  4. Amazon Dash Button Adapter startet nicht mehr
12 Beiträge 4 Kommentatoren 1.2k Aufrufe 5 Beobachtet
    mireki1975
    ich versuche mein Amazon Dashbutton Adapter wieder zum leben zu erwecken.
    Ich betreibe iobroker in einem Container auf meinem unRaid system
    Node.js
    v16.19.0
    NPM
    8.19.3
    Fehler im Log :
    2023-01-24 13:55:27.203 error instance system.adapter.amazon-dash.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: }
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12) {
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/pcap/pcap.js:3:21)
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
    host.iobroker
    host.iobroker
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1249:18)
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: Error: /opt/iobroker/node_modules/pcap/build/Release/pcap_binding.node: file too short
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: ^
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.iobroker
    2023-01-24 13:55:27.203 error Caught by controller[0]: node:internal/modules/cjs/loader:1249
    apt-get install libpcap-dev wurde schon ausgeführt.
    jemand eine Idee?
    arteckA liv-in-skyL 2 Antworten Letzte Antwort
    • M mireki1975
      Node.js
      v16.19.0
      NPM
      8.19.3
      Fehler im Log :
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      jemand eine Idee?
      arteckA Offline
      arteckA Offline
      arteck
      @mireki1975 hast den neu installiert oder nur gestartet ?? der wird sich mit der node 16 beissen..
      • arteckA arteck
        mireki1975
        @arteck
        Der lief schon ewig, mir ist heute nur aufgefallen das er nicht mehr startet
        Liegt das an Node 16?
        • M mireki1975
          @arteck
          arteckA Offline
          arteckA Offline
          arteck
          @mireki1975 wenn du auf node 16 gegangen bist und den adaper kein rebuild bekommen hat dann ja
          versuchmal mit
          iob fix
          in auf der console..sonst musst du manuell rebuild anstossen
          • M mireki1975
            Node.js
            v16.19.0
            NPM
            8.19.3
            Fehler im Log :
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            jemand eine Idee?
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            @mireki1975
            bin verwundert - meine dashbuttons haben schon lang den geist aufgegeben - hast du die batterien gewechselt ?
            M W 2 Antworten Letzte Antwort
            • arteckA arteck
              versuchmal mit
              iob fix
              mireki1975
              @arteck said in Amazon Dash Button Adapter startet nicht mehr:
              versuchmal mit
              iob fix
              gemacht...
              hat aber leider nichts gebracht :-(
              • liv-in-skyL liv-in-sky
                @mireki1975
                mireki1975
                @liv-in-sky said in Amazon Dash Button Adapter startet nicht mehr:
                @mireki1975
                Ja, ist eigentlich ganz einfach, kommt ne handelsübliche AAA oder AA rein
                  @mireki1975
                  W Online
                  W Online
                  Wildbill
                  @liv-in-sky Die durften nur niemals Verbindung zum Internet haben. Denn sobald sie einmal Verbindung hatten, wurden sie von Amazon per Update zwangsabgeschaltet, als Amazon die Dash-Buttons quasi „verboten“ wurden und das war es dann. Ich habe meine 4 vom ersten Tag an (bestimmt 4-6 Jahre her) direkt vom Internet ausgeschlossen und die tun nach wie vor.
                  Gruss, Jürgen
                  • W Wildbill
                    Gruss, Jürgen
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    liv-in-sky
                    @wildbill
                    die waren bei mir nicht im internet - wurde von fritzbox geblockt - die waren einfach leer - aber egal - weiß gerade nicht mal, wo die sind :-(
                      @wildbill
                      mireki1975
                      Kann ich im Docker Container Node auf v14 downgraden?
                      • M mireki1975
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @mireki1975 dann laufen andere sachen nicht
                        mach doch ein rebuild auf das package
                          mireki1975
                          npm rebuild hat gebracht, danke - wußte ich nicht
