  4. MQTT Adapter - lässt sich nicht schalten
    5.7k
22 Beiträge 4 Kommentatoren 3.3k Aufrufe
  • N Offline
    N Offline
    noxx
    Moin,
    mit meinem Sonoff bin ich erstmal auf Tasmoto umgestiegen, der läuft.
    Aber hier habe hier noch diverse NodeMCUs, die benötige ich ebenfalls.
    Ich bekomme es aber nicht hin, das sich dieser schalten lässt.
    In den LOGs steht leider nichts.
    mqtt.0	2017-07-12 21:37:34.351	info	publishOnSubscribe send all known states
    mqtt.0	2017-07-12 21:37:34.351	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^mqtt\.0\.ESP03\..*/
    mqtt.0	2017-07-12 21:37:34.349	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^ESP03\..*/
    mqtt.0	2017-07-12 21:37:33.853	info	Client [ESPClient13] connected
    mqtt.0	2017-07-12 21:37:15.912	info	Starting MQTT-WebSocket server on port 1884
    mqtt.0	2017-07-12 21:37:15.907	info	Starting MQTT server on port 1883
    mqtt.0	2017-07-12 21:37:14.501	info	starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v4.6.2
    mqtt.0	2017-07-12 21:37:09.716	info	terminating
    mqtt.0	2017-07-12 21:37:09.246	info	Client [ESPClient13] closed
    mqtt.0	2017-07-12 21:37:09.242	info	Client [ESPClient13] closed
    mqtt.0	2017-07-12 21:37:09.233	info	Client [ESPClient13] closed
    mqtt.0	2017-07-12 21:36:32.702	info	publishOnSubscribe send all known states
    mqtt.0	2017-07-12 21:36:32.701	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^mqtt\.0\.ESP03\..*/
    mqtt.0	2017-07-12 21:36:32.700	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^ESP03\..*/
    mqtt.0	2017-07-12 21:36:32.686	info	Client [ESPClient13] connected
    mqtt.0	2017-07-12 21:35:46.782	info	publishOnSubscribe send all known states
    mqtt.0	2017-07-12 21:35:46.781	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^mqtt\.0\.ESP03\..*/
    mqtt.0	2017-07-12 21:35:46.780	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^ESP03\..*/
    mqtt.0	2017-07-12 21:35:46.744	info	Client [ESPClient13] connected
    Evtl hat ja doch noch einer eine Idee.
    • N Offline
      N Offline
      noxx
      Keiner eine Idee warum der Adapter nicht funktioniert? Werde noch bekloppt…. :oops:
      • kmxakK Offline
        kmxakK Offline
        kmxak
        hast du die option fhem mqtt? damit klappte es bei mir ansonsten müssen wir mal genauer schauen
        Gruß Alex
        • N Offline
          N Offline
          noxx
          FHEM wäre möglich, aber ich hätte gerne, wenn möglich, ein reines iobroker. Wenn MQTT nicht geht, dann würde ich FHEM installieren.
          Gesendet von meinem GT-I9195 mit Tapatalk
          • kmxakK Offline
            kmxakK Offline
            kmxak
            na das meinte ich nicht im 2.png anstatt openhab mqtt fhem mqtt nehmen wenn es verfügbar ist.
            Das kommuniziert dann auch mit iobroker mqtt direkt
            Gruß Alex
            • K Offline
              knopers1
              @noxx
              schau doch mal hier nach!
              http://forum.iobroker.net/viewtopic.php … 460#p55564
              Kannst Du mir sagen, was Du genau erzeugen willst? Soll es ein Schalter/Taster sein? oder eher ein Relai was geschaltet werden soll?
              Im oberen Link hat der Kollege Starfisch ein paar Beispiele gegeben.
              Schaue auch unter Rules nach!
              • BluefoxB Offline
                BluefoxB Offline
                Schalte Debug Level an. Da sieht man mehr.
                • N Offline
                  N Offline
                  noxx
                  @kmxak
                  FHEM MQTT gibts nicht, aber FHEM HTTP
                  @knopers1
                  schaue ich mir an, es sollen Relais geschaltet werden
                  @Bluefox
                  Kommt
                  • kmxakK Offline
                    kmxakK Offline
                    kmxak
                    Hey kannst du mir mitteilen welche Firmware du drauf hast? Wenn es irgendwas spezielles ist kannst es mir auch gerne senden dann teste ich es mal an meinem nodemcu
                    Gruß Alex
                    • N Offline
                      N Offline
                      noxx
                      @Bluefox
                      Habe nun mal auf ESPeasy Mega upgedatet.
                      Gehen tuts dennoch nicht.
                      LOG sieht so aus.
                      mqtt.0	2017-07-14 17:23:39.194	info	publishOnSubscribe send all known states
                      mqtt.0	2017-07-14 17:23:39.193	info	Client [ESPClient0] subscribes on "ESP03.#" with regex /^mqtt\.0\.ESP03\..*/
                      mqtt.0	2017-07-14 17:23:39.193	info	Client [ESPClient0] subscribes on "ESP03.#" with regex /^ESP03\..*/
                      mqtt.0	2017-07-14 17:23:39.193	info	Client [ESPClient0] connected
                      mqtt.0	2017-07-14 17:23:25.802	info	Starting MQTT-WebSocket server on port 1884
                      mqtt.0	2017-07-14 17:23:25.798	info	Starting MQTT server on port 1883
                      mqtt.0	2017-07-14 17:23:24.288	info	starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v4.6.2
                      mqtt.0	2017-07-14 17:23:19.447	info	terminating
                      mqtt.0	2017-07-14 17:23:19.008	debug	onStateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1500045798973,"q":0,"from":"system.adapter.mqtt.0","lc":1500045798973}
                      mqtt.0	2017-07-14 17:23:19.007	debug	stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1500045798973,"q":0,"from":"system.adapter.mqtt.0","lc":1500045798973}
                      mqtt.0	2017-07-14 17:23:19.005	debug	inMem message mqtt.0.* mqtt.0.info.connection val=, ack=true, ts=1500045798973, q=0, from=system.adapter.mqtt.0, lc=1500045798973
                      mqtt.0	2017-07-14 17:23:18.985	debug	Использование последней версии MQTT пакета, en=fix authentication in server, de=Korregiere Kennwortprüfung im Broker, ru=Исправлена проверка пароля, en=do not parse JSON states, that do not have attri
                      mqtt.0	2017-07-14 17:23:18.985	debug	Benutzung von neuem MQTT Paket, ru=Поддержка LWT для сервера
                      mqtt.0	2017-07-14 17:23:18.985	debug	update mqtt package version, de=Implementierung von LWT für Sevrer
                      mqtt.0	2017-07-14 17:23:18.985	debug	Настраиваемый Client ID, en=Fix server publishing, de=Korregiere ServerPublish, ru=Исправлен publish сервера, en=additional debug output, de=Debug-Ausgaben hinzugefügt, ru=Добавлена отладочная информа
                      mqtt.0	2017-07-14 17:23:18.985	debug	Einstellbares Client ID, ru=Обновлён mqtt модуль
                      mqtt.0	2017-07-14 17:23:18.985	debug	configurable client ID, de=Update mqtt Packet
                      mqtt.0	2017-07-14 17:23:18.985	debug	изменеён диалог настроек, en=Update mqtt package
                      mqtt.0	2017-07-14 17:23:18.985	debug	Добавлены новые настройки для сервера
                      mqtt.0	2017-07-14 17:23:18.985	debug	Ändere Konfigurationsdialog, ru=Обновлён mqtt модуль
                      mqtt.0	2017-07-14 17:23:18.985	debug	Neue Einstellungen für Server hizugefügt
                      mqtt.0	2017-07-14 17:23:18.985	debug	reorganise configuration dialog, de=Update mqtt Packet
                      mqtt.0	2017-07-14 17:23:18.985	debug	add Interval before send topics by connection ans send interval settings
                      mqtt.0	2017-07-14 17:23:18.985	debug	inMem message system.adapter.* system.adapter.mqtt.0 _id=system.adapter.mqtt.0, type=instance, name=mqtt, js-controller=>=0.10.0, version=1.3.2, en=Fix convert of UTF8 payloads, de=Korregiere die Ko
                      mqtt.0	2017-07-14 17:23:18.979	debug	stateChange mqtt.0.ESP03.status: {"val":"[object Object]","ack":true,"ts":1500045798964,"q":0,"from":"system.adapter.mqtt.0","lc":1500045798964}
                      mqtt.0	2017-07-14 17:23:18.974	debug	inMem message mqtt.0.* mqtt.0.ESP03.status val=[object Object], ack=true, ts=1500045798964, q=0, from=system.adapter.mqtt.0, lc=1500045798964
                      mqtt.0	2017-07-14 17:23:18.960	info	Client [ESPClient0] closed
                      mqtt.0	2017-07-14 17:23:10.404	debug	Client [ESPClient0] pingreq
                      mqtt.0	2017-07-14 17:22:55.328	debug	Client [ESPClient0] pingreq
                      mqtt.0	2017-07-14 17:22:40.326	debug	Client [ESPClient0] pingreq
                      mqtt.0	2017-07-14 17:22:40.311	debug	onStateChange mqtt.0.ESP03.Temperatur.Temperature: {"val":18.5,"ack":true,"ts":1500045760296,"q":0,"from":"system.adapter.mqtt.0","lc":1500045218582}
                      mqtt.0	2017-07-14 17:22:40.310	debug	stateChange mqtt.0.ESP03.Temperatur.Temperature: {"val":18.5,"ack":true,"ts":1500045760296,"q":0,"from":"system.adapter.mqtt.0","lc":1500045218582}
                      mqtt.0	2017-07-14 17:22:40.305	debug	inMem message mqtt.0.* mqtt.0.ESP03.Temperatur.Temperature val=18.5, ack=true, ts=1500045760296, q=0, from=system.adapter.mqtt.0, lc=1500045218582
                      mqtt.0	2017-07-14 17:22:25.284	debug	Client [ESPClient0] pingreq
                      mqtt.0	2017-07-14 17:22:10.283	debug	Client [ESPClient0] pingreq
                      mqtt.0	2017-07-14 17:21:55.282	debug	Client [ESPClient0] pingreq
                      mqtt.0	2017-07-14 17:21:40.282	debug	Client [ESPClient0] pingreq
                      mqtt.0	2017-07-14 17:21:40.247	debug	stateChange mqtt.0.ESP03.Temperatur.Temperature: {"val":18.5,"ack":true,"ts":1500045700237,"q":0,"from":"system.adapter.mqtt.0","lc":1500045218582}
                      mqtt.0	2017-07-14 17:21:40.244	debug	inMem message mqtt.0.* mqtt.0.ESP03.Temperatur.Temperature val=18.5, ack=true, ts=1500045700237, q=0, from=system.adapter.mqtt.0, lc=1500045218582
                      mqtt.0	2017-07-14 17:21:25.234	debug	Client [ESPClient0] pingreq
                      mqtt.0	2017-07-14 17:21:10.232	debug	Client [ESPClient0] pingreq
                      mqtt.0	2017-07-14 17:20:55.233	debug	Client [ESPClient0] pingreq
                      mqtt.0	2017-07-14 17:20:40.731	debug	onStateChange mqtt.0.ESP03.Notlicht.Switch: {"val":1,"ack":false,"ts":1500045640721,"q":0,"from":"system.adapter.admin.0","lc":1500045640721}
                      mqtt.0	2017-07-14 17:20:40.730	debug	stateChange mqtt.0.ESP03.Notlicht.Switch: {"val":1,"ack":false,"ts":1500045640721,"q":0,"from":"system.adapter.admin.0","lc":1500045640721}
                      mqtt.0	2017-07-14 17:20:40.727	debug	inMem message mqtt.0.* mqtt.0.ESP03.Notlicht.Switch val=1, ack=false, ts=1500045640721, q=0, from=system.adapter.admin.0, lc=1500045640721
                      mqtt.0	2017-07-14 17:20:40.207	debug	onStateChange mqtt.0.ESP03.Temperatur.Temperature: {"val":18.5,"ack":true,"ts":1500045640191,"q":0,"from":"system.adapter.mqtt.0","lc":1500045218582}
                      mqtt.0	2017-07-14 17:20:40.206	debug	stateChange mqtt.0.ESP03.Temperatur.Temperature: {"val":18.5,"ack":true,"ts":1500045640191,"q":0,"from":"system.adapter.mqtt.0","lc":1500045218582}
                      mqtt.0	2017-07-14 17:20:40.201	debug	inMem message mqtt.0.* mqtt.0.ESP03.Temperatur.Temperature val=18.5, ack=true, ts=1500045640191, q=0, from=system.adapter.mqtt.0, lc=1500045218582
                      mqtt.0	2017-07-14 17:20:39.366	debug	onStateChange mqtt.0.ESP03.status: {"val":"Connected","ack":true,"ts":1500045639326,"q":0,"from":"system.adapter.mqtt.0","lc":1500045639326}
                      mqtt.0	2017-07-14 17:20:39.365	debug	stateChange mqtt.0.ESP03.status: {"val":"Connected","ack":true,"ts":1500045639326,"q":0,"from":"system.adapter.mqtt.0","lc":1500045639326}
                      mqtt.0	2017-07-14 17:20:39.358	debug	inMem message mqtt.0.* mqtt.0.ESP03.status val=Connected, ack=true, ts=1500045639326, q=0, from=system.adapter.mqtt.0, lc=1500045639326
                      mqtt.0	2017-07-14 17:20:39.300	info	publishOnSubscribe send all known states
                      mqtt.0	2017-07-14 17:20:39.300	info	Client [ESPClient0] subscribes on "ESP03.#" with regex /^mqtt\.0\.ESP03\..*/
                      mqtt.0	2017-07-14 17:20:39.297	info	Client [ESPClient0] subscribes on "ESP03.#" with regex /^ESP03\..*/
                      mqtt.0	2017-07-14 17:20:39.195	debug	onStateChange mqtt.0.info.connection: {"val":"ESPClient0","ack":true,"ts":1500045639176,"q":0,"from":"system.adapter.mqtt.0","lc":1500045639176}
                      mqtt.0	2017-07-14 17:20:39.193	debug	stateChange mqtt.0.info.connection: {"val":"ESPClient0","ack":true,"ts":1500045639176,"q":0,"from":"system.adapter.mqtt.0","lc":1500045639176}
                      mqtt.0	2017-07-14 17:20:39.188	debug	inMem message mqtt.0.* mqtt.0.info.connection val=ESPClient0, ack=true, ts=1500045639176, q=0, from=system.adapter.mqtt.0, lc=1500045639176
                      mqtt.0	2017-07-14 17:20:38.747	info	Client [ESPClient0] connected
                      mqtt.0	2017-07-14 17:20:35.379	debug	onStateChange mqtt.0.ESP03.Innenlicht.Switch: {"val":1,"ack":false,"ts":1500045635366,"q":0,"from":"system.adapter.admin.0","lc":1500045635366}
                      mqtt.0	2017-07-14 17:20:35.378	debug	stateChange mqtt.0.ESP03.Innenlicht.Switch: {"val":1,"ack":false,"ts":1500045635366,"q":0,"from":"system.adapter.admin.0","lc":1500045635366}
                      mqtt.0	2017-07-14 17:20:35.375	debug	inMem message mqtt.0.* mqtt.0.ESP03.Innenlicht.Switch val=1, ack=false, ts=1500045635366, q=0, from=system.adapter.admin.0, lc=1500045635366
                      mqtt.0	2017-07-14 17:20:29.450	debug	onStateChange mqtt.0.ESP03.Aussenlicht.Switch: {"val":1,"ack":false,"ts":1500045629431,"q":0,"from":"system.adapter.admin.0","lc":1500045629431}
                      mqtt.0	2017-07-14 17:20:29.445	debug	stateChange mqtt.0.ESP03.Aussenlicht.Switch: {"val":1,"ack":false,"ts":1500045629431,"q":0,"from":"system.adapter.admin.0","lc":1500045629431}
                      mqtt.0	2017-07-14 17:20:29.441	debug	inMem message mqtt.0.* mqtt.0.ESP03.Aussenlicht.Switch val=1, ack=false, ts=1500045629431, q=0, from=system.adapter.admin.0, lc=1500045629431
                      mqtt.0	2017-07-14 17:20:09.921	debug	stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1500045609888,"q":0,"from":"system.adapter.mqtt.0","lc":1500045603045}
                      mqtt.0	2017-07-14 17:20:09.899	debug	inMem message mqtt.0.* mqtt.0.info.connection val=, ack=true, ts=1500045609888, q=0, from=system.adapter.mqtt.0, lc=1500045603045
                      mqtt.0	2017-07-14 17:20:09.859	info	Starting MQTT-WebSocket server on port 1884
                      mqtt.0	2017-07-14 17:20:09.858	info	Starting MQTT server on port 1883
                      mqtt.0	2017-07-14 17:20:08.547	info	starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v4.6.2
                      mqtt.0	2017-07-14 17:20:08.447	debug	statesDB connected
                      mqtt.0	2017-07-14 17:20:08.299	debug	objectDB connected
                      • N Offline
                        N Offline
                        noxx
                        @kmxak:
                        Hey kannst du mir mitteilen welche Firmware du drauf hast? Wenn es irgendwas spezielles ist kannst es mir auch gerne senden dann teste ich es mal an meinem nodemcu `
                        installiert ist
                        Release v2.0.0-dev10
                        von hier:
                        https://github.com/letscontrolit/ESPEasy/releases
                        • kmxakK Offline
                          kmxakK Offline
                          kmxak
                          Ok ich checke das und gebe Info.
                          Gesendet von meinem SM-G930F mit Tapatalk
                          Gruß Alex
                          • N Offline
                            N Offline
                            noxx
                            • kmxakK Offline
                              kmxakK Offline
                              kmxak
                              also ich bekomme es mit der 2er version auch nicht hin. Habe nun noch einen anderen MQTT Server unter Windows aufgesetzt aber auch der empfängt rein gar nichts. Auch test.mosquitto.org funzt nicht.
                              Ich vermute es liegt an der Firmware
                              Die 148er Version funktioniert dagegen wunderbar :?
                              Gruß Alex
                              • N Offline
                                N Offline
                                noxx
                                hmm, hatte ja vorher die 147 drauf, die wollte ja auch nicht.
                                und unter FHEM ging die 2er auch, allerdings mit dem FHEM HTTP
                                Controller. Für FHEM wird dann auch kein MQTT benötigt.
                                Kannst mal zeigen, wie die 148 bei dir eingestellt ist?
                                • kmxakK Offline
                                  kmxakK Offline
                                  kmxak
                                  Unter Tools und dann Log kannst dir ja anschauen was der gerade macht. Dort steht in der 148 5306 : MQTT : Connected to broker
                                  und es geht auch.
                                  Einstellungen genau wie die 2er version
                                  Gruß Alex
                                  • N Offline
                                    N Offline
                                    noxx
                                    Sonst keine Unterschiede zu meinen aus Post 1?
                                    Wie sehen deine Datenpunkte aus?
                                    • kmxakK Offline
                                      kmxakK Offline
                                      kmxak
                                      Jetzt mal unabhängig von der MQTT Einrichtung. Funktioniert das überhaupt einen Schalter per MQTT zu schalten? Müsste auf dem NodeMCU nicht ein Dummy eingerichtet werden den du per MQTT schaltest?
                                      Gruß Alex
                                      • N Offline
                                        N Offline
                                        noxx
                                        Bisher war das weder bei FHEM noch bei pimatic notwendig einen Dummy einzurichten. Gibt ja leider kein richtige Anleitung wie es unter iobroker geht.
                                        • kmxakK Offline
                                          kmxakK Offline
                                          kmxak
                                          Warte leider immer noch auf meine China teile bis ich richtig damit loslegen kann dann kommt das auch noch auf mich zu dann sehen wir weiter.
                                          Gruß Alex
