  4. Go-e Charger Fehlermeldung API response validation error:
    5.3k
6 Beiträge 3 Kommentatoren 742 Aufrufe 2 Beobachtet
    prospeedy
    schrieb am zuletzt editiert von prospeedy
    Systemdata Bitte Ausfüllen
    Hardwaresystem: ARMv7 Processor rev 3 (v7l) ; PI4
    Arbeitsspeicher: 3,75GB
    Festplattenart: SD-Karte; 32GB
    Betriebssystem: Raspbian GNU/Linux
    Node-Version: 14.21.1
    Nodejs-Version: 16.19.0
    NPM-Version: 6.14.17
    Installationsart: Manuell
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    Bin Anfänger, bitte um Hilfe.
    Ohne wissentliche Änderung kommt neuerdings bei der Aktualisierung alle 30 Sekunden diese Fehlermeldung.
    {"version":"B","tme":"2806231721","rbc":"44","rbt":"252852797","car":"1","amp":"12","amx":"7","err":"0","ast":"0","alw":"0","stp":"0","cbl":"32","pha":"56","tmp":"8","tma":[25.25,24.88,24.63,25.13,27.88,28.5],"amt":"32","dws":"0","dwo":"0","adi":"1","uby":"0","eto":"8250","wst":"3","txi":"0","nrg":[228,227,227,1,0,0,0,0,0,0,0,0,0,0,0,0],"fwv":"042.0","sse":"029275","wss":"WLAN-380283","wke":"********************","wen":"1","cdi":"0","tof":"101","tds":"1","lbr":"53","aho":"3","afi":"20","azo":"0","ama":"32","al1":"6","al2":"8","al3":"10","al4":"12","al5":"16","cid":"9408492","cch":"15086341","cfi":"65280","lse":"1","ust":"1","wak":"192bb2d1ba","r1x":"2","dto":"0","nmo":"0","sch":"AAAAAAAAAAAAAAAA","sdp":"0","eca":"0","ecr":"0","ecd":"0","ec4":"0","ec5":"0","ec6":"0","ec7":"0","ec8":"0","ec9":"0","ec1":"0","rca":"0448F77A","rcr":"","rcd":"","rc4":"","rc5":"","rc6":"","rc7":"","rc8":"","rc9":"","rc1":"","rna":"","rnm":"","rne":"","rn4":"","rn5":"","rn6":"","rn7":"","rn8":"","rn9":"","rn1":"","loe":0,"lot":0,"lod":65535,"lts":0,"lom":0,"lop":0,"log":"","lon":0,"lof":0,"loa":0,"lch":85181,"mce":0,"mcs":"test.mosquitto.org","mcp":1883,"mcu":"","mck":"","mcc":0,"pco":"","cmf":0,"ath":1200,"psp":11300,"cco":180,"map":123,"frm":1,"los":"{"chg":[["053644",10,0,1,0,[1,2,3],6]]}"}
    API response validation error: [{"message":""lod" is not allowed","path":["lod"],"type":"object.unknown","context":{"child":"lod","label":"lod","value":65535,"key":"lod"}},{"message":""lts" is not allowed","path":["lts"],"type":"object.unknown","context":{"child":"lts","label":"lts","value":0,"key":"lts"}},{"message":""pco" is not allowed","path":["pco"],"type":"object.unknown","context":{"child":"pco","label":"pco","value":"","key":"pco"}},{"message":""cmf" is not allowed","path":["cmf"],"type":"object.unknown","context":{"child":"cmf","label":"cmf","value":0,"key":"cmf"}},{"message":""ath" is not allowed","path":["ath"],"type":"object.unknown","context":{"child":"ath","label":"ath","value":1200,"key":"ath"}},{"message":""psp" is not allowed","path":["psp"],"type":"object.unknown","context":{"child":"psp","label":"psp","value":11300,"key":"psp"}},{"message":""cco" is not allowed","path":["cco"],"type":"object.unknown","context":{"child":"cco","label":"cco","value":180,"key":"cco"}},{"message":""map" is not allowed","path":["map"],"type":"object.unknown","context":{"child":"map","label":"map","value":123,"key":"map"}},{"message":""frm" is not allowed","path":["frm"],"type":"object.unknown","context":{"child":"frm","label":"frm","value":1,"key":"frm"}},{"message":""los" is not allowed","path":["los"],"type":"object.unknown","context":{"child":"los","label":"los","value":"{"chg":[["053644",10,0,1,0,[1,2,3],6]]}","key":"los"}}]
    • P prospeedy
      Image genutzt: Nein
      @prospeedy da gibt's schon was
      https://forum.iobroker.net/search?term="lod" &in=titlesposts&matchWords=all&sortBy=timestamp&sortDirection=desc&showAs=posts
      P 1 Antwort Letzte Antwort
        prospeedy
        Vilen Dank!!!
        • P prospeedy
          Vilen Dank!!!
          @prospeedy
          Wenn du dir die Versionsnummern nicht ausgedacht haben solltest
          stimmt da mit großer Sicherheit was nicht in deinem System.
          Jag mal ein
          iob diag
          drüber.
            @prospeedy
            Jag mal ein
            iob diag
            drüber.
            prospeedy
            		     v.2023-04-16
            Operatingsystem: 	Raspbian GNU/Linux 10 (buster)
            Kernel: 		5.10.103-v7l+
            Installation: 		Native
            Timezone: 		Europe/Berlin (CEST, +0200)
            User-ID: 		0
            X-Server: 		false
            Boot Target: 		graphical.target
            Pending OS-Updates: 	128
            Pending iob updates: 	14
            Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
            			/usr/local/bin/node 		v14.21.2
            			/usr/local/bin/npm 		6.14.17
            			/usr/local/bin/npx 		6.14.17
            Recommended versions are nodejs 18.x.y and npm 9.x.y
            *** nodejs is NOT correctly installed ***
            MEMORY:
            Mem:           3.8G        1.9G        579M         15M        1.4G        1.9G
            Swap:           99M         10M         89M
            Total:         3.9G        1.9G        668M
            Active iob-Instances: 	34
            ioBroker Core: 		js-controller 		4.0.24
            			admin 			6.3.5
            ioBroker Status: 	iobroker is running on this host.
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.2.207, run as: admin
            Objects: 		13994
            States: 		11659
            Size of iob-Database:
            27M	/opt/iobroker/iobroker-data/objects.jsonl
            12M	/opt/iobroker/iobroker-data/objects.json.migrated
            12M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
            19M	/opt/iobroker/iobroker-data/states.jsonl
            2.2M	/opt/iobroker/iobroker-data/states.json.migrated
            2.2M	/opt/iobroker/iobroker-data/states.json.bak.migrated
            Some problems detected, please run iob fix and try to have them fixed
            Sorry bin Anfänger: Wie bekomme ich das repariert? Ansicht läuft alles und das geschilderte Problem hängt wohl mit der Softwareversion von go-e zusammen.
            npm ls | grep -E 'github|ERR'
            ├─┬ iobroker.alexa2@3.23.2 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#84a50cc1e18cec38f6c02c84715f230451100f23)
            │ │ │ ├── github-from-package@0.0.0
            npm ERR! peer dep missing: tough-cookie@^4.0.0, required by http-cookie-agent@5.0.2
            │   │   │   ├── github-from-package@0.0.0 deduped
            │   ├── github-url-from-git@1.5.0
            │   ├─┬ new-github-release-url@1.0.0
            • P prospeedy
              		     v.2023-04-16
              User-ID: 		0
              X-Server: 		false
              MEMORY:
              Swap:           99M         10M         89M
              			admin 			6.3.5
              Objects type: jsonl
              States  type: jsonl
              Objects: 		13994
              States: 		11659
              @prospeedy
              Für nodejs und Konsorten: Schau in meine Signatur.
              Buster / Debian10 ist auch tot, installier da ein lebendiges Release.
              Insgesamt auch mal wieder Update-Infarkt.
              Halt die Kiste insgesamt auf Stand, sowohl das Betriebssystem wie den ioBroker.
