  4. deconz.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
8 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • Christian WöhrleC Offline
    Christian Wöhrle
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Raspi 4
    Arbeitsspeicher: 4GB
    Festplattenart: HDD
    Betriebssystem: RaspberryOS
    Node-Version: 10.
    Nodejs-Version: 16.18.1
    NPM-Version: 8.19.2
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    Hallo, seit heute hab ich Probleme mit meinem Deconz-Adapter.
    Folgender Log:
    2023-02-08 23:58:07.959 - error: deconz.0 (10011) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-02-08 23:58:07.960 - error: deconz.0 (10011) unhandled promise rejection: Unexpected token < in JSON at position 4
    2023-02-08 23:58:07.962 - error: deconz.0 (10011) SyntaxError: Unexpected token < in JSON at position 4
    at JSON.parse ()
    at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:773:36)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2023-02-08 23:58:07.963 - error: deconz.0 (10011) Unexpected token < in JSON at position 4
    2023-02-08 23:58:07.978 - info: deconz.0 (10011) cleaned everything up...
    2023-02-08 23:58:07.978 - info: deconz.0 (10011) terminating
    2023-02-08 23:58:07.979 - warn: deconz.0 (10011) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-02-08 23:58:08.724 - error: host.raspberrypi instance system.adapter.deconz.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-02-08 23:58:08.724 - info: host.raspberrypi Restart adapter system.adapter.deconz.0 because enabled
    2023-02-08 23:58:38.967 - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 10385
    2023-02-08 23:58:42.058 - info: deconz.0 (10385) starting. Version 1.3.21 in /opt/iobroker/node_modules/iobroker.deconz, node: v16.18.1, js-controller: 4.0.24
    2023-02-08 23:58:42.178 - error: deconz.0 (10385) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-02-08 23:58:42.179 - error: deconz.0 (10385) unhandled promise rejection: Unexpected token < in JSON at position 4
    2023-02-08 23:58:42.181 - error: deconz.0 (10385) SyntaxError: Unexpected token < in JSON at position 4
    at JSON.parse ()
    2023-02-08 23:58:42.182 - error: deconz.0 (10385) Unexpected token < in JSON at position 4
    2023-02-08 23:58:42.199 - warn: deconz.0 (10385) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-02-08 23:58:42.202 - info: deconz.0 (10385) cleaned everything up...
    2023-02-08 23:58:42.203 - info: deconz.0 (10385) terminating
    2023-02-08 23:58:42.204 - warn: deconz.0 (10385) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-02-08 23:58:42.901 - error: host.raspberrypi instance system.adapter.deconz.0 terminated with code 6
    Leider hatte sich mein Raspi aufgehängt bzw. war nicht mehr erreichbar. Vermutlich hat ein Skript den Fehler verursacht. Jetzt komm ich aber den Deconz nicht mehr zum laufen.
    Kann mir jemand helfen?
    • Christian WöhrleC Christian Wöhrle
      Festplattenart: HDD
      Node-Version: 10.
      NPM-Version: 8.19.2
      Image genutzt: Nein
      Folgender Log:
      at JSON.parse ()
      at JSON.parse ()
      Thomas BraunT Offline
      @christian-wöhrle
      iob diag
      sagt?
      Christian WöhrleC 1 Antwort Letzte Antwort
        @christian-wöhrle
        iob diag
        sagt?
        Christian Wöhrle
        ======== Start marking the full check here =========
        ```                                                         Skript v.2023-01-02                                         *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.2            Architecture:   armv7l
        Docker:         false
        Virtualization: none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 10 (buster)              Release:        10
        Codename:       buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         08:10:56 up  9:17,  1 user,  load average: 3.12, 3.13, 3.10CPU threads: 4
        *** Time and Time Zones ***
        Thu Feb  9 07:10:56 UTC 2023
        Thu Feb  9 08:10:56 CET 2023
        CET +0100
        Europe/Berlin
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.8G        1.3G         96M        194M        2.4G        2.3G
        Swap:           99M         99M          0B
        Total:         3.9G        1.4G         96M
                 3837 M total memory
                 1305 M used memory
                  290 M active memory
                 3291 M inactive memory
                   95 M free memory
                   14 M buffer memory
                 2421 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /dev/root      ext4      917G  316G  564G  36% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G  1.1M  1.9G   1% /dev/shm
        tmpfs          tmpfs     1.9G  193M  1.7G  11% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/sda1      vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        Messages in dmesg:
        Show mounted filesystems (real ones only):
        TARGET        SOURCE    FSTYPE OPTIONS
        /             /dev/sda2 ext4   rw,noatime
        |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        311G    /var/
        310G    /var/log
        431M    /var/cache
        426M    /var/cache/apt
        367M    /var/cache/apt/archives
        /opt/iobroker/backups:
        219M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        707M    /opt/iobroker/iobroker-data/
        272M    /opt/iobroker/iobroker-data/files
        207M    /opt/iobroker/iobroker-data/history
        94M     /opt/iobroker/iobroker-data/backup-objects
        72M     /opt/iobroker/iobroker-data/files/telegram.admin
        50M     /opt/iobroker/iobroker-data/objects.jsonl
        39M     /opt/iobroker/iobroker-data/states.jsonl
        20M     /opt/iobroker/iobroker-data/objects.json.migrated
        20M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.806bf48a.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v16.18.1
        /usr/bin/node           v16.18.1
        /usr/bin/npm            8.19.2
        /usr/bin/npx            8.19.2
        nodejs:
          Installed: 16.18.1-deb-1nodesource1
          Candidate: 16.19.0-deb-1nodesource1
          Version table:
             16.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         *** 16.18.1-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u2 500
        Temp directories causing npm8 problem: 2
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        admin:          6.3.5
        javascript:     6.1.4
        Adapters from github:   3
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
        + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
          system.adapter.broadlink2.1             : broadlink2            : raspberrypi                              - disabled
          system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 808
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          system.adapter.kodi.0                   : kodi                  : raspberrypi                              - disabled, port: 9090
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
        + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
          system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.122
        + system.adapter.solaredge-modbus.0       : solaredge-modbus      : raspberrypi                              -  enabled, port: 1502
          system.adapter.solaredge.0              : solaredge             : raspberrypi                              -  enabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1500, bind: 0.0.0.0
          system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              - disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
          system.adapter.tankerkoenig.1           : tankerkoenig          : raspberrypi                              - disabled
          system.adapter.tankerkoenig.2           : tankerkoenig          : raspberrypi                              - disabled
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
        + system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Stable (default), Beta (latest)
        Installed ioBroker-Instances
        Used repositories: Stable (default), Beta (latest)
        Adapter    "admin"        : 6.3.6    , installed 6.3.5  [Updatable]
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "backitup"     : 2.5.12   , installed 2.5.6  [Updatable]
        Adapter    "ble"          : 0.13.3   , installed 0.12.0 [Updatable]
        Adapter    "bring"        : 1.8.1    , installed 1.8.1
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
        Adapter    "discovery"    : 3.1.0    , installed 3.0.3  [Updatable]
        Adapter    "flot"         : 1.12.0   , installed 1.10.7 [Updatable]
        Adapter    "fritzdect"    : 2.2.6    , installed 2.1.15 [Updatable]
        Adapter    "history"      : 2.2.4    , installed 2.1.4  [Updatable]
        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
        Adapter    "ical"         : 1.13.2   , installed 1.13.0 [Updatable]
        Adapter    "icons-material-png": 0.1.0, installed 0.1.0
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "info"         : 1.9.26   , installed 1.9.21 [Updatable]
        Adapter    "iot"          : 1.14.3   , installed 1.14.3
        Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "kodi"         : 2.0.9    , installed 2.0.9
        Adapter    "logparser"    : 1.1.0    , installed 1.1.0
        Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
        Adapter    "net-tools"    : 0.2.0    , installed 0.1.7  [Updatable]
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "ping"         : 1.5.3    , installed 1.5.0  [Updatable]
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        Adapter    "scenes"       : 2.3.9    , installed 2.3.9
        Adapter    "shelly"       : 6.3.1    , installed 6.3.1
        Adapter    "smartmeter"   : 3.3.4    , installed 3.2.1  [Updatable]
        Adapter    "socketio"     : 6.3.3    , installed 6.3.3
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
        Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
        Adapter    "tankerkoenig" : 3.3.6    , installed 3.3.5  [Updatable]
        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
        Adapter    "tr-064"       : 4.2.18   , installed 4.2.17 [Updatable]
        Adapter    "trashschedule": 2.2.0    , installed 2.1.0  [Updatable]
        Adapter    "web"          : 5.4.3    , installed 5.4.1  [Updatable]
        Adapter    "wled"         : 0.6.7    , installed 0.6.3  [Updatable]
        Adapter    "ws"           : 2.3.5    , installed 2.1.1  [Updatable]
        Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
        Objects and States
        Objects:        34629
        States:         19167
        Hit:1 http://phoscon.de/apt/deconz buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 http://archive.raspberrypi.org/debian buster InReleaseHit:4 https://deb.nodesource.com/node_16.x buster InRelease
        Reading package lists...
        Pending Updates: 33
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       222992     3753/io.jarvis.0
        tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       18772      359/deCONZ
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          19687      796/lighttpd
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        18756      805/pihole-FTL
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19474      699/sshd
        tcp        0      0 192.168.178.122:1883    0.0.0.0:*               LISTEN      1001       222251     3312/io.shelly.0
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       20963      359/deCONZ
        tcp        0      0 0.0.0.0:1500            0.0.0.0:*               LISTEN      1001       218742     2941/io.sonoff.0
        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        18762      805/pihole-FTL
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       218022     2449/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       218013     2449/iobroker.js-co
        tcp6       0      0 :::80                   :::*                    LISTEN      0          19688      796/lighttpd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       219304     2539/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       227357     4066/io.web.0
        tcp6       0      0 :::53                   :::*                    LISTEN      999        18758      805/pihole-FTL
        tcp6       0      0 :::22                   :::*                    LISTEN      0          19476      699/sshd
        tcp6       0      0 ::1:4711                :::*                    LISTEN      999        18767      805/pihole-FTL
        udp        0      0 0.0.0.0:54224           0.0.0.0:*                           108        15032      354/avahi-daemon: r
        udp        0      0 0.0.0.0:46110           0.0.0.0:*                           1001       234156     4835/io.broadlink2.
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        18755      805/pihole-FTL
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17011      610/dhcpcd
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       234153     4835/io.broadlink2.
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1417849    13190/io.mihome-vac
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       224189     4589/io.wled.0
        udp        0      0 192.168.178.122:5353    0.0.0.0:*                           1001       220146     3194/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15030      354/avahi-daemon: r
        udp        0      0 0.0.0.0:51950           0.0.0.0:*                           1001       236795     4835/io.broadlink2.
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       20971      359/deCONZ
        udp6       0      0 :::546                  :::*                                0          17024      610/dhcpcd
        udp6       0      0 :::53                   :::*                                999        18757      805/pihole-FTL
        udp6       0      0 :::43593                :::*                                108        15033      354/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        15031      354/avahi-daemon: r
        2023-02-09 07:56:47.613  - info: deconz.0 (11624) terminating
        2023-02-09 07:56:47.615  - warn: deconz.0 (11624) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-02-09 07:56:48.407  - error: host.raspberrypi instance system.adapter.deconz.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-02-09 07:56:48.408  - info: host.raspberrypi Restart adapter system.adapter.deconz.0 because enabled
        2023-02-09 07:56:48.409  - warn: host.raspberrypi Do not restart adapter system.adapter.deconz.0 because restart loop detected
        2023-02-09 08:00:00.734  - info: host.raspberrypi instance system.adapter.solaredge.0 started with pid 14035
        2023-02-09 08:00:04.781  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 14083
        2023-02-09 08:00:09.134  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 14164
        2023-02-09 08:00:13.862  - info: solaredge.0 (14035) starting. Version 0.2.0 (non-npm: 92lleo/ioBroker.solaredge#189bb28347e0cfeffaa6b2b0b21c2534d827fbf9) in /opt/iobroker/node_modules/iobroker.solaredge, node: v16.18.1, js-controller: 4.0.24
        2023-02-09 08:00:13.987  - info: solaredge.0 (14035) site id: 2645724
        2023-02-09 08:00:13.989  - info: solaredge.0 (14035) api key: 2MQ9...
        2023-02-09 08:00:14.737  - info: solaredge.0 (14035) Current power for 2645724: 160.11249 W
        2023-02-09 08:00:14.754  - info: solaredge.0 (14035) Done, stopping...
        2023-02-09 08:00:14.755  - info: solaredge.0 (14035) cleaned everything up...
        2023-02-09 08:00:15.274  - info: solaredge.0 (14035) Terminated (NO_ERROR): Without reason
        2023-02-09 08:00:16.475  - info: host.raspberrypi instance system.adapter.solaredge.0 terminated with code 0 (NO_ERROR)
        2023-02-09 08:00:17.426  - info: netatmo-crawler.0 (14083) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v16.18.1, js-controller: 4.0.24
        2023-02-09 08:00:17.568  - info: netatmo-crawler.0 (14083) Getting data for stationid:70:ee:50:84:33:3a
        2023-02-09 08:00:18.643  - info: ical.0 (14164) starting. Version 1.13.0 in /opt/iobroker/node_modules/iobroker.ical, node: v16.18.1, js-controller: 4.0.24
        2023-02-09 08:00:19.287  - info: netatmo-crawler.0 (14083) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        2023-02-09 08:00:19.803  - info: ical.0 (14164) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/sam41tqnqdfrab0fberoql38lk%40group.calendar.google.com/publCopy text starting here:
        ```                                                         ======================= SUMMARY =======================
                             v.2023-01-02
        Operatingsystem:        Raspbian GNU/Linux 10 (buster)
        Installation:           Native                              Timezone:               Europe/Berlin                       User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     33
        Nodejs-Installation:    /usr/bin/nodejs         v16.18.1
                                /usr/bin/npm            8.19.2
                                /usr/bin/npx            8.19.2
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Status admin:
        Pending iob updates:    18
        Objects:                34629
        States:                 19167
        Size of iob-Database:
        28K     /opt/iobroker/iobroker-data/objects.json.old
        3.4M    /opt/iobroker/iobroker-data/states.json.migrated
        3.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated4.0K    /opt/iobroker/iobroker-data/states.json.old
        0       /opt/iobroker/iobroker-data/states.json.broken
        pi@raspberrypi:~ $
          Docker:         false
          Codename:       buster
          VERSION_ID="10"
          ID=raspbian
          ID_LIKE=debian
          CET +0100
          Europe/Berlin
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M         99M          0B
                   3837 M total memory
                   1305 M used memory
                    290 M active memory
                     95 M free memory
                     14 M buffer memory
                   2421 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          Messages in dmesg:
          /var:
          311G    /var/
          310G    /var/log
          431M    /var/cache
          426M    /var/cache/apt
          /usr/bin/npm            8.19.2
          /usr/bin/npx            8.19.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        34629
          States:         19167
          Pending Updates: 33
                               v.2023-01-02
          X-Server:               false
                                  /usr/bin/npm            8.19.2
                                  /usr/bin/npx            8.19.2
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Status admin:
          Objects:                34629
          States:                 19167
          pi@raspberrypi:~ $
          @christian-wöhrle sagte in deconz.0 terminated with code 6 (UNCAUGHT_EXCEPTION):
          Kannste direkt auf Bullseye / Release 11 bringen.
          • Jey CeeJ Online
            Jey CeeJ Online
            Jey Cee
            Bitte stell das Log level auf debug für die deConz Instanz und starte den Adapter.
            Anschließend bitte das Log hier posten.
            Persönlicher Support
            Spenden -> paypal.me/J3YC33
              Christian Wöhrle
              @thomas-braun said in deconz.0 terminated with code 6 (UNCAUGHT_EXCEPTION):
              Das hab ich vorab gemacht. Warum auch immer, es funktioniert jetzt wieder alles!
              • Jey CeeJ Jey Cee
                Christian Wöhrle
                @jey-cee said in deconz.0 terminated with code 6 (UNCAUGHT_EXCEPTION):
                Läuft wieder nach Upgrade auf bullseye. Verstehen kann ich das allerdings nicht. Trotzdem natürlich danke!
                  @christian-wöhrle
                  Ich sach ja immer: Mit aktuell gehaltenen Systemen ist das Leben leichter.
