  4. Keine Adapter-Updates (ERROR: Process exited with code 25)
    5.8k
4 Beiträge 3 Kommentatoren 995 Aufrufe 2 Beobachtet
    Toskache
    ich habe iobroker auf einem unraid-System via docker (buanet/iobroker) laufen. Soweit funktioniert alles problemlos.
    Nun bietet mir das System Adapter-Updates an (Admin und e3dc-rscp). Leider schlagen die Updates jedoch fehl.
    z.B. e3dc-rscp:
    $ iobroker upgrade e3dc-rscp@1.0.7
    Update e3dc-rscp from @1.0.6 to @1.0.7
    NPM version: 8.15.0
    Installing iobroker.e3dc-rscp@1.0.7... (System call)
    host.a7cf71cb9b3e Cannot install iobroker.e3dc-rscp@1.0.7: 217
    Ich habe schon den installer-fix durchgeführt und ein
    npm cache clean --force
    Weitere Informationen:
    iobroker@a7cf71cb9b3e:~$ iobroker update
    Used repository: stable
    Adapter    "admin"        : 6.2.17   , installed 6.2.14 [Updatable]
    Adapter    "alexa2"       : 3.11.2   , installed 3.19.5
    Adapter    "backitup"     : 2.4.10   , installed 2.4.12
    Adapter    "bshb"         : 0.1.20   , installed 0.1.20
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "e3dc-rscp"    : 1.0.7    , installed 1.0.6  [Updatable]
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.0    , installed 2.2.1
    Adapter    "homeconnect"  : 1.0.1    , installed 1.0.1
    Adapter    "homee"        : 1.2.0    , installed 1.2.0
    Adapter    "influxdb"     : 3.1.7    , installed 3.1.8
    Adapter    "javascript"   : 6.0.0    , installed 6.0.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "material"     : 1.1.2    , installed 1.1.2
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
    Adapter    "node-red"     : 3.3.1    , installed 4.0.0
    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "socketio"     : 4.2.0    , installed 6.1.8
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "web"          : 4.3.0    , installed 5.2.4
    Adapter    "ws"           : 1.3.0    , installed 2.1.3
    iobroker@a7cf71cb9b3e:~$ iobroker list instances
    + system.adapter.admin.0                  : admin                 : a7cf71cb9b3e                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : a7cf71cb9b3e                             -  enabled
      system.adapter.devices.0                : devices               : a7cf71cb9b3e                             -  enabled
    + system.adapter.discovery.0              : discovery             : a7cf71cb9b3e                             -  enabled
    + system.adapter.e3dc-rscp.0              : e3dc-rscp             : a7cf71cb9b3e                             -  enabled
    + system.adapter.history.0                : history               : a7cf71cb9b3e                             -  enabled
    + system.adapter.homee.0                  : homee                 : a7cf71cb9b3e                             -  enabled
    + system.adapter.influxdb.0               : influxdb              : a7cf71cb9b3e                             -  enabled, port: 8086
    + system.adapter.midea.0                  : midea                 : a7cf71cb9b3e                             -  enabled
    + system.adapter.netatmo.0                : netatmo               : a7cf71cb9b3e                             -  enabled
      system.adapter.node-red.0               : node-red              : a7cf71cb9b3e                             - disabled, port: 1880, bind: 0.0.0.0
    + system.adapter.pvforecast.1             : pvforecast            : a7cf71cb9b3e                             -  enabled
    + instance is alive
    iobroker@a7cf71cb9b3e:~$ ps -ef|grep io
    root         1     0  0 Aug29 ?        00:00:00 /bin/bash /opt/scripts/iobroker_startup.sh
    iobroker  2594     1  1 09:14 ?        00:00:26 iobroker.js-controller
    iobroker  2611  2594  0 09:14 ?        00:00:02 io.history.0
    iobroker  2626  2594  0 09:14 ?        00:00:07 io.influxdb.0
    iobroker  2641  2594  0 09:14 ?        00:00:02 io.homee.0
    iobroker  2656  2594  0 09:14 ?        00:00:01 io.netatmo.0
    iobroker  2671  2594  0 09:14 ?        00:00:01 io.discovery.0
    iobroker  2686  2594  0 09:14 ?        00:00:01 io.backitup.0
    iobroker  2701  2594  0 09:14 ?        00:00:01 io.midea.0
    iobroker  2716  2594  0 09:14 ?        00:00:01 io.pvforecast.1
    iobroker  2731  2594  0 09:14 ?        00:00:09 io.e3dc-rscp.0
    iobroker  2764  2594  0 09:15 ?        00:00:04 io.admin.0
    root      2867   875  0 09:19 pts/0    00:00:00 su iobroker
    iobroker  2868  2867  0 09:19 pts/0    00:00:00 bash
    iobroker  3120  2868  0 09:40 pts/0    00:00:00 ps -ef
    iobroker  3121  2868  0 09:40 pts/0    00:00:00 grep io
    Hat jemand eine Idee, was ich tun kann?
    sigi234S D 2 Antworten Letzte Antwort
    • T Toskache
      z.B. e3dc-rscp:
      NPM version: 8.15.0
      + instance is alive
      sigi234S Online
      sigi234S Online
      sigi234
      @toskache
      https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
      Immer Daten sichern!
      • T Toskache
        z.B. e3dc-rscp:
        NPM version: 8.15.0
        + instance is alive
        DarkSoul
        @toskache : Ich kenn mich mit dem Linux nicht so aus, aber ich bekomme unter Windows immer den Fehler 25 wenn der Adapter/die Instance nicht gestoppt ist beim Update.
        Es gibt wohl Updateroutinen die das automatisch mit machen und es gibt welche die machen das nicht. Dann muss ich die Instance von Hand anhalten. Danach klappt es auch mit dem Update. Anschließend Instance wieder starten und gut.
        • sigi234S sigi234
          @toskache
          Toskache
          schrieb am zuletzt editiert von Toskache
          @sigi234 said in Keine Adapter-Updates (ERROR: Process exited with code 25):
          @toskache
          Danke! Den Thread hatte ich irgendwie übersehen/nicht gefunden.
          Folgender Befehl in /opt/iobroker/node_modules ausgeführt brachte die Lösung!
          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
          Vorher kam folgende Meldung:
          iobroker@a7cf71cb9b3e:~$ iobroker upgrade --debug e3dc-rscp
          This upgrade of "e3dc-rscp" will introduce the following changes:
          -> 1.0.7:
          Fixed DB object handling
          Would you like to upgrade e3dc-rscp from @1.0.6 to @1.0.7 now? [(y)es, (n)o]: y
          NPM version: 8.15.0
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/argparse
          npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi'
          npm ERR!     /opt/iobroker/.npm/_logs/2022-08-30T07_59_24_457Z-debug-0.log
