  4. Zigbee Adapter nach Update auf 1.8.23 "rot" / node.js
    5.2k
zigbeenode.js
6 Beiträge 3 Kommentatoren 724 Aufrufe 3 Beobachtet
  • F Offline
    flitzpiepe
    ich benötige hier einmal mangels ausreichender Linux-Kenntnisse ein wenig Hilfe:
    Nachdem ich meine Adapter aktualisiert habe, bleibt der Zigbee-Adapter in der neuen Version 1.8.23 Version bei mir "rot". Node.js ist bei mir in der Version v14.21.1 installiert.
    im Log ist zu lesen:
    host.raspberrypi
    2023-08-12 15:30:40.152	info	Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.raspberrypi
    2023-08-12 15:30:40.152	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-12 15:30:40.152	error	Caught by controller[0]: }
    host.raspberrypi
    2023-08-12 15:30:40.151	error	Caught by controller[0]: ]
    host.raspberrypi
    2023-08-12 15:30:40.151	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
    host.raspberrypi
    2023-08-12 15:30:40.151	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js',
    host.raspberrypi
    2023-08-12 15:30:40.151	error	Caught by controller[0]: requireStack: [
    host.raspberrypi
    2023-08-12 15:30:40.151	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi
    2023-08-12 15:30:40.151	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19) {
    host.raspberrypi
    2023-08-12 15:30:40.150	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.raspberrypi
    2023-08-12 15:30:40.150	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.raspberrypi
    2023-08-12 15:30:40.150	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.raspberrypi
    2023-08-12 15:30:40.150	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.raspberrypi
    2023-08-12 15:30:40.150	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js:21:1)
    host.raspberrypi
    2023-08-12 15:30:40.149	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    host.raspberrypi
    2023-08-12 15:30:40.149	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.raspberrypi
    2023-08-12 15:30:40.149	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    host.raspberrypi
    2023-08-12 15:30:40.149	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
    host.raspberrypi
    2023-08-12 15:30:40.149	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
    host.raspberrypi
    2023-08-12 15:30:40.148	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js
    host.raspberrypi
    2023-08-12 15:30:40.148	error	Caught by controller[0]: Require stack:
    host.raspberrypi
    2023-08-12 15:30:40.148	error	Caught by controller[0]: Error: Cannot find module '@iobroker/types'
    host.raspberrypi
    2023-08-12 15:30:40.148	error	Caught by controller[0]: ^
    host.raspberrypi
    2023-08-12 15:30:40.148	error	Caught by controller[0]: throw err;
    host.raspberrypi
    2023-08-12 15:30:40.147	error	Caught by controller[0]: internal/modules/cjs/loader.js:905
    host.raspberrypi
    2023-08-12 15:30:38.706	info	instance system.adapter.zigbee.0 started with pid 30216
    host.raspberrypi
    2023-08-12 15:30:38.074	info	"system.adapter.zigbee.0" enabled
    Erster voreiliger Aktionismus war (nachdem ich ein Backup gezogen habe) den Zigbee-Adapter zu deinstallieren und neu zu installieren, was keinen Erfolg gebracht hat. Fehler im Log bleibt natürlich identisch.
    Erste Frage: Kann ich mich mit dieser Aktion jetzt schon gedanklich damit anfreunden, meine ganzen Geräte neu anzulernen, wenn das eigentliche Problem gelöst ist, oder sind diese Informationen weiterhin verfügbar, obwohl ich den Adapter deinstalliert habe?
    Die Google-Suche hat mich dann auf diesen Beitrag gebracht:
    Zigbee Adapter bleibt nach Update auf rot
    Anschließend habe ich versucht den Zigbee-Adapter von Github über die Katze manuell zu installieren. Hierfür ist aber meine node.js Version zu alt:
    $ iobroker url https://github.com/ioBroker/ioBroker.zigbee --host raspberrypi --debug
    install ioBroker/ioBroker.zigbee#6ab8f0ccaeff528777a17c220976bc76d55e6163
    NPM version: 6.14.17
    Installing ioBroker/ioBroker.zigbee#6ab8f0ccaeff528777a17c220976bc76d55e6163... (System call)
    npm ERR! code ENOTSUP
    npm ERR! notsup Unsupported engine for @serialport/bindings-cpp@12.0.1: wanted: {"node":">=16.0.0"} (current: {"node":"14.21.1","npm":"6.14.17"})
    npm ERR! notsup Not compatible with your version of node/npm: @serialport/bindings-cpp@12.0.1npm ERR! notsup Not compatible with your version of node/npm: @serialport/bindings-cpp@12.0.1npm ERR! notsup Required: {"node":">=16.0.0"}npm ERR! notsup Actual: {"npm":"6.14.17","node":"14.21.1"}
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-08-14T21_50_57_820Z-debug.log
    host.raspberrypi Cannot install ioBroker/ioBroker.zigbee#6ab8f0ccaeff528777a17c220976bc76d55e6163: 1
    ERROR: Process exited with code 25
    Deswegen habe ich versucht meine node.js Version unter User "pi" auf dem Raspberry zu aktualisieren:
    curl -fsSL https://deb.nodesource.com/setup_20.x | bash - &&apt-get install -y nodejs
    Hierbei dann folgendes Problem:
    ## Installing the NodeSource Node.js 20.x repo...
    ## Populating apt-get cache...
    + apt-get update
    E: Sperrdatei /var/lib/apt/lists/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
    E: Das Verzeichnis /var/lib/apt/lists/ kann nicht gesperrt werden.
    W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/pkgcache.bin - RemoveCaches (13: Keine Berechtigung)
    W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Keine Berechtigung)
    Error executing command, exiting
    Ich stehe jetzt also vor der Herausforderung wieder einen lauffähigen Zigbee-Adapter herzustellen bei dem idealerweise meine bisher angelernten Geräte wieder verfügbar sind.
    Wie stelle ich das am Besten an?
    Und generell würde mich interessieren, was beim ursprünglichen Update des Zigbee-Adapters auf die Version 1.8.23 falsch gelaufen ist, dass ich mich in diese Situation manövriert habe? Hätte vor dem Update nicht erkannt werden müssen, dass meine node.js Version zu alt ist und der Update-Prozess erst gar nicht gestartet werden dürfen?
    Danke im Voraus und Grüße...
    • F flitzpiepe
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      + apt-get update
      @flitzpiepe sagte in Zigbee Adapter nach Update auf 1.8.23 "rot" / node.js:
      Zu alt. Installier da nodejs@18. Und NICHT nodejs@20.
      Siehe meine Signatur.
      Oder versuch es mit der Beta-Version von hier:
      curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
      chmod 744 iob_diag
      ./iob_diag
      F 1 Antwort Letzte Antwort
        chmod 744 iob_diag
        ./iob_diag
        flitzpiepe
        danke für die prompte Hilfe.
        Ich habe die Version wie im Link beschrieben erfolgreich installiert:
        pi@raspberrypi:/opt/iobroker $ node -v
        v18.17.1
        Anschließend den Zigbee-Adapter von Github über die Katze ebenfalls erfolgreich installiert.
        Allerdings wird er mir in "Instanzen", bzw. im Menu links nicht angezeigt, obwohl er als erfolgreich installiert angezeigt wird:
        Was muss hier noch getan werden und werde ich meine bisherigen Zigbee-Geräte noch haben, ohne diese neu anlernen zu müssen?
        Grüße...
        • F flitzpiepe
          v18.17.1
          Grüße...
          arteckA Offline
          arteckA Offline
          arteck
          @flitzpiepe die instan ist nicht da..
          dann links auf + klicken
          aber da wird alles weg sein.. hoffe du hast eine Sicherung
          • arteckA arteck
            flitzpiepe
            @arteck
            Es war gestern wohl zu spät.. hab den Wald vor lauter Bäumen mit dem "+" nicht gesehen :-)
            Also: Adapter läuft und noch fast besser: Meine Geräte sind noch da!
            Wo/Wie ist die Information der vorhandenen Geräte eigentlich gespeichert, dass sie auch nach Deinstallation des Adapters noch vorhanden ist? Sicherung wäre aber auch vorhanden gewesen ;-)
            Grüße....
            • F flitzpiepe
              @arteck
              Grüße....
              In Teilen im Stick.
