  4. Bitte rflink, modbus, mysensors Testen (serialport upgrade)
53 Beiträge 8 Kommentatoren 10.3k Aufrufe
  • apollon77A Offline
    Jupp, Fehler gefunden … Please retry. Neu vom Github bitte installieren (Version bleibt die gleiche)
    • C Offline
      ChristianF
      Gibt es einen Trick wie man mit sudo von github installieren kann?
        sudo npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production
          knopers1
          hmm, nach Installation findet man den Adapter unter IOBroker nicht….
          login as: root
          root@192.168.1.99's password:
            ___                               ____  _         ____  _____
           / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_)  _    |___ \| ____|
          | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | |_| |_    __) |  _|
          | |_| | | | (_| | | | | (_| |  __/ |  __/| |_   _|  / __/| |___
           \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| |_|   |_____|_____|
                                 |___/
          Welcome to ARMBIAN 5.25 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i
          System load:   2.80             Up time:       4 min
          Memory usage:  2 % of 2014Mb    IP:            192.168.1.99
          CPU temp:      31°C
          Usage of /:    7% of 29G        storage/:      7% of 29G
          Last login: Sun Jun  4 20:17:44 2017 from lenovo-pc.fritz.box
          root@orangepiplus2e:~# cd /opt/iobroker
          root@orangepiplus2e:/opt/iobroker# iobroker start
          Starting iobroker controller daemon...
          iobroker controller daemon started. PID: 959
          root@orangepiplus2e:/opt/iobroker# sudo npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production
          iobroker@1.0.0 /opt/iobroker
          └─┬ iobroker.rflink@1.1.5
            └─┬ avrgirl-arduino@1.11.12
              ├── browser-serialport@2.0.3  (git://github.com/noopkat/browser-serialport.git#a1cecbee1276bfe78b0491f8d13544c70859ff36)
              └── stk500@1.0.4  (git://github.com/noopkat/js-stk500v1.git#e116a1f72abdafc7d57eb0ee58221556d2b5def4)
          npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/mdns/package.json'
          npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/stk500/package.json'
            Welches Repository hast du eingestellt?
            Welche Admin Version?
            @knopers1:
            hmm, nach Installation findet man den Adapter unter IOBroker nicht…. `
            Und warum zeigst du uns die Instanzen und nicht die verfügbaren Adapter?
            Oder meintest du, dass nach Hinzufügen einer Instanz diese nicht erscheint?
              knopers1
              eigentlich habe ich oben schon alles geschrieben… Hier eine kleine Zusammenfassung :)
              root@orangepiplus2e:/opt/iobroker# node -v
              v6.10.3
              root@orangepiplus2e:/opt/iobroker# npm -v
              3.10.10
              js-controller ist bereits die Ver. 1.0.3 installiert
              IOBroker-Admin hat die Version 1.7.6
              Habe Rflink 1.1.5 mit node 6.x, Ja, nach der Installation aus dem Github wird der Adapter unter den installierten Adaptern nicht angezeigt. Wenn ich allerdings ganz normal über den + installiere, geht es ohne Probleme. Dort lässt sich aber die Schnittstelle nicht auswählen. Im Feld steht Text "nicht möglich"
              node 6 habe ich so installiert:
              curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
              sudo apt-get install -y build-essential python nodejs
              Mit älteren Node Version ging es auch nicht:
              root@orangepiplus2e:~# node -v
              v4.2.1
              root@orangepiplus2e:~# v4.2.1^C
              root@orangepiplus2e:~# npm -v
              2.14.7
              Dort konnte man wenigstens /dev/ttyS0 auswählen. Aber auch dort war die USB Schnittstelle nicht da! :|
                @knopers1:
                eigentlich habe ich oben schon alles geschrieben… `
                leider nicht.
                Die Frage nach dem Repository hast du auch jetzt nicht beantwortet.
                Und auch hier scheinen wir (wegen unterschiedlicher Benutzung der Termini?) aneinander vorbeizureden.
                @knopers1:
                nach der Installation aus dem Github wird der Adapter unter den installierten Adaptern nicht angezeigt `
                Die installierten Adapter werden im Reiter Adapter angezeigt, die angelegten Instanzen im Reiter Instanzen.
                Ich habe das bereits ausführlich erklärt, finde jetzt nach intensiven Suchen den Thread nicht mehr.
                • Adapter installieren bedeutet die notwendigen Dateien aus dem Internet auf den ioBroker-Server zu spielen.
                  • dabei rutscht der Adapter bei der alphabetischen Sortierung in der Liste der verfügbaren Adapter nach oben unter die installierten Adapter
                dies ist der Konsolenbefehl
                sudo iobroker install AdapterName
                • Instanz erzeugen bedeutet, dass eine für die Installation verwendbare und konfigurierbare Version des Adapters angelegt wird
                  • jetzt sollte zusätzlich eine [1] in der Adapterliste und die Instanz unter Instanzen erscheinen
                  • ist diese Instanz konfiguriert und gestartet erscheint unter Adapter eine [1/~~[b]~~1],
                sudo iobroker add AdapterName
                und entspricht dem (+) im Reiter Adapter
                Natürlich musstest du das noch zusätzlich(!) machen.
                EDIT: nachdem ich das alles nochmal getippt habe, habe ich den Post endlich gefunden
                http://forum.iobroker.net/viewtopic.php … 779#p68779
                @knopers1:
                Dort lässt sich aber die Schnittstelle nicht auswählen `
                Das Phänomen habe ich auf meinen Tinkerboards auch. allerdings keine ("nicht möglich" info. Die Version 1.1.5 ist ok, auf dem Pine64 läuft sie.
                IMHO liegt das am Paket serialport
                  knopers1
                  o.k, wo sieht man es welche Repository ich habe? Tut mir leid Rainer, ich habe alles nach der Anleitung installiert und lediglich nur die Node in der Version 6 mit dem oben genannten Befehlen installiert.
                  Ich habe Bilder upgeloadet, dort sieht man doch den RF-Link Adapter und deren Version
                  Version 1.1.2 und installiert 1.1.5… [1/1]
                  Wir können jetzt noch lange so diskutieren, nur bringen tut es nicht wirklich viel…
                  Kannst Du helfen? Welche infos brauchst Du noch? Und wie kann ich die die Infos am besten zukommen lassen?
                  Ich bin kein Profi Rainer. Da könntest mir sagen wie ich an die benötigten Sachen kommen kann...
                  Wo sehe ich welche Repository ich habe?
                    @Homoran:
                    @knopers1:
                    IMHO liegt das am Paket serialport `
                    Korrekt, aber wenn das so ist dann gibts an sich auch Fehler bei der Installation des Adapters!
                    Wenn es die nicht gab und Seriell auftaucht dann die Frage: Läuft iobroker auf der Maschine als Root oder nicht? Wenn nicht dann kann es noch daran liegen.
                    Mal Adapter in "Debug" laufen lassen?
                      @knopers1:
                      wo sieht man es welche Repository ich habe? `
                      Die Pfade zu den verschiedenen Repositories sollten hier zu sehen sein:
                      http://www.iobroker.net/docu/?page_id=6 … positories
                      das ausgewählte im Pulldownmenü im Reiter Haupteinstellungen unter aktiver Verwahrungsort
                      @knopers1:
                      Version 1.1.2 und installiert 1.1.5… [1/1] `
                      ist ja auch alles im grünen Bereich.
                      @knopers1:
                      Wir können jetzt noch lange so diskutieren, nur bringen tut es nicht wirklich viel.. `
                      naja, vielleicht für die Zukunft damit wir (und andere) nicht aneinander vorbeireden.
                      @knopers1:
                      Kannst Du helfen? `
                      Leider nein, wie gesagt habe ich das selbe Problem
                      @knopers1:
                      Welche infos brauchst Du noch? Und wie kann ich die die Infos am besten zukommen lassen? `
                      Im Moment nichts - jetzt sind wir beide auf dem neuesten Stand - also müssen wir den gemeinsamen Nenner von OPi und Tinkerboard finden, um der Sache auf den Grund gehen zu können.
                      Vielleicht kann @apollon77 da noch etwas zu sagen - ich glaube er hatte woanders gerade etwas gefixt.
                      EDIT: hat er gerade
                      @knopers1:
                      Ich bin kein Profi Rainer. `
                      ich auch nicht!
                        Marcolotti
                        Ich habe das gleiche Phänomen bei den Raspis gehabt. Beim Acer Revo stecken nun alle Sticks (CUL;RFLINK;JEELINK) in einem Gerät und da funktioniert es.
                        Gruß Marco
                        CCU2-CuxD&Cul868MHz, 44xHM Geräte, 20xMAX Fenstersensoren.Acer Revo mit IoBroker, Tablet Captiva 9,7 SFHD. SMA SB2.5,STP7000TL20,SMA Energy Meter, Echo, Harmony, JeeLink868, Arduino 433MHz, MaxtoxCUL868,MilightEasyLED,Hue
                          knopers1
                          ok, hier noch Repositories, dort aber habe ich nichts verstellt…
                            @apollon77:
                            Wenn es die nicht gab und Seriell auftaucht dann die Frage: Läuft iobroker auf der Maschine als Root oder nicht? `
                            Das ist das was ich auch vermute.
                            Ich habe zuwenig Ahnung von Linux.
                            Früher habe ich alles als "echter" root installiert, dann nur noch mit sudo, letzte Zeit nur noch mit sudo su. (auch die aktuellen Images!)
                            Trotzdem denke ich, dass da ein Unterschied zur echten root-Installation ist. Zumindest glaube ich, dass der Besitzer trotzdem der nicht privilegierte User bleibt, auch wenn root am Prompt steht.
                              @knopers1:
                              ok, hier noch Repositories, dort aber habe ich nichts verstellt… `
                              Danke, aber entscheidend ist die Auswahl, die unter dem Reiter Haupteinstellungen steht.
                                knopers1
                                ok, Danke Rainer… Unter Haupteinstellungen sieht man nicht viel...siehe Bild.
                                ich habe alles neu aufgesetzt! Anbei der Auszug aus der Konsole von derb Installation!
                                System load:   1.20             Up time:       7 hours
                                Memory usage:  8 % of 2014Mb    IP:            192.168.1.99
                                CPU temp:      34°C
                                Last login: Mon Jun  5 13:15:16 2017 from lenovo-pc.fritz.box
                                root@orangepiplus2e:~# sudo npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production
                                > serialport@4.0.7 install /root/node_modules/avrgirl-arduino/node_modules/serialport
                                > node-pre-gyp install --fallback-to-build
                                node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
                                node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.3 (node-v48 ABI) (falling back to source compile with node-gyp)
                                make: Entering directory '/root/node_modules/avrgirl-arduino/node_modules/serialport/build'
                                  CXX(target) Release/obj.target/serialport/src/serialport.o
                                ../src/serialport.cpp: In function ‘int getIntFromObject(v8::Local<v8::object>, std::string)’:
                                ../src/serialport.cpp:90:52: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                   return getValueFromObject(options, key)->ToInt32()->Int32Value();
                                ../src/serialport.cpp: In function ‘double getDoubleFromObject(v8::Local<v8::object>, std::string)’:
                                ../src/serialport.cpp:102:53: warning: ‘v8::Local <v8::number>v8::Value::ToNumber() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8166): Use maybe version [-Wdeprecated-declarations]
                                   return getValueFromObject(options, key)->ToNumber()->NumberValue();
                                ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
                                ../src/serialport.cpp:174:31: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                     int fd = argv[1]->ToInt32()->Int32Value();
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:193:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                   int fd = info[0]->ToInt32()->Int32Value();
                                ../src/serialport.cpp:217:116: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                   baton->baudRate = Nan::Get(options, Nan::New<v8::string>("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Write(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:252:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:369:32: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                   baton->fd = info[0]->ToInt32()->Int32Value();
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:480:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:528:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:585:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                  CXX(target) Release/obj.target/serialport/src/serialport_unix.o
                                ../src/serialport_unix.cpp: In function ‘OpenBatonPlatformOptions* ParsePlatformOptions(const v8::Local<v8::object>&)’:
                                ../src/serialport_unix.cpp:44:109: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                   result->vmin = Nan::Get(options, Nan::New<v8::string>("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                                ../src/serialport_unix.cpp:45:111: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                   result->vtime = Nan::Get(options, Nan::New<v8::string>("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                                  CXX(target) Release/obj.target/serialport/src/serialport_poller.o
                                ../src/serialport_poller.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE SerialportPoller::New(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport_poller.cpp:86:31: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
                                   obj->fd_ = info[0]->ToInt32()->Int32Value();
                                  SOLINK_MODULE(target) Release/obj.target/serialport.node
                                  COPY Release/serialport.node
                                make: Leaving directory '/root/node_modules/avrgirl-arduino/node_modules/serialport/build'
                                > serialport@4.0.7 install /root/node_modules/iobroker.rflink/node_modules/serialport
                                make: Entering directory '/root/node_modules/iobroker.rflink/node_modules/serialport/build'
                                make: Leaving directory '/root/node_modules/iobroker.rflink/node_modules/serialport/build'
                                /root
                                  ├─┬ avrgirl-arduino@1.11.12
                                  │ ├─┬ async@2.4.1
                                  │ │ └── lodash@4.17.4
                                  │ ├─┬ awty@0.1.0
                                  │ │ └── isval@0.0.2
                                  │ ├── browser-serialport@2.0.3  (git://github.com/noopkat/browser-serialport.git#a1cecbee1276bfe78b0491f8d13544c70859ff36)
                                  │ ├── chip.avr.avr109@1.1.0
                                  │ ├── colors@1.1.2
                                  │ ├── graceful-fs@4.1.11
                                  │ ├── intel-hex@0.1.1
                                  │ ├── minimist@1.2.0
                                  │ ├─┬ serialport@4.0.7
                                  │ │ ├── nan@2.6.2
                                  │ │ └─┬ node-pre-gyp@0.6.32
                                  │ │   ├─┬ mkdirp@0.5.1
                                  │ │   │ └── minimist@0.0.8
                                  │ │   ├─┬ nopt@3.0.6
                                  │ │   │ └── abbrev@1.0.9
                                  │ │   ├─┬ npmlog@4.0.1
                                  │ │   │ ├─┬ are-we-there-yet@1.1.2
                                  │ │   │ │ ├── delegates@1.0.0
                                  │ │   │ │ └─┬ readable-stream@2.2.2
                                  │ │   │ │   ├── buffer-shims@1.0.0
                                  │ │   │ │   ├── core-util-is@1.0.2
                                  │ │   │ │   ├── inherits@2.0.3
                                  │ │   │ │   ├── isarray@1.0.0
                                  │ │   │ │   ├── process-nextick-args@1.0.7
                                  │ │   │ │   ├── string_decoder@0.10.31
                                  │ │   │ │   └── util-deprecate@1.0.2
                                  │ │   │ ├── console-control-strings@1.1.0
                                  │ │   │ ├─┬ gauge@2.7.2
                                  │ │   │ │ ├── aproba@1.0.4
                                  │ │   │ │ ├── has-unicode@2.0.1
                                  │ │   │ │ ├── object-assign@4.1.0
                                  │ │   │ │ ├── signal-exit@3.0.2
                                  │ │   │ │ ├─┬ string-width@1.0.2
                                  │ │   │ │ │ ├── code-point-at@1.1.0
                                  │ │   │ │ │ └─┬ is-fullwidth-code-point@1.0.0
                                  │ │   │ │ │   └── number-is-nan@1.0.1
                                  │ │   │ │ ├─┬ strip-ansi@3.0.1
                                  │ │   │ │ │ └── ansi-regex@2.0.0
                                  │ │   │ │ ├── supports-color@0.2.0
                                  │ │   │ │ └── wide-align@1.1.0
                                  │ │   │ └── set-blocking@2.0.0
                                  │ │   ├─┬ rc@1.1.6
                                  │ │   │ ├── deep-extend@0.4.1
                                  │ │   │ ├── ini@1.3.4
                                  │ │   │ ├── minimist@1.2.0
                                  │ │   │ └── strip-json-comments@1.0.4
                                  │ │   ├─┬ request@2.79.0
                                  │ │   │ ├── aws-sign2@0.6.0
                                  │ │   │ ├── aws4@1.5.0
                                  │ │   │ ├── caseless@0.11.0
                                  │ │   │ ├─┬ combined-stream@1.0.5
                                  │ │   │ │ └── delayed-stream@1.0.0
                                  │ │   │ ├── extend@3.0.0
                                  │ │   │ ├── forever-agent@0.6.1
                                  │ │   │ ├─┬ form-data@2.1.2
                                  │ │   │ │ └── asynckit@0.4.0
                                  │ │   │ ├─┬ har-validator@2.0.6
                                  │ │   │ │ ├─┬ chalk@1.1.3
                                  │ │   │ │ │ ├── ansi-styles@2.2.1
                                  │ │   │ │ │ ├── escape-string-regexp@1.0.5
                                  │ │   │ │ │ ├─┬ has-ansi@2.0.0
                                  │ │   │ │ │ │ └── ansi-regex@2.0.0
                                  │ │   │ │ │ ├─┬ strip-ansi@3.0.1
                                  │ │   │ │ │ └── supports-color@2.0.0
                                  │ │   │ │ ├─┬ is-my-json-valid@2.15.0
                                  │ │   │ │ │ ├── generate-function@2.0.0
                                  │ │   │ │ │ ├─┬ generate-object-property@1.2.0
                                  │ │   │ │ │ │ └── is-property@1.0.2
                                  │ │   │ │ │ ├── jsonpointer@4.0.0
                                  │ │   │ │ │ └── xtend@4.0.1
                                  │ │   │ │ └─┬ pinkie-promise@2.0.1
                                  │ │   │ │   └── pinkie@2.0.4
                                  │ │   │ ├─┬ hawk@3.1.3
                                  │ │   │ │ ├── boom@2.10.1
                                  │ │   │ │ ├── cryptiles@2.0.5
                                  │ │   │ │ ├── hoek@2.16.3
                                  │ │   │ │ └── sntp@1.0.9
                                  │ │   │ ├─┬ http-signature@1.1.1
                                  │ │   │ │ ├── assert-plus@0.2.0
                                  │ │   │ │ ├─┬ jsprim@1.3.1
                                  │ │   │ │ │ ├── extsprintf@1.0.2
                                  │ │   │ │ │ ├── json-schema@0.2.3
                                  │ │   │ │ │ └── verror@1.3.6
                                  │ │   │ │ └─┬ sshpk@1.10.1
                                  │ │   │ │   ├── asn1@0.2.3
                                  │ │   │ │   ├── assert-plus@1.0.0
                                  │ │   │ │   ├── bcrypt-pbkdf@1.0.0
                                  │ │   │ │   ├── dashdash@1.14.1
                                  │ │   │ │   ├── ecc-jsbn@0.1.1
                                  │ │   │ │   ├── getpass@0.1.6
                                  │ │   │ │   ├── jodid25519@1.0.2
                                  │ │   │ │   ├── jsbn@0.1.0
                                  │ │   │ │   └── tweetnacl@0.14.4
                                  │ │   │ ├── is-typedarray@1.0.0
                                  │ │   │ ├── isstream@0.1.2
                                  │ │   │ ├── json-stringify-safe@5.0.1
                                  │ │   │ ├─┬ mime-types@2.1.13
                                  │ │   │ │ └── mime-db@1.25.0
                                  │ │   │ ├── oauth-sign@0.8.2
                                  │ │   │ ├── qs@6.3.0
                                  │ │   │ ├── stringstream@0.0.5
                                  │ │   │ ├─┬ tough-cookie@2.3.2
                                  │ │   │ │ └── punycode@1.4.1
                                  │ │   │ ├── tunnel-agent@0.4.3
                                  │ │   │ └── uuid@3.0.1
                                  │ │   ├─┬ rimraf@2.5.4
                                  │ │   │ └─┬ glob@7.1.1
                                  │ │   │   ├── fs.realpath@1.0.0
                                  │ │   │   ├─┬ inflight@1.0.6
                                  │ │   │   │ └── wrappy@1.0.2
                                  │ │   │   ├─┬ minimatch@3.0.3
                                  │ │   │   │ └─┬ brace-expansion@1.1.6
                                  │ │   │   │   ├── balanced-match@0.4.2
                                  │ │   │   │   └── concat-map@0.0.1
                                  │ │   │   ├─┬ once@1.4.0
                                  │ │   │   └── path-is-absolute@1.0.1
                                  │ │   ├── semver@5.3.0
                                  │ │   ├─┬ tar@2.2.1
                                  │ │   │ ├── block-stream@0.0.9
                                  │ │   │ ├─┬ fstream@1.0.10
                                  │ │   │ │ └── graceful-fs@4.1.11
                                  │ │   │ └── inherits@2.0.3
                                  │ │   └─┬ tar-pack@3.3.0
                                  │ │     ├─┬ debug@2.2.0
                                  │ │     │ └── ms@0.7.1
                                  │ │     │ ├── graceful-fs@4.1.11
                                  │ │     ├─┬ fstream-ignore@1.0.5
                                  │ │     │ └─┬ minimatch@3.0.3
                                  │ │     ├─┬ once@1.3.3
                                  │ │     ├─┬ readable-stream@2.1.5
                                  │ │     └── uid-number@0.0.6
                                  │ ├─┬ stk500@1.0.4  (git://github.com/noopkat/js-stk500v1.git#e116a1f72abdafc7d57eb0ee58221556d2b5def4)
                                  │ │ ├── async@0.9.2
                                  │ │ └── buffer-equal@0.0.1
                                  │ └─┬ stk500-v2@1.0.2
                                  │   └── async@0.9.2
                                  ├─┬ request@2.81.0
                                  │ ├── aws4@1.6.0
                                  │ ├── caseless@0.12.0
                                  │ ├── extend@3.0.1
                                  │ ├─┬ form-data@2.1.4
                                  │ ├─┬ har-validator@4.2.1
                                  │ │ ├─┬ ajv@4.11.8
                                  │ │ │ ├── co@4.6.0
                                  │ │ │ └─┬ json-stable-stringify@1.0.1
                                  │ │ │   └── jsonify@0.0.0
                                  │ │ └── har-schema@1.0.5
                                  │ ├─┬ hawk@3.1.3
                                  │ │ ├── boom@2.10.1
                                  │ │ ├── hoek@2.16.3
                                  │ │ └── sntp@1.0.9
                                  │ │ ├─┬ jsprim@1.4.0
                                  │ │ └─┬ sshpk@1.13.0
                                  │ │   ├── asn1@0.2.3
                                  │ │   ├── bcrypt-pbkdf@1.0.1
                                  │ │   ├─┬ dashdash@1.14.1
                                  │ │   │ └── assert-plus@1.0.0
                                  │ │   ├─┬ getpass@0.1.7
                                  │ │   ├── jsbn@0.1.1
                                  │ │   └── tweetnacl@0.14.5
                                  │ ├─┬ mime-types@2.1.15
                                  │ │ └── mime-db@1.27.0
                                  │ ├── performance-now@0.2.0
                                  │ ├── qs@6.4.0
                                  │ ├── safe-buffer@5.1.0
                                  │ ├── tunnel-agent@0.6.0
                                  │ └── uuid@3.0.1
                                  └─┬ serialport@4.0.7
                                    ├─┬ commander@2.9.0
                                    │ └── graceful-readlink@1.0.1
                                    ├─┬ debug@2.6.8
                                    │ └── ms@2.0.0
                                    ├─┬ lie@3.1.1
                                    │ └── immediate@3.0.6
                                    ├── nan@2.6.2
                                      ├─┬ mkdirp@0.5.1
                                      ├─┬ nopt@3.0.6
                                      │ └── abbrev@1.0.9
                                      ├─┬ npmlog@4.0.1
                                      │ ├─┬ gauge@2.7.2
                                      ├─┬ rc@1.1.6
                                      │ ├── ini@1.3.4
                                      ├─┬ request@2.79.0
                                      │ ├── aws4@1.5.0
                                      │ ├── extend@3.0.0
                                      │ │ ├─┬ chalk@1.1.3
                                      │ ├─┬ hawk@3.1.3
                                      │ │ ├── boom@2.10.1
                                      │ │ ├── hoek@2.16.3
                                      │ │ └── sntp@1.0.9
                                      │ │   ├── asn1@0.2.3
                                      │ │   ├── jsbn@0.1.0
                                      │ ├── qs@6.3.0
                                      │ └── uuid@3.0.1
                                      ├─┬ rimraf@2.5.4
                                      │ └─┬ glob@7.1.1
                                      │   ├─┬ once@1.4.0
                                      ├── semver@5.3.0
                                      ├─┬ tar@2.2.1
                                      └─┬ tar-pack@3.3.0
                                        ├─┬ debug@2.2.0
                                        │ └── ms@0.7.1
                                        ├─┬ fstream@1.0.10
                                        ├─┬ once@1.3.3
                                        │ └── wrappy@1.0.2
                                        │ ├── isarray@1.0.0
                                npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
                                npm WARN root No description
                                npm WARN root No repository field.
                                npm WARN root No README data
                                npm WARN root No license field.
                                root@orangepiplus2e:~#</v8::int32></v8::string></v8::int32></v8::string></v8::int32></v8::object></v8::int32></v8::int32></v8::int32></v8::int32></v8::int32></v8::string></v8::int32></v8::int32></v8::int32></v8::number></v8::object></v8::int32></v8::object></v8::int32></v8::string></v8::int32></v8::string></v8::int32></v8::object></v8::int32></v8::int32></v8::int32></v8::int32></v8::int32></v8::string></v8::int32></v8::int32></v8::int32></v8::number></v8::object></v8::int32></v8::object>
                                Die ersten Zeilen spucken schon Fehler aus!
                                ****> serialport@4.0.7 install /root/node_modules/avrgirl-arduino/node_modules/serialport
                                node-pre-gyp install –fallback-to-build****
                                ****node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd … arm.tar.gz
                                node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.3 (node-v48 ABI) (falling back to source compile with node-gyp)****
                                Ideeen ????
                                  @knopers1:
                                  ok, Danke Rainer… Unter Haupteinstellungen sieht man nicht viel...siehe Bild. `
                                  Man sieht, dass du das "default" Repository und damit das stable ausgewählt hast, das erklärt auch, dass deine angebotene rf-Link Version relativ alt ist.
                                    knopers1
                                    o.k, kommen wir der Sache etwa näher???
                                    der Link unten funktioniert nicht. Kein Wunder dass es Fehler spuckt…
                                    Welche Repository soll ich als default wählen?
                                    node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz
                                      @knopers1:
                                      o.k, kommen wir der Sache etwa näher??? `
                                      Nee, wir entfernen uns schon wieder vom bestmöglichen!
                                      default ist ok = stable
                                      WENN du auf latest gehen WILLST nicht die Pfade ändern, sondern unter Haupteinstellungen im pulldown default gegen latest tauschen.
                                      Da du aber sogar die Github-Version hast bist du auf dem allerneuesten Stand.
                                      @knopers1:
                                      der Link unten funktioniert nicht. Kein Wunder dass es Fehler spuckt… `
                                      Das sind keine Fehler!
                                      Die Installation überprüft ob es für deine Hardware passende fertige Pakete gibt - und findet keine.
                                      Das ist vollkommen normal.
                                      Jetzt sagt sich die Installation: Mist, dann muss ich das Paket selber bauen :( und macht das dann auch.
                                        Und die Installation danach sieht ok aus. serialport ist installiert.
                                        AM besten mal in Debug laufen lassen und Log schicken. Log vom Aufruf der Admin-Seite reicht
                                          Hier mein log:
                                          rflink.0	2017-06-05 20:43:36.055	debug	sendTo "readNewVersion" to system.adapter.admin.0 from system.adapter.rflink.0
                                          rflink.0	2017-06-05 20:43:35.955	debug	sendTo "listUart" to system.adapter.admin.0 from system.adapter.rflink.0
                                          rflink.0	2017-06-05 20:43:35.952	info	List of port: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS3"}]
                                          rflink.0	2017-06-05 20:43:35.850	debug	inMem message messagebox.system.adapter.rflink.0 messagebox.system.adapter.rflink.0 command=listUart, message=null, from=system.adapter.admin.0, message=null, id=12, ack=false, time=1496688215043, _
                                          rflink.0	2017-06-05 20:43:35.045	debug	inMem message messagebox.system.adapter.rflink.0 messagebox.system.adapter.rflink.0 command=readNewVersion, message=null, from=system.adapter.admin.0, message=null, id=11, ack=false, time=1496688215
                                          rflink.0	2017-06-05 20:43:32.342	error	No serial port defined
                                          rflink.0	2017-06-05 20:43:32.195	info	starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.rflink, node: v6.10.3
                                          rflink.0	2017-06-05 20:43:32.141	debug	statesDB connected
                                          rflink.0	2017-06-05 20:43:32.091	debug	objectDB connected
                                          in der Konfig gibt es nur /dev/ttyS0 bis S3 kein USB und kein AMA0 (?)
                                          Daher kann ich da auch nichts sinnvolles auswählen
