  4. LG-thinq Error: Request failed with status code 400
3 Beiträge 3 Kommentatoren 858 Aufrufe 3 Beobachtet
  • tomtomzurichT Offline
    tomtomzurich
    Since a couple of weeks this io-broker adapter doesn't work any more.
    The running instance is throwing hundreds of errors that there is something wrong either with the login or an token.
    Based on the fact, that this adapter doesn't have anything to refresh a token, I guess that there is now something wrong with the login process coded. (most probably LG changed something at the login)
    My credentials are definitely right, because the LG App as well as the LG web-platform works fine and the login in both cases are working as well.
    Systemdata
    Hardwaresystem: i386 Atom
    Arbeitsspeicher: 8 GB
    Festplattenart: SD-Karte 64 GB
    Betriebssystem: Debian Bullseye
    Nodejs-Version: 14.18.1
    Installationsart: Skript
    • tomtomzurichT tomtomzurich
      Systemdata
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @tomtomzurich möchtest Du das jetzt auch mal auf deutsch schreiben ? Deine anderen Beiträge sind ja auch auf deutsch !!!
      Lehrling seit 1975 !!!
      • L Online
        L Online
        Lucky_ESA
        ResultCode 0110 bedeutet, dass die AGB`s in der APP akzeptiert werden müssen.
        Gruß//Lucky
