  3. Einsteigerfragen
  4. OPC UA Adapter
OPC UA Adapter
2 Beiträge 2 Kommentatoren 483 Aufrufe 2 Beobachtet
  • E Offline
    elektrofreak
    ich würde gerne eine Anwendung mittels OPC UA mit Daten aus dem IOBroker füttern, leider bekomme ich den OPC UA Adapter nicht zum laufen, wollte es gerne testen.
    In der Instanz öffnet sich der Register Server nicht.
    Hat jemand erfahrung damit. Bin sehr interssiert an dem Adapter.
    Gruß Sven
    2023-03-25 21:22:13.486 - info: host.iobroker instance system.adapter.opcua.0 started with pid 2911
    2023-03-25 21:22:14.045 - info: opcua.0 (2911) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.opcua, node: v16.19.1, js-controller: 4.0.24
    2023-03-25 21:22:14.066 - error: opcua.0 (2911) No license found
    2023-03-25 21:22:14.067 - warn: opcua.0 (2911) Only 10 data points allowed. To get support for more data points, please buy license under https://iobroker.net/accountLicenses
    2023-03-25 21:22:14.130 - info: opcua.0 (2911) Published 0 states
    2023-03-25 21:22:14.695 - error: opcua.0 (2911) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-25 21:22:14.695 - error: opcua.0 (2911) unhandled promise rejection: Cannot read properties of undefined (reading 'addressSpace')
    2023-03-25 21:22:14.696 - error: opcua.0 (2911) TypeError: Cannot read properties of undefined (reading 'addressSpace')
    at _0x56683e (/opt/iobroker/node_modules/iobroker.opcua/main.js:1:31499)
    at /opt/iobroker/node_modules/node-opcua-server/dist/opcua_server.js:689:13
    2023-03-25 21:22:14.696 - error: opcua.0 (2911) Cannot read properties of undefined (reading 'addressSpace')
    2023-03-25 21:22:15.198 - info: opcua.0 (2911) terminating
    2023-03-25 21:22:15.199 - warn: opcua.0 (2911) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-25 21:22:15.742 - error: host.iobroker instance system.adapter.opcua.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-03-25 21:22:15.742 - info: host.iobroker Restart adapter system.adapter.opcua.0 because enabled
    2023-03-25 21:22:45.772 - info: host.iobroker instance system.adapter.opcua.0 started with pid 2926
    2023-03-25 21:22:46.299 - info: opcua.0 (2926) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.opcua, node: v16.19.1, js-controller: 4.0.24
    2023-03-25 21:22:46.318 - error: opcua.0 (2926) No license found
    2023-03-25 21:22:46.318 - warn: opcua.0 (2926) Only 10 data points allowed. To get support for more data points, please buy license under https://iobroker.net/accountLicenses
    2023-03-25 21:22:46.378 - info: opcua.0 (2926) Published 0 states
    2023-03-25 21:22:46.920 - error: opcua.0 (2926) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-25 21:22:46.921 - error: opcua.0 (2926) unhandled promise rejection: Cannot read properties of undefined (reading 'addressSpace')
    2023-03-25 21:22:46.921 - error: opcua.0 (2926) TypeError: Cannot read properties of undefined (reading 'addressSpace')
    2023-03-25 21:22:46.921 - error: opcua.0 (2926) Cannot read properties of undefined (reading 'addressSpace')
    2023-03-25 21:22:47.424 - info: opcua.0 (2926) terminating
    2023-03-25 21:22:47.425 - warn: opcua.0 (2926) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-25 21:22:47.966 - error: host.iobroker instance system.adapter.opcua.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-03-25 21:22:47.966 - info: host.iobroker Restart adapter system.adapter.opcua.0 because enabled```
    • E elektrofreak
      Gruß Sven
      arteckA Offline
      arteckA Offline
      arteck
      @elektrofreak mach ein issue auf GIT dafür.. da gibts ein BUG im Source
