-09-29 08:16:54.267	info	MQTT initialized
              roborock.0
              2023-09-29 08:16:52.229	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
              roborock.0
              2023-09-29 08:16:52.080	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              S GlasfaserG 2 Antworten Letzte Antwort
                @glasfaser
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                SpacerX
                schrieb am zuletzt editiert von SpacerX
                @michael-sauer Hast du einen Raspi laufen? Wenn ja dort funzt das mit der Map nicht richtig. Deshalb vielleicht die deine Probs. Schau mal in den Beitrag zum Adapter.
                https://forum.iobroker.net/topic/67186/neuer-adapter-f%C3%BCr-roborock-staubsauger
                DS720|Nuc8i3BEH|Proxmox|RaspberryMatic|ioBroker|influxDB2|Grafana
                  @glasfaser
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  @michael-sauer sagte in Roborock - Adapter stürzt ständig ab:
                  Steht auf Debug.
                  Nö ist nicht , ist die gleiche Info wie zuvor !
                  Die Adapter Instanz auf DEBUG stellen .
                  Beispiel :
                  Was war hiermit !?
                  @glasfaser sagte in Roborock - Adapter stürzt ständig ab:
                  Und Zeige mal die Full Ausgabe von
                  iob diag
                  • T Nicht stören
                    T Nicht stören
                    ticaki
                    Kannst du das versenden von anonymisierten Daten mal aktivieren? Sentry
                    Spenden
                      Steht auf Debug.
                      Beispiel :
                      Was war hiermit !?
                      iob diag
                      Michael Sauer
                      @glasfaser Hast recht.
                      Hier der vollständige Log:
                      roborock.0
                      2023-09-29 20:44:27.997	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
                      roborock.0
                      2023-09-29 20:44:27.787	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      roborock.0
                      2023-09-29 20:44:27.769	debug	Plugin sentry Initialize Plugin (enabled=true)
                      roborock.0
                      2023-09-29 20:43:40.797	warn	Failed to execute get_clean_summary on robot 5Eo7zrAcFZhjGJqyG5saSx TypeError: Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-29 20:43:40.797	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
                      roborock.0
                      2023-09-29 20:43:40.791	warn	Failed to execute get_clean_record_map on robot 5Eo7zrAcFZhjGJqyG5saSx retry
                      roborock.0
                      2023-09-29 20:43:40.790	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
                      roborock.0
                      2023-09-29 20:43:40.775	debug	Length of message queue: 0
                      roborock.0
                      2023-09-29 20:43:40.774	debug	dps debug: {"id":3403,"result":["retry"]}
                      roborock.0
                      2023-09-29 20:43:40.614	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
                      roborock.0
                      2023-09-29 20:43:40.611	warn	setTimeout called, but adapter is shutting down
                      roborock.0
                      2023-09-29 20:43:40.610	warn	setTimeout called, but adapter is shutting down
                      roborock.0
                      2023-09-29 20:43:40.591	debug	Length of message queue: 0
                      roborock.0
                      2023-09-29 20:43:40.591	debug	dps debug: {"id":8382,"result":[{"begin":1695980402,"end":1695981303,"duration":901,"area":11682500,"error":0,"complete":0,"start_type":3,"clean_type":3,"finish_reason":62,"dust_collection_status":1,"avoid_count":2,"map_flag":0}]}
                      roborock.0
                      2023-09-29 20:43:40.379	warn	Failed to create map. retry
                      roborock.0
                      2023-09-29 20:43:40.377	warn	setTimeout called, but adapter is shutting down
                      roborock.0
                      2023-09-29 20:43:40.344	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      roborock.0
                      2023-09-29 20:43:40.343	debug	Plugin sentry destroyed
                      roborock.0
                      2023-09-29 20:43:40.341	info	terminating
                      roborock.0
                      2023-09-29 20:43:40.321	error	Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-29 20:43:40.320	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
                      roborock.0
                      2023-09-29 20:43:40.319	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-29 20:43:40.319	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      roborock.0
                      2023-09-29 20:43:40.316	debug	Length of message queue: 2
                      roborock.0
                      2023-09-29 20:43:40.316	debug	Not clearing messageQueue. null - 24752
                      roborock.0
                      2023-09-29 20:43:40.315	debug	dps debug: {"id":5996,"result":["retry"]}
                      roborock.0
                      2023-09-29 20:43:40.312	debug	Length of message queue: 2
                      roborock.0
                      2023-09-29 20:43:40.312	debug	dps debug: {"id":1492,"result":{"clean_time":202871,"clean_area":2843662500,"clean_count":144,"dust_collection_count":128,"records":[1695980402,1695978009,1695807600,1695805205,1695718805,1695634800,1695632403,1695546005,1695459607,1695375600,1695373208,1695286806,1695202799,1695200405,1695114008,1695030000,1695027609,1694941211,1694854807,1694770801]}}
                      roborock.0
                      2023-09-29 20:43:39.961	debug	downloadURL: https://github.com/AlexxIT/go2rtc/releases/download/v1.3.0/go2rtc_linux_arm
                      roborock.0
                      2023-09-29 20:43:39.961	debug	System type: go2rtc_linux_arm
                      roborock.0
                      2023-09-29 20:43:39.961	debug	platform: linux
                      roborock.0
                      2023-09-29 20:43:39.960	debug	arch: arm
                      roborock.0
                      2023-09-29 20:43:39.958	debug	Update map
                      roborock.0
                      2023-09-29 20:43:39.955	debug	Length of message queue: 1
                      roborock.0
                      2023-09-29 20:43:39.954	debug	dps debug: {"id":1643,"result":{"water_box_mode":201}}
                      roborock.0
                      2023-09-29 20:43:39.684	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_water_box_custom_mode
                      roborock.0
                      2023-09-29 20:43:39.681	debug	Length of message queue: 1
                      roborock.0
                      2023-09-29 20:43:39.679	debug	dps debug: {"id":3641,"result":[{"carpet_clean_mode":3}]}
                      roborock.0
                      2023-09-29 20:43:39.388	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_clean_mode
                      roborock.0
                      2023-09-29 20:43:39.386	debug	Length of message queue: 1
                      roborock.0
                      2023-09-29 20:43:39.384	debug	dps debug: {"id":5183,"result":[{"enable":1,"current_integral":1000,"current_high":500,"current_low":1000,"stall_time":10}]}
                      roborock.0
                      2023-09-29 20:43:39.303	debug	get_timer: []
                      roborock.0
                      2023-09-29 20:43:39.302	debug	Length of message queue: 2
                      roborock.0
                      2023-09-29 20:43:39.301	debug	dps debug: {"id":1710,"result":[]}
                      roborock.0
                      2023-09-29 20:43:39.299	debug	get_server_timer: [["1688127243968","on",0],["1688127295244","on",0]]
                      roborock.0
                      2023-09-29 20:43:39.298	debug	Length of message queue: 3
                      roborock.0
                      2023-09-29 20:43:39.297	debug	dps debug: {"id":9140,"result":[["1688127243968","on",0],["1688127295244","on",0]]}
                      roborock.0
                      2023-09-29 20:43:38.906	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_mode
                      roborock.0
                      2023-09-29 20:43:38.905	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_timer
                      roborock.0
                      2023-09-29 20:43:38.904	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_server_timer
                      roborock.0
                      2023-09-29 20:43:38.903	debug	Length of message queue: 1
                      roborock.0
                      2023-09-29 20:43:38.902	debug	dps debug: {"id":1525,"result":{"ssid":"S-Home","ip":"192.168.78.122","mac":"b0:4a:39:6b:e2:59","bssid":"b0:f2:08:d9:88:ed","rssi":-68}}
                      roborock.0
                      2023-09-29 20:43:38.555	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_network_info
                      roborock.0
                      2023-09-29 20:43:38.554	debug	Consumables of robot: [{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]
                      roborock.0
                      2023-09-29 20:43:38.551	debug	Length of message queue: 1
                      roborock.0
                      2023-09-29 20:43:38.550	debug	dps debug: {"id":1936,"result":[{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]}
                      roborock.0
                      2023-09-29 20:43:38.287	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_consumable
                      roborock.0
                      2023-09-29 20:43:38.286	debug	Mapped room matched: 11316198 with name: Küche
                      roborock.0
                      2023-09-29 20:43:38.285	debug	Mapped room matched: 11316194 with name: Flur
                      roborock.0
                      2023-09-29 20:43:38.284	debug	Mapped room matched: 12646380 with name: Esszimmer
                      roborock.0
                      2023-09-29 20:43:38.283	debug	Mapped room matched: 11309675 with name: Wohnzimmer
                      roborock.0
                      2023-09-29 20:43:38.282	debug	All mapped rooms: [[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]
                      roborock.0
                      2023-09-29 20:43:38.281	debug	Length of message queue: 1
                      roborock.0
                      2023-09-29 20:43:38.281	debug	dps debug: {"id":8606,"result":[[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]}
                      roborock.0
                      2023-09-29 20:43:38.238	debug	foreign.message attribute: 128 with value: 4
                      roborock.0
                      2023-09-29 20:43:38.237	debug	dps debug: {"128":4}
                      roborock.0
                      2023-09-29 20:43:38.143	debug	Length of message queue: 1
                      roborock.0
                      2023-09-29 20:43:38.142	debug	dps debug: {"id":8398,"result":[{"msg_ver":2,"msg_seq":126,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
                      roborock.0
                      2023-09-29 20:43:37.907	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_room_mapping
                      roborock.0
                      2023-09-29 20:43:37.891	debug	get_status: {"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}
                      roborock.0
                      2023-09-29 20:43:37.889	debug	Length of message queue: 0
                      roborock.0
                      2023-09-29 20:43:37.888	debug	dps debug: {"id":5982,"result":[{"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
                      roborock.0
                      2023-09-29 20:43:37.645	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_status
                      roborock.0
                      2023-09-29 20:43:37.644	debug	Latest data requested
                      roborock.0
                      2023-09-29 20:43:37.642	debug	Length of message queue: 0
                      roborock.0
                      2023-09-29 20:43:37.640	debug	dps debug: {"id":1305,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1695979052,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1695806345}]},{"mapFlag":1,"add_time":1692254347,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1688451884}]}]}]}
                      roborock.0
                      2023-09-29 20:43:37.486	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_multi_maps_list
                      roborock.0
                      2023-09-29 20:43:37.382	debug	Length of message queue: 0
                      roborock.0
                      2023-09-29 20:43:37.379	debug	dps debug: {"id":3178,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
                      roborock.0
                      2023-09-29 20:43:37.164	debug	Firmware features request
                      roborock.0
                      2023-09-29 20:43:37.164	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_fw_features
                      roborock.0
                      2023-09-29 20:43:37.160	debug	5Eo7zrAcFZhjGJqyG5saSx online. Starting mainUpdateInterval.
                      roborock.0
                      2023-09-29 20:43:23.804	debug	Robot key: roborock.vacuum.a51
                      roborock.0
                      2023-09-29 20:43:23.803	debug	RoomIDs debug: {"11309675":"Wohnzimmer","11314643":"Wohnzimmer1","11316194":"Flur","11316198":"Küche","11316201":"Küche1","11319794":"Badezimmer","11319802":"Spielzimmer","11319804":"Kinderzimmer","11319806":"Schlafzimmer","12646380":"Esszimmer","13421850":"Standard","13421863":"Phillip Schlafzimmer","13421865":"Badezimmer1"}
                      roborock.0
                      2023-09-29 20:43:23.801	info	MQTT initialized
                      roborock.0
                      2023-09-29 20:43:20.623	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
                      roborock.0
                      2023-09-29 20:43:20.491	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      roborock.0
                      2023-09-29 20:43:20.474	debug	Plugin sentry Initialize Plugin (enabled=true)
                      roborock.0
                      2023-09-29 20:43:20.348	debug	States connected to redis: 127.0.0.1:6379
                      roborock.0
                      2023-09-29 20:43:20.336	debug	States create User PubSub Client
                      roborock.0
                      2023-09-29 20:43:20.335	debug	States create System PubSub Client
                      roborock.0
                      2023-09-29 20:43:20.327	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                      roborock.0
                      2023-09-29 20:43:20.307	debug	Objects connected to redis: 127.0.0.1:6379
                      roborock.0
                      2023-09-29 20:43:20.300	debug	Objects client initialize lua scripts
                      roborock.0
                      2023-09-29 20:43:19.846	debug	Objects create User PubSub Client
                      roborock.0
                      2023-09-29 20:43:19.844	debug	Objects create System PubSub Client
                      roborock.0
                      2023-09-29 20:43:19.842	debug	Objects client ready ... initialize now
                      roborock.0
                      2023-09-29 20:43:19.803	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
                      Skript v.2023-06-20
                      *** BASE SYSTEM ***
                         Static hostname: iobroker
                               Icon name: computer
                              Machine ID: 5f09e0dc24364fc8951dcf01ea03774d
                                 Boot ID: 687f969e56cf41c2bcbbdd9cffef19bb
                        Operating System: Raspbian GNU/Linux 10 (buster)
                                  Kernel: Linux 5.10.103-v7l+
                            Architecture: arm
                      Model           : Raspberry Pi 4 Model B Rev 1.2
                      Docker          : false
                      Virtualization  : none
                      Kernel          : armv7l
                      Userland        : armhf
                      Systemuptime and Load:
                       20:55:52 up 23:02,  1 user,  load average: 4.01, 3.35, 2.81
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      Other values than 0x0 hint to temperature/voltage problems
                      temp=57.4'C
                      volt=0.8500V
                      *** Time and Time Zones ***
                                     Local time: Fri 2023-09-29 20:55:53 CEST
                                 Universal time: Fri 2023-09-29 18:55:53 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      pi
                      /home/pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:           3.8G        2.7G        111M         13M        1.0G        971M
                      Swap:           99M         99M        0.0K
                      Total:         3.9G        2.8G        111M
                               3838 M total memory
                               2706 M used memory
                                670 M active memory
                               2888 M inactive memory
                                111 M free memory
                                167 M buffer memory
                                853 M swap cache
                                 99 M total swap
                                 99 M used swap
                                  0 M free swap
                      Raspberry only:
                      oom events: 0
                      lifetime oom required: 0 Mbytes
                      total time in oom handler: 0 ms
                      max time spent in oom handler: 0 ms
                      *** FILESYSTEM ***
                      /dev/root      ext4       59G   19G   38G  34% /
                      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                      tmpfs          tmpfs     1.9G  2.2M  1.9G   1% /dev/shm
                      tmpfs          tmpfs     1.9G   18M  1.9G   1% /run
                      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                      /dev/loop1     squashfs   41M   41M     0 100% /snap/certbot/3025
                      /dev/loop0     squashfs   54M   54M     0 100% /snap/core20/2018
                      /dev/loop2     squashfs   91M   91M     0 100% /snap/core/15929
                      /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16098
                      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                      Show mounted filesystems (real ones only):
                      TARGET               SOURCE         FSTYPE   OPTIONS
                      /                    /dev/mmcblk0p2 ext4     rw,noatime
                      |-/sys/fs/bpf        none           bpf      rw,nosuid,nodev,noexec,relatime,mode=700
                      |-/snap/certbot/3025 /dev/loop1     squashfs ro,nodev,relatime
                      |-/snap/core20/2018  /dev/loop0     squashfs ro,nodev,relatime
                      |-/snap/core/15929   /dev/loop2     squashfs ro,nodev,relatime
                      |-/snap/core/16098   /dev/loop3     squashfs ro,nodev,relatime
                      `-/boot              /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      3.6G    /var/
                      3.1G    /var/lib
                      1.9G    /var/lib/mysql
                      1.7G    /var/lib/mysql/iobroker
                      525M    /var/lib/piVCCU3
                      Archived and active journals take up 16.0M in the file system.
                      /opt/iobroker/backups:
                      197M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      695M    /opt/iobroker/iobroker-data/
                      466M    /opt/iobroker/iobroker-data/files
                      136M    /opt/iobroker/iobroker-data/backup-objects
                      87M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
                      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                      28M     /opt/iobroker/iobroker-data/objects.jsonl
                      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
                      20M     /opt/iobroker/iobroker-data/objects.json.migrated
                      20M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.18.0
                      /usr/bin/node           v18.18.0
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Installed: 18.18.0-1nodesource1
                        Candidate: 18.18.0-1nodesource1
                        Version table:
                       *** 18.18.0-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                              100 /var/lib/dpkg/status
                           18.17.1-1nodesource1 500
                           18.17.0-1nodesource1 500
                           18.16.1-1nodesource1 500
                           18.16.0-1nodesource1 500
                           18.15.0-1nodesource1 500
                           18.14.2-1nodesource1 500
                           18.14.1-1nodesource1 500
                           18.14.0-1nodesource1 500
                           18.13.0-1nodesource1 500
                           18.12.0-1nodesource1 500
                           18.11.0-1nodesource1 500
                           18.10.0-1nodesource1 500
                           18.9.1-1nodesource1 500
                           18.9.0-1nodesource1 500
                           18.8.0-1nodesource1 500
                           18.7.0-1nodesource1 500
                           18.6.0-1nodesource1 500
                           18.5.0-1nodesource1 500
                           18.4.0-1nodesource1 500
                           18.3.0-1nodesource1 500
                           18.2.0-1nodesource1 500
                           18.1.0-1nodesource1 500
                           18.0.0-1nodesource1 500
                           10.24.0~dfsg-1~deb10u3 500
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: redis
                      States  type: redis
                      No configuration change needed.
                      Multihost discovery server: disabled
                      Discovery authentication:   enabled
                      Persistent activation:      disabled
                      Objects:                    redis on 127.0.0.1
                      States:                     redis on 127.0.0.1
                      Core adapters versions
                      admin:          6.10.2
                      javascript:     7.1.4
                      Adapters from github:   2
                      Adapter State
                        system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                        system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
                        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                        system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
                        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 42001
                      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                      + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                      + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
                      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                      + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
                      + system.adapter.radar2.1                 : radar2                : iobroker                                 -  enabled
                        system.adapter.ring.0                   : ring                  : iobroker                                 - disabled
                        system.adapter.roadtraffic.0            : roadtraffic           : iobroker                                 - disabled
                        system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                        system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                      + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
                        system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                        system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                        system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
                      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                        system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): beta
                      Installed ioBroker-Instances
                      Used repository: beta
                      Adapter    "admin"        : 6.10.4   , installed 6.10.2 [Updatable]
                      Adapter    "alarm"        : 3.3.13   , installed 3.3.13
                      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                      Adapter    "backitup"     : 2.8.2    , installed 2.8.1  [Updatable]
                      Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
                      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                      Adapter    "email"        : 1.2.0    , installed 1.2.0
                      Adapter    "eusec"        : 1.1.2    , installed 1.1.0  [Updatable]
                      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                      Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                      Adapter    "ical"         : 1.13.3   , installed 1.13.3
                      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                      Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
                      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                      Adapter    "info"         : 2.0.0    , installed 2.0.0
                      Adapter    "iot"          : 2.0.11   , installed 2.0.11
                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                      Controller "js-controller": 5.0.12   , installed 5.0.12
                      Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
                      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                      Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                      Adapter    "pvforecast"   : 2.8.1    , installed 2.8.1
                      Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                      Adapter    "ring"         : 5.0.0-alpha.0, installed 3.4.0 [Updatable]
                      Adapter    "roadtraffic"  : 0.2.0    , installed 0.2.0
                      Adapter    "roborock"     : 0.4.4    , installed 0.4.4
                      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                      Adapter    "scenes"       : 2.3.9    , installed 2.3.9
                      Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
                      Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
                      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                      Adapter    "socketio"     : 6.5.6    , installed 6.5.5  [Updatable]
                      Adapter    "sonos"        : 2.3.3    , installed 2.3.1  [Updatable]
                      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                      Adapter    "sql"          : 2.2.0    , installed 2.2.0
                      Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
                      Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
                      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                      Adapter    "vis"          : 1.4.16   , installed 1.4.16
                      Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
                      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
                      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                      Adapter    "web"          : 6.1.3    , installed 6.1.2  [Updatable]
                      Adapter    "ws"           : 2.5.6    , installed 2.5.5  [Updatable]
                      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                      Objects and States
                      Objects:        32411
                      States:         52049
                      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:2 http://phoscon.de/apt/deconz buster InRelease
                      Ign:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Hit:4 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                      Err:6 https://deb.nodesource.com/node_18.x nodistro Release
                        Could not handshake: Error in the pull function. [IP: 2606:4700:10::6816:41a 443]
                      Get:7 https://apt.grafana.com stable InRelease [5984 B]
                      Reading package lists...
                      E: The repository 'https://deb.nodesource.com/node_18.x nodistro Release' no longer has a Release file.
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1318755    12061/io.jarvis.0
                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          22913      809/lighttpd
                      tcp        0      0 192.168.78.83:42001     0.0.0.0:*               LISTEN      1001       87501      6525/io.hm-rpc.0
                      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        21806      724/pihole-FTL
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18356      738/sshd
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          332335     14432/cupsd
                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       88205      6262/node-red
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       86309      6281/io.shelly.0
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       87235      6402/io.mqtt.0
                      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          22964      818/smbd
                      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        21812      724/pihole-FTL
                      tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      110        16875      808/mysqld
                      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          22965      818/smbd
                      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16819      772/redis-server 12
                      tcp6       0      0 :::80                   :::*                    LISTEN      0          22914      809/lighttpd
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3021956    27005/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2963823    25413/io.web.0
                      tcp6       0      0 :::53                   :::*                    LISTEN      999        21808      724/pihole-FTL
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          18358      738/sshd
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          332334     14432/cupsd
                      tcp6       0      0 :::3000                 :::*                    LISTEN      113        136316     8949/grafana
                      tcp6       0      0 :::445                  :::*                    LISTEN      0          22962      818/smbd
                      tcp6       0      0 ::1:4711                :::*                    LISTEN      999        21813      724/pihole-FTL
                      tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16820      772/redis-server 12
                      tcp6       0      0 :::139                  :::*                    LISTEN      0          22963      818/smbd
                      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       90354      6593/io.sonos.0
                      udp        0      0 0.0.0.0:41879           0.0.0.0:*                           1001       601710     9411/io.backitup.0
                      udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        21805      724/pihole-FTL
                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       89218      6437/io.radar2.0
                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       88118      6318/io.radar2.1
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16209      471/dhclient
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          332343     14433/cups-browsed
                      udp        0      0 192.168.78.255:137      0.0.0.0:*                           0          21669      701/nmbd
                      udp        0      0 192.168.78.83:137       0.0.0.0:*                           0          21668      701/nmbd
                      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          21656      701/nmbd
                      udp        0      0 192.168.78.255:138      0.0.0.0:*                           0          21671      701/nmbd
                      udp        0      0 192.168.78.83:138       0.0.0.0:*                           0          21670      701/nmbd
                      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          21657      701/nmbd
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17448      402/avahi-daemon: r
                      udp        0      0 0.0.0.0:44942           0.0.0.0:*                           108        17450      402/avahi-daemon: r
                      udp6       0      0 :::53                   :::*                                999        21807      724/pihole-FTL
                      udp6       0      0 :::5353                 :::*                                108        17449      402/avahi-daemon: r
                      udp6       0      0 :::52557                :::*                                108        17451      402/avahi-daemon: r
                      2023-09-29 20:45:44.387  - warn: host.iobroker Do not restart adapter system.adapter.roborock.0 because restart loop detected
                      2023-09-29 20:46:00.229  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                          at /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/maps/core/core/modbus-client-core.js:79:156
                          at processTicksAndRejections (node:internal/process/task_queues:95:5)
                      2023-09-29 20:46:00.249  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                      2023-09-29 20:48:08.985  - error: node-red.0 (6192) 29 Sep 20:48:08 - [error] [modbus-getter:n37000-37123] Error: Timed out
                      2023-09-29 20:48:09.020  - error: node-red.0 (6192) 29 Sep 20:48:09 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                      2023-09-29 20:50:45.740  - info: javascript.0 (6113) script.js.common.Weather: Material Design Widgets: Wetter Skript triggered by 'linkeddevices.0.Sensor.Wetter.temperature'
                      2023-09-29 20:55:00.944  - info: sql.0 (6216) Do not store value "NULL" for hm-rpc.0.LTK0086602.4.VALVE_STATE because no number
                      2023-09-29 20:56:42.693  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Timed out
                      2023-09-29 20:56:42.720  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                      Danke fürs ansehen.
                      • T ticaki
                        Michael Sauer
                        @ticaki Ist jetzt aktiviert.
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          Skript v.2023-06-20
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : armhf
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=57.4'C
                          volt=0.8500V
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           99M         99M        0.0K
                                   3838 M total memory
                                   2706 M used memory
                                    670 M active memory
                                    111 M free memory
                                    167 M buffer memory
                                    853 M swap cache
                                     99 M total swap
                                     99 M used swap
                                      0 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          3.6G    /var/
                          3.1G    /var/lib
                          1.9G    /var/lib/mysql
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: redis
                          States  type: redis
                          admin:          6.10.2
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        32411
                          States:         52049
                          Pending Updates: 0
                          Danke fürs ansehen.
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          Bullseye ist aktuell
                          free 111M
                          Dein Speicher geht aus ...
                          Redis OK , dann läuft aber
                          redis-server 12
                          Beta Tester ... OK ... aber nicht Aktuell ... up to Date!!!
                          Dann
                            free 111M
                            redis-server 12
                            Dann
                            Michael Sauer
                            @glasfaser Was möchtest du mir damit sagen?
                            GlasfaserG S 2 Antworten Letzte Antwort
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              @michael-sauer
                              Ziemlich ausgelastet dein Raspberry und auch nicht ioBroker als "Beta Tester" gepflegt !
                              Ich würde auf jeden Fall mal PiHole prüfen , denn ich habe oben geschrieben :
                              Keine Verbindung !?
                                SpacerX
                                @michael-sauer ich bleibe dabei. Stelle die Maperstellung ab, dann sollte er laufen.
                                • T Nicht stören
                                  T Nicht stören
                                  ticaki
                                  Der hängt in der Fehlerbehandlung(Map) beim Aufruf von Sentry. Das abschalten der Maperzeugung, so das diese Fehlerbehandlung nicht mehr aufgerufen wird, ist sicher ein Weg. @copystring
                                  Hab nur den Sauger aber nicht den Adapter im Einsatz, sollte wohl ein github issue aufgemacht werden.
                                  https://github.com/copystring/ioBroker.roborock
                                  Spenden
                                  Michael SauerM A 2 Antworten Letzte Antwort
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    Jemand eine Idee?
                                    copystringC Offline
                                    copystringC Offline
                                    copystring
                                    @michael-sauer Die Kartenerstellung kann auf einem RPi nicht funktionieren. Da gibt es ein Problem mit der Canvas-Bibliothek.
                                    https://github.com/copystring/ioBroker.roborock#map-creation-does-not-work-on-raspberry-pi
                                    Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
                                    https://paypal.me/copystring
                                    • T ticaki
                                      Michael Sauer
                                      @ticaki sagte in Roborock - Adapter stürzt ständig ab:
                                      Das war die Lösung. Danke.
                                      • T ticaki
                                        Almeda
                                        @ticaki said in Roborock - Adapter stürzt ständig ab:
                                        ich möchte mich an dieses Thema kurz mit anhängen. Nutze den Roborock Adapter seit ca. 4 Wochen und habe seit Anbeginn, trotz ausgeschalteter Map Erstellung, das Problem, dass der Adapter laut dem Host ständig abstürzt und er ihn daher regelhaft nach 1-2 Tagen aus dem Rennen nimmt und den Neustart verhindert.
                                        Tatsächlich hat die Einrichtung nach der Installation problemlos geklappt und auch die Anbindung an Node-Red zum Ausspielen der Stati über Telegramm hat sofort funktioniert.
                                        Eine De- und Neuinstallation des Apdaters hat nichts gebracht. Ich habe dann auf das aktuelle Update gewartet, weil ich es für ein vllt. bekanntes Problem hielt. Das Update von vor einigen Tagen hat jedoch keine Besserung gebracht.
                                        IoB läuft auf einem Synology 918+ mit ausreichend RAM. Kein anderer Adapter macht Probleme.
                                        Kann einer weiterhelfen?
                                        Vielen Dank
                                        Almeda
                                        Thomas BraunT haselchenH 2 Antworten Letzte Antwort
                                        • A Almeda
                                          Vielen Dank
                                          Almeda
                                          @almeda sagte in Roborock - Adapter stürzt ständig ab:
                                          Ohne Log? Schwierig.
                                          A 1 Antwort Letzte Antwort
