  3. Off Topic
  4. Volumio adapter?
    6.0k
Volumio adapter?
75 Beiträge 10 Kommentatoren 13.3k Aufrufe 7 Beobachtet
  • da_WoodyD da_Woody
    @muellerra autsch...
    19:19:22.367	info	javascript.0 (521) Start javascript script.js.common.Volumio.Volumio
    19:19:22.392	info	javascript.0 (521) script.js.common.Volumio.Volumio: registered 22 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    19:19:25.887	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:601:8)
    19:19:25.887	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:942:9)
    19:19:26.387	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:601:8)
    19:19:26.387	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:942:9)
    19:19:26.887	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:601:8)
    19:19:26.887	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:942:9)
    19:19:27.387	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:601:8)
    19:19:27.387	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:942:9)
    19:19:27.889	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:601:8)
    19:19:27.889	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:942:9)
    19:19:28.391	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:601:8)
    19:19:28.391	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:942:9)
    19:19:28.890	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:601:8)
    19:19:28.890	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:942:9)
    19:19:29.011	info	javascript.0 (521) Stop script script.js.common.Volumio.Volumio
    ok, da dürfte was nicht passen... rrBroker gibts bei mir ja nicht.
    if(getState('ping.1.rrBroker.' + Volumios[ID_Volumio]).val){
    warum allerdings 942 motzt...
    muellerra
    #61
    @da_woody hab den Hinweis auf den ping Adapter im Post ergänzt. Danke für den Hinweis!!! Zeile 942 motzt, weil der Fehler in der Funktion restapiRequest ist und die in Zeile 942 aufgerufen wird.
    Installier mal dem ping Adapter und pass die Zeile an (s. Ursprungspost).
    Falls noch was auffällt einfach bescheid sagen, mir fällt es manchmal schwer selbst immer alle Abhängigkeiten in meinen unzähligen Skripten sofort zu finden 😆
    • M muellerra
      da_WoodyD Offline
      da_WoodyD Offline
      da_Woody
      #62
      @muellerra okido
      zeile 7-9
      var Folder = 'javascript.0.Volumio.Player.Volumio_Player_' //
      var Volumios = ["Studio"] //["rStream","workStream","kitchenStream","flurStream"]  //muss in beiden Skripten identisch sein
      var Volumios_IPs = ["210"] //["82","58","48","72"] //192.168.178 wird dann im Skript hart gesetzt -> ggf. abändern!
      zeile 601
         if(getState('ping.0.Studio.' + Volumios[ID_Volumio]).val){
      zeile 942
              restapiRequest('192.168.0.' + Volumios_IPs[ID_Volumio],"getState",ID_Volumio)
      ping ist schon lange an board, wegen anwesenheit, hinzugefügt Studio
      fehler tropsdem noch da... rest-api einstellungen?
      gruß vom Woody
        @muellerra okido
        zeile 7-9
        zeile 601
        zeile 942
        muellerra
        schrieb am zuletzt editiert von muellerra
        #63
        @da_woody
        ändern zu:
        if(getState('ping.0.ioBroker.' + Volumios[ID_Volumio]+ '.alive').val){
        er muss auf alle Fälle auf den boolschen State zugreifen, welcher anzeigt ob das Gerät erreichbar ist oder nicht.
        Zudem den Volumio Namen, bei dir Studio nicht rein schreiben, der wird ja über die schleife aus dem Volumios Array ausgelesen. Bei dir entspricht dann
        Volumios[ID_Volumio] gleich "Studio"
        Anscheinend hab ich damals bei mir keine erweiterte info im ping adapter eingestellt:
        Bildschirmfoto 2024-01-30 um 21.13.55.png ,
        daher ohne .alive
        • M muellerra
          @da_woody
          ändern zu:
          daher ohne .alive
          da_WoodyD Offline
          da_WoodyD Offline
          da_Woody
          #64
          @muellerra moin. dachte, ich hätte eine eingebung gehabt, dachte ich aber nur... wutb.gif
          hatte im 2. script
          nicht angepasst.
          dann komplett neu angefangen, da der fehler nach wie vor da war. kurioser weise hat sich durch deine änderung das warning um eine zeile verschoben.
          09:53:07.452	info	javascript.0 (521) Start javascript script.js.common.Volumio.Volumio
          09:53:07.473	info	javascript.0 (521) script.js.common.Volumio.Volumio: registered 22 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          09:53:10.972	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:602:8)
          09:53:10.972	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:943:9)
          09:53:11.471	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:602:8)
          09:53:11.471	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:943:9)
          09:53:11.976	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:602:8)
          09:53:11.976	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:943:9)
          09:53:12.472	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:602:8)
          09:53:12.472	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:943:9)
          09:53:12.972	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:602:8)
          09:53:12.972	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:943:9)
          09:53:13.472	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:602:8)
          09:53:13.472	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:943:9)
          09:53:13.973	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:602:8)
          09:53:13.973	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:943:9)
          09:53:14.473	warn	javascript.0 (521) at restapiRequest (script.js.common.Volumio.Volumio:602:8)
          09:53:14.473	warn	javascript.0 (521) at Object.getVolumioStates (script.js.common.Volumio.Volumio:943:9)
          09:53:14.800	info	javascript.0 (521) Stop script script.js.common.Volumio.Volumio
          602 nach deinen angaben ausgebessert
          if(getState('ping.0.ioBroker.' + Volumios[ID_Volumio]).val + '.alive'){
          der DP ist da und auf true
          943 sehe ich auch keinen fehler
          zusätzlich hab ich im states_icons script die zeile 4 geändert, damit ich in den objekten nur mehr player0 bekomme
          var names = ['Volumio_Player_0'] //,'Volumio_Player_1','Volumio_Player_2','Volumio_Player_3']
          das klappt auch.
          ich weis echt nicht mehr weiter... nochmal das neue hauptscript...
          Volumio.txt
          alle 3 scripte 3x durchsucht ob ich was übersehn habe. (notepad++ mit suchen und ersetzen)
          gruß vom Woody
            hatte im 2. script
            nicht angepasst.
            das klappt auch.
            Volumio.txt
            muellerra
            #65
            @da_woody
            if(getState('ping.<instance>.<iobrokerHostName>.' + Volumios[ID_Volumio] + '.alive').val){
            Das .val ist an falscher stelle. Da wäre ein Syntax highlighting im Forum ganz nett
            • M muellerra
              @da_woody
              da_WoodyD Offline
              da_WoodyD Offline
              da_Woody
              #66
              wollte schon am rad drehn. hab ich gestern abend echt nicht mehr mitbekommen. näxter fault dann, hab iobroker getippt statt ioBroker. logischer weise selber fehler. fool.gif
              okido, die 3 scripte laufen jetzt. jetzt kann ich mich um iQontrol kümmern... banane2.gif
              gruß vom Woody
                muellerra
                #67
                @da_woody das freut mich 😊
                Viel Spaß mit dem Skript 😊
                • M muellerra
                  da_WoodyD Offline
                  da_WoodyD Offline
                  da_Woody
                  #68
                  @muellerra jup!
                  auch schon bißchen in iQontrol gefummelt.
                  gruß vom Woody
                    muellerra
                    #69
                    Mir kam grad noch in den Sinn, das der im Skript angelegte javascript.0.Allgemeine_Variablen.Player.Volumio_Player_<VolumioID>.playbackInfo.statusIncomingCall Datenpunkt durchaus sinnvoll in Verwendung ist. Ich verwende ihn als Merker für den Play/Pause Status. So werden dann z.b. bei einem aus- oder eingehendem Anruf (über Fritz!Box) alle spielenden Volumios pausiert und nach dem auflegen wieder fortgesetzt. Volumios die nicht spielen werden nicht angesteuert. Bei Playern im Multiroomverbund, wird nur der sendende Volumio getriggert.
                    Die im Ursprungspost geposteten globalen Funktionen werden vorausgesetzt:
                    @muellerra sagte in Volumio adapter?:
                    und hier noch weitere, vllt nützliche, Funktionen (bei mir global definiert)
                    function getVolumiosReceiving(VolumiosReceiving,ReturnID){
                    usw...
                    var ID_Ringing = "tr-064.0.callmonitor.ringing"
                    var ID_PhoneStatus = "tr-064.0.callmonitor.toPauseState" // connected, end(wenn nichts ist), ring
                    var FolderVolumio = 'javascript.0.Allgemeine_Variablen.Player.Volumio_Player_'
                    on({id: ID_PhoneStatus, change: 'ne'}, function (obj) {
                        var value = obj.state.val;
                        var timestamp = obj.state.ts;
                        var oldValue = obj.oldState.val
                        var Verursacher = obj.id;
                        var VolumiosStatus = getVolumiosStatus([])
                        var ReceivingVolumiosIDs = getVolumiosReceiving([],true)
                        if(value != 'end' && value != 'connect'){ // connect da sonst nichts ausgeführt wird, wenn der angenommene anruf beendet wird
                            //Aktionen die passieren, wenn jemand anruft oder jemand im gespräch ist
                            //Volumios auf Pause
                            var PlayingVolumiosIDs = getVolumiosPlaying([],true)
                            log(ReceivingVolumiosIDs)
                            for(var iop in VolumiosStatus){
                                setState(FolderVolumio + iop + '.playbackInfo.statusIncomingCall',VolumiosStatus[iop])
                                //nur pis die nicht empfangen auf pause setzen, der rest erledigt sich von alleine
                                if(ReceivingVolumiosIDs.indexOf(String(iop)) != -1 ){ // pi empfängt
                                }else{ // pi empfängt nicht
                                    setState(FolderVolumio + iop + '.control.pause',true)
                        if(value == 'end' && oldValue != 'end'){
                            // aktionen, wenn aufgelegt wird oder das telefon nicht mehr klingelt
                            //Volumios auf Play, wenn sie vorher pausiert wurden
                            for(var xbf in VolumiosStatus){
                                var VolumioStatusHistoric = getState(FolderVolumio + xbf + '.playbackInfo.statusIncomingCall').val
                                if(VolumioStatusHistoric == 'play' || VolumioStatusHistoric == "play"){ // hier aber aich nur die die nicht receiven!
                                    //nur pis die nicht empfangen auf play setzen, bzw toggeln
                                    if(ReceivingVolumiosIDs.indexOf(String(xbf)) != -1 ){ // pi empfängt
                                        setState(FolderVolumio + xbf + '.PlayPause',true) //toogle, da play multiroom killt wenn multiroom aktiv ist...
                    • M muellerra
                      usw...
                      da_WoodyD Offline
                      da_WoodyD Offline
                      da_Woody
                      #70
                      @muellerra nicht schlecht!
                      was mir noch gefallen würde, favoriten, sender und co. auswahl...
                      gruß vom Woody
                        muellerra
                        #71
                        @da_woody Gute Idee!, den Use Case hab ich bei mir aber tatsächlich nicht, daher hab ich es auch nicht implementiert. Darf gerne jemand anders übernehmen😜
                        • mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          #72
                          Wenn ich das hier grob überfliege dann geht es schon länger nicht mehr um den VOLUMIO ADAPTER sondern um eine Skript das ihn - wenn ichs richtig sehe - ersetzt.
                          Könnte hier jemand klarstellen, ob der Adapter:
                          https://github.com/a-i-ks/ioBroker.volumio
                          nun brauchbar ist (mit Einschränkungen) oder derzeit bereits ein Totalausfall?
                          Es gibt zwar ein Issue dazu (https://github.com/a-i-ks/ioBroker.volumio/issues/12) aber so richtig klar ist (mir) nicht ob es da um ein Einzelproblem handelt oder nicht,
                          Auf was ich raus will:
                          Wenn der Adapter zu 99% nicht mehr unfktioniert würde ich / sollte man ein Issue mit einem gewissen Timeout erstellen. Und anschließend den Adapter zumindest mal aus dem Stable Repo nehmen.
                          Das kann und will ich aber nicht tun, nur weil er ev bei einigen wenigen Installationen zickt. Ich brächte also eher klare Aussagen. EV. kann auch wer der Probleme nachvollziehen kann im referenzierten Issue nachfrage und / oder wenn das besser passt ein neues Issue anlegen.
                          Support Repositoryverwaltung.
                          LESEN - gute Forenbeitrage
                          • mcm1957M mcm1957
                            da_WoodyD Offline
                            da_WoodyD Offline
                            da_Woody
                            #73
                            @mcm57 naja, länger ist relativ. ich bin mit besagtem adapter nicht zurecht gekommen und hat mir immer wieder probleme gemacht. ja, die scripte ersetzen den adapter komplett.
                            da du mein issue erwähnst. nuja, nicht wirklich was verändert, auch wenn da was gemacht wurde.
                            im moment komm ich mit den scripten von @muellerra (trotz meiner unfähigkeit mit JS) gut zurecht.
                            vllt könnte man das mal in einen "neuen" adapter gießen?
                            edith ist da: wie gesagt, für mich ist das reine spielerei. so ein mugge geschichtel mit alexa würe mir mehr wert bringen. die beschreibung im iQontrol wiki ist auch nicht mehr up2date. zumindest klapperts bei mir nicht mehr.
                            gruß vom Woody
                            a-i-ksA 1 Antwort Letzte Antwort
                              a-i-ksA Offline
                              a-i-ksA Offline
                              a-i-ks
                              #74
                              Hallo Leute, der Volumio Adapter ist jetzt gefixt. Entschuldigt, dass es so lange gedauert hat. Der aktuelle master Stand auf Github kann noch bis Samstag Abend getestet werden. Danach veröffentliche ich ihn offiziell in v0.2.0.
                              • da_WoodyD Offline
                                da_WoodyD Offline
                                da_Woody
                                #75
                                @a-i-ks na Mal schauen. Wollte seit Tagen den Raspberry schon zusätzlich in der Werkstatt rein operieren.
                                Alexa klappt ja so. Allerdings hab ich auch Boxen hängen. Muss ich nur noch Adapter für die Mini Klinke basteln.
                                gruß vom Woody
