  4. ioBroker funktioniert nicht mehr
34 Beiträge 6 Kommentatoren 3.2k Aufrufe 4 Beobachtet
  • R rsw2004
    Hat nicht lange gehalten 😕
    Dieses mal wurden wohl die Instanzen nur deaktiviert/gestoppt.
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     18:17:48 up 19:23,  0 users,  load average: 0.00, 0.00, 0.00
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=52.5'C
    volt=0.9160V
    *** Time and Time Zones ***
                   Local time: Wed 2023-08-09 18:17:48 CEST
               Universal time: Wed 2023-08-09 16:17:48 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    robin
    /home/robin
    robin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        255M        3.1G        1.0M        419M        3.5G
    Swap:            99M          0B         99M
    Total:          3.9G        255M        3.2G
             3794 M total memory
              255 M used memory
              382 M active memory
              192 M inactive memory
             3118 M free memory
               40 M buffer memory
              379 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4       15G  3.3G   11G  24% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /devtmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  1.1M  758M   1% /runtmpfs          tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Tue Aug  8 22:54:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Aug  8 22:54:47 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Aug  8 22:54:47 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Aug  8 22:54:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600`-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    558M    /var/
    180M    /var/cache
    174M    /var/cache/apt
    147M    /var/lib
    131M    /var/log
    Archived and active journals take up 128.0M in the file system.
    /opt/iobroker/backups:
    8.0M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    181M    /opt/iobroker/iobroker-data/
    122M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    sort: 20M       /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
    7.7M    /opt/iobroker/iobroker-data/states.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
    write failed: 'standard output': Broken pipe
    sort: write error
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.0
    /usr/bin/node           v18.17.0
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.0-deb-1nodesource1
      Candidate: 18.17.0-deb-1nodesource1
      Version table:
     *** 18.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi4                             - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : raspberrypi4                             - disabled
      system.adapter.geofency.0               : geofency              : raspberrypi4                             - disabled, port: 7999, bind: 0.0.0.0
      system.adapter.info.0                   : info                  : raspberrypi4                             - disabled
      system.adapter.iot.0                    : iot                   : raspberrypi4                             - disabled
      system.adapter.javascript.0             : javascript            : raspberrypi4                             - disabled
      system.adapter.openknx.0                : openknx               : raspberrypi4                             - disabled
      system.adapter.solax.0                  : solax                 : raspberrypi4                             - disabled
      system.adapter.web.0                    : web                   : raspberrypi4                             - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : raspberrypi4                             - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "openknx"      : 0.5.3    , installed 0.5.3
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "solax"        : 0.7.5    , installed 0.7.5
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Objects and States
    Objects:        905
    States:         702
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12989      504/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12959      504/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14039      539/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14444      539/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12955      678/dhcpcd
    udp        0      0 0.0.0.0:37781           0.0.0.0:*                           108        13939      372/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13937      372/avahi-daemon: r
    udp6       0      0 :::55672                :::*                                108        13940      372/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        13938      372/avahi-daemon: r
    2023-08-09 09:07:38.505  - info: host.raspberrypi4 stopInstance system.adapter.web.0 send kill signal
    2023-08-09 09:07:38.473  - info: web.0 (1341) Got terminate signal TERMINATE_YOURSELF
    2023-08-09 09:07:38.588  - info: web.0 (1341) terminated http server on port 8082
    2023-08-09 09:07:38.589  - info: web.0 (1341) terminating
    2023-08-09 09:07:38.591  - info: web.0 (1341) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-08-09 09:07:38.768  - info: host.raspberrypi4 "system.adapter.yahka.0" disabled
    2023-08-09 09:07:38.769  - info: host.raspberrypi4 stopInstance system.adapter.yahka.0 (force=false, process=true)
    2023-08-09 09:07:38.768  - info: yahka.0 (1358) Adapter is disabled => stop
    2023-08-09 09:07:38.779  - info: yahka.0 (1358) cleaning up ...
    2023-08-09 09:07:38.780  - info: yahka.0 (1358) cleaned up ...
    2023-08-09 09:07:38.786  - info: yahka.0 (1358) Got terminate signal TERMINATE_YOURSELF
    2023-08-09 09:07:38.816  - info: host.raspberrypi4 stopInstance system.adapter.yahka.0 send kill signal
    2023-08-09 09:07:38.832  - info: yahka.0 (1358) terminating
    2023-08-09 09:07:38.833  - info: yahka.0 (1358) Terminated (NO_ERROR): Without reason
    2023-08-09 09:07:39.140  - info: host.raspberrypi4 instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-09 09:07:39.381  - info: host.raspberrypi4 instance system.adapter.yahka.0 terminated with code 0 (NO_ERROR)
    2023-08-09 09:07:42.922  - info: admin.0 (574) Adapter is disabled => stop
    2023-08-09 09:07:42.923  - info: host.raspberrypi4 "system.adapter.admin.0" disabled
    2023-08-09 09:07:42.923  - info: host.raspberrypi4 stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-08-09 09:07:42.924  - info: admin.0 (574) terminating http server on port 8081
    2023-08-09 09:07:42.935  - info: admin.0 (574) Got terminate signal TERMINATE_YOURSELF
    2023-08-09 09:07:42.942  - info: admin.0 (574) terminating
    2023-08-09 09:07:42.943  - info: admin.0 (574) Terminated (NO_ERROR): Without reason
    2023-08-09 09:07:42.968  - info: host.raspberrypi4 stopInstance system.adapter.admin.0 send kill signal
    2023-08-09 09:07:43.503  - info: host.raspberrypi4 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @rsw2004 sagte in ioBroker funktioniert nicht mehr:
    kann eigentlich auch so nicht stimmen 🤔
    Lehrling seit 1975 !!!
      Wie 0 users?
      Irgendwas stimmt da ganz und gar nicht mit dem System, würde ich sagen.
      dmesg -T
      sagt? Achtung, kann viel sein...
      rsw2004
      [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
      [    0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
      [    0.000000] random: crng init done
      [    0.000000] Detected PIPT I-cache on CPU0
      [    0.000000] CPU features: detected: Spectre-v2
      [    0.000000] CPU features: detected: Spectre-v3a
      [    0.000000] CPU features: detected: Spectre-v4
      [    0.000000] CPU features: detected: Spectre-BHB
      [    0.000000] CPU features: kernel page table isolation forced ON by KASLR
      [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
      [    0.000000] CPU features: detected: ARM erratum 1742098
      [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
      [    0.000000] alternatives: applying boot alternatives
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 996912
      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
      [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
      [    0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
      [    0.000000] efi: UEFI not found.
      [    0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [    0.000000] Zone ranges:
      [    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
      [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000fbffffff]
      [    0.000000]   Normal   empty
      [    0.000000] Movable zone start for each node
      [    0.000000] Early memory node ranges
      [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
      [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
      [    0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
      [    0.000000] On node 0, zone DMA32: 16384 pages in unavailable ranges
      [    0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
      [    0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
      [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [    0.000000] software IO TLB: area num 4.
      [    0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
      [    0.000000] Memory: 3356948K/4050944K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 169708K reserved, 524288K cma-reserved)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 39744 entries in 156 pages
      [    0.000000] ftrace: allocated 156 pages with 4 groups
      [    0.000000] trace event string verifier disabled[    0.000000] rcu: Preemptible hierarchical RCU implementation.
      [    0.000000] rcu:     RCU event tracing is enabled.
      [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
      [    0.000000]  Trampoline variant of Tasks RCU enabled.
      [    0.000000]  Rude variant of Tasks RCU enabled.
      [    0.000000]  Tracing variant of Tasks RCU enabled.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
      [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
      [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
      [    0.000000] Root IRQ handler: gic_handle_irq
      [    0.000000] GIC: Using split EOI/Deactivate mode[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
      [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [    0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
      [    0.000320] Console: colour dummy device 80x25
      [    0.000923] printk: console [tty1] enabled
      [    0.000993] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
      [    0.001034] pid_max: default: 32768 minimum: 301[    0.001177] LSM: Security Framework initializing[    0.001412] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.001500] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.002842] cgroup: Disabling memory control group subsystem
      [    0.005174] cblist_init_generic: Setting adjustable number of callback queues.
      [    0.005209] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.005410] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.005605] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.006081] rcu: Hierarchical SRCU implementation.
      [    0.006106] rcu:     Max phase no-delay instances is 1000.
      [    0.007475] EFI services will not be available.
      [    0.008119] smp: Bringing up secondary CPUs ...
      [    0.009238] Detected PIPT I-cache on CPU1
      [    0.009396] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
      [    0.010584] Detected PIPT I-cache on CPU2
      [    0.010705] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
      [    0.011862] Detected PIPT I-cache on CPU3
      [    0.011990] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
      [    0.012140] smp: Brought up 1 node, 4 CPUs
      [    0.012231] SMP: Total of 4 processors activated.
      [    0.012253] CPU features: detected: 32-bit EL0 Support
      [    0.012272] CPU features: detected: 32-bit EL1 Support
      [    0.012294] CPU features: detected: CRC32 instructions
      [    0.012441] CPU: All CPU(s) started at EL2
      [    0.012477] alternatives: applying system-wide alternatives
      [    0.014365] devtmpfs: initialized
      [    0.026516] Enabled cp15_barrier support
      [    0.026583] Enabled setend support
      [    0.026817] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      [    0.026870] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.040956] pinctrl core: initialized pinctrl subsystem
      [    0.041868] DMI not present or invalid.
      [    0.042584] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [    0.046262] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
      [    0.046585] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
      [    0.047571] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
      [    0.047683] audit: initializing netlink subsys (disabled)
      [    0.047983] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
      [    0.048646] thermal_sys: Registered thermal governor 'step_wise'
      [    0.048741] cpuidle: using governor menu
      [    0.049164] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
      [    0.049383] ASID allocator initialised with 32768 entries
      [    0.049565] Serial: AMBA PL011 UART driver
      [    0.063137] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [    0.084311] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
      [    0.088327] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
      [    0.104676] KASLR enabled
      [    0.140261] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
      [    0.146221] SCSI subsystem initialized
      [    0.146507] usbcore: registered new interface driver usbfs
      [    0.146580] usbcore: registered new interface driver hub
      [    0.146662] usbcore: registered new device driver usb
      [    0.147073] usb_phy_generic phy: supply vcc not found, using dummy regulator
      [    0.147309] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
      [    0.147691] pps_core: LinuxPPS API ver. 1 registered
      [    0.147716] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    0.147757] PTP clock support registered
      [    0.148896] vgaarb: loaded
      [    0.149710] clocksource: Switched to clocksource arch_sys_counter
      [    0.150281] VFS: Disk quotas dquot_6.6.0
      [    0.150377] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
      [    0.150578] FS-Cache: Loaded
      [    0.150752] CacheFiles: Loaded
      [    0.160200] NET: Registered PF_INET protocol family
      [    0.160964] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
      [    0.165755] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
      [    0.165933] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.165980] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
      [    0.166244] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
      [    0.167292] TCP: Hash tables configured (established 32768 bind 32768)
      [    0.167581] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
      [    0.167697] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
      [    0.168044] NET: Registered PF_UNIX/PF_LOCAL protocol family
      [    0.168924] RPC: Registered named UNIX socket transport module.
      [    0.168960] RPC: Registered udp transport module.
      [    0.168980] RPC: Registered tcp transport module.
      [    0.168999] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.169035] PCI: CLS 0 bytes, default 64
      [    0.171722] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
      [    0.172153] kvm [1]: IPA Size Limit: 44 bits
      [    0.173502] kvm [1]: vgic interrupt IRQ9
      [    0.173797] kvm [1]: Hyp mode initialized successfully
      [    1.334410] Initialise system trusted keyrings
      [    1.334915] workingset: timestamp_bits=46 max_order=20 bucket_order=0
      [    1.342628] zbud: loaded
      [    1.345546] NFS: Registering the id_resolver key type
      [    1.345613] Key type id_resolver registered
      [    1.345634] Key type id_legacy registered
      [    1.345814] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    1.345845] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      [    1.347312] Key type asymmetric registered
      [    1.347345] Asymmetric key parser 'x509' registered
      [    1.347439] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
      [    1.347734] io scheduler mq-deadline registered
      [    1.347762] io scheduler kyber registered
      [    1.349781] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)[    1.358754] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      [    1.358821] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff][    1.358930] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
      [    1.359032] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00ffffffff -> 0x0400000000
      [    1.360100] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      [    1.360134] pci_bus 0000:00: root bus resource [bus 00-ff]
      [    1.360163] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
      [    1.360254] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [    1.360534] pci 0000:00:00.0: PME# supported from D0 D3hot
      [    1.364740] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
      [    1.364941] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
      [    1.365083] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
      [    1.431804] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
      [    1.431989] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [    1.432131] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
      [    1.432629] pci 0000:01:00.0: PME# supported from D0 D3hot
      [    1.433436] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      [    1.433477] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      [    1.433535] pci 0000:00:00.0: PCI bridge to [bus 01]
      [    1.433567] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      [    1.447270] iproc-rng200 fe104000.rng: hwrng registered
      [    1.447901] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      [    1.449533] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      [    1.463027] brd: module loaded
      [    1.472079] loop: module loaded
      [    1.472972] Loading iSCSI transport class v2.0-870.
      [    1.478582] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [    1.537878] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [    1.539089] usbcore: registered new interface driver r8152
      [    1.539178] usbcore: registered new interface driver lan78xx
      [    1.539273] usbcore: registered new interface driver smsc95xx
      [    1.586796] pci 0000:00:00.0: enabling device (0000 -> 0002)
      [    1.586993] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.587037] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      [    1.587824] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
      [    1.588893] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.588928] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      [    1.588965] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      [    1.589391] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
      [    1.589428] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.589456] usb usb1: Product: xHCI Host Controller
      [    1.589478] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
      [    1.589500] usb usb1: SerialNumber: 0000:01:00.0[    1.590334] hub 1-0:1.0: USB hub found
      [    1.590421] hub 1-0:1.0: 1 port detected
      [    1.591402] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
      [    1.591439] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.591466] usb usb2: Product: xHCI Host Controller
      [    1.591489] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
      [    1.591511] usb usb2: SerialNumber: 0000:01:00.0[    1.592216] hub 2-0:1.0: USB hub found
      [    1.592340] hub 2-0:1.0: 4 ports detected
      [    1.594223] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    1.594604] dwc_otg: FIQ enabled
      [    1.594616] dwc_otg: NAK holdoff enabled
      [    1.594627] dwc_otg: FIQ split-transaction FSM enabled
      [    1.594644] Module dwc_common_port init
      [    1.595244] usbcore: registered new interface driver uas
      [    1.595367] usbcore: registered new interface driver usb-storage
      [    1.595625] mousedev: PS/2 mouse device common for all mice
      [    1.602490] sdhci: Secure Digital Host Controller Interface driver
      [    1.602530] sdhci: Copyright(c) Pierre Ossman
      [    1.603257] sdhci-pltfm: SDHCI platform and OF driver helper
      [    1.607001] ledtrig-cpu: registered to indicate activity on CPUs
      [    1.607381] hid: raw HID events driver (C) Jiri Kosina
      [    1.607617] usbcore: registered new interface driver usbhid
      [    1.607644] usbhid: USB HID core driver
      [    1.616816] NET: Registered PF_PACKET protocol family
      [    1.616991] Key type dns_resolver registered
      [    1.618462] registered taskstats version 1
      [    1.618561] Loading compiled-in X.509 certificates
      [    1.619507] Key type .fscrypt registered
      [    1.619535] Key type fscrypt-provisioning registered
      [    1.635627] uart-pl011 fe201000.serial: there is not valid maps for state default
      [    1.636409] uart-pl011 fe201000.serial: cts_event_workaround enabled
      [    1.636599] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
      [    1.646078] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [    1.646583] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [    1.647952] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [    1.647985] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [    1.679960] of_cfs_init
      [    1.680106] of_cfs_init: OK
      [    1.712931] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
      [    1.713531] Waiting for root device PARTUUID=105e3ec4-02...
      [    1.767144] mmc1: new high speed SDIO card at address 0001
      [    1.815348] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
      [    1.816450] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
      [    1.821077]  mmcblk0: p1 p2
      [    1.821735] mmcblk0: mmc0:aaaa SL16G 14.8 GiB (quirks 0x00004000)
      [    1.845752] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      [    1.850330] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [    1.850439] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    1.855942] devtmpfs: mounted
      [    1.864826] Freeing unused kernel memory: 4160K
      [    1.865049] Run /sbin/init as init process
      [    1.865071]   with arguments:
      [    1.865081]     /sbin/init
      [    1.865091]   with environment:
      [    1.865100]     HOME=/
      [    1.865110]     TERM=linux
      [    1.996424] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
      [    1.996485] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      [    1.996514] usb 1-1: Product: USB2.0 Hub
      [    1.998823] hub 1-1:1.0: USB hub found
      [    1.999163] hub 1-1:1.0: 4 ports detected
      [    2.248990] systemd[1]: System time before build time, advancing clock.
      [    2.429091] NET: Registered PF_INET6 protocol family
      [    2.431100] Segment Routing with IPv6
      [    2.431161] In-situ OAM (IOAM) with IPv6
      [    2.508178] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
      [    2.509274] systemd[1]: Detected architecture arm64.
      [    2.520793] systemd[1]: Set hostname to <raspberrypi4>.
      [    3.289012] systemd[1]: Queued start job for default target Multi-User System.
      [    3.311430] systemd[1]: Created slice system-getty.slice.
      [    3.313274] systemd[1]: Created slice system-modprobe.slice.
      [    3.314709] systemd[1]: Created slice system-systemd\x2dfsck.slice.
      [    3.315891] systemd[1]: Created slice User and Session Slice.
      [    3.316725] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
      [    3.317483] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
      [    3.318996] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
      [    3.319540] systemd[1]: Reached target Local Encrypted Volumes.
      [    3.320038] systemd[1]: Reached target Paths.
      [    3.320465] systemd[1]: Reached target Slices.
      [    3.320866] systemd[1]: Reached target Swap.
      [    3.326933] systemd[1]: Listening on Syslog Socket.
      [    3.328075] systemd[1]: Listening on fsck to fsckd communication Socket.
      [    3.328784] systemd[1]: Listening on initctl Compatibility Named Pipe.
      [    3.330439] systemd[1]: Listening on Journal Audit Socket.
      [    3.331557] systemd[1]: Listening on Journal Socket (/dev/log).
      [    3.332842] systemd[1]: Listening on Journal Socket.
      [    3.335075] systemd[1]: Listening on udev Control Socket.
      [    3.336215] systemd[1]: Listening on udev Kernel Socket.
      [    3.337489] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
      [    3.358240] systemd[1]: Mounting POSIX Message Queue File System...
      [    3.363375] systemd[1]: Mounting RPC Pipe File System...
      [    3.369344] systemd[1]: Mounting Kernel Debug File System...
      [    3.375373] systemd[1]: Mounting Kernel Trace File System...
      [    3.376420] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
      [    3.383453] systemd[1]: Starting Restore / save the current clock...
      [    3.390057] systemd[1]: Starting Set the console keyboard layout...
      [    3.396146] systemd[1]: Starting Create list of static device nodes for the current kernel...
      [    3.402500] systemd[1]: Starting Load Kernel Module configfs...
      [    3.409132] systemd[1]: Starting Load Kernel Module drm...
      [    3.415968] systemd[1]: Starting Load Kernel Module fuse...
      [    3.419780] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.[    3.428792] systemd[1]: Starting File System Check on Root Device...
      [    3.439346] systemd[1]: Starting Journal Service...
      [    3.467401] systemd[1]: Starting Load Kernel Modules...
      [    3.473558] systemd[1]: Starting Coldplug All udev Devices...
      [    3.483740] fuse: init (API version 7.37)
      [    3.494242] systemd[1]: Mounted POSIX Message Queue File System.
      [    3.495657] systemd[1]: Mounted RPC Pipe File System.
      [    3.499033] systemd[1]: Mounted Kernel Debug File System.
      [    3.500545] systemd[1]: Mounted Kernel Trace File System.
      [    3.503366] systemd[1]: Finished Restore / save the current clock.
      [    3.510380] systemd[1]: Finished Create list of static device nodes for the current kernel.
      [    3.513188] systemd[1]: modprobe@configfs.service: Succeeded.
      [    3.516525] systemd[1]: Finished Load Kernel Module configfs.
      [    3.519251] systemd[1]: modprobe@fuse.service: Succeeded.
      [    3.520982] systemd[1]: Finished Load Kernel Module fuse.
      [    3.555682] systemd[1]: Mounting FUSE Control File System...
      [    3.569009] systemd[1]: Mounting Kernel Configuration File System...
      [    3.576662] systemd[1]: Started File System Check Daemon to report status.
      [    3.594430] systemd[1]: Finished Load Kernel Modules.
      [    3.595784] systemd[1]: Mounted FUSE Control File System.
      [    3.596760] systemd[1]: Mounted Kernel Configuration File System.
      [    3.603099] systemd[1]: Starting Apply Kernel Variables...
      [    3.625556] systemd[1]: modprobe@drm.service: Succeeded.
      [    3.627838] systemd[1]: Finished Load Kernel Module drm.
      [    3.663414] systemd[1]: Finished File System Check on Root Device.
      [    3.666385] systemd[1]: Finished Apply Kernel Variables.
      [    3.694871] systemd[1]: Starting Remount Root and Kernel File Systems...
      [    3.844759] systemd[1]: Started Journal Service.[    3.847279] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      [    3.962764] systemd-journald[142]: Received client request to flush runtime journal.
      [    3.975388] systemd-journald[142]: File /var/log/journal/d3a8466ddfb64ce6bef13e128446c843/system.journal corrupted or uncleanly shut down, renaming and replacing.
      [    4.905676] mc: Linux media interface: v0.10
      [    4.914953] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.917029] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [    4.917069] [vc_sm_connected_init]: start
      [    4.926201] [vc_sm_connected_init]: installed successfully
      [    5.018774] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
      [    5.046480] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
      [    5.169627] videodev: Linux video capture interface: v2.00
      [    5.173973] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.254392] bcm2835_audio bcm2835_audio: card created with 8 channels
      [    5.448834] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.493359] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.507510] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.523435] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.588822] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.593790] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.627287] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.648568] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [    5.648649] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [    5.655271] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [    5.655333] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [    5.675489] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [    5.675550] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [    5.676946] rpivid feb10000.codec: Device registered as /dev/video19
      [    5.707838] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
      [    5.715130] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
      [    5.715224] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
      [    5.722136] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
      [    5.722197] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
      [    5.726668] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      [    5.733318] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      [    5.739418] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      [    5.740081] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      [    5.740123] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [    5.740145] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [    5.740171] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [    5.740200] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [    5.811652] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
      [    5.911546] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
      [    5.922153] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
      [    5.978814] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
      [    5.978863] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [    5.978887] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [    5.978922] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [    5.978946] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [    5.979378] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [    6.001857] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    6.060334] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    6.083789] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
      [    6.401215] brcmfmac: F1 signature read @0x18000000=0x15264345
      [    6.416568] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    6.417891] usbcore: registered new interface driver brcmfmac
      [    6.687279] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
      [    6.797633] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
      [    6.817046] Registered IR keymap rc-cec
      [    6.818226] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
      [    6.819325] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
      [    6.853345] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
      [    6.878085] Registered IR keymap rc-cec
      [    6.878363] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
      [    6.878602] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
      [    6.935958] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
      [    6.946363] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
      [    6.970239] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
      [    6.973814] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
      [    6.974407] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
      [    6.974740] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
      [    6.975200] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
      [    7.078286] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
      [    7.084554] vc4-drm gpu: [drm] Cannot find any crtc or sizes
      [    7.167676] uart-pl011 fe201000.serial: no DMA platform data
      [    7.190981] 8021q: 802.1Q VLAN Support v1.8
      [    7.316217] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
      [    8.039347] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
      [    8.048847] bcmgenet fd580000.ethernet eth0: Link is Down
      [   12.125872] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
      [   12.125916] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   13.888659] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
      [   15.390312] Bluetooth: Core ver 2.22
      [   15.390400] NET: Registered PF_BLUETOOTH protocol family
      [   15.390405] Bluetooth: HCI device and connection manager initialized
      [   15.390421] Bluetooth: HCI socket layer initialized
      [   15.390429] Bluetooth: L2CAP socket layer initialized
      [   15.390442] Bluetooth: SCO socket layer initialized
      [   15.398400] Bluetooth: HCI UART driver ver 2.3
      [   15.398423] Bluetooth: HCI UART protocol H4 registered
      [   15.398847] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [   15.400455] Bluetooth: HCI UART protocol Broadcom registered
      [   15.760872] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [   15.760892] Bluetooth: BNEP filters: protocol multicast
      [   15.760908] Bluetooth: BNEP socket layer initialized
      [   15.765360] Bluetooth: MGMT ver 1.22
      [   15.774030] NET: Registered PF_ALG protocol family
      robin@raspberrypi4:/ $
      • R rsw2004
        [    1.865100]     HOME=/
        @rsw2004
        Keine Ahnung was da schief ist.
        Aber hast du auch
        dmesg -T
        eingegeben? Eigentlich sollten dann auch Zeitstempel in der Ausgabe erscheinen.
        R 1 Antwort Letzte Antwort
          @rsw2004
          Aber hast du auch
          dmesg -T
          rsw2004
          Neuer Versuch
          [Tue Aug  8 22:54:46 2023] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
          [Tue Aug  8 22:54:46 2023] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
          [Tue Aug  8 22:54:46 2023] random: crng init done
          [Tue Aug  8 22:54:46 2023] Machine model: Raspberry Pi 4 Model B Rev 1.4
          [Tue Aug  8 22:54:46 2023] efi: UEFI not found.
          [Tue Aug  8 22:54:46 2023] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
          [Tue Aug  8 22:54:46 2023] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool[Tue Aug  8 22:54:46 2023] Zone ranges:
          [Tue Aug  8 22:54:46 2023]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
          [Tue Aug  8 22:54:46 2023]   DMA32    [mem 0x0000000040000000-0x00000000fbffffff]
          [Tue Aug  8 22:54:46 2023]   Normal   empty
          [Tue Aug  8 22:54:46 2023] Movable zone start for each node
          [Tue Aug  8 22:54:46 2023] Early memory node ranges[Tue Aug  8 22:54:46 2023]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
          [Tue Aug  8 22:54:46 2023]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
          [Tue Aug  8 22:54:46 2023] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
          [Tue Aug  8 22:54:46 2023] On node 0, zone DMA32: 19456 pages in unavailable ranges
          [Tue Aug  8 22:54:46 2023] On node 0, zone DMA32: 16384 pages in unavailable ranges
          [Tue Aug  8 22:54:46 2023] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
          [Tue Aug  8 22:54:46 2023] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
          [Tue Aug  8 22:54:46 2023] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
          [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU0
          [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-v2
          [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-v3a
          [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-v4
          [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-BHB
          [Tue Aug  8 22:54:46 2023] CPU features: kernel page table isolation forced ON by KASLR
          [Tue Aug  8 22:54:46 2023] CPU features: detected: Kernel page table isolation (KPTI)
          [Tue Aug  8 22:54:46 2023] CPU features: detected: ARM erratum 1742098
          [Tue Aug  8 22:54:46 2023] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
          [Tue Aug  8 22:54:46 2023] alternatives: applying boot alternatives
          [Tue Aug  8 22:54:46 2023] Built 1 zonelists, mobility grouping on.  Total pages: 996912
          [Tue Aug  8 22:54:46 2023] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
          [Tue Aug  8 22:54:46 2023] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
          [Tue Aug  8 22:54:46 2023] mem auto-init: stack:off, heap alloc:off, heap free:off
          [Tue Aug  8 22:54:46 2023] software IO TLB: area num 4.
          [Tue Aug  8 22:54:46 2023] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
          [Tue Aug  8 22:54:46 2023] Memory: 3356948K/4050944K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 169708K reserved, 524288K cma-reserved)
          [Tue Aug  8 22:54:46 2023] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
          [Tue Aug  8 22:54:46 2023] ftrace: allocating 39744 entries in 156 pages
          [Tue Aug  8 22:54:46 2023] ftrace: allocated 156 pages with 4 groups
          [Tue Aug  8 22:54:46 2023] trace event string verifier disabled
          [Tue Aug  8 22:54:46 2023] rcu: Preemptible hierarchical RCU implementation.
          [Tue Aug  8 22:54:46 2023] rcu:         RCU event tracing is enabled.
          [Tue Aug  8 22:54:46 2023] rcu:         RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
          [Tue Aug  8 22:54:46 2023]      Trampoline variant of Tasks RCU enabled.
          [Tue Aug  8 22:54:46 2023]      Rude variant of Tasks RCU enabled.
          [Tue Aug  8 22:54:46 2023]      Tracing variant of Tasks RCU enabled.
          [Tue Aug  8 22:54:46 2023] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
          [Tue Aug  8 22:54:46 2023] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
          [Tue Aug  8 22:54:46 2023] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
          [Tue Aug  8 22:54:46 2023] Root IRQ handler: gic_handle_irq
          [Tue Aug  8 22:54:46 2023] GIC: Using split EOI/Deactivate mode
          [Tue Aug  8 22:54:46 2023] rcu: srcu_init: Setting srcu_struct sizes based on contention.
          [Tue Aug  8 22:54:46 2023] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
          [Tue Aug  8 22:54:46 2023] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
          [Tue Aug  8 22:54:46 2023] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns[Tue Aug  8 22:54:46 2023] Console: colour dummy device 80x25
          [Tue Aug  8 22:54:46 2023] printk: console [tty1] enabled
          [Tue Aug  8 22:54:46 2023] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
          [Tue Aug  8 22:54:46 2023] pid_max: default: 32768 minimum: 301
          [Tue Aug  8 22:54:46 2023] LSM: Security Framework initializing
          [Tue Aug  8 22:54:46 2023] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
          [Tue Aug  8 22:54:46 2023] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
          [Tue Aug  8 22:54:46 2023] cgroup: Disabling memory control group subsystem
          [Tue Aug  8 22:54:46 2023] cblist_init_generic: Setting adjustable number of callback queues.
          [Tue Aug  8 22:54:46 2023] cblist_init_generic: Setting shift to 2 and lim to 1.
          [Tue Aug  8 22:54:46 2023] rcu: Hierarchical SRCU implementation.
          [Tue Aug  8 22:54:46 2023] rcu:         Max phase no-delay instances is 1000.
          [Tue Aug  8 22:54:46 2023] EFI services will not be available.
          [Tue Aug  8 22:54:46 2023] smp: Bringing up secondary CPUs ...
          [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU1
          [Tue Aug  8 22:54:46 2023] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
          [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU2
          [Tue Aug  8 22:54:46 2023] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
          [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU3
          [Tue Aug  8 22:54:46 2023] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
          [Tue Aug  8 22:54:46 2023] smp: Brought up 1 node, 4 CPUs
          [Tue Aug  8 22:54:46 2023] SMP: Total of 4 processors activated.
          [Tue Aug  8 22:54:46 2023] CPU features: detected: 32-bit EL0 Support
          [Tue Aug  8 22:54:46 2023] CPU features: detected: 32-bit EL1 Support
          [Tue Aug  8 22:54:46 2023] CPU features: detected: CRC32 instructions
          [Tue Aug  8 22:54:46 2023] CPU: All CPU(s) started at EL2
          [Tue Aug  8 22:54:46 2023] alternatives: applying system-wide alternatives
          [Tue Aug  8 22:54:46 2023] devtmpfs: initialized
          [Tue Aug  8 22:54:46 2023] Enabled cp15_barrier support
          [Tue Aug  8 22:54:46 2023] Enabled setend support
          [Tue Aug  8 22:54:46 2023] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
          [Tue Aug  8 22:54:46 2023] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
          [Tue Aug  8 22:54:46 2023] pinctrl core: initialized pinctrl subsystem
          [Tue Aug  8 22:54:46 2023] DMI not present or invalid.
          [Tue Aug  8 22:54:46 2023] NET: Registered PF_NETLINK/PF_ROUTE protocol family
          [Tue Aug  8 22:54:46 2023] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
          [Tue Aug  8 22:54:46 2023] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
          [Tue Aug  8 22:54:46 2023] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations[Tue Aug  8 22:54:46 2023] audit: initializing netlink subsys (disabled)
          [Tue Aug  8 22:54:46 2023] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
          [Tue Aug  8 22:54:46 2023] thermal_sys: Registered thermal governor 'step_wise'
          [Tue Aug  8 22:54:46 2023] cpuidle: using governor menu
          [Tue Aug  8 22:54:46 2023] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
          [Tue Aug  8 22:54:46 2023] ASID allocator initialised with 32768 entries
          [Tue Aug  8 22:54:46 2023] Serial: AMBA PL011 UART driver
          [Tue Aug  8 22:54:46 2023] bcm2835-mbox fe00b880.mailbox: mailbox enabled
          [Tue Aug  8 22:54:46 2023] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
          [Tue Aug  8 22:54:46 2023] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
          [Tue Aug  8 22:54:46 2023] KASLR enabled
          [Tue Aug  8 22:54:46 2023] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
          [Tue Aug  8 22:54:46 2023] SCSI subsystem initialized
          [Tue Aug  8 22:54:46 2023] usbcore: registered new interface driver usbfs
          [Tue Aug  8 22:54:46 2023] usbcore: registered new interface driver hub
          [Tue Aug  8 22:54:46 2023] usbcore: registered new device driver usb
          [Tue Aug  8 22:54:46 2023] usb_phy_generic phy: supply vcc not found, using dummy regulator
          [Tue Aug  8 22:54:46 2023] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
          [Tue Aug  8 22:54:46 2023] pps_core: LinuxPPS API ver. 1 registered
          [Tue Aug  8 22:54:46 2023] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
          [Tue Aug  8 22:54:46 2023] PTP clock support registered
          [Tue Aug  8 22:54:46 2023] vgaarb: loaded
          [Tue Aug  8 22:54:46 2023] clocksource: Switched to clocksource arch_sys_counter
          [Tue Aug  8 22:54:46 2023] VFS: Disk quotas dquot_6.6.0
          [Tue Aug  8 22:54:46 2023] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
          [Tue Aug  8 22:54:46 2023] FS-Cache: Loaded
          [Tue Aug  8 22:54:46 2023] CacheFiles: Loaded
          [Tue Aug  8 22:54:46 2023] NET: Registered PF_INET protocol family
          [Tue Aug  8 22:54:46 2023] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
          [Tue Aug  8 22:54:46 2023] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
          [Tue Aug  8 22:54:46 2023] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
          [Tue Aug  8 22:54:46 2023] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
          [Tue Aug  8 22:54:46 2023] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
          [Tue Aug  8 22:54:46 2023] TCP: Hash tables configured (established 32768 bind 32768)
          [Tue Aug  8 22:54:46 2023] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
          [Tue Aug  8 22:54:46 2023] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
          [Tue Aug  8 22:54:46 2023] NET: Registered PF_UNIX/PF_LOCAL protocol family
          [Tue Aug  8 22:54:46 2023] RPC: Registered named UNIX socket transport module.
          [Tue Aug  8 22:54:46 2023] RPC: Registered udp transport module.
          [Tue Aug  8 22:54:46 2023] RPC: Registered tcp transport module.
          [Tue Aug  8 22:54:46 2023] RPC: Registered tcp NFSv4.1 backchannel transport module.
          [Tue Aug  8 22:54:46 2023] PCI: CLS 0 bytes, default 64
          [Tue Aug  8 22:54:46 2023] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
          [Tue Aug  8 22:54:46 2023] kvm [1]: IPA Size Limit: 44 bits
          [Tue Aug  8 22:54:46 2023] kvm [1]: vgic interrupt IRQ9
          [Tue Aug  8 22:54:46 2023] kvm [1]: Hyp mode initialized successfully
          [Tue Aug  8 22:54:47 2023] Initialise system trusted keyrings
          [Tue Aug  8 22:54:47 2023] workingset: timestamp_bits=46 max_order=20 bucket_order=0
          [Tue Aug  8 22:54:47 2023] zbud: loaded
          [Tue Aug  8 22:54:47 2023] NFS: Registering the id_resolver key type
          [Tue Aug  8 22:54:47 2023] Key type id_resolver registered
          [Tue Aug  8 22:54:47 2023] Key type id_legacy registered
          [Tue Aug  8 22:54:47 2023] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
          [Tue Aug  8 22:54:47 2023] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
          [Tue Aug  8 22:54:47 2023] Key type asymmetric registered
          [Tue Aug  8 22:54:47 2023] Asymmetric key parser 'x509' registered
          [Tue Aug  8 22:54:47 2023] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
          [Tue Aug  8 22:54:47 2023] io scheduler mq-deadline registered
          [Tue Aug  8 22:54:47 2023] io scheduler kyber registered
          [Tue Aug  8 22:54:47 2023] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00ffffffff -> 0x0400000000
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
          [Tue Aug  8 22:54:47 2023] pci_bus 0000:00: root bus resource [bus 00-ff]
          [Tue Aug  8 22:54:47 2023] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: PME# supported from D0 D3hot
          [Tue Aug  8 22:54:47 2023] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
          [Tue Aug  8 22:54:47 2023] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
          [Tue Aug  8 22:54:47 2023] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
          [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
          [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
          [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: PME# supported from D0 D3hot
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
          [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: PCI bridge to [bus 01]
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
          [Tue Aug  8 22:54:47 2023] iproc-rng200 fe104000.rng: hwrng registered
          [Tue Aug  8 22:54:47 2023] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
          [Tue Aug  8 22:54:47 2023] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
          [Tue Aug  8 22:54:47 2023] brd: module loaded
          [Tue Aug  8 22:54:47 2023] loop: module loaded
          [Tue Aug  8 22:54:47 2023] Loading iSCSI transport class v2.0-870.
          [Tue Aug  8 22:54:47 2023] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
          [Tue Aug  8 22:54:47 2023] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver r8152
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver lan78xx
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver smsc95xx
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: enabling device (0000 -> 0002)
          [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: xHCI Host Controller
          [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
          [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
          [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
          [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
          [Tue Aug  8 22:54:47 2023] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
          [Tue Aug  8 22:54:47 2023] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Tue Aug  8 22:54:47 2023] usb usb1: Product: xHCI Host Controller
          [Tue Aug  8 22:54:47 2023] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
          [Tue Aug  8 22:54:47 2023] usb usb1: SerialNumber: 0000:01:00.0
          [Tue Aug  8 22:54:47 2023] hub 1-0:1.0: USB hub found
          [Tue Aug  8 22:54:47 2023] hub 1-0:1.0: 1 port detected
          [Tue Aug  8 22:54:47 2023] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
          [Tue Aug  8 22:54:47 2023] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Tue Aug  8 22:54:47 2023] usb usb2: Product: xHCI Host Controller
          [Tue Aug  8 22:54:47 2023] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
          [Tue Aug  8 22:54:47 2023] usb usb2: SerialNumber: 0000:01:00.0
          [Tue Aug  8 22:54:47 2023] hub 2-0:1.0: USB hub found
          [Tue Aug  8 22:54:47 2023] hub 2-0:1.0: 4 ports detected
          [Tue Aug  8 22:54:47 2023] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
          [Tue Aug  8 22:54:47 2023] dwc_otg: FIQ enabled
          [Tue Aug  8 22:54:47 2023] dwc_otg: NAK holdoff enabled
          [Tue Aug  8 22:54:47 2023] dwc_otg: FIQ split-transaction FSM enabled
          [Tue Aug  8 22:54:47 2023] Module dwc_common_port init
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver uas
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver usb-storage
          [Tue Aug  8 22:54:47 2023] mousedev: PS/2 mouse device common for all mice
          [Tue Aug  8 22:54:47 2023] sdhci: Secure Digital Host Controller Interface driver
          [Tue Aug  8 22:54:47 2023] sdhci: Copyright(c) Pierre Ossman
          [Tue Aug  8 22:54:47 2023] sdhci-pltfm: SDHCI platform and OF driver helper
          [Tue Aug  8 22:54:47 2023] ledtrig-cpu: registered to indicate activity on CPUs
          [Tue Aug  8 22:54:47 2023] hid: raw HID events driver (C) Jiri Kosina
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver usbhid
          [Tue Aug  8 22:54:47 2023] usbhid: USB HID core driver
          [Tue Aug  8 22:54:47 2023] NET: Registered PF_PACKET protocol family
          [Tue Aug  8 22:54:47 2023] Key type dns_resolver registered
          [Tue Aug  8 22:54:47 2023] registered taskstats version 1
          [Tue Aug  8 22:54:47 2023] Loading compiled-in X.509 certificates
          [Tue Aug  8 22:54:47 2023] Key type .fscrypt registered
          [Tue Aug  8 22:54:47 2023] Key type fscrypt-provisioning registered
          [Tue Aug  8 22:54:47 2023] uart-pl011 fe201000.serial: there is not valid maps for state default
          [Tue Aug  8 22:54:47 2023] uart-pl011 fe201000.serial: cts_event_workaround enabled
          [Tue Aug  8 22:54:47 2023] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
          [Tue Aug  8 22:54:47 2023] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
          [Tue Aug  8 22:54:47 2023] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
          [Tue Aug  8 22:54:47 2023] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
          [Tue Aug  8 22:54:47 2023] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
          [Tue Aug  8 22:54:47 2023] of_cfs_init
          [Tue Aug  8 22:54:47 2023] of_cfs_init: OK
          [Tue Aug  8 22:54:47 2023] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
          [Tue Aug  8 22:54:47 2023] Waiting for root device PARTUUID=105e3ec4-02...
          [Tue Aug  8 22:54:47 2023] mmc1: new high speed SDIO card at address 0001
          [Tue Aug  8 22:54:47 2023] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
          [Tue Aug  8 22:54:47 2023] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
          [Tue Aug  8 22:54:47 2023]  mmcblk0: p1 p2
          [Tue Aug  8 22:54:47 2023] mmcblk0: mmc0:aaaa SL16G 14.8 GiB (quirks 0x00004000)
          [Tue Aug  8 22:54:47 2023] usb 1-1: new high-speed USB device number 2 using xhci_hcd
          [Tue Aug  8 22:54:47 2023] devtmpfs: mounted
          [Tue Aug  8 22:54:47 2023] Freeing unused kernel memory: 4160K
          [Tue Aug  8 22:54:47 2023] Run /sbin/init as init process
          [Tue Aug  8 22:54:47 2023]   with arguments:
          [Tue Aug  8 22:54:47 2023]     /sbin/init
          [Tue Aug  8 22:54:47 2023]   with environment:
          [Tue Aug  8 22:54:47 2023]     HOME=/
          [Tue Aug  8 22:54:47 2023]     TERM=linux
          [Tue Aug  8 22:54:47 2023] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
          [Tue Aug  8 22:54:47 2023] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
          [Tue Aug  8 22:54:47 2023] usb 1-1: Product: USB2.0 Hub
          [Tue Aug  8 22:54:47 2023] hub 1-1:1.0: USB hub found
          [Tue Aug  8 22:54:47 2023] hub 1-1:1.0: 4 ports detected
          [Tue Aug  8 22:54:48 2023] systemd[1]: System time before build time, advancing clock.
          [Tue Aug  8 22:54:48 2023] NET: Registered PF_INET6 protocol family
          [Tue Aug  8 22:54:48 2023] Segment Routing with IPv6
          [Tue Aug  8 22:54:48 2023] In-situ OAM (IOAM) with IPv6
          [Tue Aug  8 22:54:48 2023] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
          [Tue Aug  8 22:54:48 2023] systemd[1]: Detected architecture arm64.
          [Tue Aug  8 22:54:48 2023] systemd[1]: Set hostname to <raspberrypi4>.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Queued start job for default target Multi-User System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice system-getty.slice.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice system-modprobe.slice.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice system-systemd\x2dfsck.slice.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice User and Session Slice.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Local Encrypted Volumes.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Paths.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Slices.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Swap.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Syslog Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on fsck to fsckd communication Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on initctl Compatibility Named Pipe.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Journal Audit Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Journal Socket (/dev/log).
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Journal Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on udev Control Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on udev Kernel Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting POSIX Message Queue File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting RPC Pipe File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting Kernel Debug File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting Kernel Trace File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Restore / save the current clock...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Set the console keyboard layout...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Create list of static device nodes for the current kernel...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Module configfs...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Module drm...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Module fuse...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting File System Check on Root Device...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Journal Service...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Modules...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Coldplug All udev Devices...
          [Tue Aug  8 22:54:49 2023] fuse: init (API version 7.37)
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted POSIX Message Queue File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted RPC Pipe File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted Kernel Debug File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted Kernel Trace File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Restore / save the current clock.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Create list of static device nodes for the current kernel.
          [Tue Aug  8 22:54:49 2023] systemd[1]: modprobe@configfs.service: Succeeded.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Module configfs.
          [Tue Aug  8 22:54:49 2023] systemd[1]: modprobe@fuse.service: Succeeded.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Module fuse.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting FUSE Control File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting Kernel Configuration File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Started File System Check Daemon to report status.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Modules.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted FUSE Control File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted Kernel Configuration File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Apply Kernel Variables...
          [Tue Aug  8 22:54:49 2023] systemd[1]: modprobe@drm.service: Succeeded.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Module drm.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished File System Check on Root Device.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Apply Kernel Variables.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Remount Root and Kernel File Systems...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Started Journal Service.
          [Tue Aug  8 22:54:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          [Tue Aug  8 22:54:49 2023] systemd-journald[142]: Received client request to flush runtime journal.
          [Tue Aug  8 22:54:49 2023] systemd-journald[142]: File /var/log/journal/d3a8466ddfb64ce6bef13e128446c843/system.journal corrupted or uncleanly shut down, renaming and replacing.
          [Tue Aug  8 22:54:50 2023] mc: Linux media interface: v0.10
          [Tue Aug  8 22:54:50 2023] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:50 2023] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
          [Tue Aug  8 22:54:50 2023] [vc_sm_connected_init]: start
          [Tue Aug  8 22:54:50 2023] [vc_sm_connected_init]: installed successfully
          [Tue Aug  8 22:54:51 2023] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
          [Tue Aug  8 22:54:51 2023] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
          [Tue Aug  8 22:54:51 2023] videodev: Linux video capture interface: v2.00
          [Tue Aug  8 22:54:51 2023] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] bcm2835_audio bcm2835_audio: card created with 8 channels
          [Tue Aug  8 22:54:51 2023] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
          [Tue Aug  8 22:54:51 2023] rpivid feb10000.codec: Device registered as /dev/video19
          [Tue Aug  8 22:54:51 2023] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
          [Tue Aug  8 22:54:52 2023] cfg80211: Loading compiled-in X.509 certificates for regulatory database
          [Tue Aug  8 22:54:52 2023] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [Tue Aug  8 22:54:52 2023] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid[Tue Aug  8 22:54:52 2023] brcmfmac: F1 signature read @0x18000000=0x15264345
          [Tue Aug  8 22:54:52 2023] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
          [Tue Aug  8 22:54:52 2023] usbcore: registered new interface driver brcmfmac
          [Tue Aug  8 22:54:52 2023] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
          [Tue Aug  8 22:54:52 2023] Registered IR keymap rc-cec
          [Tue Aug  8 22:54:52 2023] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
          [Tue Aug  8 22:54:52 2023] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
          [Tue Aug  8 22:54:52 2023] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
          [Tue Aug  8 22:54:52 2023] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Tue Aug  8 22:54:53 2023] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
          [Tue Aug  8 22:54:53 2023] vc4-drm gpu: [drm] Cannot find any crtc or sizes
          [Tue Aug  8 22:54:53 2023] uart-pl011 fe201000.serial: no DMA platform data
          [Tue Aug  8 22:54:53 2023] 8021q: 802.1Q VLAN Support v1.8
          [Tue Aug  8 22:54:53 2023] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
          [Tue Aug  8 22:54:54 2023] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
          [Tue Aug  8 22:54:54 2023] bcmgenet fd580000.ethernet eth0: Link is Down
          [Tue Aug  8 22:54:58 2023] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
          [Tue Aug  8 22:54:58 2023] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
          [Tue Aug  8 22:54:59 2023] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
          [Tue Aug  8 22:55:01 2023] Bluetooth: Core ver 2.22[Tue Aug  8 22:55:01 2023] NET: Registered PF_BLUETOOTH protocol family
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI device and connection manager initialized
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI socket layer initialized
          [Tue Aug  8 22:55:01 2023] Bluetooth: L2CAP socket layer initialized
          [Tue Aug  8 22:55:01 2023] Bluetooth: SCO socket layer initialized
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART driver ver 2.3
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART protocol H4 registered
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART protocol Three-wire (H5) registered
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART protocol Broadcom registered
          [Tue Aug  8 22:55:01 2023] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
          [Tue Aug  8 22:55:01 2023] Bluetooth: BNEP filters: protocol multicast
          [Tue Aug  8 22:55:01 2023] Bluetooth: BNEP socket layer initialized
          [Tue Aug  8 22:55:01 2023] Bluetooth: MGMT ver 1.22[Tue Aug  8 22:55:01 2023] NET: Registered PF_ALG protocol family
          • R rsw2004
            Neuer Versuch
            [Tue Aug  8 22:54:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Tue Aug  8 22:54:47 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Tue Aug  8 22:54:47 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            rsw2004
            @Thomas-Braun
            Was wäre denn in dem Fall wahrscheinlicher? Defekte Speicherkarte oder gar ein defekt am Raspberry?
            Thomas BraunT Ro75R 2 Antworten Letzte Antwort
            • R rsw2004
              @Thomas-Braun
              @rsw2004
              Keine Ahnung.
              • R rsw2004
                @Thomas-Braun
                Ro75R Offline
                Ro75R Offline
                Ro75
                @rsw2004 sagte in ioBroker funktioniert nicht mehr:
                Ich habe hier einige Raspberry's am Laufen. SD-Karten sind mir schon einige abgeflogen. Die "preiswerteste" Variante wäre wohl testweise es mal mit einer frischen zu versuchen - so würde ich herangehen.
                Ro75.
                mcm1957M R 2 Antworten Letzte Antwort
                • Ro75R Ro75
                  Ro75.
                  mcm1957M Offline
                  mcm1957M Offline
                  mcm1957
                  Wenn du nicht nur was zum Spielen brauchst solltest du eine SSD an den Raspi anschließen.
                  SD ist immer problematisch
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  Ro75R R 2 Antworten Letzte Antwort
                  • mcm1957M mcm1957
                    Ro75R Offline
                    Ro75R Offline
                    Ro75
                    @mcm57 sagte in ioBroker funktioniert nicht mehr:
                    Da stimme ich dir zu 100% zu. Nur hier ging es ja um
                    • mcm1957M mcm1957
                      rsw2004
                      @mcm57
                      Ich denke das wäre für meine Zwecke etwas dick aufgetragen. Im Endeffekt kopple ich mit ioBroker lediglich eine handvoll Funktionen aus meinem KNX-System mit HomeKit und nutze Geofencing um die Heizung runterzuregeln, wenn Bereich verlassen wird.
                      Also tatsächlich Spielerei.
                      • Ro75R Ro75
                        Ro75.
                        rsw2004
                        @ro75
                        Irgendwelche Empfehlung was Hersteller und Typ betrifft?
                        Dann werde ich mir demnächst mal eine Neue besorgen.
                        • R rsw2004
                          @ro75
                          @rsw2004
                          Ich hatte zu meiner SD-Karten-Zeit ausschließlich Samsung im Einsatz.
                          Bis auf einmal, als ich auf eine billige Intenso aus dem Supermarkt notgedrungen ausgewichen bin. Die hat dann auch nur wenige Wochen gehalten. Lesson learned...
                          • mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            @rsw2004
                            Bei ca 20,-- EUR für 240GB ?
                            Da kommt ja die SD schon fast teurer...
                            Abgesehen davon dass du natürlich ein USB Gehäuse brauchst. (Argon One M2 oder ein anderes)
                            https://geizhals.at/?cat=hdssd&xf=1035_Western+Digital
                            (Keine direkte Empfehlung, soll nur zeigen dass die ssd Preise für kleine ssds im Keller sind)
                            • mcm1957M mcm1957
                              @rsw2004
                              HomoranH Offline
                              HomoranH Offline
                              nicht nur für kleine!
                              M2 NVMe 1TB für unter 50 Euro https://www.alternate.de/listing.xhtml?q=nvme+1tb&s=price_asc
