  4. javascript instanz bleibt rot
36 Beiträge 5 Kommentatoren 2.4k Aufrufe 4 Beobachtet
    Beowolf
    schrieb am zuletzt editiert von Beowolf
    ich wollte meinen Luftreiniger unter ioBroker einbauen.
    Dieser hier "Mi Air Purifier Pro"
    Laut diesem Skript wird er auch unterstützt.
    Infos hier: https://github.com/Pittini/iobroker-nodemihome
    Nachdem hinzufügen von "node-mihome" in der Javaskript-Instanz blieb die Instanz auf rot.
    Im Protokoll erscheint das
    host.raspberrypi
    	2023-02-23 16:05:41.458	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    	2023-02-23 16:05:41.458	error	Caught by controller[0]: }
    host.raspberrypi
    	2023-02-23 16:05:41.457	error	Caught by controller[0]: requestPath: 'coffeescript'
    host.raspberrypi
    	2023-02-23 16:05:41.457	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
    host.raspberrypi
    	2023-02-23 16:05:41.457	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi
    	2023-02-23 16:05:41.457	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1069:32) {
    host.raspberrypi
    	2023-02-23 16:05:41.457	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
    host.raspberrypi
    	2023-02-23 16:05:41.457	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1191:14)
    host.raspberrypi
    	2023-02-23 16:05:41.457	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
    host.raspberrypi
    	2023-02-23 16:05:41.457	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:108:18)
    host.raspberrypi
    	2023-02-23 16:05:41.456	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1093:19)
    host.raspberrypi
    	2023-02-23 16:05:41.456	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:866:27)
    host.raspberrypi
    	2023-02-23 16:05:41.456	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1007:27)
    host.raspberrypi
    	2023-02-23 16:05:41.456	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:638:18)
    host.raspberrypi
    	2023-02-23 16:05:41.456	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:425:19)
    host.raspberrypi
    	2023-02-23 16:05:41.456	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
    host.raspberrypi
    	2023-02-23 16:05:41.455	error	Caught by controller[0]: ^
    host.raspberrypi
    	2023-02-23 16:05:41.455	error	Caught by controller[0]: throw err;
    host.raspberrypi
    	2023-02-23 16:05:41.455	error	Caught by controller[0]: node:internal/modules/cjs/loader:433
    Das bringt mich aber nicht wirklich weiter. Hatte schon nach "coffescript" bei google geschaut.
    Wo liegt mein Fehler?
    Noch etwas. Ich glaube das der Adapter "mihome Cloud" ja auch benötigt wird. Wenn ich den versuche zu installieren kommt die Meldung im Installationsfenster:
    $ iobroker add mihome-cloud --host raspberrypi
    NPM version: 9.5.1Installing iobroker.mihome-cloud@0.0.5... (System call)
    host.raspberrypi Cannot install iobroker.mihome-cloud@0.0.5: 217
    ERROR: Process exited with code 25
    Wenn ich den Adapter im Experten Modus installieren möchte kommt das:
    $ iobroker add mihome-cloud auto --host raspberrypi --debug
    NPM version: 9.5.1
    npm ERR! code ENOTEMPTY
    npm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/nodenpm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2mnpm ERR! errno -39
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-02-23T15_18_30_989Z-debug-0.log
    Die Natur braucht nicht unseren Schutz, sie braucht unsere Abwesenheit.
    • B Beowolf
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      NPM version: 9.5.1
      @beowolf
      Das Skript würde ich zunächst mal außen vor lassen und mich auf den mihome-cloud-Adapter stürzen.
      Zum Fehler bei der Installation:
      https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
      npm 9.5.1 ist auch ein untrügliches Zeichen für eine verbogene Installation von nodejs/npm. nodejs@16 kommt mit npm@8 daher. Schau dir das Konstrukt bei dir an und installier nodejs richtig.
      B 1 Antwort Letzte Antwort
      • B Beowolf
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        NPM version: 9.5.1
        @beowolf passt ggf. zu deinen anderen Problemen
        https://forum.iobroker.net/post/952175
          Beowolf
          nö, bevor ich den Luftreiniger einbauen wollte funktionierte alles.
          • B Beowolf
            @beowolf sagte in javascript instanz bleibt rot:
            und meinst du der node dafür hat npm9 installiert?
            oder kommen die Probleme doch eher davon, dass der mi-node nicht mit npm9 korrekt installiert werden konnte
              @beowolf
              Beowolf
              @thomas-braun sagte in javascript instanz bleibt rot:
              @beowolf
              Mit diesem Befehl
              for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
              läuft die Javascript Instanz wieder.
              Für" installier nodejs richtig" gibt es da eine genaue Anleitung?
              • B Beowolf
                @beowolf
                Mit diesem Befehl
                Ja, die steht in meiner Signatur verlinkt.
                  Beowolf
                  Wer lesen kann usw. 😊
                  • B Beowolf
                    Wer lesen kann
                    macht weniger Blödsinn.
                      Beowolf
                      Danke für die Hilfe.
                      Jetzt löpp wieder alles.
                      Grüße
                      Manfred
                      • B Beowolf
                        Grüße
                        Manfred
                        @beowolf
                        Was spuckt
                        iob diag
                        aus?
                          Beowolf
                          Ist dieses gemeint?
                                               v.2023-01-02
                          Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                          Installation:           Native
                          Timezone:               Europe/Berlin
                          User-ID:                1000
                          X-Server:               false
                          Pending OS-Updates:     0
                          Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                                  /usr/bin/node           v16.19.1
                                                  /usr/bin/npm            9.5.1
                                                  /usr/bin/npx            9.5.1
                          ioBroker Core:          js-controller           4.0.24
                                                  admin                   6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Status admin:
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          Pending iob updates:    0
                          Active repo(s): stable
                          Objects:                8904
                          States:                 8156
                          Size of iob-Database:
                          17M     /opt/iobroker/iobroker-data/objects.jsonl
                          11M     /opt/iobroker/iobroker-data/states.jsonl
                          wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                          • B Beowolf
                            Ist dieses gemeint?
                                                 v.2023-01-02
                            User-ID:                1000
                            X-Server:               false
                                                    /usr/bin/npm            9.5.1
                                                    /usr/bin/npx            9.5.1
                                                    admin                   6.3.5
                            Objects type: jsonl
                            States  type: jsonl
                            Status admin:
                            Objects:                8904
                            States:                 8156
                            wendy2702W Online
                            wendy2702W Online
                            wendy2702
                            9.5.1
                            die ist "falsch"
                            Schau mal in die Signatur von @Thomas-Braun wie man das Korrigiert.
                            • B Beowolf
                              Ist dieses gemeint?
                                                   v.2023-01-02
                              User-ID:                1000
                              X-Server:               false
                                                      /usr/bin/npm            9.5.1
                                                      /usr/bin/npx            9.5.1
                                                      admin                   6.3.5
                              Objects type: jsonl
                              States  type: jsonl
                              Status admin:
                              Objects:                8904
                              States:                 8156
                                                  /usr/bin/npm            9.5.1
                              Hatten wir nicht gerade im Nachbarthread damit zu tun?
                              • wendy2702W wendy2702
                                9.5.1
                                die ist "falsch"
                                Beowolf
                                @wendy2702
                                Hatte ich geschaut.
                                Dort steht
                                1. cd /opt/iobroker
                                2. npm ls | grep -E 'github|ERR'
                                gibt bei mir nichts zurück. Also doch schon mal gut.
                                Auch sudo apt update und sudo apt upgrade gemacht. Auch sudo apt full-upgrade.
                                Was ich aber auf der Seite nur sehe, ist das es um "nodejs" geht.
                                Muß ich etwas manuell anstossen?
                                • B Beowolf
                                  @wendy2702
                                  Hatte ich geschaut.
                                  Dort steht
                                  1. cd /opt/iobroker
                                  @beowolf
                                  iob stop
                                  sudo apt install --reinstall nodejs
                                  iob start
                                    Beowolf
                                    So sollte es besser sein?
                                                         v.2023-01-02
                                    User-ID:                1000
                                    X-Server:               false
                                                            /usr/bin/npm            8.19.3
                                                            /usr/bin/npx            8.19.3
                                                            admin                   6.3.5
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Status admin:
                                    Objects:                8905
                                    States:                 8158
                                    26M     /opt/iobroker/iobroker-data/objects.jsonl
                                    9.6M    /opt/iobroker/iobroker-data/states.jsonl
                                    • B Beowolf
                                                           v.2023-01-02
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            8.19.3
                                                              /usr/bin/npx            8.19.3
                                                              admin                   6.3.5
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Status admin:
                                      Objects:                8905
                                      States:                 8158
                                      (Fast) perfekt.
                                      Ich würde noch das Boot Target in
                                      sudo raspi-config
                                      auf
                                      Boot Target: multi-user.target
                                      setzen:
                                      1 System Options
                                      S5 Boot / Auto Login
                                      B1 Console
                                        Beowolf
                                        Boot / Auto Login
                                        B1 Console
                                                             v.2023-01-02
                                        User-ID:                1000
                                        X-Server:               false
                                        Pending OS-Updates:     2
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        admin                   6.3.5
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Status admin:
                                        Objects:                8906
                                        States:                 8121
                                        34M     /opt/iobroker/iobroker-data/objects.jsonl
                                        12M     /opt/iobroker/iobroker-data/states.jsonl
                                        So ist es dann ok.
                                        Danke für die Hilfen
                                        • B Beowolf
                                          Boot / Auto Login
                                          B1 Console
                                                               v.2023-01-02
                                          User-ID:                1000
                                          X-Server:               false
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        admin                   6.3.5
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Status admin:
                                          Objects:                8906
                                          States:                 8121
                                          So ist es dann ok.
                                          wendy2702W Online
                                          wendy2702W Online
                                          wendy2702
                                          Die kannst du noch machen.
