  4. Telegram und Mqtt starten nicht.
29 Beiträge 4 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • R root_
    @glasfaser jetzt startet iobroker nicht mehr.
    GlasfaserG Offline
    GlasfaserG Offline
    @root_
    eigentlich nachschauen mit
    iobroker list instances
    Aber ...
    iobroker start admin
    R 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @root_
      Aber ...
      root_
      schrieb am zuletzt editiert von root_
      @glasfaser said in Telegram und Mqtt starten nicht.:
      node:internal/modules/cjs/loader:959
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
          at Function.Module._load (node:internal/modules/cjs/loader:804:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          at node:internal/main/run_main_module:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      liquid@raspberry:~$ iobroker list instances
        throw err;
        requireStack: []
      • R root_
          throw err;
          requireStack: []
          throw err;
          requireStack: []
        @root_
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
          @root_
          cd /opt/iobroker
          root_
          @thomas-braun said in Telegram und Mqtt starten nicht.:
          liquid@raspberry:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
          [sudo] password for liquid:
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm ERR! code 6
          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
          npm ERR! command failed
          npm ERR! command sh /tmp/install-ff6dd1c3.sh
          npm ERR! Uncaught Rejection: Error: Cannot find module '@iobroker/db-states-jsonl'
          npm ERR! Require stack:
          npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
          npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
          npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
          npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)
          npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
          npm ERR!     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3165:26)
          npm ERR!     /home/iobroker/.npm/_logs/2022-09-03T13_48_21_323Z-debug-0.log
            @root_ sagte in Telegram und Mqtt starten nicht.:
            Versionen aus der Beta dist.
            Ich hatte auch schon auf den jeweiligen GitHub geschaut aber nichts gefunden. deswegen hier die Frage.
            Da ist auch nichts . weil sie funktionieren .
            Ein/ und Ausgabe davon in Code-Tags </> hier einstellen
            cd /opt/iobroker
            npm ls | grep -E 'github.com|ERR'
            iobroker update -i
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            Martin-72
            @glasfaser Hallo Helfer in der Not,
            ich hänge mich hier mal an, da ich scheinbar ebenfalls dieses Problem habe.
            Die ersten Schritte bin ich schon mal durchlaufen:
            pi@raspberrypi:~ $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github.com|ERR'
            npm ERR! peer dep missing: chai@>= 2.1.2 < 5, required by chai-as-promised@7.1.1
            npm ERR! peer dep missing: chai@^4.0.0, required by sinon-chai@3.7.0
            npm ERR! peer dep missing: sinon@>=4.0.0, required by sinon-chai@3.7.0
            pi@raspberrypi:/opt/iobroker $ ^C
            pi@raspberrypi:/opt/iobroker $ iobroker update -i
            Used repository: stable
            Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
            Adapter    "admin"        : 6.2.20   , installed 5.3.8  [Updatable]
            Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
            Adapter    "backitup"     : 2.4.10   , installed 2.4.10
            Adapter    "cloud"        : 4.2.2    , installed 4.2.2
            Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
            Adapter    "cul"          : 2.0.2    , installed 2.0.2
            Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
            Adapter    "devices"      : 1.0.12   , installed 1.0.12
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "ds18b20"      : 1.6.0    , installed 1.6.0
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "email"        : 1.1.3    , installed 1.1.3
            Adapter    "fahrplan"     : 1.2.2    , installed 1.2.2
            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
            Adapter    "fhem"         : 1.6.3    , installed 1.6.3
            Adapter    "firetv"       : 1.0.0    , installed 1.0.0
            Adapter    "flot"         : 1.11.0   , installed 1.11.0
            Adapter    "followthesun" : 0.3.9    , installed 0.3.9
            Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
            Adapter    "frontier_silicon": 0.0.10, installed 0.0.10
            Adapter    "history"      : 2.2.0    , installed 2.2.0
            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
            Adapter    "homekit-controller": 0.5.1, installed 0.5.1
            Adapter    "ical"         : 1.13.1   , installed 1.13.1
            Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
            Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "iot"          : 1.11.8   , installed 1.11.8
            Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
            Adapter    "javascript"   : 6.0.0    , installed 6.0.0
            Controller "js-controller": 4.0.23   , installed 4.0.23
            Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
            Adapter    "meteoalarm"   : 2.1.3    , installed 2.1.3
            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
            Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
            Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "nina"         : 0.0.25   , installed 0.0.25
            Adapter    "openweathermap": 0.3.0   , installed 0.3.0
            Adapter    "pegelalarm"   : 1.2.8    , installed 1.2.8
            Adapter    "sayit"        : 1.12.3   , installed 1.12.3
            Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
            Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
            Adapter    "signal-cmb"   : 0.1.7    , installed 0.1.7
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
            Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
            Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
            Adapter    "sql"          : 2.1.7    , installed 2.1.7
            Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
            Adapter    "telegram"     : 1.14.1   , installed 1.14.1
            Adapter    "terminal"     : 0.2.6    , installed 0.2.6
            Adapter    "text2command" : 2.2.2    , installed 2.2.2
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "trashschedule": 2.0.3    , installed 2.0.3
            Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
            Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
            Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
            Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
            Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
            Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
            Adapter    "yr"           : 5.3.0    , installed 5.3.0
            Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
            pi@raspberrypi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
            pi@raspberrypi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.20.0
            v14.20.0
            6.14.17
            pi
            /opt/iobroker
            OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            OK:2 http://repo.feed.flightradar24.com flightradar24 InRelease
            Alle Pakete sind aktuell.
            nodejs:
              Installiert:           14.20.0-deb-1nodesource1
              Installationskandidat: 14.20.0-deb-1nodesource1
              Versionstabelle:
             *** 14.20.0-deb-1nodesource1 100
                 12.22.12~dfsg-1~deb11u1 500
            • M Martin-72
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v14.20.0
              v14.20.0
              6.14.17
              pi
              /opt/iobroker
              nodejs:
                Versionstabelle:
              @martin-72
              Da fehlen dir Quellen, direkt vom OS.
              Und die Quelle für nodejs (nodesource.list) fehlt auch.
                @martin-72
                Martin-72
                schrieb am zuletzt editiert von Martin-72
                Meinst Du diese hier?
                deb http://deb.debian.org/debian bullseye main contrib non-free
                deb http://deb.debian.org/debian bullseye-updates main contrib non-free
                deb http://security.debian.org/debian-security bullseye-security main contrib non-free
                und diesen Befehl:
                curl -fsSL https://deb.nodesource.com/setup_current.x | sudo -E bash -
                • M Martin-72
                  und diesen Befehl:
                  @martin-72
                  Möglich. Kann gerade nicht nachschauen.
                  Der Befehl für nodejs ist aber falsch, der würde dir nodejs18 aufs System knallen. Das willst du nicht.
                    @martin-72
                    root_
                    Ich hab mein Problem behoben. Bei mir ist ausser dem Host noch ein Slave installiert und der war noch nicht upgedatet. Anscheinend kennen Mqtt, Telegram und der Info Adapter nicht, das der Master Admin aktuell ist, sondern nehmen den Slave Admin als "Quelle".
                    Ganz klar aber ein Fehler beim Updaten meinerseits, da ich den Slave noch nicht aktualisiert hatte.
                    • R root_
                      @root_
                      Ja, die Versionen sollte übereinstimmen.
                      • M Martin-72
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v14.20.0
                        v14.20.0
                        6.14.17
                        pi
                        /opt/iobroker
                        nodejs:
                          Versionstabelle:
                        @martin-72
                        Die drei relevanten Dateien sehen so aus:
                        echad@chet:~ $ cat /etc/apt/sources.list
                        # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
                        #deb-src http://deb.debian.org/debian bullseye main contrib non-free
                        #deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free
                        #deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
                        echad@chet:~ $ cat /etc/apt/sources.list.d/raspi.list
                        deb http://archive.raspberrypi.org/debian/ bullseye main
                        # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                        #deb-src http://archive.raspberrypi.org/debian/ bullseye main
                        echad@chet:~ $ cat /etc/apt/sources.list.d/nodesource.list
                        deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                        deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
