  4. WEB-Adapter Absturz, Wenn URL aus einem DP kommt.
    3.1k
15 Beiträge 4 Kommentatoren 1.2k Aufrufe 4 Beobachtet
  • a200A Offline
    a200A Offline
    a200
    schrieb am zuletzt editiert von a200
    Moin,
    habe folgendes Problem. Im VIS nutze ich ein Dialog:
    [{"tpl":"tplJquiDialog","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_dialog":"<img src=\"{frigate.0.garage.objects.person.web.snap.snap_0}\" width=\"1100px\" height=\"620px\">","modal":true,"closeOnClick":true,"html":"<img src=\"{frigate.0.buero.objects.person.web.snap.snap_0}\" width=\"550px\" height=\"310px\">","dialog_width":"1110px","dialog_height":"630px"},"style":{"left":"1316px","top":"86px","z-index":"14","width":"550px","height":"310px"},"widgetSet":"jqui"}]
    Dort wird als HTML ein Bild angezeigt. Der Inhalt des DP = "http://192.168.10.40:5000//api/events/1687000208.037646-ybkenw/snapshot.jpg"
    Rufe ich die URL direkt auf:
    <img src="http://192.168.10.40:5000//api/events/1687000208.037646-ybkenw/snapshot.jpg" width="250px" height="155px">
    dann ist alles in Ordnung. Wenn ich die URL aus dem DP ziehe:
    <img src="{frigate.0.buero.objects.person.web.snap.snap_0}" width="250px" height="155px">
    Dann wird das Bild angezeigt, aber nach einigen senkenden stürzt der WEB Adapter (5.5.3) mit folgender Meldung ab:
    host.iobroker	2023-06-17 13:36:58.205	error	instance system.adapter.web.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    web.0	2023-06-17 13:36:57.593	error	The pattern "<img src="http://192.168.10.40:5000//api/events/1687000208.037646-ybkenw/snapshot.jpg" width="1100px" height="620px">" is not a valid ID pattern
    web.0	2023-06-17 13:36:57.592	error	Error: The pattern "<img src="http://192.168.10.40:5000//api/events/1687000208.037646-ybkenw/snapshot.jpg" width="1100px" height="620px">" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2156:15) at pattern2RegEx (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:44) at SocketCommands.subscribe (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:267:13) at SocketCommands._subscribeStates (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:492:22) at commands.subscribe (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1356:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1556:43) at /opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:100 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:83) at process.processImmediate (node:internal/timers:476:21)
    web.0	2023-06-17 13:36:57.591	error	uncaught exception: The pattern "<img src="http://192.168.10.40:5000//api/events/1687000208.037646-ybkenw/snapshot.jpg" width="1100px" height="620px">" is not a valid ID pattern
    Ideen?
    DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
    • a200A a200
      Moin,
      Ideen?
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @a200 sagte in WEB-Adapter Absturz, Wenn URL aus einem DP kommt.:
      Ideen?
      Version von VIS ?
      Lehrling seit 1975 !!!
      a200A 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        Ideen?
        Version von VIS ?
        a200A Offline
        a200A Offline
        a200
        @djmarc75 VIS = 1.4.16
        • a200A a200
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @a200 Bist Du Betatester vom JS-Controller ?
            a200A Offline
            a200A Offline
            a200
            @djmarc75 leider.
            • a200A a200
              @djmarc75 leider.
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @djmarc75 leider.
              Dann setz da mal an... ggf wieder auf stabile Version gehen und dann nochmal das Ganze testen.
              • a200A a200
                Moin,
                Ideen?
                @a200
                Gab eben einen Thread dazu, wo falsche Bindings solch einen Fehler werfen.
                  @djmarc75 leider.
                  a200A Offline
                  a200A Offline
                  a200
                  @djmarc75 Soweit ich weiss ist ein Downgrade des Controllers nicht möglich. Und das ganze neu aufzusetzen... Naja braucht Zeit.
                  • a200A a200
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    Sagt wer? ;)
                      Sagt wer? ;)
                      a200A Offline
                      a200A Offline
                      a200
                      @djmarc75 Das wäre natürlich eine Lösung. Hast du ne Ahnung wo ich eine Anleitung finde? oder kann ich einfach mit install adapter@version die alte einspielen?
                      • a200A a200
                        @a200
                        Sowas steht im entsprechenden Ankündigunsthread drin. Sollte man halt lesen, wenn man mit Beta-Zeug hantiert.
                          @a200
                          a200A Offline
                          a200A Offline
                          a200
                          @thomas-braun @DJMarc75 mea maxima culpa. Wollte mal die Updates mal schnell einspielen und dann auch noch den Controller upgadeted. Unnötig... jetzt habe ich die Kacke...
                          Thomas BraunT NegaleinN 3 Antworten Letzte Antwort
                          • a200A a200
                            Kommt davon wenn man ohne Not auf der Beta-Welle surft...
                            Lasst den Scheiß doch bleiben, wenn man sich mit den Beta-Versionen eigentlich gar nicht beschäftigen will. Bleib halt auf Stable mit deinem System, dann passiert das auch nicht (so leicht).
                            • a200A a200
                              @a200
                              Und die Suchfunktion schmeißt zu
                              auch was raus
                              • a200A a200
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                ich geb dir mal einen Schups in die richtige Richtung ;)
                                im besagten Thread steht unteranderem Eine alte 4.0.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen (Letzter Stable Stand ist die 4.0.24)
                                ° Fixer ---> iob fix
