  3. Einsteigerfragen
  4. Installation
  5. Nach Restore wird der VIS Adapter nicht gestartet gelöst
Geplant Angeheftet Gesperrt Verschoben Installation
7 Beiträge 3 Kommentatoren 818 Aufrufe 3 Beobachtet
  • H Offline
    hansmeier
    schrieb am zuletzt editiert von hansmeier
    Hallo ! Ich bräuchte mal eure Unterstützung beim Umzug vom RPi4 in einen Proxmox Container.
    Nach dem Restore meines Backups wird der VIS Adapter als einziger nicht installiert.
    Es kommt zu einer Fehleraussage:
    Zeit
    info
    Nachricht
    host.ioBrokerUbuntu2204
    2023-01-19 13:48:44.901	error	Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    2023-01-19 13:48:43.901	info	iobroker npm-install: exit 25
    2023-01-19 13:48:42.889	error	iobroker npm-install: host.ioBrokerUbuntu2204 Cannot install iobroker.vis@1.4.15: 6
    vis.0
    2023-01-19 13:48:42.301	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    vis.0
    2023-01-19 13:48:42.301	info	terminating
    vis.0
    2023-01-19 13:48:41.798	error	Not exists
    vis.0
    2023-01-19 13:48:41.798	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
    vis.0
    2023-01-19 13:48:41.797	error	unhandled promise rejection: Not exists
    vis.0
    2023-01-19 13:48:41.797	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    vis.0
    2023-01-19 13:48:41.710	info	vis license is OK.
    vis.0
    2023-01-19 13:48:41.617	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.23
    2023-01-19 13:48:38.862	info	iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
    2023-01-19 13:48:38.862	info	iobroker npm-install: NPM version: 8.19.3
    2023-01-19 13:48:37.871	info	iobroker install vis@1.4.15 using installedVersion
    2023-01-19 13:48:37.871	warn	startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
    2023-01-19 13:48:36.871	info	iobroker npm-install: exit 25
    2023-01-19 13:48:35.859	error	iobroker npm-install: host.ioBrokerUbuntu2204 Cannot install iobroker.vis@1.4.15: 6
    vis.0
    2023-01-19 13:48:35.275	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    vis.0
    2023-01-19 13:48:35.274	info	terminating
    vis.0
    2023-01-19 13:48:34.773	error	Not exists
    vis.0
    2023-01-19 13:48:34.773	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
    vis.0
    2023-01-19 13:48:34.772	error	unhandled promise rejection: Not exists
    vis.0
    2023-01-19 13:48:34.771	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    vis.0
    2023-01-19 13:48:34.684	info	vis license is OK.
    vis.0
    2023-01-19 13:48:34.595	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.23
    host.i
    Adapter und Instanzen sehen so aus:
    root@ioBrokerUbuntu2204:~#  iobroker update -1
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.5.10   , installed 2.5.10
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "denon"        : 1.13.4   , installed 1.13.4
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "firetv"       : 1.0.0    , installed 1.0.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "ical"         : 1.13.2   , installed 1.13.2
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "shelly"       : 6.0.0    , installed 6.2.4
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "tankerkoenig" : 3.1.0    , installed 2.1.1  [Updatable]
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "yeelight-2"   : 1.1.2    , installed 1.1.2
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    root@ioBrokerUbuntu2204:~# iobroker list adapters
    system.adapter.admin                   : admin          - v6.3.5
    system.adapter.alexa2                  : alexa2         - v3.23.2
    system.adapter.backitup                : backitup       - v2.5.10
    system.adapter.broadlink2              : broadlink2     - v2.1.5
    system.adapter.chromecast              : chromecast     - v2.3.1
    system.adapter.cloud                   : cloud          - v4.3.0
    system.adapter.deconz                  : deconz         - v1.3.21
    system.adapter.denon                   : denon          - v1.13.4
    system.adapter.device-reminder         : device-reminder - v1.2.9
    system.adapter.discovery               : discovery      - v3.1.0
    system.adapter.dwd                     : dwd            - v2.8.3
    system.adapter.echarts                 : echarts        - v1.0.12
    system.adapter.firetv                  : firetv         - v1.0.0
    system.adapter.flot                    : flot           - v1.11.0
    system.adapter.fritzbox                : fritzbox       - v0.2.1
    system.adapter.fullybrowser            : fullybrowser   - v2.1.2
    system.adapter.harmony                 : harmony        - v1.2.2
    system.adapter.history                 : history        - v2.2.4
    system.adapter.hue                     : hue            - v3.7.1
    system.adapter.ical                    : ical           - v1.13.2
    system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
    system.adapter.icons-icons8            : icons-icons8   - v0.0.1
    system.adapter.icons-mfd-png           : icons-mfd-png  - v1.1.0
    system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
    system.adapter.influxdb                : influxdb       - v3.2.0
    system.adapter.info                    : info           - v1.9.19
    system.adapter.javascript              : javascript     - v6.1.4
    system.adapter.mihome                  : mihome         - v1.4.0
    system.adapter.mqtt                    : mqtt           - v4.0.7
    system.adapter.nut                     : nut            - v1.1.3
    system.adapter.openweathermap          : openweathermap - v0.3.3
    system.adapter.paw                     : paw            - v0.3.2
    system.adapter.ping                    : ping           - v1.5.3
    system.adapter.reolink                 : reolink        - v0.1.1
    system.adapter.rpi2                    : rpi2           - v1.3.2
    system.adapter.samsung                 : samsung        - v0.5.11
    system.adapter.scenes                  : scenes         - v2.3.9
    system.adapter.shelly                  : shelly         - v6.2.4
    system.adapter.simple-api              : simple-api     - v2.7.2
    system.adapter.smartmeter              : smartmeter     - v3.3.4
    system.adapter.socketio                : socketio       - v4.2.0
    system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
    system.adapter.telegram                : telegram       - v1.15.2
    system.adapter.tr-064                  : tr-064         - v4.2.17
    system.adapter.trashschedule           : trashschedule  - v2.0.3
    system.adapter.upnp                    : upnp           - v1.0.21
    system.adapter.vis                     : vis            - v1.4.15
    system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.3.0
    system.adapter.vis-icontwo             : vis-icontwo    - v0.90.0
    system.adapter.vis-inventwo            : vis-inventwo   - v3.3.1
    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
    system.adapter.vis-metro               : vis-metro      - v1.2.0
    system.adapter.vis-players             : vis-players    - v0.1.6
    system.adapter.vis-plumb               : vis-plumb      - v1.0.2
    system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
    system.adapter.vis-weather             : vis-weather    - v2.5.6
    system.adapter.weatherunderground      : weatherunderground - v3.1.6
    system.adapter.web                     : web            - v4.3.0
    system.adapter.yahka                   : yahka          - v0.13.1
    system.adapter.yeelight-2              : yeelight-2     - v1.1.2
    system.adapter.yr                      : yr             - v5.3.0
    root@ioBrokerUbuntu2204:~#  iobroker list instances
    + system.adapter.admin.0                  : admin                 : ioBrokerUbuntu2204                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.1                 : alexa2                : ioBrokerUbuntu2204                       - disabled
    + system.adapter.backitup.0               : backitup              : ioBrokerUbuntu2204                       -  enabled
      system.adapter.broadlink2.0             : broadlink2            : ioBrokerUbuntu2204                       - disabled
      system.adapter.cloud.0                  : cloud                 : ioBrokerUbuntu2204                       - disabled
      system.adapter.deconz.0                 : deconz                : ioBrokerUbuntu2204                       - disabled, port: 80
      system.adapter.denon.0                  : denon                 : ioBrokerUbuntu2204                       - disabled
      system.adapter.device-reminder.0        : device-reminder       : ioBrokerUbuntu2204                       - disabled
      system.adapter.discovery.0              : discovery             : ioBrokerUbuntu2204                       - disabled
      system.adapter.dwd.0                    : dwd                   : ioBrokerUbuntu2204                       - disabled
      system.adapter.echarts.0                : echarts               : ioBrokerUbuntu2204                       - disabled
      system.adapter.firetv.0                 : firetv                : ioBrokerUbuntu2204                       - disabled
      system.adapter.flot.0                   : flot                  : ioBrokerUbuntu2204                       - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : ioBrokerUbuntu2204                       - disabled
      system.adapter.harmony.0                : harmony               : ioBrokerUbuntu2204                       - disabled
      system.adapter.history.0                : history               : ioBrokerUbuntu2204                       - disabled
      system.adapter.hue.0                    : hue                   : ioBrokerUbuntu2204                       - disabled, port: 80
      system.adapter.ical.0                   : ical                  : ioBrokerUbuntu2204                       - disabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBrokerUbuntu2204                       - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBrokerUbuntu2204                       - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBrokerUbuntu2204                       - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBrokerUbuntu2204                       - disabled
      system.adapter.influxdb.0               : influxdb              : ioBrokerUbuntu2204                       - disabled, port: 8086
      system.adapter.info.0                   : info                  : ioBrokerUbuntu2204                       - disabled
      system.adapter.javascript.0             : javascript            : ioBrokerUbuntu2204                       - disabled
      system.adapter.mihome.0                 : mihome                : ioBrokerUbuntu2204                       - disabled, port: 9898, bind: 0.0.0.0
      system.adapter.mqtt.0                   : mqtt                  : ioBrokerUbuntu2204                       - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : ioBrokerUbuntu2204                       - disabled
      system.adapter.ping.0                   : ping                  : ioBrokerUbuntu2204                       - disabled
      system.adapter.reolink.0                : reolink               : ioBrokerUbuntu2204                       - disabled
      system.adapter.rpi2.0                   : rpi2                  : ioBrokerUbuntu2204                       - disabled
      system.adapter.samsung.0                : samsung               : ioBrokerUbuntu2204                       - disabled
      system.adapter.scenes.0                 : scenes                : ioBrokerUbuntu2204                       - disabled
      system.adapter.shelly.0                 : shelly                : ioBrokerUbuntu2204                       - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : ioBrokerUbuntu2204                       - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.simple-api.0             : simple-api            : ioBrokerUbuntu2204                       - disabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : ioBrokerUbuntu2204                       - disabled, port: 8084, bind: 192.168.178.92, run as: admin
      system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerUbuntu2204                       - disabled
      system.adapter.telegram.0               : telegram              : ioBrokerUbuntu2204                       - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : ioBrokerUbuntu2204                       - disabled
      system.adapter.trashschedule.0          : trashschedule         : ioBrokerUbuntu2204                       - disabled
      system.adapter.upnp.0                   : upnp                  : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis-players.0            : vis-players           : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioBrokerUbuntu2204                       - disabled
      system.adapter.vis.0                    : vis                   : ioBrokerUbuntu2204                       - disabled
      system.adapter.web.0                    : web                   : ioBrokerUbuntu2204                       - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yeelight-2.0             : yeelight-2            : ioBrokerUbuntu2204                       - disabled
      system.adapter.yr.0                     : yr                    : ioBrokerUbuntu2204                       - disabled
    Ich konnte alle anderen Adapter starten, und habe auch mal händisch die fehlende VIS-Instanz hinzugefügt, aber starten läßt die sich leider nicht.
    Auf dem Host habe wahlweise Debian 11 oder Ubuntu 2204 installiert, der Fehler bleibt gleich.
    Auf meinem RPi 4 war die 32 Bit Version von Bullseye installiert.
    Ich vermute einen Versionen-Konflikt mit anderen Adaptern ?
    Was kann ich tun ?
    Danke für eure Unterstützung.
    Thomas BraunT B 2 Antworten Letzte Antwort
    • H hansmeier
      Zeit
      info
      Nachricht
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      host.i
      Was kann ich tun ?
      @hansmeier sagte in Nach Backitup-Restore wird der VIS Adapter nicht gestartet:
      Auch im Container: NIE als root herumkaspern.
      Zu vis: Zuerst vis installieren, DANN erst das Backup einspielen.
      • H hansmeier
        Zeit
        info
        Nachricht
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        host.i
        Was kann ich tun ?
        badsnoopy667
        @hansmeier
        Hatte ich auch letztens. Entweder so machen wie @Thomas-Braun gesagt hat, oder folgendes probieren, das hat bei mir geholfen:
        iobroker upgrade vis@1.4.0
        Damit installierst Du die alte Version von Vis, die geht dann wieder und danach kannst Du VIS über den Admin Adapter wieder auf die aktuelle Version upgraden.
        • H Offline
          hansmeier
          Vielen Dank euch beiden.
          Habe die Snapshot Funktion von Proxmox genutzt und schnell noch mal alles neu installiert. Zunächst WEB Adapter , dann VIS Adapter installiert und dann den Rest per Backup.
          Hat geholfen ! Danke.
          • H hansmeier
            @hansmeier
            Hast du auch einen Standard-User angelegt?
            Wie gesagt: root shell ist verboten!
            H 1 Antwort Letzte Antwort
              @hansmeier
              hansmeier
              @thomas-braun Nein, habe ich noch nicht. Wie gehe ich da vor ?
              • H hansmeier
                @hansmeier
                Steht hier drin:
                https://www.iobroker.net/#de/documentation/install/proxmox.md
                @apollon77 Denkst du an den PR? :-D
