  4. VIS.0 startet immer neu, normal?
    5.2k
vis-adaptervis
34 Beiträge 6 Kommentatoren 2.8k Aufrufe 5 Beobachtet
  • RoboCopR RoboCop
    @thomas-braun said in VIS.0 startet immer neu, normal?:
    @robocop
    Das riecht irgendwie nach 'bereits verfummelt'.
    nodejs war irgendwie komisch bei dir, Vis wohl auch.
    Schau dir das im Ganzen mal über
    iob diag
    an.
    ======== Start marking the full check here =========
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : microsoft
    Distributor ID: Debian
    Description:    Debian GNU/Linux 12 (bookworm)
    Release:        12
    Codename:       bookworm
    PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
    NAME="Debian GNU/Linux"
    VERSION_ID="12"
    VERSION="12 (bookworm)"
    VERSION_CODENAME=bookworm
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     15:54:57 up  7:24,  2 users,  load average: 0.23, 0.42, 0.62
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sat 2023-09-09 15:54:57 CEST
               Universal time: Sat 2023-09-09 13:54:57 UTC
                     RTC time: Sat 2023-09-09 13:54:57
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    robocop0815
    /home/robocop0815
    robocop0815 cdrom floppy sudo audio dip video plugdev users netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            6.2G        5.5G        488M        4.0M        490M        680M
    Swap:           1.0G        218M        803M
    Total:          7.2G        5.7G        1.3G
             5890 M total memory
             5242 M used memory
              364 M active memory
             4490 M inactive memory
              465 M free memory
               58 M buffer memory
              409 M swap cache
              974 M total swap
              208 M used swap
              766 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  2.9G     0  2.9G   0% /dev
    tmpfs          tmpfs     590M  560K  589M   1% /run
    /dev/sda1      ext4      124G  7.8G  110G   7% /
    tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     590M     0  590M   0% /run/user/1000
    [Sat Sep  9 08:31:07 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Sep  9 08:31:11 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    449M    /var/
    182M    /var/lib
    146M    /var/lib/apt/lists
    146M    /var/lib/apt
    139M    /var/cache
    Archived and active journals take up 39.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    769M    /opt/iobroker/iobroker-data/
    471M    /opt/iobroker/iobroker-data/files
    139M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    72M     /opt/iobroker/iobroker-data/history
    53M     /opt/iobroker/iobroker-data/states.jsonl
    36M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-1nodesource1
      Candidate: 18.17.1-1nodesource1
      Version table:
     *** 18.17.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 cdrom://[Debian GNU/Linux 12.1.0 _Bookworm_ - Official amd64 DVD Binary-1 with firmware 20230722-10:49] bookworm/main amd64 Packages
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.8.0
    javascript:     7.0.3
    Adapters from github:   6
    Adapter State
    + system.adapter.admin.0                  : admin                 : debian12                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : debian12                                 -  enabled
    + system.adapter.backitup.0               : backitup              : debian12                                 -  enabled
    + system.adapter.backitup.1               : backitup              : iob-slave                                -  enabled
    + system.adapter.ble.0                    : ble                   : iob-slave                                -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : debian12                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : debian12                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : debian12                                 -  enabled
      system.adapter.devices.0                : devices               : debian12                                 -  enabled
    + system.adapter.discovery.0              : discovery             : debian12                                 -  enabled
      system.adapter.flot.0                   : flot                  : debian12                                 -  enabled
    + system.adapter.harmony.0                : harmony               : debian12                                 -  enabled
    + system.adapter.history.0                : history               : debian12                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : debian12                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : debian12                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : debian12                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : debian12                                 -  enabled
      system.adapter.ical.1                   : ical                  : debian12                                 -  enabled
      system.adapter.ical.2                   : ical                  : debian12                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : debian12                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : debian12                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian12                                 -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: debian12                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : debian12                                 -  enabled
    + system.adapter.info.0                   : info                  : debian12                                 -  enabled
    + system.adapter.iot.0                    : iot                   : debian12                                 -  enabled
    + system.adapter.javascript.0             : javascript            : debian12                                 -  enabled
      system.adapter.mclighting.0             : mclighting            : debian12                                 - disabled, port: 81
    + system.adapter.mihome.0                 : mihome                : debian12                                 -  enabled, port: 9898, bind: 0.0.0.0
    + system.adapter.mqtt.0                   : mqtt                  : debian12                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.nina.0                   : nina                  : debian12                                 -  enabled
    + system.adapter.node-red.0               : node-red              : debian12                                 -  enabled, port: 1888, bind: 0.0.0.0
      system.adapter.octoprint.0              : octoprint             : debian12                                 - disabled
      system.adapter.octoprint.1              : octoprint             : debian12                                 - disabled
      system.adapter.octoprint.2              : octoprint             : debian12                                 - disabled
    + system.adapter.parcel.0                 : parcel                : debian12                                 -  enabled
    + system.adapter.ping.0                   : ping                  : debian12                                 -  enabled
    + system.adapter.plenticore.0             : plenticore            : debian12                                 -  enabled, port: 80
    + system.adapter.pollenflug.0             : pollenflug            : debian12                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : debian12                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : debian12                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : debian12                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : debian12                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : debian12                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : debian12                                 -  enabled
    + system.adapter.tankerkoenig.1           : tankerkoenig          : debian12                                 -  enabled
    + system.adapter.tankerkoenig.2           : tankerkoenig          : debian12                                 -  enabled
    + system.adapter.telegram.0               : telegram              : debian12                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : debian12                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : debian12                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : debian12                                 -  enabled
    + system.adapter.text2command.1           : text2command          : debian12                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : debian12                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : debian12                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : debian12                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : debian12                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian12                                 -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian12                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : debian12                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian12                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : debian12                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : debian12                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian12                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : debian12                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : debian12                                 -  enabled
      system.adapter.vis-owl.0                : vis-owl               : debian12                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : debian12                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian12                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : debian12                                 -  enabled
      system.adapter.vis.0                    : vis                   : debian12                                 - disabled
    + system.adapter.web.0                    : web                   : debian12                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : debian12                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iob-slave                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_64d0cc0f5286ec11ae4beb3719c2d21c-if00-port0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.8.0    , installed 6.8.0
    Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 6.5.3    , installed 6.5.3
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.1    , installed 6.1.1
    Adapter    "worx"         : 2.3.2    , installed 2.3.2
    Adapter    "ws"           : 2.5.4    , installed 2.5.4
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        25938
    States:         22150
    E: The repository 'cdrom://[Debian GNU/Linux 12.1.0 _Bookworm_ - Official amd64 DVD Binary-1 with firmware 20230722-10:49] bookworm Release' does not have a Release file.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.149:8701    0.0.0.0:*               LISTEN      1001       660397     569507/io.hm-rpc.1
    tcp        0      0 192.168.178.149:2001    0.0.0.0:*               LISTEN      1001       661720     569474/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       657367     569353/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       657397     570094/io.sonoff.0
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       657334     569963/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       657333     569963/io.mqtt.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       658163     569224/iobroker.js-
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       658170     569224/iobroker.js-
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15406      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20828      616/sshd: /usr/sbin
    tcp6       0      0 :::40483                :::*                    LISTEN      1001       668580     571451/./pawns-cli
    tcp6       0      0 :::36487                :::*                    LISTEN      1001       670755     571227/./pawns-cli
    tcp6       0      0 :::40829                :::*                    LISTEN      1001       664229     570925/./pawns-cli
    tcp6       0      0 :::40955                :::*                    LISTEN      1001       664370     571151/./pawns-cli
    tcp6       0      0 :::45011                :::*                    LISTEN      1001       670853     571399/./pawns-cli
    tcp6       0      0 :::45019                :::*                    LISTEN      1001       662375     570953/./pawns-cli
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       660238     569245/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       665674     570222/io.web.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       663497     570761/io.terminal.
    tcp6       0      0 :::40039                :::*                    LISTEN      1001       670813     571333/./pawns-cli
    tcp6       0      0 :::35907                :::*                    LISTEN      1001       671212     572109/./pawns-cli
    tcp6       0      0 :::44091                :::*                    LISTEN      1001       671920     571468/./pawns-cli
    tcp6       0      0 :::36071                :::*                    LISTEN      1001       669305     571377/./pawns-cli
    tcp6       0      0 :::40145                :::*                    LISTEN      1001       675898     572051/./pawns-cli
    tcp6       0      0 :::44385                :::*                    LISTEN      1001       665271     570774/./pawns-cli
    tcp6       0      0 :::36203                :::*                    LISTEN      1001       668924     570848/./pawns-cli
    tcp6       0      0 :::36137                :::*                    LISTEN      1001       669248     571320/./pawns-cli
    tcp6       0      0 :::44343                :::*                    LISTEN      1001       664421     571293/./pawns-cli
    tcp6       0      0 :::36115                :::*                    LISTEN      1001       669324     571371/./pawns-cli
    tcp6       0      0 :::36227                :::*                    LISTEN      1001       663202     570731/./pawns-cli
    tcp6       0      0 :::39507                :::*                    LISTEN      1001       666209     570969/./pawns-cli
    tcp6       0      0 :::39439                :::*                    LISTEN      1001       667279     570931/./pawns-cli
    tcp6       0      0 :::35471                :::*                    LISTEN      1001       668636     571515/./pawns-cli
    tcp6       0      0 :::35665                :::*                    LISTEN      1001       664086     570696/./pawns-cli
    tcp6       0      0 :::43827                :::*                    LISTEN      1001       669200     571241/./pawns-cli
    tcp6       0      0 :::35717                :::*                    LISTEN      1001       664464     571443/./pawns-cli
    tcp6       0      0 :::34885                :::*                    LISTEN      1001       669947     571605/./pawns-cli
    tcp6       0      0 :::35069                :::*                    LISTEN      1001       673822     571650/./pawns-cli
    tcp6       0      0 :::43213                :::*                    LISTEN      1001       665437     571029/./pawns-cli
    tcp6       0      0 :::43195                :::*                    LISTEN      1001       668223     570983/./pawns-cli
    tcp6       0      0 :::43197                :::*                    LISTEN      1001       668471     571307/./pawns-cli
    tcp6       0      0 :::39245                :::*                    LISTEN      1001       668485     571351/./pawns-cli
    tcp6       0      0 :::43287                :::*                    LISTEN      1001       667239     570898/./pawns-cli
    tcp6       0      0 :::38497                :::*                    LISTEN      1001       671223     572124/./pawns-cli
    tcp6       0      0 :::46713                :::*                    LISTEN      1001       675869     572031/./pawns-cli
    tcp6       0      0 :::38451                :::*                    LISTEN      1001       669429     571533/./pawns-cli
    tcp6       0      0 :::42505                :::*                    LISTEN      1001       675973     572125/./pawns-cli
    tcp6       0      0 :::34559                :::*                    LISTEN      1001       675041     572167/./pawns-cli
    tcp6       0      0 :::42851                :::*                    LISTEN      1001       668951     570910/./pawns-cli
    tcp6       0      0 :::42865                :::*                    LISTEN      1001       664120     570781/./pawns-cli
    tcp6       0      0 :::38723                :::*                    LISTEN      1001       668323     571110/./pawns-cli
    tcp6       0      0 :::42789                :::*                    LISTEN      1001       667452     571174/./pawns-cli
    tcp6       0      0 :::34615                :::*                    LISTEN      1001       671269     572152/./pawns-cli
    tcp6       0      0 :::42957                :::*                    LISTEN      1001       668432     571264/./pawns-cli
    tcp6       0      0 :::38827                :::*                    LISTEN      1001       670955     571505/./pawns-cli
    tcp6       0      0 :::34739                :::*                    LISTEN      1001       664283     571050/./pawns-cli
    tcp6       0      0 :::33863                :::*                    LISTEN      1001       674821     571600/./pawns-cli
    tcp6       0      0 :::33877                :::*                    LISTEN      1001       668420     571250/./pawns-cli
    tcp6       0      0 :::46331                :::*                    LISTEN      1001       671939     571487/./pawns-cli
    tcp6       0      0 :::46333                :::*                    LISTEN      1001       675947     572102/./pawns-cli
    tcp6       0      0 :::46301                :::*                    LISTEN      1001       664441     571385/./pawns-cli
    tcp6       0      0 :::46253                :::*                    LISTEN      1001       669260     571327/./pawns-cli
    tcp6       0      0 :::46271                :::*                    LISTEN      1001       672239     572145/./pawns-cli
    tcp6       0      0 :::42119                :::*                    LISTEN      1001       667426     571103/./pawns-cli
    tcp6       0      0 :::46229                :::*                    LISTEN      1001       668917     570839/./pawns-cli
    tcp6       0      0 :::42333                :::*                    LISTEN      1001       668562     571437/./pawns-cli
    tcp6       0      0 :::46377                :::*                    LISTEN      1001       669077     571084/./pawns-cli
    tcp6       0      0 :::42283                :::*                    LISTEN      1001       669148     571091/./pawns-cli
    tcp6       0      0 :::46349                :::*                    LISTEN      1001       668572     571418/./pawns-cli
    tcp6       0      0 :::46541                :::*                    LISTEN      1001       668465     571301/./pawns-cli
    tcp6       0      0 :::34269                :::*                    LISTEN      1001       669535     571616/./pawns-cli
    tcp6       0      0 :::42405                :::*                    LISTEN      1001       664409     571256/./pawns-cli
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       663952     570508/io.harmony.0
    tcp6       0      0 :::33339                :::*                    LISTEN      1001       664260     570991/./pawns-cli
    tcp6       0      0 :::37389                :::*                    LISTEN      1001       674887     572058/./pawns-cli
    tcp6       0      0 :::41713                :::*                    LISTEN      1001       667299     570946/./pawns-cli
    tcp6       0      0 :::33473                :::*                    LISTEN      1001       669380     571477/./pawns-cli
    tcp6       0      0 :::33481                :::*                    LISTEN      1001       668997     571004/./pawns-cli
    tcp6       0      0 :::33445                :::*                    LISTEN      1001       663536     571192/./pawns-cli
    tcp6       0      0 :::33459                :::*                    LISTEN      1001       663362     570959/./pawns-cli
    tcp6       0      0 :::45751                :::*                    LISTEN      1001       664458     571429/./pawns-cli
    tcp6       0      0 :::45707                :::*                    LISTEN      1001       672030     571606/./pawns-cli
    tcp6       0      0 :::37759                :::*                    LISTEN      1001       672770     571424/./pawns-cli
    tcp6       0      0 :::37701                :::*                    LISTEN      1001       662454     571065/./pawns-cli
    tcp6       0      0 :::33613                :::*                    LISTEN      1001       665283     570787/./pawns-cli
    tcp6       0      0 :::45867                :::*                    LISTEN      1001       667432     571118/./pawns-cli
    tcp6       0      0 :::33705                :::*                    LISTEN      1001       664143     570800/./pawns-cli
    tcp6       0      0 :::111                  :::*                    LISTEN      0          15407      1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          25317      618/apache2
    tcp6       0      0 :::32851                :::*                    LISTEN      1001       669716     571162/./pawns-cli
    tcp6       0      0 :::40995                :::*                    LISTEN      1001       671811     571279/./pawns-cli
    tcp6       0      0 :::36903                :::*                    LISTEN      1001       664470     571448/./pawns-cli
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20830      616/sshd: /usr/sbin
    tcp6       0      0 :::32987                :::*                    LISTEN      1001       672155     572072/./pawns-cli
    tcp6       0      0 :::45245                :::*                    LISTEN      1001       669815     571340/./pawns-cli
    tcp6       0      0 :::37007                :::*                    LISTEN      1001       672790     571462/./pawns-cli
    tcp6       0      0 :::41113                :::*                    LISTEN      1001       669221     571286/./pawns-cli
    tcp6       0      0 :::41315                :::*                    LISTEN      1001       665065     570568/./pawns-cli
    tcp6       0      0 :::45415                :::*                    LISTEN      1001       668863     570725/./pawns-cli
    tcp6       0      0 :::37143                :::*                    LISTEN      1001       664355     571044/./pawns-cli
    tcp6       0      0 :::41449                :::*                    LISTEN      1001       667223     570864/./pawns-cli
    tcp6       0      0 :::33269                :::*                    LISTEN      1001       668869     570741/./pawns-cli
    tcp6       0      0 :::41469                :::*                    LISTEN      1001       670780     571273/./pawns-cli
    tcp6       0      0 :::45509                :::*                    LISTEN      1001       666216     570975/./pawns-cli
    tcp6       0      0 :::33161                :::*                    LISTEN      1001       667399     571059/./pawns-cli
    tcp6       0      0 :::45457                :::*                    LISTEN      1001       672009     571558/./pawns-cli
    udp        0      0 192.168.178.149:5353    0.0.0.0:*                           1001       656147     570148/io.tr-064.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       663633     570029/io.shelly.0
    udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       1358851    569919/io.mihome.0
    udp        0      0 0.0.0.0:59683           0.0.0.0:*                           1001       663899     570321/io.broadlink
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       666717     570162/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       666718     570162/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       662015     570321/io.broadlink
    udp        0      0 0.0.0.0:52890           0.0.0.0:*                           1001       663898     570321/io.broadlink
    udp        0      0 0.0.0.0:53024           0.0.0.0:*                           1001       663897     570321/io.broadlink
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14080      1/init
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       663953     570508/io.harmony.0
    udp6       0      0 :::111                  :::*                                0          19180      1/init
    2023-09-09 15:49:52.709  - info: javascript.0 (569283) script.js.AWTRIX_LED.AWTRIX_Controller: {"name":"TempHumOutdoor","force":false,"icon":912,"moveIcon":false,"repeat":2,"text":"33.4°C / 65%rH","color":[0,255,0]}
    2023-09-09 15:50:00.017  - info: javascript.0 (569283) script.js.Telegram.NINA: Nina Meldung :
    2023-09-09 15:50:36.204  - info: worx.0 (570996) Refresh token for MQTT-Connection
    2023-09-09 15:50:36.206  - info: worx.0 (570996) Disconnected
    2023-09-09 15:50:36.564  - info: worx.0 (570996) MQTT connected to: iot.eu-west-1.worxlandroid.com
    2023-09-09 15:51:27.321  - info: javascript.0 (569283) script.js.Geräte.Shaun2: Klingenarbeitszeit wurde aktualisiert:  75781
    2023-09-09 15:51:27.350  - info: javascript.0 (569283) script.js.Geräte.Shaun2: Temperatur Akku hat sich geändert: 32.2
    2023-09-09 15:51:27.464  - info: javascript.0 (569283) script.js.Geräte.Shaun2: Wifi Qualität wurde geändert: -65
    2023-09-09 15:51:52.708  - info: javascript.0 (569283) script.js.AWTRIX_LED.AWTRIX_Controller: Gelb:10 Grün:13 Schwarz:26
    2023-09-09 15:51:52.709  - info: javascript.0 (569283) script.js.AWTRIX_LED.AWTRIX_Controller: {"name":"TempHumIndoor","force":false,"icon":924,"moveIcon":false,"repeat":2,"text":"25.2°C / 58%rH","color":[0,255,0]}
    2023-09-09 15:51:52.709  - info: javascript.0 (569283) script.js.AWTRIX_LED.AWTRIX_Controller: {"name":"TempHumOutdoor","force":false,"icon":912,"moveIcon":false,"repeat":2,"text":"33.4°C / 65%rH","color":[0,255,0]}
    2023-09-09 15:53:52.708  - info: javascript.0 (569283) script.js.AWTRIX_LED.AWTRIX_Controller: Gelb:10 Grün:13 Schwarz:26
    2023-09-09 15:53:52.709  - info: javascript.0 (569283) script.js.AWTRIX_LED.AWTRIX_Controller: {"name":"TempHumIndoor","force":false,"icon":924,"moveIcon":false,"repeat":2,"text":"25.2°C / 58%rH","color":[0,255,0]}
    2023-09-09 15:53:52.709  - info: javascript.0 (569283) script.js.AWTRIX_LED.AWTRIX_Controller: {"name":"TempHumOutdoor","force":false,"icon":912,"moveIcon":false,"repeat":2,"text":"33.4°C / 65%rH","color":[0,255,0]}
    2023-09-09 15:53:55.224  - info: javascript.0 (569283) script.js.Geräte.Shaun2: Klingenarbeitszeit wurde aktualisiert:  75781
    2023-09-09 15:53:55.257  - info: javascript.0 (569283) script.js.Geräte.Shaun2: Temperatur Akku hat sich geändert: 32.2
    2023-09-09 15:53:55.274  - info: javascript.0 (569283) script.js.Geräte.Shaun2: Wifi Qualität wurde geändert: -65
    2023-09-09 15:55:00.027  - info: javascript.0 (569283) script.js.Telegram.NINA: Nina Meldung :
    2023-09-09 15:55:52.709  - info: javascript.0 (569283) script.js.AWTRIX_LED.AWTRIX_Controller: Gelb:10 Grün:13 Schwarz:26
    2023-09-09 15:55:52.710  - info: javascript.0 (569283) script.js.AWTRIX_LED.AWTRIX_Controller: {"name":"TempHumIndoor","force":false,"icon":924,"moveIcon":false,"repeat":2,"text":"25.3°C / 58%rH","color":[0,255,0]}
    2023-09-09 15:55:52.711  - info: javascript.0 (569283) script.js.AWTRIX_LED.AWTRIX_Controller: {"name":"TempHumOutdoor","force":false,"icon":912,"moveIcon":false,"repeat":2,"text":"33.4°C / 65%rH","color":[0,255,0]}
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 12 (bookworm)
    Kernel:                 6.1.0-11-amd64
    Installation:           microsoft
    Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            6.2G        5.5G        234M        4.0M        716M        669M
    Swap:           1.0G        285M        736M
    Total:          7.2G        5.8G        970M
    Active iob-Instances:   45
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                25938
    States:                 22150
    Size of iob-Database:
    56M     /opt/iobroker/iobroker-data/states.jsonl
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    @robocop
    pawns-cli
    Das kam mir doch noch bekannt vor .....
    WICHTIG siehe hier :
    https://forum.iobroker.net/topic/66381/gelöst-seltsames-script-unter-global
    • GlasfaserG Glasfaser
      @robocop sagte in VIS.0 startet immer neu, normal?:
      MEMORY
      total used free shared buff/cache available
      Da laufen aber viele Prozesse von !!
      Make Money with Your Raspberry Pi:
      RoboCopR Offline
      RoboCopR Offline
      RoboCop
      @glasfaser said in [VIS.0 startet immer neu, normal?]
      kann ich dir nicht sagen was das ist.... habe es mit Sicherheit nicht aktiviert ... wenns was böses ist ... wie bekomme ich es weg?
      • GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        siehe meinen Link zum anderen Thread !
          denjo
          schrieb am zuletzt editiert von denjo
          Ich habe seit Monaten das gleiche Problem. Ich hatte vis2 damals installiert und seit dem hat vis eine Ampel. Gibt es eine Lösung dazu? habe versucht das hier zu verstehen.
          HomoranH GlasfaserG 2 Antworten Letzte Antwort
          • D denjo
            @denjo sagte in VIS.0 startet immer neu, normal?:
            auch einen cryptominer eingefangen?
            oder welches ""gleiche" Problem?
              denjo
              @homoran ich habe auch die ampel die immer von grün auf rot springt und deaktivieren kann ich vis auch nicht.
              • D denjo
                @denjo steht im Alpha-Tester Thread nichts dazu?
                • D denjo
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  Kann ich mir nicht vorstellen !?
                  und warum schreibst du hier nicht weiter
                  https://forum.iobroker.net/topic/61448/vis-probleme
                    denjo
                    weil mir da ja keiner mehr auf mein problem geantwortet hatte und ich das hier jetzt zufällig gelesen hatte.
                    • D denjo
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      @denjo
                      Deine Anfrage hier im Thread verwirrt nur .
                      dann hätte ich auch geschrieben bzw. deinen Thread dazu verlinkt .
                      Die Lösungen in anderen Threads ist ... Backup vor VIS2 installation wiederherstellen .
                        @denjo
                        denjo
                        @glasfaser und wenn ich kein Backup mehr habe?
                        • D denjo
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          @denjo sagte in VIS.0 startet immer neu, normal?:u
                          Sorry , aber was soll ich dazu noch antworten .
                          Wenn man schon so wie du eine Alpha Version ( 28.12.2022 ) zuvor testet , sollte man schon ein Backup gemacht haben .
                            denjo
                            @glasfaser das weiß ich jetzt auch, habe gehofft man könnte es wieder gerade biegen irgendwie. Schade
                            • D denjo
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              irgendwie. Schade
                              Kopf hoch !
                              Vorschlag :
                              Der Alpha Thread ist schon geschlossen aber du kannst im Thread BETA
                              https://forum.iobroker.net/topic/67676/vis-2-0-neuer-adapter-als-beta
                              deine Anfrage stellen inkl. Verlinkung zu deinem Thread , vielleicht hat jemand in diesem Beta Thread eine bessere Lösung dazu !
