  4. Test c&p iob diag
Test c&p iob diag
3 Beiträge 1 Kommentatoren 297 Aufrufe 4 Beobachtet
  • Thomas BraunT Online
    Test C&P iob diag
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    ======== Start marking the full check here =========
    Skript v.2022.12.29
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture:   aarch64
    Docker:         false
    Virtualization: none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     01:14:47 up 10 days, 10:38,  3 users,  load average: 0.13, 0.21, 0.25
    CPU threads: 4
    *** Time and Time Zones ***
    Thu Dec 29 00:14:47 UTC 2022
    Thu Dec 29 01:14:47 CET 2022
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    echad
    /home/echad
    echad adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin boinc gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        2.5G        3.2G        0.0K        2.2G        5.3G
    Swap:            99M          0B         99M
    Total:          8.0G        2.5G        3.3G
             7855 M total memory
             2458 M used memory
              715 M active memory
             3407 M inactive memory
             3236 M free memory
              216 M buffer memory
             1943 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4      110G  7.1G   99G   7% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  880K  1.6G   1% /run
    /dev/sda1      vfat      253M   31M  222M  13% /boot
    tmpfs          tmpfs     786M  4.0K  786M   1% /run/user/1000
    Show mounted filesystems (real ones only):
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.3G    /var/
    880M    /var/cache
    865M    /var/cache/apt
    761M    /var/cache/apt/archives
    753M    /var/log
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    311M    /opt/iobroker/iobroker-data/
    187M    /opt/iobroker/iobroker-data/files
    101M    /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.806bf48a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v19.3.0
    /usr/bin/node           v19.3.0
    /usr/bin/npm            9.2.0
    nodejs:
      Installed: 19.3.0-deb-1nodesource1
      Candidate: 19.3.0-deb-1nodesource1
      Version table:
     *** 19.3.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_19.x bullseye/main arm64 Packages
            100 /var/lib/dpkg/status
         18.12.1-deb-1nodesource1 501
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         14.21.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u1 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   7
    Adapter State
    + system.adapter.admin.0                  : admin                 : chet                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : chet                                     -  enabled
      system.adapter.alias-manager.0          : alias-manager         : chet                                     - disabled
    + system.adapter.backitup.0               : backitup              : chet                                     -  enabled
      system.adapter.ble.0                    : ble                   : chet                                     - disabled
      system.adapter.cloud.0                  : cloud                 : chet                                     - disabled
    + system.adapter.echarts.0                : echarts               : chet                                     -  enabled
    + system.adapter.firetv.0                 : firetv                : chet                                     -  enabled
    + system.adapter.followthesun.0           : followthesun          : chet                                     -  enabled
    + system.adapter.govee.0                  : govee                 : chet                                     -  enabled
    + system.adapter.history.0                : history               : chet                                     -  enabled
      system.adapter.ical.0                   : ical                  : chet                                     -  enabled
      system.adapter.iceroad.0                : iceroad               : chet                                     - disabled
    + system.adapter.info.0                   : info                  : chet                                     -  enabled
    + system.adapter.iot.0                    : iot                   : chet                                     -  enabled
    + system.adapter.javascript.0             : javascript            : chet                                     -  enabled
      system.adapter.midea.0                  : midea                 : chet                                     - disabled
      system.adapter.mihome-cloud.0           : mihome-cloud          : chet                                     - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : chet                                     -  enabled, port: 54321
    + system.adapter.mihome.0                 : mihome                : chet                                     -  enabled, port: 9898, bind: 0.0.0.0
    + system.adapter.miio.0                   : miio                  : chet                                     -  enabled
    + system.adapter.nina.0                   : nina                  : chet                                     -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : chet                                     -  enabled
    + system.adapter.parcel.0                 : parcel                : chet                                     -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : chet                                     -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : chet                                     -  enabled
    + system.adapter.sainlogic.0              : sainlogic             : chet                                     -  enabled, port: 45000, bind: 0.0.0.0
      system.adapter.samsung.0                : samsung               : chet                                     - disabled
    + system.adapter.simple-api.0             : simple-api            : chet                                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : chet                                     -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
      system.adapter.switchbot-ble.0          : switchbot-ble         : chet                                     - disabled
    + system.adapter.switchbot-hub.0          : switchbot-hub         : chet                                     -  enabled
    + system.adapter.tado.0                   : tado                  : chet                                     -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : chet                                     -  enabled
    + system.adapter.tr-064.0                 : tr-064                : chet                                     -  enabled
    + system.adapter.tradfri.0                : tradfri               : chet                                     -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : chet                                     -  enabled
    + system.adapter.tuya.0                   : tuya                  : chet                                     -  enabled
    + system.adapter.web.0                    : web                   : chet                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : chet                                     -  enabled
    + system.adapter.ws.0                     : ws                    : chet                                     -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : chet                                     -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
    + instance is alive
    ioBroker-Repositories
    live-stable   : http://iobroker.live/repo/sources-dist.json
    live-beta     : http://iobroker.live/repo/sources-dist-latest.json
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.5.9    , installed 2.5.9
    Adapter    "ble"          : 0.13.1   , installed 0.13.1
    Adapter    "cloud"        : 4.3.1    , installed 4.3.1
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "firetv"       : 1.0.0    , installed 1.0.0
    Adapter    "followthesun" : 0.4.0    , installed 0.4.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "ical"         : 1.13.2   , installed 1.13.2
    Adapter    "iceroad"      : 1.1.2    , installed 1.1.2
    Adapter    "info"         : 1.9.24   , installed 1.9.24
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "midea"        : 0.0.7    , installed 0.1.0
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
    Adapter    "miio"         : 0.0.13   , installed 0.0.13
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "parcel"       : 0.0.23   , installed 0.0.23
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "sainlogic"    : 0.9.0    , installed 0.9.0
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "socketio"     : 6.3.3    , installed 6.3.3
    Adapter    "tado"         : 0.4.3    , installed 0.4.3
    Adapter    "tankerkoenig" : 3.2.4    , installed 3.2.4
    Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "trashschedule": 2.1.0    , installed 2.1.0
    Adapter    "tuya"         : 3.11.4   , installed 3.11.4
    Adapter    "web"          : 5.4.1    , installed 5.4.1
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.3.4    , installed 2.3.4
    Adapter    "zigbee"       : 1.8.9    , installed 1.8.9
    Objects and States
    Objects:        9266
    States:         7388
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://deb.debian.org/debian bullseye-backports InRelease
    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:5 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:7 http://packages.azlux.fr/debian bullseye InRelease
    Hit:8 https://cli.github.com/packages stable InRelease
    Hit:9 https://packages.grafana.com/oss/deb stable InRelease
    Hit:10 https://deb.nodesource.com/node_14.x bullseye InRelease
    Hit:11 https://repos.influxdata.com/debian bullseye InRelease
    Hit:12 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:13 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:14 https://deb.volian.org/volian scar InRelease
    Hit:15 https://deb.nodesource.com/node_19.x bullseye InRelease
    Hit:16 https://packages.redis.io/deb bullseye InRelease
    Get:18 https://pkgs.tailscale.com/stable/debian bullseye InRelease
    Hit:17 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Fetched 5545 B in 3s (1771 B/s)
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1001       2545037    329663/io.sainlogic
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12591      554/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          11758      568/dnsmasq
    tcp        0      0 100.93.118.24:41687     0.0.0.0:*               LISTEN      0          15841      647/tailscaled
    tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       2544658    329445/adb
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       2541338    329196/iobroker.js-
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       2542660    329196/iobroker.js-
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       5204120    677604/io.ws.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      1001       2543592    329734/io.socketio.
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       2543534    329719/io.simple-ap
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2541692    329214/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       5205095    677616/io.web.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       3183579    414819/io.nuki-exte
    tcp6       0      0 fd7a:115c:a1e0:ab:41687 :::*                    LISTEN      0          15842      647/tailscaled
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12593      554/sshd: /usr/sbin
    tcp6       0      0 :::53                   :::*                    LISTEN      0          11760      568/dnsmasq
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11639      397/avahi-daemon: r
    udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       2541458    329328/io.mihome.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5990534    773342/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5990535    773342/io.tuya.0
    udp        0      0 0.0.0.0:39588           0.0.0.0:*                           1001       6000070    329794/io.tradfri.0
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          11757      568/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11895      799/dhcpcd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       2541446    329313/io.mihome-va
    udp        0      0 0.0.0.0:45231           0.0.0.0:*                           1001       2544056    329603/io.miio.0
    udp        0      0 0.0.0.0:49456           0.0.0.0:*                           108        11641      397/avahi-daemon: r
    udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          17653      647/tailscaled
    udp6       0      0 :::5353                 :::*                                108        11640      397/avahi-daemon: r
    udp6       0      0 :::39054                :::*                                108        11642      397/avahi-daemon: r
    udp6       0      0 :::53                   :::*                                0          11759      568/dnsmasq
    udp6       0      0 :::546                  :::*                                0          11917      799/dhcpcd
    udp6       0      0 :::41641                :::*                                0          17652      647/tailscaled
    iob diag has finished.
    Press any key for a summary
      Test C&P iob diag
      Skript v.2022.12.29
      *** BASE SYSTEM ***
      Docker:         false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      echad
      /home/echad
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7855 M total memory
               2458 M used memory
                715 M active memory
               3236 M free memory
                216 M buffer memory
               1943 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      2.3G    /var/
      880M    /var/cache
      865M    /var/cache/apt
      753M    /var/log
      /usr/bin/npm            9.2.0
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        9266
      States:         7388
      Pending Updates: 0
      Skript v.2022.12.29
      *** BASE SYSTEM ***
      Docker: false
      Release: 11
      Codename: bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      echad
      /home/echad
      X-Server: false
      Desktop:
      Terminal: tty
      *** MEMORY ***
      total used free shared buff/cache available
      Swap: 99M 0B 99M
           7855 M total memory
           2458 M used memory
            715 M active memory
           3236 M free memory
            216 M buffer memory
           1943 M swap cache
             99 M total swap
              0 M used swap
             99 M free swap
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      /var:
      2.3G /var/
      880M /var/cache
      865M /var/cache/apt
      753M /var/log
      /usr/bin/npm 9.2.0
      nodejs:
      Version table:
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      admin: 6.3.5
      javascript: 6.1.4
      Adapter State
      • system.adapter.admin.0 : admin : chet - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.alexa2.0 : alexa2 : chet - enabled
      • system.adapter.backitup.0 : backitup : chet - enabled
      • system.adapter.echarts.0 : echarts : chet - enabled
      • system.adapter.firetv.0 : firetv : chet - enabled
      • system.adapter.followthesun.0 : followthesun : chet - enabled
      • system.adapter.govee.0 : govee : chet - enabled
      • system.adapter.history.0 : history : chet - enabled
      • system.adapter.info.0 : info : chet - enabled
      • system.adapter.iot.0 : iot : chet - enabled
      • system.adapter.javascript.0 : javascript : chet - enabled
      • system.adapter.mihome-vacuum.0 : mihome-vacuum : chet - enabled, port: 54321
      • system.adapter.mihome.0 : mihome : chet - enabled, port: 9898, bind: 0.0.0.0
      • system.adapter.miio.0 : miio : chet - enabled
      • system.adapter.nina.0 : nina : chet - enabled
      • system.adapter.nuki-extended.0 : nuki-extended : chet - enabled
      • system.adapter.parcel.0 : parcel : chet - enabled
      • system.adapter.pi-hole.0 : pi-hole : chet - enabled
      • system.adapter.rpi2.0 : rpi2 : chet - enabled
      • system.adapter.sainlogic.0 : sainlogic : chet - enabled, port: 45000, bind: 0.0.0.0
      • system.adapter.simple-api.0 : simple-api : chet - enabled, port: 8087, bind: 0.0.0.0, run as: admin
      • system.adapter.socketio.0 : socketio : chet - enabled, port: 8086, bind: 0.0.0.0, run as: admin
      • system.adapter.switchbot-hub.0 : switchbot-hub : chet - enabled
      • system.adapter.tado.0 : tado : chet - enabled
      • system.adapter.tankerkoenig.0 : tankerkoenig : chet - enabled
      • system.adapter.tr-064.0 : tr-064 : chet - enabled
      • system.adapter.tradfri.0 : tradfri : chet - enabled
      • system.adapter.trashschedule.0 : trashschedule : chet - enabled
      • system.adapter.tuya.0 : tuya : chet - enabled
      • system.adapter.web.0 : web : chet - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      • system.adapter.whatsapp-cmb.0 : whatsapp-cmb : chet - enabled
      • system.adapter.ws.0 : ws : chet - enabled, port: 8084, bind: 0.0.0.0, run as: admin
      • system.adapter.zigbee.0 : zigbee : chet - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
      • instance is alive
      beta : http://download.iobroker.net/sources-dist-latest.json
      stable : http://download.iobroker.net/sources-dist.json
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Objects and States
      Objects: 9266
      States: 7388
      Pending Updates: 0
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp6 0 0 fd7a:115c:a1e0🆎41687 :::* LISTEN 0 15842 647/tailscaled
        Skript v.2022.12.29
        *** BASE SYSTEM ***
        Docker: false
        Release: 11
        Codename: bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        CET +0100
        Europe/Berlin
        echad
        /home/echad
        X-Server: false
        Desktop:
        Terminal: tty
        *** MEMORY ***
        Swap: 99M 0B 99M
             7855 M total memory
             2458 M used memory
              715 M active memory
             3236 M free memory
              216 M buffer memory
             1943 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
        *** FILESYSTEM ***
        /var:
        2.3G /var/
        880M /var/cache
        865M /var/cache/apt
        753M /var/log
        /usr/bin/npm 9.2.0
        nodejs:
        Version table:
        ioBroker Status
        Objects type: jsonl
        States type: jsonl
        admin: 6.3.5
        javascript: 6.1.4
        Adapter State
        • instance is alive
        Objects and States
        Objects: 9266
        States: 7388
        Pending Updates: 0
        Copy text starting here:
                                v.2024-07-21
         Static hostname: chet
               Icon name: computer
        Operating System: Debian GNU/Linux trixie/sid
                  Kernel: Linux 6.6.31+rpt-rpi-v8
            Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        Display-Server:         false
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/nodejs         v22.5.1
        /usr/bin/node           v22.5.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.2
        Recommended versions are nodejs 20.15.1 and npm 10.7.0
        MEMORY:
        Mem:            8.2G        2.8G        726M        872K        4.9G        5.4G
        Swap:           209M          0B        209M
        Total:          8.4G        2.8G        936M
        Active iob-Instances:   38
        Upgrade policy: none
        ioBroker Core:          js-controller           6.0.9
                                admin                   7.0.17
        Objects type: jsonl
        States  type: jsonl
        Objects:                11112
        States:                 8907
        Size of iob-Database:
        29M     /opt/iobroker/iobroker-data/objects.jsonl
        4.6M    /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
