  3. Einsteigerfragen
  4. Tuya Zigbee Warung
    5.4k
Tuya Zigbee Warung
10 Beiträge 5 Kommentatoren 1.5k Aufrufe 5 Beobachtet
  • Stefan KaupelS Offline
    Stefan Kaupel
    schrieb am zuletzt editiert von Stefan Kaupel
    Guten morgen,
    ich habe im Logg immer folgende Warnung:
    tuya.1
    2023-05-26 08:56:25.990	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:56:20.234	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:56:15.329	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:56:15.328	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:55:25.988	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:55:20.234	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:55:10.277	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:55:10.276	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:54:24.295	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:54:16.695	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:54:05.221	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:54:05.220	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:53:20.984	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:53:15.230	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:53:00.150	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:53:00.149	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:52:19.293	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:52:11.692	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:51:55.093	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:51:55.093	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:51:15.982	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:51:10.227	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:50:50.029	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:50:50.028	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:50:14.289	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:50:06.688	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:49:44.972	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:49:44.972	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:49:10.978	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:49:05.222	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:48:39.913	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:48:39.912	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:48:09.287	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:48:01.684	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:47:34.849	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:47:34.848	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:47:05.977	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:47:00.221	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:46:29.788	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:46:29.788	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:46:04.284	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:45:56.681	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:45:24.729	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:45:24.728	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:45:04.283	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:44:56.681	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:44:19.668	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:44:19.668	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:44:04.074	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:43:55.974	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:43:14.625	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:43:14.624	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:43:04.072	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:42:55.973	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:42:09.569	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:42:09.568	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:42:04.072	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:41:55.971	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:41:04.504	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:41:04.504	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:41:02.986	warn	bf4a533ab6a774458czwnq error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:40:54.629	warn	bfe68640991a25be52veah error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:40:04.444	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:40:04.444	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:39:59.069	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:39:50.968	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:38:59.377	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:38:59.376	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:38:57.984	warn	bf4a533ab6a774458czwnq error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:38:49.628	warn	bfe68640991a25be52veah error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:37:59.325	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:37:59.324	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:37:54.066	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:37:45.964	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:36:54.272	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:36:54.272	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:36:52.982	warn	bf4a533ab6a774458czwnq error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:36:44.624	warn	bfe68640991a25be52veah error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:35:54.213	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:35:54.212	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:35:49.063	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:35:44.622	warn	bfe68640991a25be52veah error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:35:40.961	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:34:47.977	warn	bf4a533ab6a774458czwnq error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:34:44.621	warn	bfe68640991a25be52veah error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:33:47.977	warn	bf4a533ab6a774458czwnq error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:33:44.061	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:33:29.073	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
    tuya.1
    2023-05-26 08:33:29.072	info	bf94604840f71479d7tuuq: Connect locally to device
    tuya.1
    2023-05-26 08:32:45.758	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    tuya.1
    2023-05-26 08:32:44.059	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
    Es handelt sich hierbei um die Tuya Zigbee Geräte inkl. Gateway. Kann mir jemand was dazu sagen?
    Gruß Stefan
    arteckA K 2 Antworten Letzte Antwort
    • Stefan KaupelS Stefan Kaupel
      Guten morgen,
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      tuya.1
      Gruß Stefan
      arteckA Offline
      arteckA Offline
      arteck
      @stefan-kaupel so und jetzt nochmal aber richtig
      LOGS im Tag einpacken
        Guten morgen,
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        tuya.1
        Gruß Stefan
        kimukao
        schrieb am zuletzt editiert von kimukao
        @stefan-kaupel same here... Hast Du das Problem zwischenzeitlich lösen können?
        tuya.0
        2023-06-05 13:31:55.619	warn	bf98506c8e6089f6c9ayje error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
        tuya.0
        2023-06-05 13:30:55.575	warn	bfae48d545cf9d2929sbl4 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
        • arteckA Offline
          arteckA Offline
          arteck
          da antwortet was nicht.. ist vielleicht ein WLAN Signal der es überlagert in der nähe?
          W 1 Antwort Letzte Antwort
          • arteckA arteck
            W Offline
            W Offline
            warp-it
            Ich habe alle 2 Minuten die gleiche Warnung für zwei Sensoren (Erschütterung und T&H-Sensor), wobei eigentlich alles zu funktionieren scheint. Da kommt doch folgender Verdacht auf, obwohl der dazugehörige Haken nicht gesetzt ist. ?!
            arteckA ? 2 Antworten Letzte Antwort
            • W warp-it
              arteckA Offline
              arteckA Offline
              arteck
              @warp-it was hat der tuya adapter mit dem zigbee zu tun ..genau .. NIX
              • arteckA arteck
                W Offline
                W Offline
                warp-it
                @arteck said in Tuya Zigbee Warung:
                Sorry, deine Antwort verstehe ich nicht.
                • W warp-it
                  @warp-it
                  ja, der Fehler ist bekannt, gibt ein issue dazu - der Tuya-Adapter bekommt die Commands, waehrend einer noch aktiv ist, liegt wohl am delay der Cloud.. bei lokalen Devices ist das nicht.. zumindest hier..
                  @arteck
                  doch, Tuya-Adapter, Tuya-Devices, hat nix mit Zigbee zu tun, diesmal.. ( nur im Thread-Titel so benannt, warum weiss nur der @Stefan-Kaupel ..)
                  W 2 Antworten Letzte Antwort
                    @warp-it
                    @arteck
                    W Offline
                    W Offline
                    warp-it
                    @arteck
                    Wenn man nach dem beschriebenen Fehler sucht, landet man hier. Der Titel des Threads ist falsch.
                      @warp-it
                      @arteck
                      W Offline
                      W Offline
                      warp-it
                      @ilovegym
                      Danke für die Info.
