  4. Iobroker startet nicht mehr
24 Beiträge 3 Kommentatoren 2.7k Aufrufe 2 Beobachtet
  • S SR277
    Wie bekomme ich beim nächsten Befehl das "/opt/iobroker $" wieder weg?
    pi@raspberrypi:/opt/iobroker $ iob status
     Objects database error: connect ECONNREFUSED 127.0.0.1:9001
     States database error: connect ECONNREFUSED 127.0.0.1:9000
     redis get system.host.raspberrypi.alive, error - Connection is closed.
     redis get system.host.raspberrypi.plugins.sentry.enabled, error - Connection is closed.
    Uncaught Rejection: /opt/iobroker/node_modules/source-map/lib/base64-vlq.js:91
    0 var di'it;
    SyntaxError: Unexpected token 'var'
        at Object.compileFunction (node:vm:360:18)
        at wrapSafe (node:internal/modules/cjs/loader:1094:15)
        at Module._compile (node:internal/modules/cjs/loader:1129:27)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
        at Module.load (node:internal/modules/cjs/loader:1043:32)
        at Function.Module._load (node:internal/modules/cjs/loader:878:12)
        at Module.require (node:internal/modules/cjs/loader:1067:19)
        at require (node:internal/modules/cjs/helpers:103:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/source-map/lib/source-map-generator.js:8:17)
        at Module._compile (node:internal/modules/cjs/loader:1165:14)
    Thomas BraunT Offline
    @sr277
    ls -lAh /opt/iobroker/iobroker-data/
    Im Prompt steht der Verzeichnispfad, in dem du dich gerade befindest. Vollkommen korrekt für den Moment.
      @sr277
      SR277
      pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
      total 53M
      drwxrwxr-x+  2 iobroker iobroker 4.0K Feb 11  2022 backitup
      drwxrwxr-x+  2 iobroker iobroker  12K Oct  1 20:53 backup-objects
      drwxrwxr-x+ 70 iobroker iobroker 4.0K May 13  2022 files
      -rw-rwxr--+  1 iobroker iobroker 5.0K Feb  8  2022 iobroker.json
      drwxrwxr-x+  3 iobroker iobroker 4.0K Jan 26  2022 jarvis
      -rw-rwxr--+  1 iobroker iobroker    3 Jan 15 17:19 notifications.json
      -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.bak.migrated
      -rw-rw-r--+  1 iobroker iobroker  17M Jan 15 17:19 objects.jsonl
      -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.migrated
      -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.bak.migrated
      -rw-rw-r--+  1 iobroker iobroker 4.2M Jan 15 17:19 states.jsonl
      -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.migrated
      drwxrwxr-x+  2 iobroker iobroker 4.0K May  1  2022 telegram_0
      drwxrwxr-x+  3 iobroker iobroker 4.0K Feb  8  2022 tmp
      • S SR277
        total 53M
        @sr277 sagte in Iobroker startet nicht mehr:
        getfacl /opt/iobroker/iobroker-data/objects.jsonl
          SR277
          pi@raspberrypi:/opt/iobroker $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
          getfacl: Removing leading '/' from absolute path names
          # file: opt/iobroker/iobroker-data/objects.jsonl
          # owner: iobroker
          # group: iobroker
          user::rw-
          group::r-x                      #effective:r--
          group:iobroker:rwx              #effective:rw-
          mask::rw-
          other::r--
