  4. backitup Fehlermeldung
    6.6k
39 Beiträge 4 Kommentatoren 6.2k Aufrufe 4 Beobachtet
    maximinus
    backitup v2.6.19
    admin v6.3.5
    Da ich trotz Forumsuche nichts Passendes gefunden habe.
    Seit einigen Tagen blieb der Adapter rot. Ursache war wie sich herausstellte der veraltete admin adapter. Nach update wurde backitup wieder grün, brachte aber bei der nächtlichen Sicherung die folgende Fehlermeldung:
    BackItUp:
    Your backup was not completely created. Please check the errors!!
    grafana: {"message":"Request failed with status code 500","name":"AxiosError","stack":"AxiosError: Request failed with status code 500\n    at settle (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/lib/core/settle.js:19:12)\n    at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/lib/adapters/http.js:570:11)\n    at IncomingMessage.emit (node:events:525:35)\n    at IncomingMessage.emit (node:domain:489:12)\n    at endReadableNT (node:internal/streams/readable:1358:12)\n    at processTicksAndRejections (node:internal/process/task_queues:83:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{"Blob":null},"headers":{"Accept":"application/json, text/plain, */*","Authorization":"Bearer ****","User-Agent":"axios/1.4.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.159:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_RESPONSE","status":500}
    Wenn man ein manuelles Backup macht läuft es durch. Es kommen 2 Errormeldungen aber das Backup scheint von den Größen her i. O. zu sein
    [ERROR] [grafana] - Error on Grafana Dashoard Request: AxiosError: Request failed with status code 500
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    Wie ist das zu beheben?
    Ich bin nicht so versiert dass ich das aus der Meldung erkennen könnte.
    LG Gerhard
    RasPi 4 4GB bookworm
    nodejs v20.19.4
    npm 10.8.2
    Objects type: jsonl
    States type: redis
    js-controller: 7.0.6
    admin: 7.6.17
    javascript: 8.9.2
    DJMarc75D ? 2 Antworten Letzte Antwort
    • M maximinus
      backitup v2.6.19
      admin v6.3.5
      BackItUp:
      LG Gerhard
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @maximinus sagte in backitup Fehlermeldung:
      bitte die Ausgabe von
      iob diag
      hier reinstellen - in Codetags
      Lehrling seit 1975 !!!
      • M maximinus
        backitup v2.6.19
        admin v6.3.5
        BackItUp:
        LG Gerhard
        Moin,
        zusätzlich, zu den angeforderten Informationen von @DJMarc75, ist es ja auch interessant zu wissen, was Du alles nutzt.
        Also, zusätzlich zu ioBroker, nutzt Du noch
        • Grafana ← Das ist ja auch der Störenfried
        • influxDB
        • und läuft alles auf demselben System?
        • wie hast Du die 3rd Party Produkten installiert?
        • Wie ist BackitUp eingerichtet, am besten von den Einstellungen Screenshots hier zeigen?
        Du kannst Dich aber ganz normal an Grafana anmelden? Kannst Du Dich mal durch diesen Thread arbeiten https://forum.iobroker.net/topic/65972/backitup-influxdb2-grafana/34 und schauen, ob da etwas nützliches drin steht?
        VG
        Bernd
        • DJMarc75D DJMarc75
          iob diag
          maximinus
          @djmarc75
          Irgend etwas mache ich da wohl falsch. iob diag bringt mir die gkleich eAnzeige wie iob --help
          War das gemeint?
          pi@raspberrypi:~ $ iob diag
          iobroker [command]
          Commands:
            iobroker setup                                               Setup ioBroker
            iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
            iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
            iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
            iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
            iobroker info                                                Shows the host info
            iobroker logs [<adapter>]                                    Monitor log
            iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
            iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
            iobroker rebuild [<module>]                                  Rebuild all native modules or path
            iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
            iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
            iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
            iobroker update [<repositoryUrl>]                            Update repository and list adapters
            iobroker upgrade                                             Upgrade management
            iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
            iobroker object                                              Object management  [aliases: o]
            iobroker state                                               State management  [aliases: s]
            iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
            iobroker list <type> [<filter>]                              List all entries, like objects
            iobroker chmod <mode> <file>                                 Change file rights
            iobroker chown <user> <group> <file>                         Change file ownership
            iobroker touch <file>                                        Touch file
            iobroker rm <file>                                           Remove file
            iobroker file                                                File management
            iobroker user                                                User commands
            iobroker group                                               group management
            iobroker host <hostname>                                     Set host to given hostname
            iobroker set <adapter>.<instance>                            Change settings of adapter config
            iobroker license <license.file or license.text>              Update license by given file
            iobroker cert                                                Certificate management
            iobroker clean <yes>                                         Clears all objects and states
            iobroker backup                                              Create backup
            iobroker restore <backup name or path>                       Restore a specified backup
            iobroker validate <backup name or path>                      Validate a specified backup
            iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
            iobroker repo [<name>]                                       Show repo information
            iobroker uuid                                                Show uuid of the installation  [aliases: id]
            iobroker unsetup                                             Reset license, installation secret and language
            iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
            iobroker multihost                                           Multihost management
            iobroker compact                                             compact group management
            iobroker plugin                                              Plugin management
            iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
          Options:
            --help  Show help  [boolean]
          nodejs v20.19.4
          npm 10.8.2
          Objects type: jsonl
          States type: redis
          admin: 7.6.17
          javascript: 8.9.2
          • M maximinus
            @djmarc75
            War das gemeint?
            iobroker [command]
            Commands:
            Options:
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            Nein, Deine Installation ist halt nicht neu genug für iob debug...
            iob stop
            iob fix
            iob start
            warten und dann
            iob diag
            und davon dann bitte die Langfassung hier in Codetags posten :)
              Moin,
              • influxDB
              VG
              Bernd
              maximinus
              @dp20eic
              Alles läuft am selben Raspi. ioBroker, influx und grafana laufen anstandslos und das seit vielen Monaten. Nur die Datensicherung macht Probleme.backitup Einstellungen.png
              nodejs v20.19.4
              npm 10.8.2
              Objects type: jsonl
              States type: redis
              admin: 7.6.17
              javascript: 8.9.2
              ? 1 Antwort Letzte Antwort
                iob stop
                iob fix
                iob start
                warten und dann
                iob diag
                maximinus
                @djmarc75
                Bin beeindruckt was da alles geht. Danke.
                Hoffentlich hilft das weiter
                ======== Start marking the full check here =========
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Model           : Raspberry Pi 4 Model B Rev 1.1
                Architecture    : armv7l
                Docker          : false
                Virtualization  : none
                Distributor ID: Raspbian
                Description:    Raspbian GNU/Linux 11 (bullseye)
                Release:        11
                Codename:       bullseye
                PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                NAME="Raspbian GNU/Linux"
                VERSION_ID="11"
                VERSION="11 (bullseye)"
                VERSION_CODENAME=bullseye
                ID=raspbian
                ID_LIKE=debian
                HOME_URL="http://www.raspbian.org/"
                SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                Systemuptime and Load:
                 14:59:18 up 51 days, 47 min,  2 users,  load average: 2.22, 1.16, 0.68
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                Other values than 0x0 hint to temperature/voltage problems
                temp=49.1'C
                volt=0.8375V
                *** Time and Time Zones ***
                               Local time: Wed 2023-06-14 14:59:18 CEST
                           Universal time: Wed 2023-06-14 12:59:18 UTC
                                 RTC time: n/a
                                Time zone: Europe/Vienna (CEST, +0200)
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            3.8G        1.1G        1.5G        0.0K        1.3G        3.0G
                Swap:            99M         29M         70M
                Total:          3.9G        1.1G        1.6G
                         3837 M total memory
                         1061 M used memory
                          921 M active memory
                         1201 M inactive memory
                         1500 M free memory
                          256 M buffer memory
                         1019 M swap cache
                           99 M total swap
                           29 M used swap
                           70 M free swap
                Raspberry only:
                oom events: 0
                lifetime oom required: 0 Mbytes
                total time in oom handler: 0 ms
                max time spent in oom handler: 0 ms
                *** FILESYSTEM ***
                /dev/root      ext4      117G   21G   91G  19% /
                devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                tmpfs          tmpfs     768M  1.3M  767M   1% /run
                /dev/sda1      vfat      253M   50M  203M  20% /boot
                tmpfs          tmpfs     384M   16K  384M   1% /run/user/1000
                [Mon Apr 24 14:11:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:64:1F:3C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=bcf4838c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Mon Apr 24 14:11:31 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                [Mon Apr 24 14:11:31 2023] EXT4-fs (sda2): write access will be enabled during recovery
                [Mon Apr 24 14:11:32 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
                [Mon Apr 24 14:11:32 2023] EXT4-fs (sda2): 1 orphan inode deleted
                [Mon Apr 24 14:11:32 2023] EXT4-fs (sda2): recovery complete
                [Mon Apr 24 14:11:32 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Mon Apr 24 14:11:32 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                [Mon Apr 24 14:11:35 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
                Show mounted filesystems (real ones only):
                TARGET  SOURCE    FSTYPE OPTIONS
                /       /dev/sda2 ext4   rw,noatime
                `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                /var:
                5.7G    /var/
                4.8G    /var/log
                3.8G    /var/log/journal/576f358b250c4617b98a23b9a999219a
                638M    /var/lib
                Archived and active journals take up 3.7G in the file system.
                /opt/iobroker/backups:
                9.6G    /opt/iobroker/backups/
                4.0K    /opt/iobroker/backups/scripte
                /opt/iobroker/iobroker-data:
                347M    /opt/iobroker/iobroker-data/
                272M    /opt/iobroker/iobroker-data/files
                62M     /opt/iobroker/iobroker-data/backup-objects
                51M     /opt/iobroker/iobroker-data/files/javascript.admin
                37M     /opt/iobroker/iobroker-data/files/material
                27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
                21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.2e59ed19.chunk.js.map
                11M     /opt/iobroker/iobroker-data/objects.jsonl
                9.3M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.2d545efe.chunk.js.map
                9.1M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.a2360eda.chunk.js.map
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v16.17.0
                /usr/bin/node           v16.17.0
                /usr/bin/npm            8.15.0
                /usr/bin/npx            8.15.0
                nodejs:
                  Installed: 16.17.0-deb-1nodesource1
                  Candidate: 16.20.0-deb-1nodesource1
                  Version table:
                     16.20.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                 *** 16.17.0-deb-1nodesource1 100
                        100 /var/lib/dpkg/status
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                No problems detected
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: redis
                MULTIHOSTSERVICE/enabled: false
                Core adapters versions
                js-controller:  4.0.24
                admin:          6.3.5
                javascript:     6.1.4
                Adapters from github:   2
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                  system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
                  system.adapter.awattar.0                : awattar               : raspberrypi                              -  enabled
                + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                  system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                  system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                  system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
                  system.adapter.email.0                  : email                 : raspberrypi                              - disabled
                + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                + system.adapter.evcc.1                   : evcc                  : raspberrypi                              -  enabled, port: 7070
                  system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                  system.adapter.habpanel.0               : habpanel              : raspberrypi                              -  enabled
                  system.adapter.history.0                : history               : raspberrypi                              - disabled
                + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                  system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                  system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
                  system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              - disabled
                  system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled
                + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                  system.adapter.material.0               : material              : raspberrypi                              - disabled
                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                  system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
                  system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                  system.adapter.pushover.0               : pushover              : raspberrypi                              - disabled
                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1500, bind: 0.0.0.0
                + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                  system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                  system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                + instance is alive
                ioBroker-Repositories
                live-stable   : http://iobroker.live/repo/sources-dist.json
                live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.3.5    , installed 6.3.5
                Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                Adapter    "awattar"      : 1.0.6    , installed 1.0.6
                Adapter    "backitup"     : 2.6.19   , installed 2.6.19
                Adapter    "denon"        : 1.15.0   , installed 1.15.0
                Adapter    "devices"      : 1.1.2    , installed 1.0.10 [Updatable]
                Adapter    "discovery"    : 3.1.0    , installed 3.0.3  [Updatable]
                Adapter    "echarts"      : 1.0.12   , installed 1.0.7  [Updatable]
                Adapter    "email"        : 1.1.4    , installed 1.0.10 [Updatable]
                Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
                Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                Adapter    "history"      : 2.2.4    , installed 1.11.1 [Updatable]
                Adapter    "influxdb"     : 3.2.0    , installed 2.6.3  [Updatable]
                Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
                Adapter    "iot"          : 1.14.2   , installed 1.11.4 [Updatable]
                Adapter    "iqontrol"     : 2.1.0    , installed 2.0.0  [Updatable]
                Adapter    "jarvis"       : 3.1.2    , installed 3.0.11 [Updatable]
                Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                Controller "js-controller": 4.0.24   , installed 4.0.24
                Adapter    "material"     : 1.1.2    , installed 1.1.2
                Adapter    "mqtt"         : 4.0.7    , installed 2.7.4  [Updatable]
                Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                Adapter    "node-red"     : 4.0.0    , installed 3.3.0  [Updatable]
                Adapter    "openhab"      : 1.1.0    , installed 1.1.0
                Adapter    "ping"         : 1.5.3    , installed 1.5.3
                Adapter    "pushover"     : 3.0.3    , installed 2.1.0  [Updatable]
                Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
                Adapter    "smart-eq"     : 0.0.4    , installed 0.0.4
                Adapter    "socketio"     : 4.2.0    , installed 4.2.0
                Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                Adapter    "telegram"     : 1.15.2   , installed 1.13.0 [Updatable]
                Adapter    "text2command" : 2.3.0    , installed 2.2.1  [Updatable]
                Adapter    "tr-064"       : 4.2.18   , installed 4.2.16 [Updatable]
                Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
                Adapter    "vis-hqwidgets": 1.3.0    , installed 1.2.0  [Updatable]
                Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
                Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                Adapter    "web"          : 4.3.0    , installed 4.3.0
                Adapter    "ws"           : 1.3.0    , installed 1.3.0
                Objects and States
                Objects:        5007
                States:         4233
                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                W: Some index files failed to download. They have been ignored, or old ones used instead.
                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Get:3 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
                Get:4 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
                Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                Err:3 https://packages.grafana.com/oss/deb stable InRelease
                Err:4 https://repos.influxdata.com/debian bullseye InRelease
                Fetched 7040 B in 1s (5422 B/s)
                Reading package lists...
                Pending Updates: 218
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14465      585/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      115        14482      558/redis-server 12
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          60731337   6200/cupsd
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14508      560/influxd
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       61507536   27829/io.mqtt.0
                tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       61507537   27829/io.mqtt.0
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       61507072   27714/iobroker.js-c
                tcp        0      0 0.0.0.0:1500            0.0.0.0:*               LISTEN      1001       61509312   27879/io.sonoff.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          14467      585/sshd: /usr/sbin
                tcp6       0      0 ::1:6379                :::*                    LISTEN      115        14483      558/redis-server 12
                tcp6       0      0 :::3000                 :::*                    LISTEN      116        15467      545/grafana-server
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          60731336   6200/cupsd
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       61508812   27732/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       61510263   28144/io.web.0
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        16490      560/influxd
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12186      511/dhcpcd
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          60733002   6201/cups-browsed
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12768      424/avahi-daemon: r
                udp        0      0 0.0.0.0:43002           0.0.0.0:*                           108        12770      424/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        12769      424/avahi-daemon: r
                udp6       0      0 :::53527                :::*                                108        12771      424/avahi-daemon: r
                2023-06-14 15:00:30.030  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: EntlLadeleistungSum = 00
                2023-06-14 15:00:30.030  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: BattZustand W =  480.6
                2023-06-14 15:00:30.031  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: LadestromSum =   9
                2023-06-14 15:00:30.031  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: EntladestromSum =   00
                2023-06-14 15:00:30.032  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: Batteriestrom =  9
                2023-06-14 15:00:30.032  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: PV Summe =   2225 PV 1 =   01289 PV 2 =    00936
                2023-06-14 15:00:30.032  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: SumWirk =   1762 Wirk1 =   0946 Wirk2 =    0816
                2023-06-14 15:00:30.033  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: BezugSum =   -463
                2023-06-14 15:00:30.041  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: BilanzEnergie = BezugSum + Batt_Zustand =    17.6
                2023-06-14 15:00:30.092  - info: javascript.0 (27784) script.js.common.Überschusssteuerung.03a_PVOptimierung_aus: PV Optimierung ein weil Batterisstrom =  9
                2023-06-14 15:00:30.096  - info: javascript.0 (27784) script.js.common.Überschusssteuerung.03bReglerAufBatteriestrom:  sonst: Batteriestrom = 9ReglerAuf =  true
                2023-06-14 15:00:30.097  - warn: javascript.0 (27784) getState "smart-eq.0.info.connection" not found (3)
                2023-06-14 15:00:30.099  - warn: javascript.0 (27784)     at Object.<anonymous> (script.js.common.SmartSolLadung:5:51)
                2023-06-14 15:00:30.100  - warn: javascript.0 (27784)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                2023-06-14 15:00:30.100  - warn: javascript.0 (27784)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                2023-06-14 15:00:30.101  - warn: javascript.0 (27784)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                2023-06-14 15:00:30.101  - warn: javascript.0 (27784)     at processImmediate (node:internal/timers:466:21)
                2023-06-14 15:00:30.101  - warn: javascript.0 (27784) getState "smart-eq.0.info.connection" not found (3)
                2023-06-14 15:00:30.103  - warn: javascript.0 (27784)     at Object.<anonymous> (script.js.common.SmartSolLadung:8:14)
                2023-06-14 15:00:30.104  - warn: javascript.0 (27784)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                2023-06-14 15:00:30.104  - warn: javascript.0 (27784)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                2023-06-14 15:00:30.104  - warn: javascript.0 (27784)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                2023-06-14 15:00:30.104  - warn: javascript.0 (27784)     at processImmediate (node:internal/timers:466:21)
                2023-06-14 15:00:30.153  - info: javascript.0 (27784) script.js.common.Hauptzähler.Tagesverbrauch: Tagesverbrauch ist 2.3659999999945285
                37020893
                nodejs v20.19.4
                npm 10.8.2
                Objects type: jsonl
                States type: redis
                admin: 7.6.17
                javascript: 8.9.2
                DJMarc75D M 2 Antworten Letzte Antwort
                • M maximinus
                  @djmarc75
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=raspbian
                  ID_LIKE=debian
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=49.1'C
                  volt=0.8375V
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M         29M         70M
                           3837 M total memory
                           1061 M used memory
                            921 M active memory
                           1500 M free memory
                            256 M buffer memory
                           1019 M swap cache
                             99 M total swap
                             29 M used swap
                             70 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  5.7G    /var/
                  4.8G    /var/log
                  638M    /var/lib
                  /usr/bin/npm            8.15.0
                  /usr/bin/npx            8.15.0
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: redis
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        5007
                  States:         4233
                  37020893
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Erst wenn Du das alles bitte in Codetags packst ;)
                  • M maximinus
                    @djmarc75
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=raspbian
                    ID_LIKE=debian
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=49.1'C
                    volt=0.8375V
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M         29M         70M
                             3837 M total memory
                             1061 M used memory
                              921 M active memory
                             1500 M free memory
                              256 M buffer memory
                             1019 M swap cache
                               99 M total swap
                               29 M used swap
                               70 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    5.7G    /var/
                    4.8G    /var/log
                    638M    /var/lib
                    /usr/bin/npm            8.15.0
                    /usr/bin/npx            8.15.0
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: redis
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        5007
                    States:         4233
                    37020893
                    maximinus
                    Mit Firefox ging da gar nichts (Error )
                    Mit chrome schaut es nicht viel besser aus.
                    nodejs v20.19.4
                    npm 10.8.2
                    Objects type: jsonl
                    States type: redis
                    admin: 7.6.17
                    javascript: 8.9.2
                    • M maximinus
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      Dann machst Du was falsch... keine Ahnung... Text kopieren, hier einfügen und das hat schon jeder geschaft.
                      • M maximinus
                        maximinus
                        Es geht nicht
                        Der browser zerteilt das bei copy paste , vielleicht zu groß
                        nodejs v20.19.4
                        npm 10.8.2
                        Objects type: jsonl
                        States type: redis
                        admin: 7.6.17
                        javascript: 8.9.2
                        M Thomas BraunT 2 Antworten Letzte Antwort
                        • M maximinus
                          Es geht nicht
                          maximinus
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=raspbian
                          ID_LIKE=debian
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=49.1'C
                          volt=0.8375V
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M         29M         70M
                                   3837 M total memory
                                   1061 M used memory
                                    921 M active memory
                                   1500 M free memory
                                    256 M buffer memory
                                   1019 M swap cache
                                     99 M total swap
                                     29 M used swap
                                     70 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          5.7G    /var/
                          4.8G    /var/log
                          638M    /var/lib
                          /usr/bin/npm            8.15.0
                          /usr/bin/npx            8.15.0
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: redis
                          admin:          6.3.5
                          javascript:     6.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        5007
                          States:         4233
                          37020893
                          Im notepad++ ist es noch komplett aber hier wird es zerteilt.
                          nodejs v20.19.4
                          npm 10.8.2
                          Objects type: jsonl
                          States type: redis
                          admin: 7.6.17
                          javascript: 8.9.2
                          • M maximinus
                            Es geht nicht
                            Nein, das passt alles.
                            Dein Dateisystem hat 'nen Treffer erlitten, dann sind deine Paketquellen für grafana und influxdb nicht aktuell und müssen angepackt werden und dann hängen da noch drölftrilliarden ioBroker-Adapter-Updates in der Luft.
                            Und die noch offenen Updates des Betriebssystems kann ich fast gar nicht zählen.
                            • M maximinus
                              @dp20eic
                              Moin,
                              So der erste Screenshot hat ja schon mal geklappt, aber gerade der zweite, von den Einstellungen zu Grafana nicht ;)
                              Schau noch mal in meinen Post, da siehst Du einen zweiten Screenshot und da sollte bei Dir dann etwas Sinnvolles drin stehen, bei meinem nicht, denn ich nutze das nicht und habe den Adapter nur mal zu Doku Zwecken installiert.
                              VG
                              Bernd
                                Moin,
                                VG
                                Bernd
                                maximinus
                                @dp20eic
                                Das ist die 2.Seite. Den api Key habe ich nochmals eingetragen und Grafana funktioniert immer noch. Ich werde zur Sicherheit nochmals ein manuelles Backup machen. Vielleicht hat sich seit iob fix etwas geändert.
                                nodejs v20.19.4
                                npm 10.8.2
                                Objects type: jsonl
                                States type: redis
                                admin: 7.6.17
                                javascript: 8.9.2
                                • M maximinus
                                  @dp20eic
                                  maximinus
                                  Update
                                  Die manuelle Sicherung ist durchgelaufen:
                                  und hat jetzt diese beiden Fehlermeldungen gebracht:
                                  [ERROR] [grafana] - cannot found Grafana Backup files
                                  nodejs v20.19.4
                                  npm 10.8.2
                                  Objects type: jsonl
                                  States type: redis
                                  admin: 7.6.17
                                  javascript: 8.9.2
                                    maximinus
                                    "Never touch a running system" aber vielleicht ist das falsch.
                                    Zum Thema update hatte ich mir folgendes notiert.
                                    sudo apt-get update
                                    sudo apt-get upgrade
                                    sudo apt-get --allow-releaseinfo-change update
                                    Ja bestätigen
                                    --->>> lange warten
                                    sudo iobroker stop
                                    npm -v
                                    falls der js-controller als updateable angezeigt wird : iobroker stop iobroker upgrade self iobroker start
                                    sudo iobroker upgrade -y
                                    npm -v
                                    node -v
                                    sudo iobroker start
                                    sudo iobroker stop && sudo apt update && apt upgrade -y && sudo iobroker update && iobroker upgrade -y && sudo iobroker update && iobroker upgrade self | curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add - && sudo sh -c "echo deb https://deb.nodesource.com/node_12.x main \> /etc/apt/sources.list.d/nodesource.list" && sudo apt-get update && sudo apt-get install nodejs -y && iobroker start
                                    Ist das so noch OK?
                                    nodejs v20.19.4
                                    npm 10.8.2
                                    Objects type: jsonl
                                    States type: redis
                                    admin: 7.6.17
                                    javascript: 8.9.2
                                    • M maximinus
                                      Update
                                      Moin,
                                      das Bild zeigt nur die Sicherungen der influxDB, im Verzeichnis sollten eigentlich auch Dateien liegen, die Grafana im Namen haben.
                                      Zu den Log File Eintragungen
                                      • BackitUp versucht zuerst ältere Dateien zu löschen, wenn im Verzeichnis keine da sind, dann kommt wohl diese Meldung, warum als ERROR keine Ahnung
                                      • Was dann die some errors sind kann ich nicht sagen.
                                      Kannst Du den BackitUp Adapter mal auf Debug stellen
                                      VG
                                      Bernd
                                      P.S.: Ich habe das gerade mal bei mir gemacht, das ist das Log
                                      Started iobroker ...
                                      [DEBUG] [iobroker] - host.arch-iob 6357 states saved
                                      [DEBUG] [iobroker] - host.arch-iob 7276 objects saved
                                      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_06_14-17_19_42_backupiobroker.tar.gz
                                      [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
                                      [DEBUG] [iobroker] - done
                                      [DEBUG] [grafana] - Start Grafana Backup ...
                                      [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                      [DEBUG] [grafana] - Created dashboard directory
                                      [DEBUG] [grafana] - Created dashboards_manually_restore directory
                                      [DEBUG] [grafana] - Created datasource directory
                                      [DEBUG] [grafana] - start Grafana request ...
                                      [DEBUG] [grafana] - Grafana is available ... Status: 200
                                      [ERROR] [grafana] - Error on Grafana Datasource Request
                                      [DEBUG] [grafana] - found Dashboard: ubersichten-raumklima
                                      [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-kaffeevollautomat
                                      [DEBUG] [grafana] - found Dashboard: iobroker
                                      [DEBUG] [grafana] - found Dashboard: zigbee-listen
                                      [DEBUG] [grafana] - found Dashboard: logging-dashboard-via-loki
                                      [DEBUG] [grafana] - found Dashboard: dashboards_by_dp20eic
                                      [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-gefrierschrank-new-alias
                                      [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-geschirrspuler-new-alias
                                      [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-waschmaschine-new-alias
                                      [DEBUG] [grafana] - found Dashboard: internet-speed-test
                                      [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-waschetrokner-new-alias
                                      [DEBUG] [grafana] - found Dashboard: spritpreise
                                      [DEBUG] [grafana] - found Dashboard: logs-app
                                      [DEBUG] [grafana] - found Dashboard: panel-library
                                      [DEBUG] [grafana] - found Dashboard: linux-host-overview
                                      [DEBUG] [grafana] - found Dashboard: loki-logs
                                      [DEBUG] [grafana] - found Dashboard: proxmox-server
                                      [DEBUG] [grafana] - found Dashboard: fritz-box-call-logs
                                      [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-garage-werkstatt-new-alias
                                      [DEBUG] [grafana] - found Dashboard: lokiforlogs
                                      [DEBUG] [grafana] - found Dashboard: test4forum
                                      [DEBUG] [grafana] - found Dashboard: proxmox-flux
                                      [DEBUG] [grafana] - found Dashboard: exchange-euro-thb
                                      [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-entertainment-new-alias
                                      [DEBUG] [grafana] - found Dashboard: openweathermap
                                      [DEBUG] [grafana] - found Dashboard: fritz-box-router-status
                                      [DEBUG] [grafana] - found Dashboard: syslog
                                      [DEBUG] [grafana] - found Dashboard: blutdruck
                                      [DEBUG] [grafana] - found Dashboard: synology
                                      [DEBUG] [grafana] - found Dashboard: temperaturubersicht-am-heizungkorper
                                      [DEBUG] [grafana] - found Dashboard: fritz-box-home-automation
                                      [DEBUG] [grafana] - found Dashboard: synology-dashboard-new
                                      [DEBUG] [grafana] - found Dashboard: loki-syslog-aio-all-in-one
                                      [DEBUG] [grafana] - found Dashboard: connection-over-time
                                      [DEBUG] [grafana] - found Dashboard: linux-rechner
                                      [DEBUG] [grafana] - found Dashboard: fritz-box-router-logs
                                      [DEBUG] [grafana] - found Dashboard: synology-metrics
                                      [DEBUG] [grafana] - found Dashboard: connection-over-time-copy
                                      [DEBUG] [grafana] - found Dashboard: aktuelle-e10-benzinpreise
                                      [DEBUG] [grafana] - found Dashboard: synology_dashboard
                                      [DEBUG] [grafana] - start Grafana backup compress ...
                                      [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                      [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                                      [DEBUG] [grafana] - done
                                      [DEBUG] [clean] - done
                                      [DEBUG] [historyHTML] - new history html values created
                                      [DEBUG] [historyHTML] - done
                                      [DEBUG] [historyJSON] - new history json values created
                                      [DEBUG] [historyJSON] - done
                                      [EXIT] 0
                                      P.P.S: also bei mir wird auch kein Backup erstellt, ich hab mal das Verzeichnis überwacht, schon das Anlegen des grafana_tmp Verzeichnis geschieht nicht, wenn ich es von Hand anlege wird es gelöscht aber nicht erstellt.
                                      Ich schaue mir das morgen noch mal an.
                                        Moin,
                                        VG
                                        Bernd
                                        [EXIT] 0
                                        maximinus
                                        @dp20eic
                                        Die anderen Sicherungen habbe ich nicht gezeigt, sind aber alle da.alle Sicherungen.png
                                        Adapter ist auf debug gestellt aber meiner ist in der Adapterliste auf v2.6.19, wo ist die v2.6.23 her?
                                        Und jetzt nochmals sichern?
                                        nodejs v20.19.4
                                        npm 10.8.2
                                        Objects type: jsonl
                                        States type: redis
                                        admin: 7.6.17
                                        javascript: 8.9.2
                                          Moin,
                                          VG
                                          Bernd
                                          [EXIT] 0
                                          maximinus
                                          @dp20eic
                                          das scheint also normal zu sein?
                                          Ich warte einmal ab welche Nachricht ich vom nächtlichen Backup morgen bekomme.
                                          Danke für die schnelle Hilfe
                                          nodejs v20.19.4
                                          npm 10.8.2
                                          Objects type: jsonl
                                          States type: redis
                                          admin: 7.6.17
                                          javascript: 8.9.2
