  3. Off Topic
  4. Fehlermeldung bei sudo apt update, was tun? [gelöst]
    1.0k
    6.1k
5 Beiträge 4 Kommentatoren 585 Aufrufe 3 Beobachtet
  • DuffyD Online
    DuffyD Online
    Duffy
    schrieb am zuletzt editiert von Duffy
    Hallo an Alle,
    ich wollte heute mal wieder ein sudo apt update ausfühern um meinen iob auf Stand zu halten.
    Dabei kam folgende Meldung (ab Zeile11):
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 http://deb.debian.org/debian bullseye-backports InRelease
    Hit:7 https://repos.influxdata.com/debian bullseye InRelease
    Get:8 https://packages.grafana.com/oss/deb stable InRelease [5,983 B]
    Get:9 https://deb.nodesource.com/node_18.x bullseye InRelease [4,586 B]
    Err:8 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    Fetched 4,586 B in 3s (1,484 B/s)
    Reading package lists... Done
    Building dependency tree... Done
    All packages are up to date.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    pi@raspberrypi:~ $
    Kann mir bitte jemand sagen wie ich das Problem, sollte es eins sei, beheben kann?
    Wenn ich beine Dashboards in Grafana anschaue scheint alles zu funtionieren.
    Für einen Tip wäre ich sehr dankbar.
    Gruß Duffy
    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
    Node.js: v22.23.2
    NPM: 10.9.4
    js-controller 7.1.2
    Linux: Trixie
    Thomas BraunT falke69F HomoranH 3 Antworten Letzte Antwort
    • DuffyD Duffy
      Hallo an Alle,
      pi@raspberrypi:~ $
      Gruß Duffy
      @duffy
      Da bist du aber seit Monaten nicht mehr tätig geworden. Es gibt einen Thread 'Grafana Repository muss angepasst werden' (oder so ähnlich) dazu.
      • DuffyD Duffy
        Hallo an Alle,
        pi@raspberrypi:~ $
        Gruß Duffy
        falke69F Offline
        falke69F Offline
        falke69
        @duffy
        versuche mal
        sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 963FA27710458545
        DuffyD 1 Antwort Letzte Antwort
        • DuffyD Duffy
          Hallo an Alle,
          pi@raspberrypi:~ $
          Gruß Duffy
          @duffy sagte in Fehlermeldung bei sudo apt update, was tun?:
          wie du richtig gesehen hast veht es um Grafana, nicht iobroker
          • falke69F falke69
            @duffy
            versuche mal
            DuffyD Online
            DuffyD Online
            Duffy
            @falke69
            Vielen Dank, das werde ich gleich einmal versuchen.
            Ich habe in der Tat est vor 14 Tagen ein Sudo apt update durchgeführt aber vermutlich ist es mir dabei nicht aufgefallen.
            Jetzt ist der Fehler aber weg., vielen Dank an alle die geholfen haben.
            Gruß Duffy
            Node.js: v22.23.2
            NPM: 10.9.4
            js-controller 7.1.2
            Linux: Trixie
