  3. Off Topic
  4. Sophos UDP-Port öffnen
    1.0k
    6.1k
8 Beiträge 2 Kommentatoren 412 Aufrufe 2 Beobachtet
  • David G.D Online
    David G.D Online
    David G.
    ich habe mir Wireguard auf einem Debian System installiert.
    Leider bekomme ich den Port erreichbar.
    Das NAT in der Sophos sieht wie folgt aus:
    Am Host selber sieht es auch so aus, als ob die Ports offen sind.
    wireguard@wireguard:~$ ss -tulw
    Netid       State        Recv-Q        Send-Q               Local Address:Port                 Peer Address:Port       Process
    udp         UNCONN       0             0                          0.0.0.0:bootpc                    0.0.0.0:*
    udp         UNCONN       0             0                          0.0.0.0:60017                     0.0.0.0:*
    udp         UNCONN       0             0                             [::]:60017                        [::]:*
    tcp         LISTEN       0             128                        0.0.0.0:ssh                       0.0.0.0:*
    tcp         LISTEN       0             128                           [::]:ssh                          [::]:*
    wireguard@wireguard:~$ sudo ufw status
    Status: active
    To                         Action      From
    OpenSSH                    ALLOW       Anywhere
    60017/udp                  ALLOW       Anywhere
    OpenSSH (v6)               ALLOW       Anywhere (v6)
    60017/udp (v6)             ALLOW       Anywhere (v6)
    Anywhere on ens192         ALLOW FWD   Anywhere on wg0
    Anywhere (v6) on ens192    ALLOW FWD   Anywhere (v6) on wg0
    wireguard@wireguard:~$ sudo systemctl status wg-quick@wg0.service
    ● wg-quick@wg0.service - WireGuard via wg-quick(8) for wg0
         Loaded: loaded (/lib/systemd/system/wg-quick@.service; enabled; vendor preset: enabled)
         Active: active (exited) since Mon 2023-08-28 15:36:24 CEST; 26min ago
           Docs: man:wg-quick(8)
                 man:wg(8)
                 https://www.wireguard.com/
                 https://www.wireguard.com/quickstart/
                 https://git.zx2c4.com/wireguard-tools/about/src/man/wg-quick.8
                 https://git.zx2c4.com/wireguard-tools/about/src/man/wg.8
       Main PID: 539 (code=exited, status=0/SUCCESS)
          Tasks: 0 (limit: 7072)
         Memory: 0B
            CPU: 0
         CGroup: /system.slice/system-wg\x2dquick.slice/wg-quick@wg0.service
    Aug 28 15:36:24 wireguard wg-quick[539]: [#] ip -4 address add 10.66.66.1/24 dev wg0
    Aug 28 15:36:24 wireguard wg-quick[539]: [#] ip -6 address add fd42:42:42::1/64 dev wg0
    Aug 28 15:36:24 wireguard wg-quick[539]: [#] ip link set mtu 1420 up dev wg0
    Aug 28 15:36:24 wireguard wg-quick[539]: [#] iptables -I INPUT -p udp --dport 60017 -j ACCEPT
    Aug 28 15:36:24 wireguard wg-quick[539]: [#] iptables -I FORWARD -i ens192 -o wg0 -j ACCEPT
    Aug 28 15:36:24 wireguard wg-quick[539]: [#] iptables -I FORWARD -i wg0 -j ACCEPT
    Aug 28 15:36:24 wireguard wg-quick[539]: [#] iptables -t nat -A POSTROUTING -o ens192 -j MASQUERADE
    Aug 28 15:36:24 wireguard wg-quick[539]: [#] ip6tables -I FORWARD -i wg0 -j ACCEPT
    Aug 28 15:36:24 wireguard wg-quick[539]: [#] ip6tables -t nat -A POSTROUTING -o ens192 -j MASQUERADE
    Aug 28 15:36:24 wireguard systemd[1]: Finished WireGuard via wg-quick(8) for wg0.
    Kann ich das von extern Irgendwie prüfen, ob der UDP Port am Server wirklich offen ist?
    Da ist es denke erstmal leichter Fehler zu suchen als an der Sophos, da kenne ich mich kaum aus.
    ? 1 Antwort Letzte Antwort
    • David G.D David G.
      Status: active
      To                         Action      From
                   man:wg(8)
           Memory: 0B
              CPU: 0
      @david-g
      ja, kannst du, mit nmap -uS IP zum Beispiel...
      Hier die genaue Anleitung von Nmap .. Link Text
        @david-g
        David G.D Online
        David G.D Online
        David G.
        @ilovegym
        Gerade getestet.
        Wenn ich auf dem Server selber ausführe klappt es (vermutlich löst er die externe IP nach der internen auf)
        sudo nmap -sU -v -p 60017 xxxxxxxx
        Starting Nmap 7.80 ( https://nmap.org ) at 2023-08-28 16:43 CEST
        Initiating Ping Scan at 16:43
        Scanning 87.140.22.207 [4 ports]
        Completed Ping Scan at 16:43, 0.02s elapsed (1 total hosts)
        Initiating Parallel DNS resolution of 1 host. at 16:43
        Completed Parallel DNS resolution of 1 host. at 16:43, 0.04s elapsed
        Initiating UDP Scan at 16:43
        Scanning p578c16cf.dip0.t-ipconnect.de (xxxxxx) [1 port]
        Completed UDP Scan at 16:43, 0.22s elapsed (1 total ports)
        Nmap scan report for p578c16cf.dip0.t-ipconnect.de (xxxxxx)
        Host is up (0.0042s latency).
        PORT      STATE         SERVICE
        60017/udp open|filtered unknown
        Read data files from: /usr/bin/../share/nmap
        Nmap done: 1 IP address (1 host up) scanned in 0.38 seconds
                   Raw packets sent: 6 (208B) | Rcvd: 1 (28B)
        Wenn ich mich per VPN nach woanders verbinde und es von der entfernten Maschine versuche ist der Port geschlossen.
        Starting Nmap 7.80 ( https://nmap.org ) at 2023-08-28 16:47 CEST
        Initiating Ping Scan at 16:47
        Completed Ping Scan at 16:47, 0.06s elapsed (1 total hosts)
        Initiating Parallel DNS resolution of 1 host. at 16:47
        Completed Parallel DNS resolution of 1 host. at 16:47, 0.06s elapsed
        Initiating UDP Scan at 16:47
        Completed UDP Scan at 16:47, 0.05s elapsed (1 total ports)
        Nmap scan report for p578c16cf.dip0.t-ipconnect.de (xxxxx)
        Host is up (0.035s latency).
        PORT      STATE  SERVICE
        60017/udp closed unknown
                   Raw packets sent: 5 (180B) | Rcvd: 2 (84B)
        xxx ist die externe IP.
          @ilovegym
          Gerade getestet.
          PORT      STATE         SERVICE
          PORT      STATE  SERVICE
          @david-g
          richtig testen kannst du es nur von Extern ueber dein vpn..
          Wenn ich mir die Iptables ansehe, stimmt das alles... ufw auch.. das liegt an der FW...
          Nur mit Sophos.. diese Seuche hab ich mir noch nicht angetan.. :-) denke aber hier liegt der Hund begraben... wenn moeglich .. mal zum kurzen Testen aus... dann gleich wieder einschalten.. wenn das so einfach geht.. ?
            @david-g
            David G.D Online
            David G.D Online
            David G.
            @ilovegym sagte in Debian Port öffnen und erreichbar machen.:
            Das denke ich auch.
            Einfach mal abstöpseln geht nicht.
            Die macht alles im LAN. Das Modem hängt da ganz dumm dran mit ganz eigener IP.
            Wireguard lauft in einer VM auf einem Server. Was doof umzusetzen.
              Das denke ich auch.
              @david-g ja hab ich mir schon gedacht.. sowas hat man ja nicht umsonst...
              Dann mal im Sophos-Forum nachfragen.. weiss nicht, wer sich hier damit auskennt.. ?
              Vielleicht noch das Thema aendern in Sophos und UDP ueber VPN... sollte treffender sein.. :-)
                David G.D Online
                David G.D Online
                David G.
                @ilovegym
                Geändert.
                Das Sophosforum ist Müll :-D
                Wollte da fragen. Wurde aber gesperrt, weil ich 2x kurz hintereinander gepostet hab weil meine Beiträge automatisch gelöscht wurden.
                Mit 2 Versuchen wie ich Bilder einbinden kann, was bei denen im Forum irgendwie nicht ordentlich klappt über den Upload ......
                  @ilovegym
                  Geändert.
                  @david-g 😇 🙈
                  viel Glück, ich bin da leider raus.. hab gar keine Berührungen mit Sophos... kenn Cisco und Unifi, etwas PFSense..
