  4. Update JS controller Fehlgeschlagen
18 Beiträge 3 Kommentatoren 831 Aufrufe 2 Beobachtet
  • C Offline
    Coolbeer
    Es kann anscheinend Canvas nicht installiert werden. Kann jemand helfen ?
    Hier die Fehlermeldungen.
    pi@raspberrypi-iob:/opt/iobroker $ npm install iobroker.js-controller
    > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.16
    > canvas@2.10.1 install /opt/iobroker/node_modules/canvas
    > node-pre-gyp install --fallback-to-build --update-binary
    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.1/canvas-v2.10.1-node-v72-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.1 and node@12.22.12 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
    node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.1/canvas-v2.10.1-node-v72-linux-glibc-arm.tar.gz
    Package cairo was not found in the pkg-config search path.
    Perhaps you should add the directory containing `cairo.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'cairo' found
    gyp: Call to 'pkg-config cairo --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.4.79-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--update-binary" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v12.22.12
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --update-binary --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    node-pre-gyp ERR! System Linux 5.4.79-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v12.22.12
    node-pre-gyp ERR! node-pre-gyp -v v1.0.10
    node-pre-gyp ERR! not ok
    > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Successfully migrated 2991 objects to Redis Sets
    object _design/system updated
      "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\n+kv4rqH/aK6CY1LKKa3jft9Tsl+P77C83p8uWdDgVk7ZSajwnoUx\r\n-----END RSA PRIVATE KEY-----\r\n",
      "defaultPublic": "-----BEG....
    =\r\n-----END CERTIFICATE-----\r\n"
    Update certificate defaultPrivate
    The object "system.certificates" was updated successfully.
    Update certificate defaultPublic
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.8 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.10.1 (node_modules/canvas):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.10.1 install: `node-pre-gyp install --fallback-to-build --update-binary`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + iobroker.js-controller@4.0.23
    updated 1 package in 46.994s
    49 packages are looking for funding
      run `npm fund` for details
    MOD-EDIT: Code in code-tags gesetzt und Zertifikat entfernt
    • C Coolbeer
      gyp ERR! not ok
      @coolbeer
      Nodejs aktualisieren. Version 16.
      Den sonstigen Kram auch auf Stand bringen, ich vermute da herrscht akuter Wartungsstau.
      Sind die zum Bau von canvas erforderlichen dev-Pakete installiert?
      C 1 Antwort Letzte Antwort
        @coolbeer
        Coolbeer
        Node.js 16 lässt sich nicht installieren.
        Es kommem folgende Meldungen ??
        pi@raspberrypi-iob:/opt/iobroker $ pi@raspberrypi-iob:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
        ## Installing the NodeSource Node.js 16.x repo...
        ## Populating apt-get cache...
        + apt-get update
        OK:1 https://deb.nodesource.com/node_12.x buster InRelease
        Holen:2 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
        Holen:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
        E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »oldstable« geändert.
        N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
        E: Für das Depot »http://raspbian.raspberrypi.org/raspbian-bash: pi@raspberrypi-iob:/opt/iobroker: Datei oder Verzeichnis nicht gefunden
         buster InRelease« wurde der »Suite«-Wert von »stable« in »oldstable« geändert.
        Error executing command, exiting
        • C Coolbeer
          + apt-get update
          @coolbeer
          Ich sach ja... Akutester Upgrade-Stau...
          iobroker stop
          sudo apt upgrade
          sudo apt full-upgrade
          sudo reboot
          Alle Rückfragen bejahen. Danach sollte auch node16 zu installieren sein.
          Künftig das System regelmäßig updaten!
            @coolbeer
            iobroker stop
            sudo apt upgrade
            sudo reboot
            Coolbeer
            sudo apt-get update --allow-releaseinfo-change
            ..dann hats geklappt
            • C Coolbeer
              @coolbeer
              Das hätte mit apt auch bzw. besser geklappt.
                @coolbeer
                Coolbeer
                Lasse das apt upgrade auch noch durchlaufen
                • C Coolbeer
                  @coolbeer
                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  zeigen, wenn das durch ist.
                  • C Offline
                    Coolbeer
                    Alles durchgelaufen
                    pi@raspberrypi-iob:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden:        Die Datei existiert bereits
                    pi@raspberrypi-iob:~ $ uname -m && type -P nodejs node npm && nodejs -v && node        -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/nul        l && sudo apt update && apt policy nodejs
                    armv7l
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.17.1
                    v16.17.1
                    8.15.0
                    4.0.23
                    pi
                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
                    /home/pi
                    OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                    Alle Pakete sind aktuell.
                    nodejs:
                      Installiert:           16.17.1-deb-1nodesource1
                      Installationskandidat: 16.17.1-deb-1nodesource1
                      Versionstabelle:
                     *** 16.17.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                            100 /var/lib/dpkg/status
                         10.24.0~dfsg-1~deb10u2 500
                    • C Offline
                      Coolbeer
                      IO Brocker läuft erst mal :-) Danke
                      • C Coolbeer
                        Alles durchgelaufen
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.17.1
                        v16.17.1
                        8.15.0
                        4.0.23
                        pi
                        /home/pi
                        nodejs:
                          Versionstabelle:
                        @coolbeer zieh mal dein Terminfenster breiter, dann gibt es nicht diese Lücken im Code
                        • C Coolbeer
                          @coolbeer Künftig das System nicht über ein Jahr ohne Updates versumpfen lassen! Der Wechsel von stable auf oldstable war in 08/2021.
                          Solange ist da also mindestens nichts gemacht worden!
                            Coolbeer
                            io brocker Admin update abgebrochen :-(
                            kein zugriff mehr :-(
                            • C Coolbeer
                              @coolbeer
                              iobroker update
                              in CodeTags eingebettet!
                              • C Coolbeer
                                @coolbeer
                                https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8/2
                                  @coolbeer
                                  iobroker update
                                  Coolbeer
                                  pi@raspberrypi-iob:/opt/iobroker $ iobroker update
                                  Used repository: stable
                                  Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                  Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
                                  Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                  Adapter    "firetv"       : 1.0.0    , installed 1.0.0
                                  Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                  Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
                                  Adapter    "history"      : 2.2.0    , installed 1.9.14 [Updatable]
                                  Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                  Adapter    "hm-rpc"       : 1.15.12  , installed 1.14.24 [Updatable]
                                  Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                  Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
                                  Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
                                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                                  Adapter    "iot"          : 1.11.9   , installed 1.11.9
                                  Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
                                  Adapter    "jarvis"       : 3.0.13   , installed 3.0.13
                                  Adapter    "javascript"   : 6.0.3    , installed 4.8.4  [Updatable]
                                  Controller "js-controller": 4.0.23   , installed 4.0.23
                                  Adapter    "mpd"          : 1.0.6    , installed 1.0.6
                                  Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                  Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                                  Adapter    "openweathermap": 0.3.0   , installed 0.1.0  [Updatable]
                                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                  Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                                  Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
                                  Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                  Adapter    "socketio"     : 4.2.0    , installed 3.0.13 [Updatable]
                                  Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                  Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                                  Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                  Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
                                  Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                                  Adapter    "web"          : 4.3.0    , installed 3.1.0  [Updatable]
                                  MOD-EDIT: Code in code-tags gesetzt! 😡
                                  • C Coolbeer
                                    @coolbeer
                                    Da geht der Update-Stau wie erwartet weiter.
                                    iobroker upgrade all
                                      @coolbeer
                                      Coolbeer
                                      schrieb am zuletzt editiert von Coolbeer
                                      @thomas-braun said in Update JS controller Fehlgeschlagen:
                                      Hat geholfen.....Danke
                                      Werde ein paar Donate spenden
