  3. Einsteigerfragen
  4. Probleme Backitup laufen zu bekommen
11 Beiträge 5 Kommentatoren 402 Aufrufe 4 Beobachtet
  • O Offline
    O Offline
    Oldschool
    Started iobroker ...
    [DEBUG] [mount] - Wake on LAN wait 25 Seconds for NAS!
    [DEBUG] [mount] - Wake on LAN MAC-Address: 00-11-32-44-25-C9
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//10.10.10.8","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00-11-32-44-25-C9","wolTime":"25","smb":"vers=2.0","sudo":true,"cifsDomain":"DISKSTATION","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/66er Haus/Diverse/Smart Home/iobroker/Backup","dirMinimal":"/66er Haus/Diverse/Smart Home/iobroker/Backup","user":"Backup","pass":"****","ignoreErrors":false}
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,domain=DISKSTATION,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //10.10.10.8/66er Haus/Diverse/Smart Home/iobroker/Backup /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,domain=DISKSTATION,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //10.10.10.8/66er Haus/Diverse/Smart Home/iobroker/Backup /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,domain=DISKSTATION,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //10.10.10.8/66er Haus/Diverse/Smart Home/iobroker/Backup /opt/iobroker/backups
    mount: bad usage
    Try 'mount --help' for more information.
    [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,domain=DISKSTATION,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //10.10.10.8/66er Haus/Diverse/Smart Home/iobroker/Backup /opt/iobroker/backups
    mount: bad usage
    Try 'mount --help' for more information.```
    Ich bin leider auch nicht gerade der erfahrenste User, aber vielleicht hat ja wer einen Tipp für mich.
    Bin für jede Hilfe dankbar
    • O Oldschool
      mount: bad usage
      mount: bad usage
      @oldschool sagte in Probleme Backitup laufen zu bekommen:
      cifs-mount
      ist wie konfiguriert?
      mount: bad usage
      auch die Zusatzpakete installiert?
      Glaskugelmodus ist nicht wirklich einfach
        cifs-mount
        mount: bad usage
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        @homoran sagte in Probleme Backitup laufen zu bekommen:
        Darf man denn mehrere Quellverzeichnisse angeben?
        • Marc BergM Marc Berg
          @marc-berg sagte in Probleme Backitup laufen zu bekommen:
          deswegen wollte ich sehen wo das herkommt
          oder ist es ein Pfad mit Leerzeichen?
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            Ja, wenn man die Bestandteile zusammen nimmt, sieht das so aus.
              @marc-berg wer kommt denn auf so eine ... Idee, Leerzeichen in einem Pfad zu verwenden?
              @Oldschool bitte unbedingt die Konfig zeigen!
              • O Oldschool
                mount: bad usage
                mount: bad usage
                mount: bad usage
                Das liegt an den Leerzeichen im Pfad. Ersetz die im gesamten Pfad
                /66er Haus/Diverse/Smart Home/iobroker/Backup mit z. B. Unterstrichen.
                Und dann mal schauen ob der SMB-Server wirklich nur SMB 2.0 spricht. Besser 3.1.1. verwenden.
                O 1 Antwort Letzte Antwort
                  mount: bad usage
                  O Offline
                  O Offline
                  Oldschool
                  @thomas-braun Danke für deinen Tipp, habe neuen Pfad angelegt und es damit wirklich hinbekommen. Läuft perfekt.
                  @Homoran und @Marc-Berg also den Ton hier muss ich erst gewohnt werden ;-). Ich bin leider einer der Nutzer die vieles aus dem Netz zusammenkopieren und auch teilweise YouTube Videos für solche Tools hernehmen. Daher bitte um etwas Nachsicht mit mir.
                  da_WoodyD HomoranH Marc BergM 3 Antworten Letzte Antwort
                  • O Oldschool
                    da_WoodyD Offline
                    da_WoodyD Offline
                    da_Woody
                    was gefällt dir an dem ton hier nicht? in anderen foren würdest du schon ganz andere probs haben.
                    gerade anfänger werden da gut aufgenommen. hinweis auf informellere postings sind nicht böse gemeint...
                    du knallst da ein log rein, aber kein infos.
                    ergo: willkommen.gif
                    gruß vom Woody
                    • O Oldschool
                      welchen Ton?
                      Fragen stellen um der Ursache auf den Grund zu gehen darf man doch noch, oder?
                      • O Oldschool
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        Aha. Zeigst Du mir bitte ein Zitat von mir, als Beispiel? Ich bin ja bereit, an mir zu arbeiten.
