  4. ESPHome json per mqtt senden
    5.3k
9 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • J Offline
    Jacke
    Hallo zusammen ich versuche von meinem Growatt modstick auf dem ESPHome läuft werte direkt an mein VenusOS zu senden.
    so sieht meine config aus ```
    substitutions:
    devicename: "esphome-growatt-01"
    upper_devicename: "ESPHome Growatt 01"
    esphome:
    platform: ESP8266
    board: esp07s
    Enable logging
    logger:
    baud_rate: 0
    Enable Home Assistant API
    #api:
    password: "01234"
    mqtt:
    broker: 192.168.1.12
    port: 1884
    username: Nils
    password: !secret mqtt_password
    ota:
    password: "01234"
    wifi:
    ssid: !secret wifi_ssid
    password: !secret wifi_password
    Enable fallback hotspot (captive portal) in case wifi connection fails
    ap:
    ssid: "GGrowatt"
    password: "oLjULFvNXq1l"
    Enable Web server
    web_server:
    port: 80
    captive_portal:
    #time:
    - platform: homeassistant
    output:
    Blue Led
    - id: light_bl
      platform: gpio
      pin: 16
    Green Led
    - id: light_gr
      platform: gpio
      pin: 0
    Red Led
    - id: light_rd
      platform: gpio
      pin: 2
    uart:
    tx_pin: 1
    rx_pin: 3
    baud_rate: 115200
    modbus:
    uart_id: mod_bus
    modbus_controller:
    - id: growatt
    the Modbus device addr
      address: 0x1
      modbus_id: modbus1
      update_interval: 10s
      setup_priority: -10
    sensor:
    - platform: modbus_controller
    address: 5
    register_type: "read"
    unit_of_measurement: W
    device_class: power
    icon: mdi:flash
    value_type: U_DWORD
    accuracy_decimals: 1
    filters:
    - multiply: 0.1
      name: "${devicename} DcVoltage"
      address: 3
      unit_of_measurement: V
      device_class: voltage
      icon: mdi:flash
      value_type: U_WORD
      filters:
      - multiply: 0.1
      name: "${devicename} DcInputCurrent"
      address: 4
      unit_of_measurement: A
      device_class: current
      icon: mdi:flash
      value_type: U_WORD
      filters:
      - multiply: 0.1
      name: "${devicename} AcFrequency"
      address: 37
      unit_of_measurement: Hz
      icon: mdi:flash
      value_type: U_WORD
      filters:
      - multiply: 0.01
      name: "${devicename} AcVoltage"
      address: 38
      icon: mdi:flash
      value_type: U_WORD
      filters:
      - multiply: 0.1
      name: "${devicename} AcOutputCurrent"
      address: 39
      icon: mdi:flash
      value_type: U_WORD
      filters:
      - multiply: 0.1
      address: 40
      device_class: power
      icon: mdi:flash
      value_type: U_DWORD
      filters:
      - multiply: 0.1
      on_value:
        then:
        - mqtt.publish_json:
            topic: "Growatt/mic2000/meters"
            payload: |
                "pv": {
                  "power": id(pv_power).state,
                  "voltage": id(pv_voltage).state,
                  "current": id(pv_current).state,
                  "energy_forward": id(pv_energy_forward).state,
                  "L1": {
      name: "${devicename} EnergyToday"
      address: 53
      unit_of_measurement: kWh
      device_class: energy
      icon: mdi:flash
      value_type: U_DWORD
      filters:
      - multiply: 0.1
      name: "${devicename} EnergyTotal"
      address: 55
      state_class: total_increasing
      icon: mdi:flash
      value_type: U_DWORD
      accuracy_decimals: 2
      filters:
      - multiply: 0.1
      name: "${devicename} Temperature"
      address: 93
      unit_of_measurement: C
      device_class: temperature
      icon: mdi:thermometer
      value_type: U_WORD
      filters:
      - multiply: 0.1
    - platform: mqtt_subscribe
      topic: the/topic
      on_value:
        then:
          - lambda: |-
              esphome::modbus_controller::ModbusController *controller = id(growatt);
              uint16_t reg = 3; // Register: Max output active power (in %)
              float value = id(mqtttest).state;
              uint16_t register_value = static_cast<uint16_t>(value);
              modbus_controller::ModbusCommandItem setOutputPower_command = modbus_controller::ModbusCommandItem::create_write_single_command(controller, reg, register_value);
              controller->queue_command(setOutputPower_command);
    #- platform: mqtt_subscribe
    #  name: "mqtttest"
    #  id: mqtttest
    #  topic: the/topic
    #  on_value:
    #    lambda: |-
    #      id(poweroutput).state;
    #neu test power factor 02/2023
    number:
    name: "${devicename} Max Output Active Power"
    address: 3
    value_type: U_WORD
    min_value: 0
    max_value: 100
    entity_category: config
    step: 1
    ich habe folgenden abschnitt hinzugefügt
    on_value:
    then:
    payload: |
    "pv": {
    "L1": {
    Vorweg vorher lief es über Node Red ohne Probleme
    Die payload soll folgendermaßen aussehen
    msg.payload = {
    "pv": {
    "power": msg.payload["P"],
    "voltage": msg.payload["V"],
    "current": msg.payload["I"],
    "energy_forward": msg.payload["W"],
    "L1": {
    return msg;
    Evtl hat jemand einen tip
    • mickymM Offline
      mickymM Offline
      mickym
      Warum machst Du es dann nicht weiter über NodeRed?
      J 1 Antwort Letzte Antwort
      • mickymM mickym
        Jacke
        @mickym Node red läuft auf einem zusätzlichen gerät. warum die Daten per Mqtt an den IoBroker senden dort in Node red dann wieder per Mqtt an das VenusOS senden.
        Ich habe nur leider wenig ahnung von ESPHome und yaml. Es ist merh ein Trial & Error.
        • J Jacke
          mickymM Offline
          mickymM Offline
          mickym
          @jacke Du sendest nicht. Das VenusOS ist ein mqtt-Broker und kann beliebig viele mqtt-Clients bedienen. Du kannst Dir ja dann NodeRed auf dem zusätzlichen Gerät sparen, wenn Du NodeRed als Logikmaschine im iobroker verwendest.
          • mickymM mickym
            Jacke
            schrieb am zuletzt editiert von Jacke
            @mickym ich schicke es ja nicht am das Venus sondern am einem zusätzlichen Treiber auf dem VenusOS dieser subscribed ein topic von einem Broker uns sendet die Daten an das dbus system.
            Ich bin noch ziemlich unerfahren in node red aber ist der Venus Treiber dann nicht Client?
            Mir fällt gerade auf das ich im esp Home den iobroker als Broker angebe also benötige ich ihn doch noch. Besser wäre ohne.
            Ich habe den esp Code hinbekommen das richtige Stichwort was mir geholfen hat war adruino json library.
            So sieht der richtige code aus
                  on_value:
                    then:
                          payload: |-
                              root["pv"]["power"] = id(pv_power).state;
                              root["pv"]["voltage"] = id(pv_voltage).state;
                              root["pv"]["current"] = id(pv_current).state;
                              root["pv"]["energy_forward"] = id(pv_energy_forward).state;
                              root["pv"]["L1"]["power"] = id(pv_power).state;
                              root["pv"]["L1"]["voltage"] = id(pv_voltage).state;
                              root["pv"]["L1"]["current"] = id(pv_current).state;
                              root["pv"]["L1"]["energy_forward"] = id(pv_energy_forward).state;
            • J Jacke
                    on_value:
                      then:
                            payload: |-
              mickymM Offline
              mickymM Offline
              mickym
              @jacke Für das ESP Home brauchst Du einen mqtt-Broker. Ich hätte Dir aber eher einen externen Broker, wie mosquitto empfohlen. Aber kannst Du immer noch machen,
              • mickymM mickym
                Jacke
                @mickym ich hätte es halt gerne komplett ohne zusätzliche Hardware. Also nur den Growatt stick mit ESHome und das Vensu OS ich weiß nicht ob ich den MQTT vom VenusOS benutzen kann?
                Aber das gehört bestimmt ins Victron forum?
                • J Jacke
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @jacke Ja ich kann Dir da nicht helfen. Aber ich glaube auch nicht dass Du das VenusOS als normalen Mqtt-Broker nutzen kannst.
                  • J Jacke
                    substitutions:
                    esphome:
                    platform: ESP8266
                    board: esp07s
                    Enable logging
                    logger:
                    baud_rate: 0
                    #api:
                    password: "01234"
                    mqtt:
                    port: 1884
                    username: Nils
                    ota:
                    password: "01234"
                    wifi:
                    ap:
                    ssid: "GGrowatt"
                    Enable Web server
                    web_server:
                    port: 80
                    captive_portal:
                    #time:
                    output:
                    Blue Led
                    - id: light_bl
                      platform: gpio
                      pin: 16
                    Green Led
                    - id: light_gr
                      platform: gpio
                      pin: 0
                    Red Led
                    - id: light_rd
                      platform: gpio
                      pin: 2
                    uart:
                    tx_pin: 1
                    rx_pin: 3
                    baud_rate: 115200
                    modbus:
                    uart_id: mod_bus
                    modbus_controller:
                    - id: growatt
                      address: 0x1
                      modbus_id: modbus1
                      setup_priority: -10
                    sensor:
                    address: 5
                    device_class: power
                    icon: mdi:flash
                    value_type: U_DWORD
                    filters:
                    - multiply: 0.1
                      address: 3
                      icon: mdi:flash
                      value_type: U_WORD
                      filters:
                      - multiply: 0.1
                      address: 4
                      icon: mdi:flash
                      value_type: U_WORD
                      filters:
                      - multiply: 0.1
                      address: 37
                      icon: mdi:flash
                      value_type: U_WORD
                      filters:
                      - multiply: 0.01
                      address: 38
                      icon: mdi:flash
                      value_type: U_WORD
                      filters:
                      - multiply: 0.1
                      address: 39
                      icon: mdi:flash
                      value_type: U_WORD
                      filters:
                      - multiply: 0.1
                      address: 40
                      device_class: power
                      icon: mdi:flash
                      value_type: U_DWORD
                      filters:
                      - multiply: 0.1
                      on_value:
                        then:
                            payload: |
                                "pv": {
                                  "L1": {
                      address: 53
                      icon: mdi:flash
                      value_type: U_DWORD
                      filters:
                      - multiply: 0.1
                      address: 55
                      icon: mdi:flash
                      value_type: U_DWORD
                      filters:
                      - multiply: 0.1
                      address: 93
                      value_type: U_WORD
                      filters:
                      - multiply: 0.1
                      topic: the/topic
                      on_value:
                        then:
                          - lambda: |-
                    #  name: "mqtttest"
                    #  id: mqtttest
                    #  topic: the/topic
                    #  on_value:
                    #    lambda: |-
                    number:
                    address: 3
                    value_type: U_WORD
                    min_value: 0
                    max_value: 100
                    step: 1
                    on_value:
                    then:
                    payload: |
                    "pv": {
                    "L1": {
                    msg.payload = {
                    "pv": {
                    "L1": {
                    return msg;
                    succo_J
                    @jacke
                    Ich vermute mal, du willst die Daten im Victron-System abbilden.
                    Dann müssen die noch auch dem Venus-OS von MQTT auf dbus umgeschrieben werden.
                    Hier habe ich zB. etwas dazu gefunden: https://github.com/Louisvdw/dbus-serialbattery/discussions/258#discussioncomment-5482398
                    Ansonsten, ja - auf dem Venus-OS läuft ein vollständiger MQTT-Broker. Noch ist es mosquitto, bald soll es FlashMQ werden.
