  4. [gelöst] Zigbee stürzt beim schalten ab
5 Beiträge 2 Kommentatoren 302 Aufrufe 2 Beobachtet
  • David G.D Online
    David G.D Online
    David G.
    seit heute stürzt mein Zigbee Adapter ab, sobald ich eine Birne etc schalte.
    Hatte ich so bisher noch nicht.
    Heute vormittag habe ich dem HAM Adapter installiert, kann das zusammen hängen?
    Anbei der log beim Absturz:
    zigbee.0
    2023-07-26 21:42:56.472	info	terminating
    zigbee.0
    2023-07-26 21:42:56.032	info	Zigbee: disabling joining new devices.
    zigbee.0
    2023-07-26 21:42:55.969	info	cleaned everything up...
    zigbee.0
    2023-07-26 21:42:55.937	error	Cannot read properties of undefined (reading 'Error')
    zigbee.0
    2023-07-26 21:42:55.936	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:150:18) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:703:26
    zigbee.0
    2023-07-26 21:42:55.860	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
    zigbee.0
    2023-07-26 21:42:55.860	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2023-07-26 21:42:55.857	error	Error 225 on send command to 0x60a423fffeed446c. Error: Error: Command 0x60a423fffeed446c/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    Iob diag:
    *** BASE SYSTEM ***                                              Model           : Raspberry Pi 4 Model B Rev 1.2
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian                                         Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     21:48:02 up 20 min,  2 users,  load average: 1.35, 1.71, 1.61
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=46.2'C
    volt=0.8563V
    *** Time and Time Zones ***
                   Local time: Wed 2023-07-26 21:48:02 CEST
               Universal time: Wed 2023-07-26 19:48:02 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        2.1G        1.0G        0.0K        707M        1.6G
    Swap:            99M          0B         99M
    Total:          3.9G        2.1G        1.1G
             3793 M total memory
             2084 M used memory
             2213 M active memory
              398 M inactive memory
             1001 M free memory
               75 M buffer memory
              632 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4      229G   14G  207G   7% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  896K  758M   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Wed Jul 26 21:27:19 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:AC:7B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7faabd4d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Jul 26 21:27:21 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Jul 26 21:27:21 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Jul 26 21:27:23 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    3.6G    /var/
    3.0G    /var/log
    2.9G    /var/log/journal/bd463378997f44f088b185e90db76a13
    448M    /var/lib
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    1.7G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    824M    /opt/iobroker/iobroker-data/
    577M    /opt/iobroker/iobroker-data/files
    149M    /opt/iobroker/iobroker-data/backup-objects
    111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup
    111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup/sql.sql
    51M     /opt/iobroker/iobroker-data/states.jsonl
    47M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.715a7530.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.17.0-deb-1nodesource1
      Version table:
         18.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
     *** 18.16.0-deb-1nodesource1 100
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.7
    javascript:     7.0.3
    Adapters from github:   16
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : pi                                       -  enabled
    + system.adapter.adb.0                    : adb                   : pi                                       -  enabled
    + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.alexa2.0                 : alexa2                : pi                                       - disabled
      system.adapter.alias-manager.0          : alias-manager         : pi                                       - disabled
    + system.adapter.backitup.0               : backitup              : pi                                       -  enabled
      system.adapter.birthdays.0              : birthdays             : pi                                       -  enabled
      system.adapter.bosesoundtouch.0         : bosesoundtouch        : pi                                       - disabled
      system.adapter.bring.0                  : bring                 : pi                                       - disabled
    + system.adapter.cloud.0                  : cloud                 : pi                                       -  enabled
    + system.adapter.countdown.0              : countdown             : pi                                       -  enabled
      system.adapter.daswetter.0              : daswetter             : pi                                       -  enabled
      system.adapter.daswetter.1              : daswetter             : pi                                       -  enabled
      system.adapter.device-reminder.0        : device-reminder       : pi                                       - disabled
    + system.adapter.device-watcher.0         : device-watcher        : pi                                       -  enabled
      system.adapter.devices.0                : devices               : pi                                       - disabled
      system.adapter.discovery.0              : discovery             : pi                                       - disabled
    + system.adapter.echarts.0                : echarts               : pi                                       -  enabled
    + system.adapter.email.0                  : email                 : pi                                       -  enabled
      system.adapter.feiertage.0              : feiertage             : pi                                       -  enabled
      system.adapter.flot.0                   : flot                  : pi                                       -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : pi                                       - disabled
    + system.adapter.google-sharedlocations.0 : google-sharedlocations: pi                                       -  enabled
      system.adapter.ham.0                    : ham                   : pi                                       - disabled
    + system.adapter.hm-rega.0                : hm-rega               : pi                                       -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : pi                                       -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : pi                                       -  enabled, port: 0
    + system.adapter.hmip.0                   : hmip                  : pi                                       -  enabled
      system.adapter.ical.0                   : ical                  : pi                                       -  enabled
      system.adapter.ical.1                   : ical                  : pi                                       -  enabled
      system.adapter.iceroad.0                : iceroad               : pi                                       - disabled
    + system.adapter.imap.0                   : imap                  : pi                                       -  enabled
    + system.adapter.info.0                   : info                  : pi                                       -  enabled
    + system.adapter.iot.0                    : iot                   : pi                                       -  enabled
    + system.adapter.javascript.0             : javascript            : pi                                       -  enabled
    + system.adapter.linux-control.0          : linux-control         : pi                                       -  enabled
      system.adapter.logparser.0              : logparser             : pi                                       - disabled
    + system.adapter.lovelace.0               : lovelace              : pi                                       -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.lovelace.1               : lovelace              : pi                                       -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
      system.adapter.lovelace.2               : lovelace              : pi                                       - disabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : pi                                       -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.mytime.0                 : mytime                : pi                                       - disabled
      system.adapter.nctalk.0                 : nctalk                : pi                                       - disabled, port: 443  system.adapter.net-tools.0              : net-tools             : pi                                       - disabled
      system.adapter.nina.0                   : nina                  : pi                                       - disabled
      system.adapter.notification-manager.0   : notification-manager  : pi                                       - disabled
    + system.adapter.nut.0                    : nut                   : pi                                       -  enabled
      system.adapter.parcel.0                 : parcel                : pi                                       - disabled
      system.adapter.parcel.1                 : parcel                : pi                                       - disabled
      system.adapter.parser.0                 : parser                : pi                                       - disabled
    + system.adapter.ping.0                   : ping                  : pi                                       -  enabled
    + system.adapter.places.0                 : places                : pi                                       -  enabled
      system.adapter.proxy.0                  : proxy                 : pi                                       -  enabled
      system.adapter.pushover.0               : pushover              : pi                                       - disabled
      system.adapter.rest-api.0               : rest-api              : pi                                       - disabled, port: 8093, bind: 0.0.0.0, run as: admin
      system.adapter.roborock.0               : roborock              : pi                                       - disabled
      system.adapter.rpi2.0                   : rpi2                  : pi                                       - disabled
      system.adapter.sayit.0                  : sayit                 : pi                                       - disabled, port: 0
    + system.adapter.shelly.0                 : shelly                : pi                                       -  enabled, port: 1888, bind: 192.168.99.33
    + system.adapter.simple-api.0             : simple-api            : pi                                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : pi                                       -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sony-bravia.0            : sony-bravia           : pi                                       -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : pi                                       -  enabled
    + system.adapter.sql.0                    : sql                   : pi                                       -  enabled, port: 0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : pi                                       -  enabled
      system.adapter.telegram-menu.0          : telegram-menu         : pi                                       - disabled
    + system.adapter.telegram.0               : telegram              : pi                                       -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.telegram.1               : telegram              : pi                                       - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : pi                                       -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : pi                                       -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : pi                                       - disabled
    + system.adapter.upnp.0                   : upnp                  : pi                                       -  enabled
      system.adapter.vis.0                    : vis                   : pi                                       -  enabled
      system.adapter.vw-connect.0             : vw-connect            : pi                                       - disabled
    + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.1                    : web                   : pi                                       -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      system.adapter.webcal.0                 : webcal                : pi                                       - disabled
      system.adapter.windows-control.0        : windows-control       : pi                                       - disabled
    + system.adapter.wireguard.0              : wireguard             : pi                                       -  enabled
    + system.adapter.zigbee.0                 : zigbee                : pi                                       -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
    Adapter    "adb"          : 0.0.7    , installed 0.0.7
    Adapter    "admin"        : 6.3.5    , installed 6.3.7
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
    Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "countdown"    : 2.0.1    , installed 2.0.1
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "device-watcher": 2.9.2   , installed 2.9.1  [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "iot"          : 1.14.5   , installed 2.0.0
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "linux-control": 1.1.3    , installed 1.1.5
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "operating-hours": 1.0.4  , installed 1.0.4
    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
    Adapter    "parser"       : 1.3.2    , installed 1.3.2
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "places"       : 1.1.2    , installed 1.1.2
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "puppeteer"    : 0.2.7    , installed 0.2.7
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wireguard"    : 1.3.1    , installed 1.5.0
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "zigbee"       : 1.8.16   , installed 1.8.16
    Objects and States
    Objects:        27357
    States:         25287
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InReleaseHit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1001       17111      1141/io.hm-rpc.0
    tcp        0      0 192.168.99.33:3493      0.0.0.0:*               LISTEN      0          15127      1075/upsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16561      542/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15523      542/iobroker.js-con
    tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       20532      1505/adb
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17985      1325/io.mqtt.0
    tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1001       17274      1226/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17893      1233/io.sonoff.0
    tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1001       17133      1143/io.hm-rpc.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14737      574/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          15128      1075/upsd
    tcp6       0      0 :::3306                 :::*                    LISTEN      109        831        633/mariadbd
    tcp6       0      0 :::8092                 :::*                    LISTEN      1001       22006      1664/io.lovelace.1
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       19064      1647/io.lovelace.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21546      1672/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16719      966/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22811      2016/io.web.0
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       22349      2030/io.web.1
    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       27406      2086/io.upnp.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14739      574/sshd: /usr/sbin
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24893      2086/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24892      2086/io.upnp.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12157      870/dhcpcd
    udp        0      0 0.0.0.0:59682           0.0.0.0:*                           1001       23821      2086/io.upnp.0
    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          15004      -
    udp        0      0 0.0.0.0:43871           0.0.0.0:*                           108        14592      400/avahi-daemon: r
    udp        0      0 0.0.0.0:37783           0.0.0.0:*                           1001       23820      2086/io.upnp.0
    udp        0      0 10.137.192.1:5353       0.0.0.0:*                           1001       17365      1263/io.tr-064.0
    udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1001       17364      1263/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14590      400/avahi-daemon: r
    udp6       0      0 :::34969                :::*                                108        14593      400/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12170      870/dhcpcd
    udp6       0      0 :::51820                :::*                                0          15005      -
    udp6       0      0 :::5353                 :::*                                108        14591      400/avahi-daemon: r
    • David G.D David G.
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      Iob diag:
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=46.2'C
      volt=0.8563V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3793 M total memory
               2084 M used memory
               1001 M free memory
                 75 M buffer memory
                632 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      3.6G    /var/
      3.0G    /var/log
      448M    /var/lib
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.7
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        27357
      States:         25287
      Pending Updates: 1
      Thomas BraunT Offline
      @david-g
      Sentry für die Instanz ausgeschaltet?
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        Iob diag:
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=46.2'C
        volt=0.8563V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3793 M total memory
                 2084 M used memory
                 1001 M free memory
                   75 M buffer memory
                  632 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        3.6G    /var/
        3.0G    /var/log
        448M    /var/lib
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.7
        javascript:     7.0.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        27357
        States:         25287
        Pending Updates: 1
        @david-g sagte in Zigbee stürzt. Rom schalten ab:
        Und die alpha-testest du alle?
          @david-g
          David G.D Online
          David G.D Online
          David G.
          @thomas-braun sagte in Zigbee stürzt beim schalten ab:
          Hab ich gerade deaktiviert.
          Adapter bleibt nun grün, jedoch schaltet kein Gerät.
          Es kommt immer:
          zigbee.0
          2023-07-26 21:59:02.505	error	Error 225 on send command to 0x60a423fffeed446c. Error: Error: Command 0x60a423fffeed446c/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:336:23) at async Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:19:32)
          In der Tat.
          Gibt ja so die üblichen.
          MyTime, Roborock etc.
          Alles Adapter die noch nicht im offiziellen Repro sind.
          (Wobei ich ehrlich gesagt spontan nicht wüsste, welche es alle sind. Laufen alle schon Ewigkeiten)
          • David G.D Online
            David G.D Online
            David G.
            Habs wieder am laufen.
            Es war garnichts Softwaretechnisches.
            Ich habe meine Fritzbox und den Zigbee Stick neu positioniert.
            Habe heute ein Update auf der FritzBox durchgeführt.
            Evtl hat die den Kanal geändert, was an der Sendeleistung geschraubt oder sonst was.....
