  3. Einsteigerfragen
  4. Installation
  5. Iobrocker installation Raspberry
Geplant Angeheftet Gesperrt Verschoben Installation
installationsprobleme
10 Beiträge 3 Kommentatoren 801 Aufrufe 2 Beobachtet
    Trivianni
    Hello,
    I wanted to install iobroker on my Raspberry debian 11.
    In the installation guidelines there is always mentioned a syntax starting with curl.
    Unfortunately nothing happens while executing this. It means after 2 sec the input line is appearing again.
    Does anyone has a hint for me what the problem could be?
    Is there a different why to install iobroker?
    Thanks in advance.
    Regards
    Christian
    • T Trivianni
      Hello,
      Thanks in advance.
      Regards
      Christian
      @trivianni sagte in Iobrocker installation Raspberry:
      no!
      just the one line
      curl -sLf https://iobroker.net/install.sh | bash -
      this will install nodejs and iobroker completely.
      really debian? or raspberrypi OS?
      • T Trivianni
        Hello,
        Thanks in advance.
        Regards
        Christian
        @trivianni
        Try
          @trivianni
          Try
          Trivianni
          Hi this is the syntax I have tried but nothing is happening during execution.
          No error, no warning nothing.
          Regards
          Christian
            no!
            just the one line
            Trivianni
            Hi yesterday I did the upgrade von buster to bullseye.
            • T Trivianni
              on what base?
              @homoran sagte in Iobrocker installation Raspberry:
                on what base?
                Trivianni
                I don't know from my mind but is this important for this issue?
                I thought it is a more general problem instead of related to any specific base.
                • T Trivianni
                  maybe! in basic debian installation there is no curl.
                  on the other hand Raspberry pi OS is an optimized debian for Raspberrys
                    Trivianni
                    it seems as if curl is installed:
                    pi@raspberrypi:~ $ curl -V
                    curl 7.74.0 (arm-unknown-linux-gnueabihf) libcurl/7.74.0 OpenSSL/1.1.1n zlib/1.2.11 brotli/1.0.9 libidn2/2.3.0 libpsl/0.21.0 (+libidn2/2.3.0) libssh2/1.9.0 nghttp2/1.43.0 librtmp/2.3
                    Release-Date: 2020-12-09
                    Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
                    Features: alt-svc AsynchDNS brotli GSS-API HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL TLS-SRP UnixSockets
                    Are there any other tests I can do?
                    • Thomas BraunT Online
                      @trivianni
                      curl -vL https://iobroker.net/install.sh | bash -
