  4. Telegram und Mqtt starten nicht.
    6.3k
29 Beiträge 4 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • R root_
    @glasfaser said in Telegram und Mqtt starten nicht.:
    iobroker start admin
    node:internal/modules/cjs/loader:959
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
        at Function.Module._load (node:internal/modules/cjs/loader:804:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        at node:internal/main/run_main_module:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    liquid@raspberry:~$ iobroker list instances
      throw err;
      requireStack: []
    @root_
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    R 1 Antwort Letzte Antwort
      @root_
      cd /opt/iobroker
      root_
      @thomas-braun said in Telegram und Mqtt starten nicht.:
      liquid@raspberry:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
      [sudo] password for liquid:
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm ERR! code 6
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh /tmp/install-ff6dd1c3.sh
      npm ERR! Uncaught Rejection: Error: Cannot find module '@iobroker/db-states-jsonl'
      npm ERR! Require stack:
      npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
      npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
      npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)
      npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
      npm ERR!     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3165:26)
      npm ERR!     /home/iobroker/.npm/_logs/2022-09-03T13_48_21_323Z-debug-0.log
      • GlasfaserG Glasfaser
        @root_ sagte in Telegram und Mqtt starten nicht.:
        Versionen aus der Beta dist.
        Ich hatte auch schon auf den jeweiligen GitHub geschaut aber nichts gefunden. deswegen hier die Frage.
        Da ist auch nichts . weil sie funktionieren .
        Ein/ und Ausgabe davon in Code-Tags </> hier einstellen
        cd /opt/iobroker
        npm ls | grep -E 'github.com|ERR'
        iobroker update -i
        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        Martin-72
        @glasfaser Hallo Helfer in der Not,
        ich hänge mich hier mal an, da ich scheinbar ebenfalls dieses Problem habe.
        Die ersten Schritte bin ich schon mal durchlaufen:
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github.com|ERR'
        npm ERR! peer dep missing: chai@>= 2.1.2 < 5, required by chai-as-promised@7.1.1
        npm ERR! peer dep missing: chai@^4.0.0, required by sinon-chai@3.7.0
        npm ERR! peer dep missing: sinon@>=4.0.0, required by sinon-chai@3.7.0
        pi@raspberrypi:/opt/iobroker $ ^C
        pi@raspberrypi:/opt/iobroker $ iobroker update -i
        Used repository: stable
        Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
        Adapter    "admin"        : 6.2.20   , installed 5.3.8  [Updatable]
        Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
        Adapter    "backitup"     : 2.4.10   , installed 2.4.10
        Adapter    "cloud"        : 4.2.2    , installed 4.2.2
        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
        Adapter    "cul"          : 2.0.2    , installed 2.0.2
        Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
        Adapter    "devices"      : 1.0.12   , installed 1.0.12
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "ds18b20"      : 1.6.0    , installed 1.6.0
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "email"        : 1.1.3    , installed 1.1.3
        Adapter    "fahrplan"     : 1.2.2    , installed 1.2.2
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "fhem"         : 1.6.3    , installed 1.6.3
        Adapter    "firetv"       : 1.0.0    , installed 1.0.0
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "followthesun" : 0.3.9    , installed 0.3.9
        Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
        Adapter    "frontier_silicon": 0.0.10, installed 0.0.10
        Adapter    "history"      : 2.2.0    , installed 2.2.0
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "homekit-controller": 0.5.1, installed 0.5.1
        Adapter    "ical"         : 1.13.1   , installed 1.13.1
        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
        Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.8   , installed 1.11.8
        Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
        Adapter    "javascript"   : 6.0.0    , installed 6.0.0
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
        Adapter    "meteoalarm"   : 2.1.3    , installed 2.1.3
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "openweathermap": 0.3.0   , installed 0.3.0
        Adapter    "pegelalarm"   : 1.2.8    , installed 1.2.8
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        Adapter    "sayit"        : 1.12.3   , installed 1.12.3
        Adapter    "scenes"       : 2.3.9    , installed 2.3.9
        Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
        Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
        Adapter    "signal-cmb"   : 0.1.7    , installed 0.1.7
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "socketio"     : 4.2.0    , installed 4.2.0
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
        Adapter    "sql"          : 2.1.7    , installed 2.1.7
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "telegram"     : 1.14.1   , installed 1.14.1
        Adapter    "terminal"     : 0.2.6    , installed 0.2.6
        Adapter    "text2command" : 2.2.2    , installed 2.2.2
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "trashschedule": 2.0.3    , installed 2.0.3
        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
        Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
        Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "web"          : 4.3.0    , installed 4.3.0
        Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
        Adapter    "ws"           : 1.3.0    , installed 1.3.0
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
        pi@raspberrypi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
        pi@raspberrypi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.20.0
        v14.20.0
        6.14.17
        pi
        /opt/iobroker
        OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        OK:2 http://repo.feed.flightradar24.com flightradar24 InRelease
        Alle Pakete sind aktuell.
        nodejs:
          Installiert:           14.20.0-deb-1nodesource1
          Installationskandidat: 14.20.0-deb-1nodesource1
          Versionstabelle:
         *** 14.20.0-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u1 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        • M Martin-72
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.20.0
          v14.20.0
          6.14.17
          pi
          /opt/iobroker
          nodejs:
            Versionstabelle:
          @martin-72
          Da fehlen dir Quellen, direkt vom OS.
          Und die Quelle für nodejs (nodesource.list) fehlt auch.
            @martin-72
            Martin-72
            schrieb am zuletzt editiert von Martin-72
            Meinst Du diese hier?
            deb http://deb.debian.org/debian bullseye main contrib non-free
            deb http://deb.debian.org/debian bullseye-updates main contrib non-free
            deb http://security.debian.org/debian-security bullseye-security main contrib non-free
            und diesen Befehl:
            curl -fsSL https://deb.nodesource.com/setup_current.x | sudo -E bash -
            • M Martin-72
              und diesen Befehl:
              @martin-72
              Möglich. Kann gerade nicht nachschauen.
              Der Befehl für nodejs ist aber falsch, der würde dir nodejs18 aufs System knallen. Das willst du nicht.
                @martin-72
                root_
                Ich hab mein Problem behoben. Bei mir ist ausser dem Host noch ein Slave installiert und der war noch nicht upgedatet. Anscheinend kennen Mqtt, Telegram und der Info Adapter nicht, das der Master Admin aktuell ist, sondern nehmen den Slave Admin als "Quelle".
                Ganz klar aber ein Fehler beim Updaten meinerseits, da ich den Slave noch nicht aktualisiert hatte.
                • R root_
                  @root_
                  Ja, die Versionen sollte übereinstimmen.
                  • M Martin-72
                    armv7l
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v14.20.0
                    v14.20.0
                    6.14.17
                    pi
                    /opt/iobroker
                    nodejs:
                      Versionstabelle:
                    @martin-72
                    Die drei relevanten Dateien sehen so aus:
                    echad@chet:~ $ cat /etc/apt/sources.list
                    # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
                    #deb-src http://deb.debian.org/debian bullseye main contrib non-free
                    #deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free
                    #deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
                    echad@chet:~ $ cat /etc/apt/sources.list.d/raspi.list
                    deb http://archive.raspberrypi.org/debian/ bullseye main
                    # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                    #deb-src http://archive.raspberrypi.org/debian/ bullseye main
                    echad@chet:~ $ cat /etc/apt/sources.list.d/nodesource.list
                    deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                    deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
