  4. Update von node 4.x auf 6.x auf dem pi3
    5.7k
4 Beiträge 2 Kommentatoren 1.0k Aufrufe
  • arteckA Offline
    arteckA Offline
    arteck
    könnte es bitte einer verifizieren
    nach dem Update bekomme ich komische Meldung.. konnte soeben auf js-controller1.0.3 nicht wechseln muss diesen neu installieren
    ../src/validation.cc:112:62: note: candidates are:
    In file included from ../src/validation.cc:8:0:
    /root/.node-gyp/6.11.0/include/node/node.h:246:13: note: void node::NODE_SET_METHOD(v8::Local<v8::template>, const char*, v8::FunctionCallback)
     inline void NODE_SET_METHOD(v8::Local <v8::template>recv,
    /root/.node-gyp/6.11.0/include/node/node.h:259:13: note: void node::NODE_SET_METHOD(v8::Local<v8::object>, const char*, v8::FunctionCallback)
     inline void NODE_SET_METHOD(v8::Local <v8::object>recv,
    validation.target.mk:94: recipe for target 'Release/obj.target/validation/src/validation.o' failed
    make: *** [Release/obj.target/validation/src/validation.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/utf-8-validate/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack     at emitTwo (events.js:106:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
    gyp ERR! System Linux 4.9.24-v7+
    gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
    gyp ERR! node -v v6.11.0
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    > iobroker.js-controller@1.1.0 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first</v8::object></v8::object></v8::template></v8::template>
    darüberhinaus zerhaut es mir die Ordnerstruktur im node_modules Ordner
    • apollon77A Offline
      Was meinst Du mit "es zerhaut mit die node_modules ordnerstruktur"?
      In node 6 ist einiges anders. Module werden im Normalfall in node_modules direkt installiert und dann wiederverwendet. De landen daher nicht mehr unbedingt in den Unterverzeichnissen. Das ist ok so.
      • arteckA Offline
        arteckA Offline
        arteck
        hab gestern nur das Update gemacht.. und siehe Screenshot mir ist aufgefallen wie du sagst dass alles in einem Ordner installiert wird…
        sonst sah der iobroker node_modules ordner relativ aufgeräumt aus..
        es waren nur die iobroker.xxxxx modules drin..
        wenn das so sein soll dass alles in einem Ordner landet.. nicht schön aber gut..
          Jupp, da ist seit npm 3.x so glaub ich und das kam erstmals standardmäßig mit Node 6 mit. Früher hatte man pot sehr oft die gleichen files in den Verschiedenen Verzeichnissen liegen. Jetzt nur einmal - oder nur dann mehrfach wenn wirklich hart Verschiedenen Versionen gefördert werden.
