  3. Off Topic
  4. [gelöst]JavaScript Adapter bleibt rot
    6.1k
javascript.0
9 Beiträge 3 Kommentatoren 1.0k Aufrufe 2 Beobachtet
  • heinhanH Offline
    heinhanH Offline
    heinhan
    schrieb am zuletzt editiert von heinhan
    Hallo, nach dem ich meinen Raspi neu starten musste (Stromunterbrechung) bliebt der JavaScript Adapter rot. IOB fix brachte nix. Altes Backup eingespielt auch nicht. Hier die LOG:
    host.Iobroker
    2023-03-27 09:21:37.464	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.Iobroker
    2023-03-27 09:21:37.464	error	Caught by controller[0]: Node.js v18.15.0
    host.Iobroker
    2023-03-27 09:21:37.464	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
    host.Iobroker
    2023-03-27 09:21:37.464	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    host.Iobroker
    2023-03-27 09:21:37.464	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12)
    host.Iobroker
    2023-03-27 09:21:37.464	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
    host.Iobroker
    2023-03-27 09:21:37.463	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
    host.Iobroker
    2023-03-27 09:21:37.463	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1218:27)
    host.Iobroker
    2023-03-27 09:21:37.463	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1176:20)
    host.Iobroker
    2023-03-27 09:21:37.463	error	Caught by controller[0]: at internalCompileFunction (node:internal/vm:73:18)
    host.Iobroker
    2023-03-27 09:21:37.463	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
    host.Iobroker
    2023-03-27 09:21:37.463	error	Caught by controller[0]: ���� � }
    host.Iobroker
    2023-03-27 09:21:37.462	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.javascript/main.js:2397
    System ist auf neusten Stand. Was kann ich noch machen?
    arteckA Thomas BraunT 2 Antworten Letzte Antwort
    • heinhanH heinhan
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      arteckA Offline
      arteckA Offline
      arteck
      @heinhan sagte in JavaScript Adapter bleibt rot:
      javascript
      welche Version ist installiert ?
      • heinhanH heinhan
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        host.Iobroker
        Schaut wie eine korrupte Datei aus.
        iob diag
        sagt? Adapter neuinstallieren und hoffen das die defekte Speicherzelle da nicht wieder reinspuckt.
        heinhanH 1 Antwort Letzte Antwort
          host.Iobroker
          iob diag
          heinhanH Offline
          heinhanH Offline
          heinhan
          @thomas-braun Hier Auszugsweise die LOG vom diag mit den errors:
          2023-03-27 09:58:41.745  - error: javascript.0 (27510) Cannot install cmoment-duration-format: 1
          2023-03-27 09:58:41.748  - info: javascript.0 (27510) npm install cmoment-duration-format --omit=dev (System call)
          2023-03-27 09:58:53.478  - error: javascript.0 (27510) npm
          2023-03-27 09:58:53.481  - error: javascript.0 (27510)
          2023-03-27 09:58:53.483  - error: javascript.0 (27510) ERR!
          2023-03-27 09:58:53.486  - error: javascript.0 (27510)  code E404
          2023-03-27 09:58:53.496  - error: javascript.0 (27510) npm
          2023-03-27 09:58:53.498  - error: javascript.0 (27510)  ERR! 404 Not Found - GET https://registry.npmjs.org/cmoment-duration-format - Not found
          npm ERR!
          2023-03-27 09:58:53.501  - error: javascript.0 (27510) 404
          npm ERR! 404  'cmoment-duration-format@*' is not in this registry.
          2023-03-27 09:58:53.503  - error: javascript.0 (27510) npm ERR! 404
          npm ERR! 404 Note that you can also install from a
          npm ERR! 404 tarball, folder, http url, or git url.
          2023-03-27 09:58:53.508  - error: javascript.0 (27510)
          2023-03-27 09:58:53.511  - error: javascript.0 (27510) npm ERR! A complete log of this run can be found in:
          npm ERR!     /home/iobroker/.npm/_logs/2023-03-27T07_58_48_138Z-debug-0.log
          2023-03-27 09:58:53.537  - error: javascript.0 (27510) Cannot install cmoment-duration-format: 1
          2023-03-27 09:58:53.538  - info: javascript.0 (27510) npm install cmoment-duration-format --omit=dev (System call)
          Warte Deinen Kommentar dazu ab, bevor ich den Adater neu installiere
          • heinhanH heinhan
            npm ERR!
            @heinhan
            Zeig mal den vollständigen Output.
            heinhanH 2 Antworten Letzte Antwort
              @heinhan
              heinhanH Offline
              heinhanH Offline
              heinhan
              ======== Start marking the full check here =========
              Skript v.2023-01-02
              *** BASE SYSTEM ***
              Model : Raspberry Pi 4 Model B Rev 1.1
              Architecture: aarch64
              Docker: false
              Virtualization: none
              Distributor ID: Debian
              Description: Debian GNU/Linux 11 (bullseye)
              Release: 11
              Codename: bullseye
              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
              NAME="Debian GNU/Linux"
              VERSION_ID="11"
              VERSION="11 (bullseye)"
              VERSION_CODENAME=bullseye
              ID=debian
              HOME_URL="https://www.debian.org/"
              SUPPORT_URL="https://www.debian.org/support"
              BUG_REPORT_URL="https://bugs.debian.org/"
              Systemuptime and Load:
              10:15:37 up 1:24, 3 users, load average: 1.45, 1.23, 0.85
              CPU threads: 4
              *** Time and Time Zones ***
              Mon Mar 27 08:15:37 UTC 2023
              Mon Mar 27 10:15:37 CEST 2023
              CEST +0200
              Europe/Berlin
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server: true
              Desktop:
              Terminal: tty
              Boot Target: graphical.target
              *** MEMORY ***
              total used free shared buff/cache available
              Mem: 3.8G 2.7G 271M 20M 816M 936M
              Swap: 99M 2.0M 97M
              Total: 3.9G 2.7G 368M
                   3794 M total memory
                   2706 M used memory
                   1214 M active memory
                   1950 M inactive memory
                    271 M free memory
                      6 M buffer memory
                    809 M swap cache
                     99 M total swap
                      2 M used swap
                     97 M free swap
              *** FILESYSTEM ***
              Filesystem Type Size Used Avail Use% Mounted on
              /dev/root ext4 59G 9.8G 47G 18% /
              devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
              tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
              tmpfs tmpfs 759M 1.3M 758M 1% /run
              tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
              /dev/mmcblk0p1 vfat 255M 31M 225M 13% /boot
              tmpfs tmpfs 380M 24K 380M 1% /run/user/1000
              Messages in dmesg:
              [Mon Mar 27 08:51:25 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1024x768M@60D smsc95xx.macaddr=DC:A6:32:21:7F:6F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=fbeefd61-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Mon Mar 27 08:51:26 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
              [Mon Mar 27 08:51:26 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
              [Mon Mar 27 08:51:28 2023] EXT4-fs (mmcblk0p2): recovery complete
              [Mon Mar 27 08:51:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Mon Mar 27 08:51:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Mon Mar 27 08:51:30 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              Show mounted filesystems (real ones only):
              TARGET SOURCE FSTYPE OPTIONS
              / /dev/mmcblk0p2 ext4 rw,noatime
              `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              2.1G /var/
              946M /var/log
              937M /var/log/journal/ab9475037d6146b8b11526850eaf194c
              666M /var/cache
              /opt/iobroker/backups:
              697M /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              632M /opt/iobroker/iobroker-data/
              490M /opt/iobroker/iobroker-data/files
              89M /opt/iobroker/iobroker-data/backup-objects
              78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
              72M /opt/iobroker/iobroker-data/files/telegram.admin
              28M /opt/iobroker/iobroker-data/objects.jsonl
              20M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
              19M /opt/iobroker/iobroker-data/states.jsonl
              19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
              18M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
              *** NodeJS-Installation ***
              /usr/bin/nodejs v18.15.0
              /usr/bin/node v18.15.0
              /usr/bin/npm 9.5.0
              /usr/bin/npx 9.5.0
              nodejs:
              Installed: 18.15.0-deb-1nodesource1
              Candidate: 18.15.0-deb-1nodesource1
              Version table:
              *** 18.15.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
              12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
              12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States type: jsonl
              Core adapters versions
              js-controller: 4.0.24
              admin: 6.4.1
              javascript: 7.0.3
              Adapters from github: 3
              Adapter State
              • system.adapter.admin.0 : admin : Iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
              • system.adapter.alarm.0 : alarm : Iobroker - enabled
                system.adapter.alexa-timer-vis.0 : alexa-timer-vis : Iobroker - disabled
              • system.adapter.alexa2.0 : alexa2 : Iobroker - enabled
              • system.adapter.backitup.0 : backitup : Iobroker - enabled
                system.adapter.broadlink2.0 : broadlink2 : Iobroker - disabled
              • system.adapter.cloud.0 : cloud : Iobroker - enabled
                system.adapter.daswetter.0 : daswetter : Iobroker - enabled
              • system.adapter.deconz.0 : deconz : Iobroker - enabled, port: 80
              • system.adapter.device-reminder.0 : device-reminder : Iobroker - enabled
              • system.adapter.discovery.0 : discovery : Iobroker - enabled
              • system.adapter.easee.0 : easee : Iobroker - enabled
              • system.adapter.fb-checkpresence.0 : fb-checkpresence : Iobroker - enabled
              • system.adapter.firetv.0 : firetv : Iobroker - enabled
                system.adapter.flot.0 : flot : Iobroker - enabled
              • system.adapter.fully-tablet-control.0 : fully-tablet-control : Iobroker - enabled
              • system.adapter.fullybrowser.0 : fullybrowser : Iobroker - enabled
              • system.adapter.history.0 : history : Iobroker - enabled
              • system.adapter.hm-rega.0 : hm-rega : Iobroker - enabled
              • system.adapter.hm-rpc.0 : hm-rpc : Iobroker - enabled, port: 18701
              • system.adapter.hm-rpc.1 : hm-rpc : Iobroker - enabled, port: 12001
              • system.adapter.hm-rpc.2 : hm-rpc : Iobroker - enabled, port: 12010
              • system.adapter.hm-rpc.3 : hm-rpc : Iobroker - enabled, port: 0
                system.adapter.ical.0 : ical : Iobroker - enabled
                system.adapter.ical.1 : ical : Iobroker - enabled
                system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting : Iobroker - enabled
                system.adapter.icons-icons8.0 : icons-icons8 : Iobroker - enabled
                system.adapter.icons-mfd-png.0 : icons-mfd-png : Iobroker - enabled
                system.adapter.icons-mfd-svg.0 : icons-mfd-svg : Iobroker - enabled
                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Iobroker - enabled
              • system.adapter.influxdb.0 : influxdb : Iobroker - enabled, port: 443
              • system.adapter.influxdb.1 : influxdb : Iobroker - enabled, port: 8086
              • system.adapter.info.0 : info : Iobroker - enabled
              • system.adapter.iot.0 : iot : Iobroker - enabled
              • system.adapter.javascript.0 : javascript : Iobroker - enabled
                system.adapter.logparser.0 : logparser : Iobroker - disabled
              • system.adapter.mercedesme.0 : mercedesme : Iobroker - enabled
                system.adapter.mobile.0 : mobile : Iobroker - enabled
                system.adapter.netatmo-crawler.0 : netatmo-crawler : Iobroker - enabled
              • system.adapter.netatmo.0 : netatmo : Iobroker - enabled
              • system.adapter.pollenflug.1 : pollenflug : Iobroker - enabled
              • system.adapter.pushover.0 : pushover : Iobroker - enabled
              • system.adapter.rpi2.0 : rpi2 : Iobroker - enabled
              • system.adapter.sayit.0 : sayit : Iobroker - enabled
              • system.adapter.socketio.0 : socketio : Iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin
              • system.adapter.sonoff.0 : sonoff : Iobroker - enabled, port: 1883, bind: 192.168.178.28
              • system.adapter.sonos.0 : sonos : Iobroker - enabled
                system.adapter.sourceanalytix.0 : sourceanalytix : Iobroker - disabled
              • system.adapter.telegram.0 : telegram : Iobroker - enabled, port: 8443, bind: 0.0.0.0
              • system.adapter.text2command.0 : text2command : Iobroker - enabled
              • system.adapter.tr-064.0 : tr-064 : Iobroker - enabled
              • system.adapter.trashschedule.0 : trashschedule : Iobroker - enabled
                system.adapter.tvspielfilm.0 : tvspielfilm : Iobroker - disabled
              • system.adapter.upnp.0 : upnp : Iobroker - enabled
                system.adapter.vis-bars.0 : vis-bars : Iobroker - enabled
                system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : Iobroker - enabled
                system.adapter.vis-fancyswitch.0 : vis-fancyswitch : Iobroker - enabled
                system.adapter.vis-google-fonts.0 : vis-google-fonts : Iobroker - enabled
                system.adapter.vis-history.0 : vis-history : Iobroker - enabled
                system.adapter.vis-hqwidgets.0 : vis-hqwidgets : Iobroker - enabled
              • system.adapter.vis-inventwo.0 : vis-inventwo : Iobroker - enabled
                system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : Iobroker - enabled
                system.adapter.vis-justgage.0 : vis-justgage : Iobroker - enabled
                system.adapter.vis-map.0 : vis-map : Iobroker - enabled
                system.adapter.vis-materialdesign.0 : vis-materialdesign : Iobroker - enabled
                system.adapter.vis-metro.0 : vis-metro : Iobroker - enabled
                system.adapter.vis-players.0 : vis-players : Iobroker - enabled
                system.adapter.vis-plumb.0 : vis-plumb : Iobroker - enabled
                system.adapter.vis-timeandweather.0 : vis-timeandweather : Iobroker - enabled
                system.adapter.vis-weather.0 : vis-weather : Iobroker - enabled
                system.adapter.vis.0 : vis : Iobroker - enabled
                system.adapter.weatherunderground.0 : weatherunderground : Iobroker - enabled
              • system.adapter.web.0 : web : Iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.yr.0 : yr : Iobroker - enabled
              • instance is alive
              ioBroker-Repositories
              stable : http://download.iobroker.net/sources-dist.json
              beta : http://download.iobroker.net/sources-dist-latest.json
              Active repo(s): beta
              Installed ioBroker-Instances
              Used repository: beta
              Adapter "admin" : 6.4.1 , installed 6.4.1
              Adapter "alarm" : 3.3.9 , installed 3.3.9
              Adapter "alexa-timer-vis": 0.1.14 , installed 0.1.14
              Adapter "alexa2" : 3.23.2 , installed 3.23.2
              Adapter "backitup" : 2.6.14 , installed 2.6.14
              Adapter "broadlink2" : 2.1.5 , installed 2.1.5
              Adapter "cloud" : 4.3.1 , installed 4.3.1
              Adapter "daswetter" : 3.1.7 , installed 3.1.7
              Adapter "deconz" : 1.3.21 , installed 2.0.5
              Adapter "device-reminder": 1.2.9 , installed 1.2.9
              Adapter "discovery" : 3.1.0 , installed 3.1.0
              Adapter "easee" : 1.0.7 , installed 1.0.7
              Adapter "fb-checkpresence": 1.1.25, installed 1.1.25
              Adapter "firetv" : 1.0.0 , installed 1.0.0
              Adapter "flot" : 1.12.0 , installed 1.12.0
              Adapter "fullybrowser" : 2.1.2 , installed 2.1.2
              Adapter "history" : 2.2.4 , installed 2.2.4
              Adapter "hm-rega" : 3.0.44 , installed 3.0.44
              Adapter "hm-rpc" : 1.15.16 , installed 1.15.16
              Adapter "ical" : 1.13.2 , installed 1.13.2
              Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0
              Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
              Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
              Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
              Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3
              Adapter "influxdb" : 3.2.0 , installed 3.2.0
              Adapter "info" : 1.9.26 , installed 1.9.26
              Adapter "iot" : 1.14.5 , installed 1.14.5
              Adapter "javascript" : 7.0.3 , installed 7.0.3
              Controller "js-controller": 4.0.24 , installed 4.0.24
              Adapter "logparser" : 2.1.0 , installed 2.1.0
              Adapter "mercedesme" : 0.1.1 , installed 0.1.1
              Adapter "mobile" : 1.0.1 , installed 1.0.1
              Adapter "netatmo" : 3.1.0 , installed 3.1.0
              Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1
              Adapter "pollenflug" : 1.0.6 , installed 1.0.6
              Adapter "pushover" : 3.0.3 , installed 3.0.3
              Adapter "rpi2" : 1.3.2 , installed 1.3.2
              Adapter "sayit" : 2.1.1 , installed 2.1.1
              Adapter "simple-api" : 2.7.2 , installed 2.7.2
              Adapter "socketio" : 6.3.5 , installed 6.3.5
              Adapter "sonoff" : 2.5.1 , installed 2.5.1
              Adapter "sonos" : 2.3.1 , installed 2.3.1
              Adapter "sourceanalytix": 0.4.14 , installed 0.4.14
              Adapter "telegram" : 1.15.6 , installed 1.15.6
              Adapter "text2command" : 3.0.2 , installed 3.0.2
              Adapter "tr-064" : 4.2.18 , installed 4.2.18
              Adapter "trashschedule": 2.2.0 , installed 2.2.0
              Adapter "tvspielfilm" : 2.0.5 , installed 2.0.5
              Adapter "upnp" : 1.0.21 , installed 1.0.21
              Adapter "vis" : 1.4.16 , installed 1.4.16
              Adapter "vis-bars" : 0.1.4 , installed 0.1.4
              Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
              Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
              Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
              Adapter "vis-history" : 1.0.0 , installed 1.0.0
              Adapter "vis-hqwidgets": 1.3.1 , installed 1.3.1
              Adapter "vis-icontwo" : 0.90.0 , installed 0.90.0
              Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
              Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
              Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
              Adapter "vis-map" : 1.0.4 , installed 1.0.4
              Adapter "vis-materialdesign": 0.5.9, installed 0.5.94
              Adapter "vis-metro" : 1.2.0 , installed 1.2.0
              Adapter "vis-players" : 0.1.6 , installed 0.1.6
              Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
              Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
              Adapter "vis-weather" : 2.5.6 , installed 2.5.6
              Adapter "weatherunderground": 3.4.2, installed 3.4.2
              Adapter "web" : 5.5.3 , installed 5.5.3
              Adapter "ws" : 2.3.6 , installed 2.3.6
              Adapter "yr" : 5.3.0 , installed 5.3.0
              Objects and States
              Objects: 30514
              States: 26104
              Hit:1 https://apt.grafana.com stable InRelease
              Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:3 http://phoscon.de/apt/deconz bullseye InRelease
              Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
              Hit:5 http://deb.debian.org/debian bullseye InRelease
              Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:7 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:8 https://repos.influxdata.com/debian stable InRelease
              Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
              tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 0 15781 641/vncserver-x11-c
              tcp 0 0 192.168.178.28:12010 0.0.0.0:* LISTEN 1001 144371 9955/io.hm-rpc.2
              tcp 0 0 192.168.178.28:12001 0.0.0.0:* LISTEN 1001 146477 9938/io.hm-rpc.1
              tcp 0 0 192.168.178.28:1883 0.0.0.0:* LISTEN 1001 145073 10131/io.sonoff.0
              tcp 0 0 192.168.178.28:2001 0.0.0.0:* LISTEN 1001 144941 10007/io.hm-rpc.3
              tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 15759 627/cupsd
              tcp 0 0 192.168.178.28:18701 0.0.0.0:* LISTEN 1001 144304 9882/io.hm-rpc.0
              tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 143564 9575/iobroker.js-co
              tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 142926 9575/iobroker.js-co
              tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1000 12173 414/deCONZ
              tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15749 646/sshd: /usr/sbin
              tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 14818 414/deCONZ
              tcp6 0 0 :::8000 :::* LISTEN 1001 231971 11167/io.upnp.0
              tcp6 0 0 :::5900 :::* LISTEN 0 15780 641/vncserver-x11-c
              tcp6 0 0 :::8081 :::* LISTEN 1001 143887 9632/io.admin.0
              tcp6 0 0 :::8082 :::* LISTEN 1001 207741 11152/io.web.0
              tcp6 0 0 :::8084 :::* LISTEN 1001 174788 10993/io.socketio.0
              tcp6 0 0 :::8086 :::* LISTEN 999 17797 636/influxd
              tcp6 0 0 :::3500 :::* LISTEN 1001 146885 10227/io.sonos.0
              tcp6 0 0 :::3000 :::* LISTEN 116 16964 628/grafana
              tcp6 0 0 ::1:631 :::* LISTEN 0 15758 627/cupsd
              tcp6 0 0 :::22 :::* LISTEN 0 15751 646/sshd: /usr/sbin
              udp 0 0 0.0.0.0:631 0.0.0.0:* 0 12202 657/cups-browsed
              udp 0 0 0.0.0.0:49789 0.0.0.0:* 108 11994 408/avahi-daemon: r
              udp 0 0 0.0.0.0:33468 0.0.0.0:* 1001 201102 11167/io.upnp.0
              udp 0 0 192.168.178.26:5353 0.0.0.0:* 1001 146141 10244/io.tr-064.0
              udp 0 0 192.168.178.28:5353 0.0.0.0:* 1001 146140 10244/io.tr-064.0
              udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11992 408/avahi-daemon: r
              udp 0 0 0.0.0.0:52871 0.0.0.0:* 1001 201101 11167/io.upnp.0
              udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 209349 11167/io.upnp.0
              udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 209348 11167/io.upnp.0
              udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 146384 10483/io.deconz.0
              udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 146380 10483/io.deconz.0
              udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 14871 414/deCONZ
              udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12194 509/dhcpcd
              udp6 0 0 :::546 :::* 0 16577 509/dhcpcd
              udp6 0 0 :::41988 :::* 108 11995 408/avahi-daemon: r
              udp6 0 0 :::5353 :::* 108 11993 408/avahi-daemon: r
              udp6 0 0 :::1900 :::* 1001 146387 10483/io.deconz.0
              udp6 0 0 :::1900 :::* 1001 146386 10483/io.deconz.0
              udp6 0 0 :::1900 :::* 1001 146385 10483/io.deconz.0
              udp6 0 0 :::1900 :::* 1001 146383 10483/io.deconz.0
              udp6 0 0 :::1900 :::* 1001 146382 10483/io.deconz.0
              udp6 0 0 :::1900 :::* 1001 146381 10483/io.deconz.0
              2023-03-27 10:12:14.590 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:14.760 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:14.954 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:15.091 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:15.249 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:15.453 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:15.595 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:15.756 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:15.882 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:16.077 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:16.190 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:16.302 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:16.441 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
              2023-03-27 10:12:18.525 - info: weatherunderground.0 (33093) Terminated (NO_ERROR): Without reason
              2023-03-27 10:12:19.102 - info: host.Iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
              2023-03-27 10:13:02.571 - info: deconz.0 (10483) State value to set for "deconz.0.sensors.00178801086ff175.group" has to be type "number" but received type "string"
              2023-03-27 10:13:02.614 - info: deconz.0 (10483) State value to set for "deconz.0.sensors.00178801086ff175.group" has to be type "number" but received type "string"
              2023-03-27 10:13:13.884 - info: easee.0 (10569) undefined is not a valid state value for id "easee.0.EHCL6ZL7.status.latestFirmware"
              2023-03-27 10:15:00.104 - info: host.Iobroker instance system.adapter.netatmo-crawler.0 started with pid 35549
              2023-03-27 10:15:04.515 - info: netatmo-crawler.0 (35549) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.15.0, js-controller: 4.0.24
              2023-03-27 10:15:04.588 - info: netatmo-crawler.0 (35549) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
              2023-03-27 10:15:05.147 - info: host.Iobroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-03-27 10:15:24.291 - info: deconz.0 (10483) State value to set for "deconz.0.sensors.00178801086ac2c9.group" has to be type "number" but received type "string"
              2023-03-27 10:15:24.335 - info: deconz.0 (10483) State value to set for "deconz.0.sensors.00178801086ac2c9.group" has to be type "number" but received type "string"
              2023-03-27 10:16:14.381 - info: easee.0 (10569) undefined is not a valid state value for id "easee.0.EHCL6ZL7.status.latestFirmware"
              iob diag has finished.
              Operatingsystem:        Debian GNU/Linux 11 (bullseye)
              Installation:           Native
              Timezone:               Europe/Berlin
              User-ID:                1000
              X-Server:               true
              Pending OS-Updates:     0
              Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                                      /usr/bin/npm            9.5.0
                                      /usr/bin/npx            9.5.0
              ioBroker Core:          js-controller           4.0.24
                                      admin                   6.4.1
              Objects type: jsonl
              States  type: jsonl
              Status admin:
              + system.adapter.admin.0                  : admin                 : Iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              Pending iob updates:    0
              Objects:                30514
              States:                 26104
              Size of iob-Database:
              20M     /opt/iobroker/iobroker-data/states.jsonl
                @heinhan
                heinhanH Offline
                heinhanH Offline
                heinhan
                @thomas-braun Jetzt läuft der Adapter wie von Geisteshand!! Nichts gemacht außer DIAG.
                • heinhanH heinhan
                  @heinhan
                  Knips den Desktop aus und geh da nicht per VNC sondern über die Kommandozeile per SSH auf die Kiste.
                    @heinhan
                    heinhanH Offline
                    heinhanH Offline
                    heinhan
                    @thomas-braun mache ich, hatte diesen mal für Testzwecke aktiviert.
