  4. Bitte rflink, modbus, mysensors Testen (serialport upgrade)
    5.7k
53 Beiträge 8 Kommentatoren 10.1k Aufrufe
  • C Offline
    ChristianF
    Hm, das hat nicht geklappt. Für mich sieht es so aus als würde er versuchen sich irgendwo eine Source online zu holen, die aber nicht mehr da ist:
    iobroker	2017-06-03 11:42:58.804	info	node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built
    Der Link ist auch wirklich tot (es kommt tatsächlich ein 404).
    Hier der komplette Log (von unten nach oben lesen bitte, das Logfenster war so schnell weg):
    iobroker	2017-06-03 11:43:47.777	info	exit 0
    iobroker	2017-06-03 11:43:47.593	info	upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/img/plc_back.png img/plc_back.png image/png
    iobroker	2017-06-03 11:43:47.510	info	upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index.html index.html text/html
    iobroker	2017-06-03 11:43:47.426	info	upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css
    iobroker	2017-06-03 11:43:47.345	info	upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css
    iobroker	2017-06-03 11:43:47.266	info	upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css
    iobroker	2017-06-03 11:43:47.192	info	upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css
    iobroker	2017-06-03 11:43:47.111	info	upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript
    iobroker	2017-06-03 11:43:47.034	info	upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript
    iobroker	2017-06-03 11:43:46.944	info	upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript
    iobroker	2017-06-03 11:43:46.803	info	upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.min.js lib/js/jsgrid.min.js application/javascript
    iobroker	2017-06-03 11:43:46.638	info	upload [10] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
    iobroker	2017-06-03 11:43:46.604	info	got /opt/iobroker/node_modules/iobroker.modbus/admin
    iobroker	2017-06-03 11:43:43.032	info	└── stampit@2.1.2 (supermixer@1.0.3, lodash@3.10.1)
    iobroker	2017-06-03 11:43:43.032	info	├── jsmodbus@1.2.4 (q@1.0.1)
    iobroker	2017-06-03 11:43:43.032	info	├── crc@3.4.0
    iobroker	2017-06-03 11:43:43.032	info	├── put@0.0.6
    iobroker	2017-06-03 11:43:43.032	info	├── stampit-state-machine@0.2.1
    iobroker	2017-06-03 11:43:43.032	info	├── stampit-event-bus@0.1.1
    iobroker	2017-06-03 11:43:43.032	info	iobroker.modbus@0.5.3 iobroker/node_modules/iobroker.modbus├── stampit-log@0.3.0
    iobroker	2017-06-03 11:43:11.026	info	optional dep failed, continuing serialport@4.0.7
    iobroker	2017-06-03 11:43:11.018	info
    iobroker	2017-06-03 11:43:11.007	info	WARN
    iobroker	2017-06-03 11:43:11.001	info
    iobroker	2017-06-03 11:43:10.988	info	npm
    iobroker	2017-06-03 11:43:10.945	info	Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialpor
    iobroker	2017-06-03 11:43:10.933	info	node-pre-gyp ERR! not ok
    iobroker	2017-06-03 11:43:10.933	info	node-pre-gyp ERR! node-pre-gyp -v v0.6.32
    iobroker	2017-06-03 11:43:10.933	info	node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/serialportnode-pre-gyp ERR! node -v v4.8.2
    iobroker	2017-06-03 11:43:10.929	info	node-pre-gyp ERR! System Linux 4.4.50-v7+node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--f
    iobroker	2017-06-03 11:43:10.922	info	node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:222:5)
    iobroker	2017-06-03 11:43:10.922	info	node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:862:16)
    iobroker	2017-06-03 11:43:10.922	info	node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    iobroker	2017-06-03 11:43:10.922	info	node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
    iobroker	2017-06-03 11:43:10.922	info	ERR! stack Error: Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.modbus/nod
    iobroker	2017-06-03 11:43:10.917	info	node-pre-gyp
    iobroker	2017-06-03 11:43:10.902	info	ERR! build error
    iobroker	2017-06-03 11:43:10.898	info	node-pre-gyp
    iobroker	2017-06-03 11:43:10.888	info	gyp ERR! not ok
    iobroker	2017-06-03 11:43:10.888	info	gyp ERR! node-gyp -v v3.4.0
    iobroker	2017-06-03 11:43:10.888	info	gyp ERR! node -v v4.8.2
    iobroker	2017-06-03 11:43:10.888	info	gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/se
    iobroker	2017-06-03 11:43:10.876	info	gyp ERR! System Linux 4.4.50-v7+
    iobroker	2017-06-03 11:43:10.876	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
    iobroker	2017-06-03 11:43:10.876	info	gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    iobroker	2017-06-03 11:43:10.876	info	gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:87:13)
    iobroker	2017-06-03 11:43:10.867	info	gyp ERR! stack Error: `make` failed with exit code: 2
    iobroker	2017-06-03 11:43:10.847	info	ERR! build error
    iobroker	2017-06-03 11:43:10.842	info
    iobroker	2017-06-03 11:43:10.829	info	gyp
    iobroker	2017-06-03 11:43:10.806	info	make: *** No rule to make target '../.node-gyp/4.8.2/include/node/common.gypi', needed by 'Makefile'. Schluss.
    iobroker	2017-06-03 11:43:10.806	info	make: Entering directory '/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/build'make: Leaving directory '/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/build'
    iobroker	2017-06-03 11:43:03.888	info	gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/.node-gyp"
    iobroker	2017-06-03 11:43:03.881	info	WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.2"
    iobroker	2017-06-03 11:43:03.878	info
    iobroker	2017-06-03 11:43:03.868	info	gyp
    iobroker	2017-06-03 11:42:54.651	info	> node-pre-gyp install --fallback-to-build
    iobroker	2017-06-03 11:42:54.651	info	> serialport@4.0.7 install /opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport
    iobroker	2017-06-03 11:42:18.649	info	npm install https://github.com/ioBroker/ioBroker.modbus/tarball/master --production --prefix "/opt/iobroker" (System call)
    iobroker	2017-06-03 11:42:17.936	info	install https://github.com/ioBroker/ioBroker.modbus/tarball/master
    iobroker	2017-06-03 11:42:15.306	info	url "https://github.com/ioBroker/ioBroker.modbus/tarball/master" modbus --debug
    Es ist übrigens tatsächlich so: der Adapter installiert sich, aber wenn ich Serial auswähle sagt er unter Port "not available". Dies ist übrigens auf dem Raspi und auf der Synology das gleiche (habe eine Multi Host Umgebung).
    Danke für einen Tipp :)
    • apollon77A Offline
      Das er die pre-compiled FIles nicht findet heisst nur das er selbst kompilieren will … und da gibts dann das Problem:
      Probler mal also Root bzw mit sudo den Adapter zu installieren.
      in /opt/iobroker ein "sudo install iobroker.modbus –unsafe-perm"
      • K Offline
        knopers1
        ich komme nicht weiter..
        Habe Rflink 1.1.5 mit node 6.x
        Im Log steht:
        rflink.0 2017-06-04 20:00:38.575 warn Module serialport is not available
        Ideeen Kollegen?
          Gleiche Frage wie oben … was sagt das log beim Update?
          • K Offline
            knopers1
            @apollo,
            hilf mir da etwas weiter… :D
            Ich habe das System auf ein OrangePi installiert.
            mit :
            curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
            sudo apt-get install -y build-essential python nodejs
            habe ich node 6 istalliert bekommen.
            RFlink Adapter bleibt gelb, dort kann ich auch kein Serialport auswählen. Im Feld steht "nicht möglich"
            im LOg steht:
            root@orangepiplus2e:/opt/iobroker# node -v
            v6.10.3
            root@orangepiplus2e:/opt/iobroker# npm -v
            3.10.10
            js-controller ist bereits die Ver. 1.0.3 installiert
            IOBroker-Admin hat die Version 1.7.6
            wie kann ich ein Log vom Update erstellen?
            Im Prinzip läuft alles nach der Umstellung vom RPI nach OrangePI bis auf den RFLink Adapter!
            Alles andere scheint zu funzen…
            Kannst Du helfen?
              Hast du die Version aus Github versucht?
              Hast du das Update/due Installation als root ausgeführt?
              Rainer
              • K Offline
                knopers1
                @Homoran:
                Rainer `
                ja Rainer, bin die ganze Zeit als root angemeldet.
                Die Installation aus Github geht nicht.
                Ich sehe im Fenster einige Fehler und kann sie nicht kopieren…. Danach beendet das ganze und unter Adapter sieht man dort den RFlink Adapter nicht.!
                Wie kann ich die Installation aus der Konsole Putty anstoßen? So könnte ich wenigstens die Fehler hier zeigen.
                Im Log sieht man soetwas...
                host.orangepiplus2e	2017-06-04 22:23:00.553	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                iobroker	2017-06-04 22:22:59.511	info	exit 0
                iobroker	2017-06-04 22:22:59.491	error	Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/rflink/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter
                iobroker	2017-06-04 22:22:58.166	info	npm ERR! code 1
                iobroker	2017-06-04 22:22:58.166	info	npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
                iobroker	2017-06-04 22:22:58.158	info
                iobroker	2017-06-04 22:22:57.632	info	ERR! enoent and is related to npm not being able to find a file.npm ERR! enoent
                iobroker	2017-06-04 22:22:57.629	info	npm
                iobroker	2017-06-04 22:22:57.629	info	npm ERR! enoent This is most likely not a problem with npm itself
                iobroker	2017-06-04 22:22:57.629	info	ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/minimist-f6e01a6b' -> '/opt/iobroker/node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/
                iobroker	2017-06-04 22:22:57.625	info	npm
                iobroker	2017-06-04 22:22:57.625	info	npm ERR! errno -2npm ERR! syscall rename
                iobroker	2017-06-04 22:22:57.621	info	ERR! path /opt/iobroker/node_modules/.staging/minimist-f6e01a6bnpm ERR! code ENOENT
                iobroker	2017-06-04 22:22:57.617	info	npm
                iobroker	2017-06-04 22:22:57.617	info	npm ERR! node v6.10.3npm ERR! npm v3.10.10
                iobroker	2017-06-04 22:22:57.614	info	npm ERR! Linux 3.4.113-sun8inpm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.rflink/tarball/master" "--production" "--prefix" "/opt/iobroker"
                iobroker	2017-06-04 22:22:57.605	info	WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/mdns/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/stk500/package.j
                iobroker	2017-06-04 22:22:57.601	info	npm
                iobroker	2017-06-04 22:21:06.725	info	npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production --prefix "/opt/iobroker" (System call)
                iobroker	2017-06-04 22:21:06.171	info	install https://github.com/ioBroker/ioBroker.rflink/tarball/master
                iobroker	2017-06-04 22:21:04.240	info	url "https://github.com/ioBroker/ioBroker.rflink/tarball/master" rflink
                evtl. das Bild kann dort etwas helfen…
                • C Offline
                  ChristianF
                  @apollon77:
                  in /opt/iobroker ein "sudo install iobroker.modbus –unsafe-perm" `
                  Danke Dir. So hat es zumindest für die Installation funktioniert.
                  Falls jemand anders das selbe Problem hat: im Aufruf oben fehlt ein "npm":
                  sudo npm install iobroker.modbus --unsafe-perm
                  Allerdings klappt der Zugriff auf den Port immernoch nicht:
                  modbus.0	2017-06-03 23:21:34.929	error	Cannot create modbus master!
                  modbus.0	2017-06-03 23:21:34.924	error	Cannot open port "/dev/ttyUSB0" [9600]: ReferenceError: serialport is not defined
                  modbus.0	2017-06-03 23:21:34.352	info	starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v4.8.2
                  Der Adapter liegt allerdings definitiv auf /dev/ttyUSB0, denn CUxD findet ihn:
                    USB 1-1.2 - {NONE} FT232R USB UART [FF] - /dev/ttyUSB0 {:566937s} - connected - Sun May 28 09:55:39 2017
                  Danke für (noch) einen Tipp :)
                  Viele Grüße
                  Christian
                  • K Offline
                    knopers1
                    so, wenn ich es richtig gemacht habe, soll das die Ausgabe von der Installation sein!
                    root@orangepiplus2e:/opt/iobroker# ./iobroker url "https://github.com/ioBroker/ioBroker.rflink/tarball/master" rflink
                    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/mdns/package.json'
                    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/stk500/package.json'
                    got /opt/iobroker/node_modules/iobroker.rflink/admin
                    upload [2] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/rflink.png rflink.png image/png
                    upload [1] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/parse.js parse.js application/javascript
                    upload [0] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/index.html index.html text/html
                      Jupp, Fehler gefunden … Please retry. Neu vom Github bitte installieren (Version bleibt die gleiche)
                      • C Offline
                        ChristianF
                        Gibt es einen Trick wie man mit sudo von github installieren kann?
                          sudo npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production
                          • K Offline
                            knopers1
                            hmm, nach Installation findet man den Adapter unter IOBroker nicht….
                            login as: root
                            root@192.168.1.99's password:
                              ___                               ____  _         ____  _____
                             / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_)  _    |___ \| ____|
                            | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | |_| |_    __) |  _|
                            | |_| | | | (_| | | | | (_| |  __/ |  __/| |_   _|  / __/| |___
                             \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| |_|   |_____|_____|
                                                   |___/
                            Welcome to ARMBIAN 5.25 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i
                            System load:   2.80             Up time:       4 min
                            Memory usage:  2 % of 2014Mb    IP:            192.168.1.99
                            CPU temp:      31°C
                            Usage of /:    7% of 29G        storage/:      7% of 29G
                            Last login: Sun Jun  4 20:17:44 2017 from lenovo-pc.fritz.box
                            root@orangepiplus2e:~# cd /opt/iobroker
                            root@orangepiplus2e:/opt/iobroker# iobroker start
                            Starting iobroker controller daemon...
                            iobroker controller daemon started. PID: 959
                            root@orangepiplus2e:/opt/iobroker# sudo npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production
                            iobroker@1.0.0 /opt/iobroker
                            └─┬ iobroker.rflink@1.1.5
                              └─┬ avrgirl-arduino@1.11.12
                                ├── browser-serialport@2.0.3  (git://github.com/noopkat/browser-serialport.git#a1cecbee1276bfe78b0491f8d13544c70859ff36)
                                └── stk500@1.0.4  (git://github.com/noopkat/js-stk500v1.git#e116a1f72abdafc7d57eb0ee58221556d2b5def4)
                              Welches Repository hast du eingestellt?
                              Welche Admin Version?
                              @knopers1:
                              hmm, nach Installation findet man den Adapter unter IOBroker nicht…. `
                              Und warum zeigst du uns die Instanzen und nicht die verfügbaren Adapter?
                              Oder meintest du, dass nach Hinzufügen einer Instanz diese nicht erscheint?
                              • K Offline
                                knopers1
                                eigentlich habe ich oben schon alles geschrieben… Hier eine kleine Zusammenfassung :)
                                v6.10.3
                                3.10.10
                                Habe Rflink 1.1.5 mit node 6.x, Ja, nach der Installation aus dem Github wird der Adapter unter den installierten Adaptern nicht angezeigt. Wenn ich allerdings ganz normal über den + installiere, geht es ohne Probleme. Dort lässt sich aber die Schnittstelle nicht auswählen. Im Feld steht Text "nicht möglich"
                                node 6 habe ich so installiert:
                                Mit älteren Node Version ging es auch nicht:
                                root@orangepiplus2e:~# node -v
                                v4.2.1
                                root@orangepiplus2e:~# v4.2.1^C
                                root@orangepiplus2e:~# npm -v
                                2.14.7
                                Dort konnte man wenigstens /dev/ttyS0 auswählen. Aber auch dort war die USB Schnittstelle nicht da! :|
                                  @knopers1:
                                  eigentlich habe ich oben schon alles geschrieben… `
                                  leider nicht.
                                  Die Frage nach dem Repository hast du auch jetzt nicht beantwortet.
                                  Und auch hier scheinen wir (wegen unterschiedlicher Benutzung der Termini?) aneinander vorbeizureden.
                                  @knopers1:
                                  nach der Installation aus dem Github wird der Adapter unter den installierten Adaptern nicht angezeigt `
                                  Die installierten Adapter werden im Reiter Adapter angezeigt, die angelegten Instanzen im Reiter Instanzen.
                                  Ich habe das bereits ausführlich erklärt, finde jetzt nach intensiven Suchen den Thread nicht mehr.
                                  • Adapter installieren bedeutet die notwendigen Dateien aus dem Internet auf den ioBroker-Server zu spielen.
                                    • dabei rutscht der Adapter bei der alphabetischen Sortierung in der Liste der verfügbaren Adapter nach oben unter die installierten Adapter
                                  dies ist der Konsolenbefehl
                                  sudo iobroker install AdapterName
                                  • Instanz erzeugen bedeutet, dass eine für die Installation verwendbare und konfigurierbare Version des Adapters angelegt wird
                                    • jetzt sollte zusätzlich eine [1] in der Adapterliste und die Instanz unter Instanzen erscheinen
                                    • ist diese Instanz konfiguriert und gestartet erscheint unter Adapter eine [1/~~[b]~~1],
                                  sudo iobroker add AdapterName
                                  und entspricht dem (+) im Reiter Adapter
                                  Natürlich musstest du das noch zusätzlich(!) machen.
                                  EDIT: nachdem ich das alles nochmal getippt habe, habe ich den Post endlich gefunden
                                  http://forum.iobroker.net/viewtopic.php … 779#p68779
                                  @knopers1:
                                  Dort lässt sich aber die Schnittstelle nicht auswählen `
                                  Das Phänomen habe ich auf meinen Tinkerboards auch. allerdings keine ("nicht möglich" info. Die Version 1.1.5 ist ok, auf dem Pine64 läuft sie.
                                  IMHO liegt das am Paket serialport
                                  Rainer
                                  • K Offline
                                    knopers1
                                    o.k, wo sieht man es welche Repository ich habe? Tut mir leid Rainer, ich habe alles nach der Anleitung installiert und lediglich nur die Node in der Version 6 mit dem oben genannten Befehlen installiert.
                                    Ich habe Bilder upgeloadet, dort sieht man doch den RF-Link Adapter und deren Version
                                    Version 1.1.2 und installiert 1.1.5… [1/1]
                                    Wir können jetzt noch lange so diskutieren, nur bringen tut es nicht wirklich viel…
                                    Kannst Du helfen? Welche infos brauchst Du noch? Und wie kann ich die die Infos am besten zukommen lassen?
                                    Ich bin kein Profi Rainer. Da könntest mir sagen wie ich an die benötigten Sachen kommen kann...
                                    Wo sehe ich welche Repository ich habe?
                                      @Homoran:
                                      @knopers1:
                                      IMHO liegt das am Paket serialport `
                                      Korrekt, aber wenn das so ist dann gibts an sich auch Fehler bei der Installation des Adapters!
                                      Wenn es die nicht gab und Seriell auftaucht dann die Frage: Läuft iobroker auf der Maschine als Root oder nicht? Wenn nicht dann kann es noch daran liegen.
                                      Mal Adapter in "Debug" laufen lassen?
                                        @knopers1:
                                        wo sieht man es welche Repository ich habe? `
                                        Die Pfade zu den verschiedenen Repositories sollten hier zu sehen sein:
                                        http://www.iobroker.net/docu/?page_id=6 … positories
                                        das ausgewählte im Pulldownmenü im Reiter Haupteinstellungen unter aktiver Verwahrungsort
                                        @knopers1:
                                        Version 1.1.2 und installiert 1.1.5… [1/1] `
                                        ist ja auch alles im grünen Bereich.
                                        @knopers1:
                                        Wir können jetzt noch lange so diskutieren, nur bringen tut es nicht wirklich viel.. `
                                        naja, vielleicht für die Zukunft damit wir (und andere) nicht aneinander vorbeireden.
                                        @knopers1:
                                        Kannst Du helfen? `
                                        Leider nein, wie gesagt habe ich das selbe Problem
                                        @knopers1:
                                        Welche infos brauchst Du noch? Und wie kann ich die die Infos am besten zukommen lassen? `
                                        Im Moment nichts - jetzt sind wir beide auf dem neuesten Stand - also müssen wir den gemeinsamen Nenner von OPi und Tinkerboard finden, um der Sache auf den Grund gehen zu können.
                                        Vielleicht kann @apollon77 da noch etwas zu sagen - ich glaube er hatte woanders gerade etwas gefixt.
                                        EDIT: hat er gerade
                                        @knopers1:
                                        Ich bin kein Profi Rainer. `
                                        ich auch nicht!
                                        Rainer
                                          Marcolotti
                                          Ich habe das gleiche Phänomen bei den Raspis gehabt. Beim Acer Revo stecken nun alle Sticks (CUL;RFLINK;JEELINK) in einem Gerät und da funktioniert es.
                                          Gruß Marco
                                          CCU2-CuxD&Cul868MHz, 44xHM Geräte, 20xMAX Fenstersensoren.Acer Revo mit IoBroker, Tablet Captiva 9,7 SFHD. SMA SB2.5,STP7000TL20,SMA Energy Meter, Echo, Harmony, JeeLink868, Arduino 433MHz, MaxtoxCUL868,MilightEasyLED,Hue
