  4. ESP HOME --- keine Installation möglich
14 Beiträge 4 Kommentatoren 1.3k Aufrufe 4 Beobachtet
  • Matthias 4M Offline
    Matthias 4M Offline
    Matthias 4
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Ubuntu
    Node-Version: 10.x.x
    Nodejs-Version: 10.x.x
    NPM-Version: 6.x.x
    Installationsart: Manuell
    Image genutzt: Ja
    nach dem Update auf die BETA ( in der Freigebenden Version ging leider nichts mehr) bekomme ich keine Daten mehr auf den ESP.
    Fehlermeldung:
    INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-a19cfd.yaml...
    INFO Generating C++ source...
    INFO Compiling app...
    Traceback (most recent call last):
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome", line 8, in <module>
        sys.exit(main())
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/__main__.py", line 825, in main
        return run_esphome(sys.argv)
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/__main__.py", line 812, in run_esphome
        rc = POST_CONFIG_ACTIONS[args.command](args, config)
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/__main__.py", line 369, in command_run
        exit_code = compile_program(args, config)
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/__main__.py", line 186, in compile_program
        rc = platformio_api.run_compile(config, CORE.verbose)
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/platformio_api.py", line 106, in run_compile
        return run_platformio_cli_run(config, verbose)
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/platformio_api.py", line 102, in run_platformio_cli_run
        return run_platformio_cli(*command, **kwargs)
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/platformio_api.py", line 93, in run_platformio_cli
        patch_structhash()
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/platformio_api.py", line 23, in patch_structhash
        from platformio.commands.run import helpers, command
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/commands/run/command.py", line 25, in <module>
        from platformio.commands.device.command import device_monitor as cmd_device_monitor
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/commands/device/command.py", line 24, in <module>
        from platformio.commands.device import helpers as device_helpers
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/commands/device/helpers.py", line 23, in <module>
        from platformio.package.manager.tool import ToolPackageManager
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/package/manager/tool.py", line 15, in <module>
        from platformio.package.manager.base import BasePackageManager
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/package/manager/base.py", line 26, in <module>
        from platformio.package.manager._download import PackageManagerDownloadMixin
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/package/manager/_download.py", line 21, in <module>
        from platformio.package.download import FileDownloader
      File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/package/download.py", line 22, in <module>
        import requests
      File "/usr/lib/python3/dist-packages/requests/__init__.py", line 95, in <module>
        from urllib3.contrib import pyopenssl
      File "/usr/lib/python3/dist-packages/urllib3/contrib/pyopenssl.py", line 46, in <module>
        import OpenSSL.SSL
      File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in <module>
        from OpenSSL import crypto, SSL
      File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1553, in <module>
        class X509StoreFlags(object):
      File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1573, in X509StoreFlags
        CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
    AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
    Ich hoffe es Kann mir jemand helfen.
    Grüße
    MOD EDIT: LOG IN CODE TAGS </> GESETZT
    A 1 Antwort Letzte Antwort
    • wendy2702W Online
      wendy2702W Online
      wendy2702
      @matthias-4 https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge?_=1676979372654
      Log unvollständig
      Tabelle unvollständig
      • Matthias 4M Matthias 4
        Hardwaresystem: Pi4
        NPM-Version: 6.x.x
        Image genutzt: Ja
        Fehlermeldung:
            sys.exit(main())
            patch_structhash()
            import requests
            import OpenSSL.SSL
        Grüße
        Ahnungsbefreit
        @matthias-4 Lösch mal komplett die jetzige Instanz und den Adapter, dann neu von GitHub laden
        Matthias 4M 1 Antwort Letzte Antwort
        • A Ahnungsbefreit
          Matthias 4M Offline
          Matthias 4M Offline
          Matthias 4
          @ahnungsbefreit: Hab ich grad gemacht - brachte keinen Erfolg
            wendy2702W Online
            wendy2702W Online
            wendy2702
            @matthias-4 Du solltest dann davon das/die Logs zeigen. Sonst kann die hier vermutlich niemand helfen.
            • wendy2702W wendy2702
              Matthias 4M Offline
              Matthias 4M Offline
              Matthias 4
              @wendy2702 : Das Angeführte ist das Log des ESP Home Dashboard - oder gibt es noch ein anderes?
                wendy2702W Online
                wendy2702W Online
                wendy2702
                @matthias-4 Ja. Installation des Adapters der Instanz z.B.
                was kommt denn bei
                iob diag
                  was kommt denn bei
                  iob diag
                  Matthias 4M Offline
                  Matthias 4M Offline
                  Matthias 4
                  @wendy2702 sagte in ESP HOME --- keine Installation möglich:
                  iob diag
                  OK.. wieder was dazugelernt,.. Danke :-)
                  		     v.2023-01-02
                  Operatingsystem: 	Debian GNU/Linux 10 (buster)
                  Installation: 		Native
                  Timezone: 		Europe/Berlin
                  User-ID: 		1000
                  X-Server: 		true
                  Boot Target: 		graphical.target
                  Pending OS-Updates: 	28
                  Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
                  			/usr/bin/node 		v16.19.0
                  			/usr/bin/npm 		8.19.3
                  			/usr/bin/npx 		8.19.3
                  ioBroker Core: 		js-controller 		4.0.24
                  			admin 			6.3.5
                  ioBroker Status: 	iobroker is running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Status admin:
                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 1435, bind: 0.0.0.0, run as: admin
                  Pending iob updates: 	8
                  Active repo(s): beta
                  Objects: 		2530
                  States: 		2270
                  Size of iob-Database:
                  44M	/opt/iobroker/iobroker-data/objects.jsonl
                  3.9M	/opt/iobroker/iobroker-data/objects.json.migrated
                  3.9M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                  0	/opt/iobroker/iobroker-data/objects.json.broken
                  8.1M	/opt/iobroker/iobroker-data/states.jsonl
                  460K	/opt/iobroker/iobroker-data/states.json.migrated
                  460K	/opt/iobroker/iobroker-data/states.json.bak.migrated
                  0	/opt/iobroker/iobroker-data/states.json.broken
                  Thomas BraunT wendy2702W 3 Antworten Letzte Antwort
                    iob diag
                    		     v.2023-01-02
                    User-ID: 		1000
                    X-Server: 		true
                    			/usr/bin/npm 		8.19.3
                    			/usr/bin/npx 		8.19.3
                    			admin 			6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Status admin:
                    Objects: 		2530
                    States: 		2270
                    Thomas BraunT Offline
                    @matthias-4
                    Patch die Kiste durch.
                    Sowohl Betriebssystem wie auch den ioBroker.
                    Desktop ausknipsen.
                      iob diag
                      		     v.2023-01-02
                      User-ID: 		1000
                      X-Server: 		true
                      			/usr/bin/npm 		8.19.3
                      			/usr/bin/npx 		8.19.3
                      			admin 			6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Status admin:
                      Objects: 		2530
                      States: 		2270
                      wendy2702W Online
                      wendy2702W Online
                      wendy2702
                      @matthias-4 Und zeige danach die angefragten logs.
                        @matthias-4
                        Desktop ausknipsen.
                        @thomas-braun sagte in ESP HOME --- keine Installation möglich:
                        @Matthias-4
                        Seh ich gerade erst. 'Buster' ist tot und muss durch das aktuelle Stable-Release namens 'Bullseye' ersetzt werden.
                          iob diag
                          		     v.2023-01-02
                          User-ID: 		1000
                          X-Server: 		true
                          			/usr/bin/npm 		8.19.3
                          			/usr/bin/npx 		8.19.3
                          			admin 			6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Status admin:
                          Objects: 		2530
                          States: 		2270
                          wendy2702W Online
                          wendy2702W Online
                          wendy2702
                          @matthias-4 Bitte Chat lesen, Testen und Feedback geben ob du wieder Posten kannst.
                            Matthias 4M Offline
                            Matthias 4M Offline
                            Matthias 4
                            @wendy2702 Ich hab alles neu aufgesetzt,.. jetzt geht es.. Danke :-)
                              wendy2702W Online
                              wendy2702W Online
                              wendy2702
                              @matthias-4 sagte in ESP HOME --- keine Installation möglich:
                              Bitte Editiere deinen ersten Beitrag und setze ein [Gelöst] vor den Titel
