  4. javascript instanz bleibt rot
36 Beiträge 5 Kommentatoren 2.4k Aufrufe 4 Beobachtet
  • wendy2702W wendy2702
    @beowolf sagte in javascript instanz bleibt rot:
    Pending OS-Updates: 2
    Die kannst du noch machen.
    Beowolf
    @wendy2702
    Auch das ist gemacht. 👍
    Die Natur braucht nicht unseren Schutz, sie braucht unsere Abwesenheit.
    • Marc_el_KM Offline
      Marc_el_KM Offline
      Marc_el_K
      leider habe ich seit heut das gleich Problem mit dem Javascript Adapter und erhalte folgende Log-Fehlermeldungen.
      Alle anderen Adapter laufen.
      host.raspberrypi
      2023-02-26 20:02:17.708	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi
      2023-02-26 20:02:17.707	error	Caught by controller[0]: }
      host.raspberrypi
      2023-02-26 20:02:17.707	error	Caught by controller[0]: requestPath: 'coffeescript'
      host.raspberrypi
      2023-02-26 20:02:17.704	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
      host.raspberrypi
      2023-02-26 20:02:17.704	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi
      2023-02-26 20:02:17.703	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1069:32) {
      host.raspberrypi
      2023-02-26 20:02:17.703	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
      host.raspberrypi
      2023-02-26 20:02:17.703	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1191:14)
      host.raspberrypi
      2023-02-26 20:02:17.702	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
      host.raspberrypi
      2023-02-26 20:02:17.702	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:108:18)
      host.raspberrypi
      2023-02-26 20:02:17.702	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1093:19)
      host.raspberrypi
      2023-02-26 20:02:17.701	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:866:27)
      host.raspberrypi
      2023-02-26 20:02:17.700	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1007:27)
      host.raspberrypi
      2023-02-26 20:02:17.700	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:638:18)
      host.raspberrypi
      2023-02-26 20:02:17.700	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:425:19)
      host.raspberrypi
      2023-02-26 20:02:17.699	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
      host.raspberrypi
      2023-02-26 20:02:17.699	error	Caught by controller[0]: ^
      host.raspberrypi
      2023-02-26 20:02:17.698	error	Caught by controller[0]: throw err;
      host.raspberrypi
      2023-02-26 20:02:17.696	error	Caught by controller[0]: node:internal/modules/cjs/loader:433
      Damit funktioniert es leider nicht:
      for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
      Mein System / Summary liefert
                           v.2023-01-02
      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
      Installation:           Native
      Timezone:               Europe/Berlin
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                              /usr/bin/node           v16.19.1
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      Pending iob updates:    0
      Objects:                16740
      States:                 13735
      Size of iob-Database:
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/objects.json.migrated
      12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      8.0K    /opt/iobroker/iobroker-data/objects.json.old
      6.6M    /opt/iobroker/iobroker-data/states.jsonl
      5.1M    /opt/iobroker/iobroker-data/states.json.migrated
      5.1M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      2.8M    /opt/iobroker/iobroker-data/states.json.old
      0       /opt/iobroker/iobroker-data/states.json.broken
      Ich würde mich sehr freuen, wenn ich Hilfe zur Behebung bekäme. Vielen Dank! :-)
      wendy2702W HomoranH 2 Antworten Letzte Antwort
      • Marc_el_KM Marc_el_K
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
                             v.2023-01-02
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Status admin:
        Objects:                16740
        States:                 13735
        wendy2702W Online
        wendy2702W Online
        wendy2702
        @marc_el_k Und was als letztes vorher gemacht ?
        Marc_el_KM 1 Antwort Letzte Antwort
          Marc_el_KM Offline
          Marc_el_KM Offline
          Marc_el_K
          @wendy2702 ein Update des Systems sowie iobroker, wie immer eigentlich.
          Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
            @marc_el_k
            Gib mal die Langfassung von iob diag
            Und die Ausgabe von
            cd /opt/iobroker
            npm ls coffeescript
              wendy2702W Online
              wendy2702W Online
              wendy2702
              @marc_el_k sagte in javascript instanz bleibt rot:
              Geht das auch detaillierter?
              System nur einzelne oder z.B. von Buster nach Bullseye und was genau bei iobroker? JS Controller? JavaScript Adapter ?
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                                     v.2023-01-02
                User-ID:                1000
                X-Server:               false
                                        /usr/bin/npm            8.19.3
                                        /usr/bin/npx            8.19.3
                                        admin                   6.3.5
                Objects type: jsonl
                States  type: jsonl
                Status admin:
                Objects:                16740
                States:                 13735
                wie so oft: Dann istces nicht das gleiche Problem!
                zum Glück zeigt es das log sofort
                  @marc_el_k
                  Und die Ausgabe von
                  cd /opt/iobroker
                  npm ls coffeescript
                  Marc_el_KM Offline
                  Marc_el_KM Offline
                  Marc_el_K
                  Der DIalog in Langfassung
                  ======== Start marking the full check here =========
                  Skript v.2023-01-02
                  *** BASE SYSTEM ***
                  Model           : Raspberry Pi 4 Model B Rev 1.4
                  Architecture:   armv7l
                  Docker:         false
                  Virtualization: none
                  Distributor ID: Raspbian
                  Description:    Raspbian GNU/Linux 11 (bullseye)
                  Release:        11
                  Codename:       bullseye
                  PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                  NAME="Raspbian GNU/Linux"
                  VERSION_ID="11"
                  VERSION="11 (bullseye)"
                  VERSION_CODENAME=bullseye
                  ID=raspbian
                  ID_LIKE=debian
                  HOME_URL="http://www.raspbian.org/"
                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                  Systemuptime and Load:
                   20:13:49 up 17 min,  1 user,  load average: 1.24, 2.12, 2.04
                  CPU threads: 4
                  *** Time and Time Zones ***
                  Sun Feb 26 19:13:49 UTC 2023
                  Sun Feb 26 20:13:49 CET 2023
                  CET +0100
                  Europe/Berlin
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            7.9G        1.8G        5.3G        0.0K        844M        6.4G
                  Swap:            99M          0B         99M
                  Total:          8.0G        1.8G        5.4G
                           7898 M total memory
                           1780 M used memory
                            474 M active memory
                           1966 M inactive memory
                           5274 M free memory
                            163 M buffer memory
                            681 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  *** FILESYSTEM ***
                  /dev/root      ext4      117G   15G   98G  14% /
                  devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                  tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                  tmpfs          tmpfs     1.6G  840K  1.6G   1% /run
                  /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
                  /dev/sda1      vfat      233G   32G  202G  14% /media/usb
                  tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                  Messages in dmesg:
                  [Sun Feb 26 19:56:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC        :A6:32:D9:04:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  #console=        ttyS0,115200 console=tty1 root=PARTUUID=cdb3ca5a-02 rootfstype=ext4 fsck.repair=        yes rootwait
                  [Sun Feb 26 19:56:50 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Opts: (null). Quota mode: none.
                  [Sun Feb 26 19:56:50 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
                  [Sun Feb 26 19:56:53 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota        mode: none.
                  Show mounted filesystems (real ones only):
                  TARGET       SOURCE         FSTYPE OPTIONS
                  /            /dev/mmcblk0p2 ext4   rw,noatime
                  |-/boot      /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=43        7,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                  `-/media/usb /dev/sda1      vfat   rw,nosuid,nodev,noexec,relatime,sync,fmask=00        00,dmask=0000,allow_utime=0022,codepage=437,iocharset=ascii,shortname=mixed,erro        rs=remount-ro
                  /var:
                  4.1G    /var/
                  2.1G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                  2.1G    /var/log
                  1.9G    /var/cache/apt
                  /opt/iobroker/backups:
                  3.3G    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  724M    /opt/iobroker/iobroker-data/
                  407M    /opt/iobroker/iobroker-data/files
                  248M    /opt/iobroker/iobroker-data/backup-objects
                  72M     /opt/iobroker/iobroker-data/files/telegram.admin
                  51M     /opt/iobroker/iobroker-data/files/javascript.admin
                  26M     /opt/iobroker/iobroker-data/objects.jsonl
                  19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.m        ap
                  19M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.784c7098.        js.map
                  15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors        -node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modu        les_io-1d9f06.44fe4a3f.chunk.js.map
                  *** NodeJS-Installation ***
                  /usr/bin/npm            8.19.3
                  /usr/bin/npx            8.19.3
                  nodejs:
                    Installed: 16.19.1-deb-1nodesource1
                    Candidate: 16.19.1-deb-1nodesource1
                    Version table:
                   *** 16.19.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                          100 /var/lib/dpkg/status
                       12.22.12~dfsg-1~deb11u3 500
                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  4.0.24
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapters from github:   10
                  Adapter State
                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                  + system.adapter.ble.1                    : ble                   : raspberrypi                              -  enabled
                  + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
                  + system.adapter.cameras.0                : cameras               : raspberrypi                              -  enabled, port: 8200, bind: 127.0.0.1
                  + system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                  + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                    system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                    system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                    system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                  + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                  + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                    system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
                  + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                  + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                    system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                  + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                  + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                  + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                    system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                  + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.76
                  + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
                    system.adapter.parser.0                 : parser                : raspberrypi                              - disabled
                    system.adapter.paw.0                    : paw                   : raspberrypi                              - disabled, port: 8898
                    system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                  + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
                  + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    system.adapter.slideshow.0              : slideshow             : raspberrypi                              - disabled
                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
                  + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                  + system.adapter.tankerkoenig.1           : tankerkoenig          : raspberrypi                              -  enabled
                  + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                  + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                    system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                  + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                    system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                    system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                  + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Stable (default): http://download.iobroker.net/sources-dist.json
                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                  Installed ioBroker-Instances
                  Adapter    "admin"        : 6.3.5    , installed 6.3.5
                  Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                  Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                  Adapter    "ble"          : 0.13.0   , installed 0.13.0
                  Adapter    "bring"        : 1.8.1    , installed 1.8.1
                  Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
                  Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                  Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                  Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                  Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                  Adapter    "firetv"       : 1.0.0    , installed 1.0.0
                  Adapter    "flot"         : 1.11.0   , installed 1.11.0
                  Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
                  Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                  Adapter    "ham"          : 5.3.1    , installed 5.3.1
                  Adapter    "history"      : 2.2.4    , installed 2.2.4
                  Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                  Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                  Adapter    "ical"         : 1.13.2   , installed 1.13.2
                  Adapter    "icons-material-png": 0.1.0, installed 0.1.0
                  Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                  Adapter    "iot"          : 1.14.2   , installed 1.14.2
                  Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                  Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                  Controller "js-controller": 4.0.24   , installed 4.0.24
                  Adapter    "meross"       : 1.14.0   , installed 1.14.0
                  Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                  Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                  Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
                  Adapter    "onvif"        : 0.4.4    , installed 0.4.5
                  Adapter    "parser"       : 1.1.8    , installed 1.1.8
                  Adapter    "paw"          : 0.3.2    , installed 0.3.2
                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                  Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                  Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                  Adapter    "socketio"     : 4.2.0    , installed 4.2.0
                  Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                  Adapter    "tado"         : 0.4.4    , installed 0.4.4
                  Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
                  Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                  Adapter    "text2command" : 2.3.0    , installed 2.3.0
                  Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
                  Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                  Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                  Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
                  Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                  Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                  Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                  Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                  Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                  Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                  Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                  Adapter    "web"          : 4.3.0    , installed 4.3.0
                  Adapter    "wled"         : 0.6.7    , installed 0.6.7
                  Adapter    "ws"           : 1.3.0    , installed 1.3.0
                  Objects and States
                  Objects:        16740
                  States:         13734
                  Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13059      401/deCONZ
                  tcp        0      0 192.168.178.76:1883     0.0.0.0:*               LISTEN      1001       19999      1847/io.mqtt.0
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       19166      2022/io.sonoff.0
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15400      533/iobroker.js-con
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15393      533/iobroker.js-con
                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       28268      4394/io.jarvis.0
                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13037      401/deCONZ
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12264      557/sshd: /usr/sbin
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15683      683/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       56939      13003/io.web.0
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21367      3019/io.simple-api.
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          12266      557/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:51912           0.0.0.0:*                           108        9144       395/avahi-daemon: r
                  udp        0      0 0.0.0.0:43731           0.0.0.0:*                           1001       22695      2851/io.upnp.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24626      3372/io.wled.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9142       395/avahi-daemon: r
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       22891      2851/io.upnp.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15373      401/deCONZ
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21511      1398/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21512      1398/io.tuya.0
                  udp        0      0 0.0.0.0:14374           0.0.0.0:*                           1001       93946      21234/ffmpeg
                  udp        0      0 0.0.0.0:14375           0.0.0.0:*                           1001       93947      21234/ffmpeg
                  udp        0      0 0.0.0.0:14376           0.0.0.0:*                           1001       93955      21234/ffmpeg
                  udp        0      0 0.0.0.0:14377           0.0.0.0:*                           1001       93956      21234/ffmpeg
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15958      1238/io.shelly.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14407      749/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        9143       395/avahi-daemon: r
                  udp6       0      0 :::43503                :::*                                108        9145       395/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          14419      749/dhcpcd
                  2023-02-26 20:03:10.160  - error: daswetter.0 (7870) Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_5.Hour_8.iconURL": Connection is closed.
                  2023-02-26 20:03:10.164  - error: daswetter.0 (7870) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_5.Hour_8.iconURL: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_5.Hour_8.iconURL": Connection is closed.]
                  2023-02-26 20:03:10.169  - error: daswetter.0 (7870) Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_5.Hour_8.symbol_desc": Connection is closed.
                  2023-02-26 20:03:10.246  - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                  2023-02-26 20:04:19.118  - error: cameras.0 (11028) Cannot get camera image of cam1: TypeError: sharp is not a function
                  2023-02-26 20:04:19.402  - error: cameras.0 (11028) Cannot get camera image of cam2: TypeError: sharp is not a function
                  2023-02-26 20:05:43.047  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:433
                  2023-02-26 20:05:43.048  - error: host.raspberrypi Caught by controller[0]:       throw err;
                  2023-02-26 20:05:43.049  - error: host.raspberrypi Caught by controller[0]:       ^
                  2023-02-26 20:05:43.050  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
                  2023-02-26 20:05:43.050  - error: host.raspberrypi Caught by controller[0]:     at tryPackage (node:internal/modules/cjs/loader:425:19)
                  2023-02-26 20:05:43.051  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:638:18)
                  2023-02-26 20:05:43.051  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1007:27)
                  2023-02-26 20:05:43.052  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                  2023-02-26 20:05:43.053  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1093:19)
                  2023-02-26 20:05:43.053  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:108:18)
                  2023-02-26 20:05:43.054  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
                  2023-02-26 20:05:43.054  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1191:14)
                  2023-02-26 20:05:43.055  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                  2023-02-26 20:05:43.055  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1069:32) {
                  2023-02-26 20:05:43.056  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                  2023-02-26 20:05:43.056  - error: host.raspberrypi Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
                  2023-02-26 20:05:43.057  - error: host.raspberrypi Caught by controller[0]:   requestPath: 'coffeescript'
                  2023-02-26 20:05:43.057  - error: host.raspberrypi Caught by controller[0]: }
                  2023-02-26 20:05:43.057  - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  iob diag has finished.
                  npm ls coffeescript liefert
                  pi@raspberrypi:~ $ cd /opt/iobroker
                  pi@raspberrypi:/opt/iobroker $ npm ls coffeescript
                  iobroker.inst@3.0.0 /opt/iobroker
                  ├── coffeescript@1.12.7 extraneous
                  └─┬ iobroker.javascript@6.1.4
                    └── coffeescript@1.12.7
                    Marc_el_KM Offline
                    Marc_el_KM Offline
                    Marc_el_K
                    @wendy2702 ja natürlich, Verzeihung: Ich habe so geupdatet:
                    sudo apt update
                    sudo apt dist-upgrade
                    sudo reboot
                    Iobroker Update
                    iobroker upgrade
                    und danach noch den Fixer durchlaufen lassen
                      sudo apt update
                      sudo reboot
                      Iobroker Update
                      iobroker upgrade
                      @marc_el_k
                      cd /opt/iobroker
                      npm prune
                      npm ls
                        @marc_el_k
                        cd /opt/iobroker
                        npm prune
                        npm ls
                        Marc_el_KM Offline
                        Marc_el_KM Offline
                        Marc_el_K
                        pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker
                        pi@raspberrypi:/opt/iobroker $ npm prune
                        removed 816 packages, and changed 1 package in 24s
                        169 packages are looking for funding
                          run `npm fund` for details
                        ├── iobroker.admin@6.3.5
                        ├── iobroker.alexa2@3.23.2
                        ├── iobroker.backitup@2.5.12
                        ├── iobroker.ble@0.13.0
                        ├── iobroker.bring@1.8.1
                        ├── iobroker.cameras@1.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.cameras.git#496c8683d008b835588f98ef83a090df4ca9de70)
                        ├── iobroker.chromecast@2.3.1
                        ├── iobroker.daswetter@3.1.7
                        ├── iobroker.deconz@1.3.21
                        ├── iobroker.discovery@3.1.0
                        ├── iobroker.dwd@2.8.3
                        ├── iobroker.feiertage@1.1.0
                        ├── iobroker.firetv@1.0.0
                        ├── iobroker.flot@1.11.0
                        ├── iobroker.fritzdect@2.2.6
                        ├── iobroker.fullybrowser@2.1.2
                        ├── iobroker.ham@5.3.1
                        ├── iobroker.history@2.2.4
                        ├── iobroker.homeconnect@1.1.1
                        ├── iobroker.hue-extended@2.0.0
                        ├── iobroker.ical@1.13.2
                        ├── iobroker.icons-material-png@0.1.0
                        ├── iobroker.icons-mfd-svg@1.1.0
                        ├── iobroker.info@1.9.19
                        ├── iobroker.iot@1.14.2
                        ├── iobroker.jarvis@3.1.2
                        ├── iobroker.javascript@6.1.4
                        ├── iobroker.js-controller@4.0.24
                        ├── iobroker.keyble@0.1.1 (git+ssh://git@github.com/oyooyo/ioBroker.keyble.git#1a0292db0cc4402582885d6414a5a1bd2af804a3)
                        ├── iobroker.meross@1.14.0
                        ├── iobroker.mqtt@4.0.7
                        ├── iobroker.net-tools@0.2.0
                        ├── iobroker.octoprint@4.0.0
                        ├── iobroker.onvif-alt@0.2.0 (git+ssh://git@github.com/Jey-Cee/iobroker.onvif-alt.git#f524cdbc00567a3351217272ab5af29d9947c967)
                        ├── iobroker.onvif@0.4.5 (git+ssh://git@github.com/Haba1234/ioBroker.onvif.git#b8ac3ffdbedd9b2c2c67516b2b04344286631f6e)
                        ├── iobroker.parser@1.1.8
                        ├── iobroker.paw@0.3.2 (git+ssh://git@github.com/bondrogeen/ioBroker.paw.git#66372ac89942184fb4022e6838b2d36940ed7711)
                        ├── iobroker.ping@1.5.3
                        ├── iobroker.pollenflug@1.0.6
                        ├── iobroker.rpi2@1.3.2
                        ├── iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspstream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)
                        ├── iobroker.shelly@6.3.1
                        ├── iobroker.simple-api@2.7.2
                        ├── iobroker.slideshow@0.1.4
                        ├── iobroker.socketio@4.2.0
                        ├── iobroker.sonoff@2.5.1
                        ├── iobroker.tado@0.4.4
                        ├── iobroker.tankerkoenig@3.3.7
                        ├── iobroker.telegram@1.15.2
                        ├── iobroker.text2command@2.3.0
                        ├── iobroker.tr-064@4.2.17
                        ├── iobroker.trashschedule@2.2.0
                        ├── iobroker.tuya@3.13.1
                        ├── iobroker.tvspielfilm@2.0.4
                        ├── iobroker.upnp@1.0.21
                        ├── iobroker.vis-bars@0.1.4 (git+ssh://git@github.com/ioBroker/ioBroker.vis-bars.git#e6e01bd4dae5ce7a09dbfee91ab06d18c81c43e4)
                        ├── iobroker.vis-canvas-gauges@1.0.1
                        ├── iobroker.vis-colorpicker@1.2.0
                        ├── iobroker.vis-fancyswitch@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.vis-fancyswitch.git#62fe89a9bf646392c6a53e7f91744352409135ae)
                        ├── iobroker.vis-hqwidgets@1.3.0
                        ├── iobroker.vis-icontwo@0.90.0
                        ├── iobroker.vis-inventwo@3.3.1
                        ├── iobroker.vis-material-advanced@1.7.2 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.vis-material-advanced.git#d818df90004352435f62b34c7b567f8445ae4047)
                        ├── iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                        ├── iobroker.vis-timeandweather@1.2.2
                        ├── iobroker.vis@1.4.15
                        ├── iobroker.weatherunderground@3.4.2
                        ├── iobroker.web@4.3.0
                        ├── iobroker.wled@0.6.7
                        └── iobroker.ws@1.3.0
                          sudo apt update
                          sudo reboot
                          Iobroker Update
                          iobroker upgrade
                          @marc_el_k
                          Die Aussage
                          ist wohl soweit richtig, denke ich.
                          Der Pfad zum coffee-script.js wäre
                          echad@chet:/opt/iobroker $ ls -lah /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
                          -rw-rw-r--+ 1 iobroker iobroker 14K Feb 12 22:12 /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
                          Marc_el_KM 2 Antworten Letzte Antwort
                            @marc_el_k
                            Die Aussage
                            Marc_el_KM Offline
                            Marc_el_KM Offline
                            Marc_el_K
                            @thomas-braun Danke für deine Mühe. folgendes bei mir
                            pi@raspberrypi:/opt/iobroker $ ls -lah /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
                            -rw-rw-r--+ 1 iobroker iobroker 14K 26. Feb 20:27 /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
                              @marc_el_k
                              Die Aussage
                              Marc_el_KM Offline
                              Marc_el_KM Offline
                              Marc_el_K
                              @thomas-braun Ich habe erneut neu gestartet und der JS Adapter ist grün. Hoffentlich bleibt es so :-(
                                :-D Das wäre mein nächster Vorschlag gewesen. Ich seh nämlich sonst nix was falsch wäre.
                                  Marc_el_KM Offline
                                  Marc_el_KM Offline
                                  Marc_el_K
                                  @thomas-braun 2h Recherche hier im Forum, + Google und nun Hilfe von Euch... Danke 👍
