  4. RFXCOM Adapter lässt sich nicht installieren
    5.3k
15 Beiträge 2 Kommentatoren 962 Aufrufe 2 Beobachtet
  • F Offline
    Forum-merlin
    schrieb am zuletzt editiert von Forum-merlin
    Hallo Zusammen,
    ich bin recht neu in ioBroker, also habt bitte nachsicht was das ordentliche reporten angeht...
    Folgende Ausgangslage:
    Hardware: Fujitsu Q920 TinyPC
    Hypervisor: Proxmox 8.0.3
    VM-Image: Debian12 für ioBroker
    Durchgereichte HW: BT-LE Stick, CC2531, RFXCOM
    Zielsetzung:
    Installation des rfxcom Adapters
    Problemstellung:
    bei der Installation des RFXCOM Adapters 2.0.2 bekomme ich folgende Fehlermeldung:
    iobroker@vm-iobroker:/opt/iobroker$ iobroker add rfxcom auto --debug
    NPM version: 9.8.0
    Installing iobroker.rfxcom@2.0.2... (System call)
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
    npm ERR! command failed
    npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    npm ERR! prebuild-install warn install No prebuilt binaries found (target=18.16.1 runtime=node arch=x64 libc= platform=linux)
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using node-gyp@7.1.2
    npm ERR! gyp info using node@18.16.1 | linux | x64
    npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
    npm ERR! (node:3365) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
    npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
    npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! gyp info spawn args [
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! gyp info spawn args   '-f',
    npm ERR! gyp info spawn args   'make',
    npm ERR! gyp info spawn args   '-I',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
    npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.16.1/include/node/common.gypi',
    npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.16.1',
    npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
    npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.16.1/<(target_arch)/node.lib',
    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',
    npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! gyp info spawn args   'build',
    npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! gyp info spawn args ]
    npm ERR! Traceback (most recent call last):
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
    npm ERR!     sys.exit(gyp.script_main())
    npm ERR!              ^^^^^^^^^^^^^^^^^
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
    npm ERR!     return main(sys.argv[1:])
    npm ERR!            ^^^^^^^^^^^^^^^^^^
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
    npm ERR!     return gyp_main(args)
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
    npm ERR!     [generator, flat_list, targets, data] = Load(
    npm ERR!                                             ^^^^^
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
    npm ERR!     result = gyp.input.Load(
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
    npm ERR!     LoadTargetBuildFile(
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
    npm ERR!     build_file_data = LoadOneBuildFile(
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
    npm ERR!     build_file_contents = open(build_file_path, "rU").read()
    npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
    npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
    npm ERR! gyp ERR! configure error
    npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
    npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
    npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
    npm ERR! gyp ERR! System Linux 6.1.0-10-amd64
    npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
    npm ERR! gyp ERR! node -v v18.16.1
    npm ERR! gyp ERR! node-gyp -v v7.1.2
    npm ERR! gyp ERR! not ok
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-19T15_22_54_864Z-debug-0.log
    npm ERR! code 1
    npm ERR!                                             ^^^^^
    host.vm-iobroker Cannot install iobroker.rfxcom@2.0.2: 1
    Was ich schon gemacht habe:
    Weil ich das Announcement gelesen habe:
    erstmal ein
    find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
    aber dann hab ich weitergelesen und zur Sicherheit noch:
    iob stop
    iob fix
    iob start
    Hat nix gebracht.
    Im Vorfeld hab ich schon einiges an ähnlichen Fehlern gefunden was den ZigBee Adapter angeht. Da haben User das selbe berichtet wie hier eigentlich.
    Ich hatte also schon manuell die beiden folder gelöscht
    rm -R /opt/iobroker/node_modules/@serialport
    rm -R /opt/iobroker/node_modules/serialport
    Und auch nochmal den fixer drüber.
    Ich hab auch noch...
    cd /opt/iobroker/
    npm cache clean --force
    ...ausgeführt, aber auch danach keine Besserung.
    Weiter habe ich auch noch versucht ein npm rebuild zu machen. Aber auch da keine Verbesserung
    In dem ganzen Verlauf (und ich hänge hier schon seit Stunden) hab ich auch irgendwann mal ein
    cd /opt/iobroker/node_modules/@serialport/bindings-cpp
    npm install --production
    cd /opt/iobroker/node_modules/@serialport/bindings-interface
    ...durchgeführt
    und irgendwann aus verzweiflung hab ich noch ein
    root@vm-iobroker:/opt/iobroker# npm install -g node-gyp
    npm notice
    npm notice New minor version of npm available! 9.5.1 -> 9.8.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v9.8.0
    npm notice Run npm install -g npm@9.8.0 to update!
    durchgeführt und dann anschließend noch ein
    Kann mir hier jemand helfen?
    DANKE
    • F Forum-merlin
      Hallo Zusammen,
      Zielsetzung:
      Problemstellung:
      NPM version: 9.8.0
      npm ERR! code 1
      npm ERR!                                             ^^^^^
      npm ERR! code 1
      npm ERR!                                             ^^^^^
      erstmal ein
      iob stop
      iob fix
      iob start
      Hat nix gebracht.
      cd /opt/iobroker/
      ...durchgeführt
      npm notice
      DANKE
      @forum-merlin sagte in RFXCOM Adapter lässt sich nicht installieren:
      root@vm-iobroker
      Als root führst du da gar nichts aus.
      Installier das Paket 'nodejs' nochmal neu drüber.
      F 1 Antwort Letzte Antwort
        root@vm-iobroker
        Forum-merlin
        Naja, wer so verzweifelt über stunden rumfuchtelt macht viele komische Dinge! :-)
        Und noch viel krasser, ich hab sogar was machen müssen was ich garnicht kapiere...
        npm notice
        npm notice
        npm ERR! code EACCES
        npm ERR! syscall mkdir
        npm ERR! path /usr/lib/node_modules/node-gyp
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, mkdir '/usr/lib/node_modules/node-gyp'
        npm ERR!  [Error: EACCES: permission denied, mkdir '/usr/lib/node_modules/node-gyp'] {
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'mkdir',
        npm ERR!   path: '/usr/lib/node_modules/node-gyp'
        npm ERR! }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/iobroker/.npm/_logs/2023-07-19T14_57_49_852Z-debug-0.log
        root@vm-iobroker:/opt/iobroker# npm install -g node-gyp^C
        root@vm-iobroker:/opt/iobroker# npm install -g npm@9.8.0
        npm ERR! syscall rename
        npm ERR! path /usr/lib/node_modules/npm
        npm ERR! dest /usr/lib/node_modules/.npm-qUIFSsiV
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, rename '/usr/lib/node_modules/npm' -> '/usr/lib/node_modules/.npm-qUIFSsiV'
        npm ERR!  [Error: EACCES: permission denied, rename '/usr/lib/node_modules/npm' -> '/usr/lib/node_modules/.npm-qUIFSsiV'] {
        npm ERR!   syscall: 'rename',
        npm ERR!   path: '/usr/lib/node_modules/npm',
        npm ERR!   dest: '/usr/lib/node_modules/.npm-qUIFSsiV'
        npm ERR! }
        npm ERR!
        npm ERR!
        npm ERR!     /home/iobroker/.npm/_logs/2023-07-19T14_58_31_016Z-debug-0.log
        root@vm-iobroker:
        das ging dann nur mit sudo unter root ???
        root@vm-iobroker:/opt/iobroker# sudo npm install -g npm@9.8.0
        removed 17 packages, and changed 67 packages in 3s
        28 packages are looking for funding
          run `npm fund` for details
        root@vm-iobroker:
        Ich bin ja nicht sooo der Linux Guru, aber wie kann der super-user root noch mehr als super-user werden?
        Egaaal....
        Hier eben nochmal die drüber-installation von "nodejs"
        iobroker@vm-iobroker:/opt/iobroker$ sudo apt install nodejs
        nodejs ist schon die neueste Version (18.16.1-deb-1nodesource1).
        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        dann
        iob stop
        iob fix
        iob start
        und natürlich nochmal
        NPM version: 9.8.0
        npm ERR! code 1
        npm ERR! (node:5888) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
        npm ERR!                                             ^^^^^
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-19T16_14_11_491Z-debug-0.log
        npm ERR! code 1
        npm ERR!                                             ^^^^^
        • F Forum-merlin
          npm notice
          npm notice
          npm ERR! errno -13
          npm ERR! }
          npm ERR!
          npm ERR!
          npm ERR! errno -13
          npm ERR! }
          npm ERR!
          npm ERR!
          root@vm-iobroker:
          root@vm-iobroker:
          Egaaal....
          dann
          iob stop
          iob fix
          iob start
          NPM version: 9.8.0
          npm ERR! code 1
          npm ERR!                                             ^^^^^
          npm ERR! code 1
          npm ERR!                                             ^^^^^
          Egaaal....
          Mannnnn.... LASST DIE SCHEISSE MIT DEM ROOT!!!!!!!!!11111
          root shell ist verboten!!!
            Egaaal....
            Forum-merlin
            is ja guuuut... Beruhig dich.
            • F Forum-merlin
              @forum-merlin
              sudo apt update
              sudo apt install --reinstall nodejs
              iob diag
              Als USER, NICHT! als root!
              • F Forum-merlin
                @forum-merlin
                nodejs repariert?
                Gibt es die Datei
                /usr/lib/python3.11/EXTERNALLY-MANAGED
                auf dem System?
                Grundsätzlich baut der adapter nämlich:
                echad@chet:/opt/iobroker $ iob add rfxcom
                NPM version: 9.6.7
                added 53 packages in 41s
                118 packages are looking for funding
                host.chet install adapter rfxcom
                upload [2] rfxcom.admin /opt/iobroker/node_modules/iobroker.rfxcom/admin/index.html index.html text/html
                upload [1] rfxcom.admin /opt/iobroker/node_modules/iobroker.rfxcom/admin/rfxcom.png rfxcom.png image/png
                upload [0] rfxcom.admin /opt/iobroker/node_modules/iobroker.rfxcom/admin/words.js words.js application/javascript
                host.chet object system.adapter.rfxcom created/updated
                host.chet create instance rfxcom
                host.chet object system.adapter.rfxcom.0.alive created
                host.chet object system.adapter.rfxcom.0.connected created
                host.chet object system.adapter.rfxcom.0.compactMode created
                host.chet object system.adapter.rfxcom.0.cpu created
                host.chet object system.adapter.rfxcom.0.cputime created
                host.chet object system.adapter.rfxcom.0.memHeapUsed created
                host.chet object system.adapter.rfxcom.0.memHeapTotal created
                host.chet object system.adapter.rfxcom.0.memRss created
                host.chet object system.adapter.rfxcom.0.uptime created
                host.chet object system.adapter.rfxcom.0.inputCount created
                host.chet object system.adapter.rfxcom.0.outputCount created
                host.chet object system.adapter.rfxcom.0.eventLoopLag created
                host.chet object system.adapter.rfxcom.0.sigKill created
                host.chet object system.adapter.rfxcom.0.logLevel created
                host.chet object rfxcom.0.info created
                host.chet object rfxcom.0.info.connection created
                host.chet object rfxcom.0.inclusionOn created
                host.chet object rfxcom.0.rawData created
                host.chet object rfxcom.0.firmwareVersion created
                host.chet object rfxcom.0.availableVersion created
                host.chet Set default value of rfxcom.0.info.connection: false
                host.chet object system.adapter.rfxcom.0 created
                  @forum-merlin
                  nodejs repariert?
                  Gibt es die Datei
                  auf dem System?
                  NPM version: 9.6.7
                  Forum-merlin
                  Nachdem jetzt dann alles irgendwie komisch wurde hab ich die VM komplett gelöscht und neu aufgesetzt.
                  ioBroker auch nach Anleitung from scratch installiert.
                  Und alles unter iobroker user mit sudo wenn es in der Anleitung erwähnt wurde.
                  Dann erstmal alles in ioBroker aktualisiert was ein update haben wollte.
                  Adapter rfxcom als erstes installiert und der geht nun.
                  Aber dafür der ZigBee nicht mehr.
                  • F Forum-merlin
                    iobroker ist auch keine clevere Wahl. Es gibt schon einen system user mit dem Namen.
                    Zeig mal die
                    cat /etc/passwd | sort
                      Zeig mal die
                      Forum-merlin
                      iobroker@vm-iobroker:~$ cat /etc/passwd | sort
                      _apt:x:42:65534::/nonexistent:/usr/sbin/nologin
                      backup:x:34:34:backup:/var/backups:/usr/sbin/nologin
                      bin:x:2:2:bin:/bin:/usr/sbin/nologin
                      daemon:x:1:1:daemon:/usr/sbin:/usr/sbin/nologin
                      games:x:5:60:games:/usr/games:/usr/sbin/nologin
                      iobroker:x:1000:1000:iobroker,,,:/home/iobroker:/bin/bash
                      irc:x:39:39:ircd:/run/ircd:/usr/sbin/nologin
                      list:x:38:38:Mailing List Manager:/var/list:/usr/sbin/nologin
                      lp:x:7:7:lp:/var/spool/lpd:/usr/sbin/nologin
                      mail:x:8:8:mail:/var/mail:/usr/sbin/nologin
                      man:x:6:12:man:/var/cache/man:/usr/sbin/nologin
                      messagebus:x:100:107::/nonexistent:/usr/sbin/nologin
                      news:x:9:9:news:/var/spool/news:/usr/sbin/nologin
                      nobody:x:65534:65534:nobody:/nonexistent:/usr/sbin/nologin
                      proxy:x:13:13:proxy:/bin:/usr/sbin/nologin
                      root:x:0:0:root:/root:/bin/bash
                      _rpc:x:102:65534::/run/rpcbind:/usr/sbin/nologin
                      sshd:x:101:65534::/run/sshd:/usr/sbin/nologin
                      statd:x:103:65534::/var/lib/nfs:/usr/sbin/nologin
                      sync:x:4:65534:sync:/bin:/bin/sync
                      systemd-network:x:998:998:systemd Network Management:/:/usr/sbin/nologin
                      systemd-timesync:x:997:997:systemd Time Synchronization:/:/usr/sbin/nologin
                      sys:x:3:3:sys:/dev:/usr/sbin/nologin
                      uucp:x:10:10:uucp:/var/spool/uucp:/usr/sbin/nologin
                      www-data:x:33:33:www-data:/var/www:/usr/sbin/nologin
                      • F Forum-merlin
                        @forum-merlin
                        Ja, ungünstig. 'Richtig' sähe der user so aus:
                        iobroker:x:1001:1001::/home/iobroker:/usr/sbin/nologin
                        Leg dir einen user an, der anders heißt. Hast du keinen schönen Vornamen von deinen Eltern bekommen? Oder haben die dich iobroker genannt? Oder nenn dich 'merlin'. Egal, alles gescheiter als den user 'iobroker' zu nennen.
                        • F Forum-merlin
                          Meldungen im LogFile?
                          'Geht nicht mehr' ist keine Fehlermeldung mit der irgendjemand was anfangen könnte.
                            Forum-merlin
                            Ich wollte jetzt nicht den Thread vermischen. Deswegen hab ich jetzt hier nix geschrieben und suche grad alles möglich im Forum dazu.
                            Aber vielleicht hast du ja gleich den treffenden Blick:
                            2023-07-19 19:47:12.196  - info: host.vm-iobroker instance system.adapter.zigbee.0 started with pid 1144
                            2023-07-19 19:47:13.525  - info: zigbee.0 (1144) starting. Version 1.8.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.0, js-controller: 5.0.8
                            2023-07-19 19:47:13.579  - info: zigbee.0 (1144) delete old Backup files. keep only last 10
                            2023-07-19 19:47:13.580  - info: zigbee.0 (1144) Starting Zigbee  npm ...
                            2023-07-19 19:47:13.697  - info: zigbee.0 (1144) Installed Version: iobroker.zigbee@1.8.18
                            2023-07-19 19:47:13.999  - error: zigbee.0 (1144) Configuration is not consistent with adapter state/backup!
                            2023-07-19 19:47:13.999  - error: zigbee.0 (1144) - PAN ID: configured=6754, adapter=510
                            2023-07-19 19:47:13.999  - error: zigbee.0 (1144) - Extended PAN ID: configured=00124b0018ed2fd7, adapter=00124b0018ed2fd7
                            2023-07-19 19:47:13.999  - error: zigbee.0 (1144) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                            2023-07-19 19:47:14.000  - error: zigbee.0 (1144) - Channel List: configured=11, adapter=11
                            2023-07-19 19:47:14.000  - error: zigbee.0 (1144) Please update configuration to prevent further issues.
                            2023-07-19 19:47:14.000  - error: zigbee.0 (1144) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                            2023-07-19 19:47:14.000  - error: zigbee.0 (1144) Re-commissioning your network will require re-pairing of all devices!
                            2023-07-19 19:47:14.001  - error: zigbee.0 (1144) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                            2023-07-19 19:47:14.001  - error: zigbee.0 (1144) Failed to start Zigbee
                            2023-07-19 19:47:14.001  - error: zigbee.0 (1144) Error herdsman start
                            2023-07-19 19:47:24.001  - info: zigbee.0 (1144) Try to reconnect. 1 attempts left
                            2023-07-19 19:47:24.002  - info: zigbee.0 (1144) Starting Zigbee  npm ...
                            2023-07-19 19:47:24.012  - info: zigbee.0 (1144) Installed Version: iobroker.zigbee@1.8.18
                            2023-07-19 19:47:24.113  - error: zigbee.0 (1144) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                            2023-07-19 19:47:24.113  - error: zigbee.0 (1144) Failed to start Zigbee
                            2023-07-19 19:47:24.114  - error: zigbee.0 (1144) Error herdsman start
                            2023-07-19 19:48:45.342  - error: zigbee.0 (1144) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                            2023-07-19 19:48:45.442  - info: zigbee.0 (1144) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"RFXCOM","serialNumber":"A1WJDDBR","pnpId":"usb-RFXCOM_RFXtrx433_A1WJDDBR-if00-port0","vendorId":"0403","productId":"6001"},{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018ED2FD7","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ED2FD7-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
                            2023-07-19 19:50:58.641  - info: zigbee.0 (1144) cleaned everything up...
                            2023-07-19 19:50:58.643  - info: host.vm-iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2023-07-19 19:50:58.651  - info: host.vm-iobroker stopInstance system.adapter.zigbee.0 send kill signal
                            2023-07-19 19:50:58.645  - info: zigbee.0 (1144) Zigbee: disabling joining new devices.
                            2023-07-19 19:50:58.655  - warn: zigbee.0 (1144) Failed to stop zigbee during startup
                            2023-07-19 19:50:58.656  - info: zigbee.0 (1144) Got terminate signal TERMINATE_YOURSELF
                            2023-07-19 19:50:58.701  - info: zigbee.0 (1144) terminating
                            2023-07-19 19:50:58.702  - info: zigbee.0 (1144) Terminated (NO_ERROR): Without reason
                            2023-07-19 19:50:59.144  - info: zigbee.0 (1144) terminating
                            2023-07-19 19:50:59.230  - info: host.vm-iobroker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                            2023-07-19 19:51:22.922  - info: host.vm-iobroker instance system.adapter.zigbee.0 started with pid 1797
                            2023-07-19 19:51:24.257  - info: zigbee.0 (1797) starting. Version 1.8.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.0, js-controller: 5.0.8
                            2023-07-19 19:51:24.308  - info: zigbee.0 (1797) delete old Backup files. keep only last 10
                            2023-07-19 19:51:24.309  - info: zigbee.0 (1797) Starting Zigbee  npm ...
                            2023-07-19 19:51:24.422  - info: zigbee.0 (1797) Installed Version: iobroker.zigbee@1.8.18
                            2023-07-19 19:51:24.715  - error: zigbee.0 (1797) Configuration is not consistent with adapter state/backup!
                            2023-07-19 19:51:24.715  - error: zigbee.0 (1797) - PAN ID: configured=6754, adapter=510
                            2023-07-19 19:51:24.715  - error: zigbee.0 (1797) - Extended PAN ID: configured=00124b0018ed2fd7, adapter=00124b0018ed2fd7
                            2023-07-19 19:51:24.715  - error: zigbee.0 (1797) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                            2023-07-19 19:51:24.716  - error: zigbee.0 (1797) - Channel List: configured=11, adapter=11
                            2023-07-19 19:51:24.716  - error: zigbee.0 (1797) Please update configuration to prevent further issues.
                            2023-07-19 19:51:24.716  - error: zigbee.0 (1797) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                            2023-07-19 19:51:24.716  - error: zigbee.0 (1797) Re-commissioning your network will require re-pairing of all devices!
                            2023-07-19 19:51:24.717  - error: zigbee.0 (1797) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                            2023-07-19 19:51:24.717  - error: zigbee.0 (1797) Failed to start Zigbee
                            2023-07-19 19:51:24.717  - error: zigbee.0 (1797) Error herdsman start
                            2023-07-19 19:51:34.718  - info: zigbee.0 (1797) Try to reconnect. 1 attempts left
                            2023-07-19 19:51:34.719  - info: zigbee.0 (1797) Starting Zigbee  npm ...
                            2023-07-19 19:51:34.729  - info: zigbee.0 (1797) Installed Version: iobroker.zigbee@1.8.18
                            2023-07-19 19:51:34.834  - error: zigbee.0 (1797) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                            2023-07-19 19:51:34.834  - error: zigbee.0 (1797) Failed to start Zigbee
                            2023-07-19 19:51:34.834  - error: zigbee.0 (1797) Error herdsman start
                            • F Forum-merlin
                              Steht doch da:
                              Die IDs müsssen übereinstimmen.
                                Steht doch da:
                                Forum-merlin
                                Danke Dir für Deine Hilfe.
                                Hab nun alles am Laufen.
                                (Allerdings hab ich einfach nochmal von vorne angefangen und dann auch nen anderen usernamen als initialen user verwendet. Ich hab im installer Script dann auch gesehen, dass da der user iobroker mitkommt. wer weiss wie sich das auswirkt)
                                Naja, wie auch immer, geht jetzt.
                                CLOSED!
