  4. [gelöst] Fehlermeldung bei Influxdb upgrade auf 2.x
    5.3k
9 Beiträge 2 Kommentatoren 829 Aufrufe 2 Beobachtet
  • Christian KohlöffelC Offline
    Christian Kohlöffel
    schrieb am zuletzt editiert von Christian Kohlöffel
    Ich wollte soeben mein Influxdb von 1.8 auf 2.0 upgraden. Hierzu bin ich laut Anleitung von hier vorgegangen:
    https://www.youtube.com/watch?v=QFOqLnBMTW4
    Leider bricht die Installation ab und ich weiß mir aktuell nicht weiterzuhelfen. Es wäre toll wenn mir hier jemand von euch unter die Arme greifen könnte. Anbei der Log dazu:
    root@iobroker:~# sudo -u influxdb influxd upgrade
    ERROR 2023/07/25 18:59:33 Couldn't discover absolute path
    ERROR 2023/07/25 18:59:33 stat .: permission denied
    {"level":"info","ts":1690304373.3033726,"caller":"upgrade/upgrade.go:401","msg":"Starting InfluxDB 1.x upgrade"}
    {"level":"info","ts":1690304373.3034458,"caller":"upgrade/upgrade.go:404","msg":"Upgrading config file","file":"/etc/influxdb/influxdb.conf"}
    {"level":"info","ts":1690304373.3041844,"caller":"upgrade/upgrade.go:408","msg":"Config file upgraded.","1.x config":"/etc/influxdb/influxdb.conf","2.x config":"/var/lib/influxdb/.influxdbv2/config.toml"}
    {"level":"info","ts":1690304373.304211,"caller":"upgrade/upgrade.go:418","msg":"Upgrade source paths","meta":"/var/lib/influxdb/meta","data":"/var/lib/influxdb/data"}
    {"level":"info","ts":1690304373.3042352,"caller":"upgrade/upgrade.go:419","msg":"Upgrade target paths","bolt":"/var/lib/influxdb/.influxdbv2/influxd.bolt","engine":"/var/lib/influxdb/.influxdbv2/engine"}
    {"level":"info","ts":1690304373.3210242,"caller":"bolt/bbolt.go:83","msg":"Resources opened","service":"bolt","path":"/var/lib/influxdb/.influxdbv2/influxd.bolt"}
    {"level":"info","ts":1690304373.327866,"caller":"migration/migration.go:175","msg":"Bringing up metadata migrations","service":"migrations","migration_count":20}
    > Welcome to InfluxDB 2.0!
    ? Please type your primary username
    Error: interrupt
    See 'influxd -h' for help
    Was mir noch komisch vorkam, was ich aber noch dachte dass es "nur" was mit Grafana zu tun haben sollte. Und ich mich als nächstes drum kümmern muss ..
    All packages are up to date.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    • Christian KohlöffelC Christian Kohlöffel
      Error: interrupt
      @christian-kohlöffel sagte in Fehlermeldung bei Influxdb upgrade von 1.8 auf influxdb 2.x:
      Edit: Das ist Quark von mir gewesen...
      Und in der Anleitung steht so'n Quark drin?
      sudo in Kombination mit root shell soll genau was bewirken? Doppelroot? Superroot? Mega-Super-Root?
      Würde allenfalls Sinn ergeben, wenn man da nicht ohnehin schon als root herumkaspert.
      Zu Grafana: Die Meldung muss da schon seit Monaten kommen, der Thread ist vom Januar 2023...
      https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
      Christian KohlöffelC 1 Antwort Letzte Antwort
        Christian Kohlöffel
        @thomas-braun said in Fehlermeldung bei Influxdb upgrade von 1.8 auf influxdb 2.x:
        Tatsächlich, hab's soeben nochmals geprüft. Macht tatsächlich wenig Sinn. Ich hab ja zum Glück ein Backup gemacht. Falls jemand einen Tip zu einer besseren Anleitung hat gerne ...
          Ich seh gerade, das ist ja ein sudo -u influxdb, das ist natürlich sinnvoll.
          Nicht sinnvoll ist allerdings dein login als root.
            Christian Kohlöffel
            Ok, d.h. ich sollte mich als iobroker einloggen, was wahrscheinlich mehr Sinn machen würde, oder?
              Ja, man meldet sich NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE, NIE,
              als root an. NIE!
              Leg dir einen User an, der NICHT 'iobroker' heißt. Das ist der Systemuser für den Service 'iobroker'. Nenn dich halt ganz orginell 'christian' oder 'chris' oder 'cross' oder sonst irgendwie.
                Christian Kohlöffel
                OK, ich hab's glaub verstanden
                Ich leg mir einen User zu und nehme nicht den root user. Dann versuche ich das alles nochmals. Sorry fürs dumm anstellen 😉
                  Ohne das ich Ahnung on influx hätte, aber die Meldung
                  deutet für mich schon mal wieder auf 'per root login verfummelte Rechte' hin.
                    Christian Kohlöffel
                    Hab das ganze nun wie von Dir im "Der Linux-Werkzeugkasten" beschrieben umgestellt und einen User angelegt. Im nächsten Schritt wie im Forum auch an anderer Stelle beschrieben den Fehler von apt-update korrigiert.
                    Die genannte Fehlermeldung bei
                    war zwar noch da, doch hat der update auf die 2.x Version trotzdem funktioniert.
                    Super vielen Dank nochmals ✌
                    Ps: Wie kann ich das als gelöst markieren. Konnte leider nix finden ...
