  3. Off Topic
  4. InfluxDB
    1.0k
    6.1k
InfluxDB
10 Beiträge 2 Kommentatoren 874 Aufrufe 1 Beobachtet
  • ostseereiterO Offline
    ostseereiter
    schrieb am zuletzt editiert von ostseereiter
    Hallo Freunde ich möchte InfluxDB installieren das hat auch geklappt aber nun wenn ich influx setup eingebe kommt folgendes:
    unknown arguments: setup
    Usage of influx:
      -version
                            Display the version and exit.
      -path-prefix 'url path'
                            Path that follows the host and port
      -host 'host name'
                            Host to connect to.
      -port 'port #'
                            Port to connect to.
      -socket 'unix domain socket'
                            Unix socket to connect to.
      -database 'database name'
                            Database to connect to the server.
      -password 'password'
                            Password to connect to the server.  Leaving blank will prompt for password (--password '').
      -username 'username'
                            Username to connect to the server.
      -ssl
                            Use https for requests.
      -unsafeSsl
                            Set this when connecting to the cluster using https and not use SSL verification.
      -execute 'command'
                            Execute command and quit.
      -type 'influxql|flux'
                            Type specifies the query language for executing commands or when invoking the REPL.
      -format 'json|csv|column'
                            Format specifies the format of the server responses:  json, csv, or column.
      -precision 'rfc3339|h|m|s|ms|u|ns'
                            Precision specifies the format of the timestamp:  rfc3339, h, m, s, ms, u or ns.
      -consistency 'any|one|quorum|all'
                            Set write consistency level: any, one, quorum, or all
      -pretty
                            Turns on pretty print for the json format.
      -import
                            Import a previous database export from file
      -pps
                            How many points per second the import will allow.  By default it is zero and will not throttle importing.
      -path
                            Path to file to import
      -compressed
                            Set to true if the import file is compressed
    Examples:
        # Use influx in a non-interactive mode to query the database "metrics" and pretty print json:
        $ influx -database 'metrics' -execute 'select * from cpu' -format 'json' -pretty
        # Connect to a specific database on startup and set database context:
        $ influx -database 'metrics' -host 'localhost' -port '8086'
    Kann also keine anmeldedaten engeben:
    Gruß OSR
    Plattform
    Linux x64 CPUs2 AMD G-T56N Processor 1646 MHz 8GB RAM
    ostseereiterO 1 Antwort Letzte Antwort
    • ostseereiterO ostseereiter
      Usage of influx:
        -version
        -host 'host name'
                              Host to connect to.
        -port 'port #'
                              Port to connect to.
        -ssl
        -unsafeSsl
        -execute 'command'
        -pretty
        -import
        -pps
        -path
        -compressed
      Examples:
      ostseereiter
      @ostseereiter ich habe die falsche Influxdatei instaliert. die 1.8 anstatt die 2.0
      Gruß OSR
      Plattform
        @ostseereiter sagte in (Kann erst mal auf Eis gelegt werden)InfluxDB:
        Dann installier die gewünschte Version.
        sudo apt update
        apt policy influxdb*
        sagt?
          sudo apt update
          sagt?
          ostseereiter
          @thomas-braun sagte in (Kann erst mal auf Eis gelegt werden)InfluxDB:
          sudo apt update
          andy@debianIOB:~$ sudo apt update
          E: Missgestalteter Eintrag 1 in list Datei /etc/apt/sources.list.d/influxdata.list (URI)
          E: Die Liste der Quellen konnte nicht gelesen werden.
          andy@debianIOB:~$
          Gruß OSR
          Plattform
            sudo apt update
            andy@debianIOB:~$
            @ostseereiter sagte in InfluxDB:
            Und was steht da so 'missgestaltetes' drin?
            cat /etc/apt/sources.list.d/influxdata.list
              ostseereiter
              Washabe ich gemacht:
              wget -q https://repos.influxdata.com/influxdata-archive_compat.key
              echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg]
               https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
              cat influxdata-archive_compat.key | gpg --dearmor |
               tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
              ab da geht es nicht mehr weiter.
              Gruß OSR
              Plattform
                @ostseereiter
                sudo rm /etc/apt/sources.list.d/influxdata.list
                echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                sudo apt update
                  @ostseereiter
                  sudo apt update
                  ostseereiter
                  danke das hat geklappt. alles super.
                  Gruß OSR
                  Plattform
                    @ostseereiter
                    Und
                    sudo apt update
                    sagt nun?
                      @ostseereiter
                      Und
                      sudo apt update
                      sagt nun?
                      ostseereiter
                       sudo apt update
                      [sudo] Passwort für andy:
                      OK:1 http://mirror.netcologne.de/debian bullseye InRelease
                      OK:2 http://mirror.netcologne.de/debian bullseye-updates InRelease
                      OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                      OK:4 https://repos.influxdata.com/debian stable InRelease
                      OK:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                      OK:6 https://apt.grafana.com stable InRelease
                      influxdb2-cli:
                        Installiert:           2.7.3-1
                        Installationskandidat: 2.7.3-1
                        Versionstabelle:
                       *** 2.7.3-1 500
                              500 https://repos.influxdata.com/debian stable/main amd64 Packages
                              100 /var/lib/dpkg/status
                           2.7.1-2 500
                           2.6.1 500
                           2.6.0 500
                           2.5.0 500
                           2.4.0 500
                           2.3.0 500
                      influxdb-client:
                        Installiert:           (keine)
                        Installationskandidat: 1.6.7~rc0-1+b5
                        Versionstabelle:
                           1.6.7~rc0-1+b5 500
                              500 http://mirror.netcologne.de/debian bullseye/main amd64 Packages
                      influxdb-dev:
                        Installationskandidat: (keine)
                        Versionstabelle:
                      influxdb2-client:
                        Installationskandidat: 2.7.1-1
                        Versionstabelle:
                           2.7.1-1 500
                      influxdb:
                        Installationskandidat: 1.8.10-1
                        Versionstabelle:
                           1.8.10-1 500
                           1.6.7~rc0-1+b5 500
                      influxdb2:
                        Installiert:           2.7.1-1
                        Versionstabelle:
                       *** 2.7.1-1 500
                           2.7.0-1 500
                           2.6.1-1 500
                           2.6.0-1 500
                           2.5.1-1 500
                           2.4.0-1 500
                           2.3.0-1 500
                           2.2.0 500
                      Gruß OSR
                      Plattform
