  3. Cloud Dienste
  4. [SKRIPT] Alexa über ioBroker Steuern -> Kommandos an Alexa
261 Beiträge 82 Kommentatoren 117.0k Aufrufe
  • Matten MattenM Offline
    Matten Matten
    #221
    @helfi9999:
    @matten matten,
    ja genau die kriege es nicht hin `
    entweder du erstellst dir Button dummies oder wie ich cuxd Taster.
    ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
      MyMeyer
      #222
      was bedeutet diese Fehlermeldung ?
      ! 22:28:00.887 [info] javascript.0 script.js.Alexa_Device_Command: registered 0 subscriptions and 0 schedules
      ! 22:28:01.035 [error] javascript.0 SyntaxError: Unexpected end of JSON input at Object.parse (native) at dpAbfrageAlexaAnlegen (script.js.Alexa_Device_Command:245:32) at IncomingMessage. (script.js.Alexa_Device_Command:214:81) at emitNone (events.js:91:20) at IncomingMessage.emit (events.js:185:7) at endReadableNT (_stream_readable.js:978:12) at _combinedTickCallback (internal/process/next_tick.js:80:11) at process._tickCallback (internal/process/next_tick.js:104:9)
      ! 22:28:01.051 [error] Caught by controller[0]: at dpAbfrageAlexaAnlegen (script.js.Alexa_Device_Command:245:32)
      ! 22:28:01.051 [error] Caught by controller[0]: at IncomingMessage. (script.js.Alexa_Device_Command:214:81)
      ! 22:28:32.852 [info] javascript.0 Start javascript script.js.Alexa_Device_Command
      ! 22:28:32.853 [info] javascript.0 script.js.Alexa_Device_Command: –- Alexa Kommandos - Skript gestartet ---
      ! 22:28:32.853 [info] javascript.0 script.js.Alexa_Device_Command: registered 0 subscriptions and 0 schedules
      ! 22:28:33.023 [error] Caught by controller[0]: at dpAbfrageAlexaAnlegen (script.js.Alexa_Device_Command:245:32)
      ! 22:28:33.023 [error] Caught by controller[0]: at IncomingMessage. (script.js.Alexa_Device_Command:214:81)
      ! 22:29:04.864 [info] javascript.0 Start javascript script.js.Alexa_Device_Command
      ! 22:29:04.865 [info] javascript.0 script.js.Alexa_Device_Command: –- Alexa Kommandos - Skript gestartet ---
      ! 22:29:04.865 [info] javascript.0 script.js.Alexa_Device_Command: registered 0 subscriptions and 0 schedules
      ! 22:29:05.028 [error] Caught by controller[0]: at dpAbfrageAlexaAnlegen (script.js.Alexa_Device_Command:245:32)
      ! 22:29:05.028 [error] Caught by controller[0]: at IncomingMessage. (script.js.Alexa_Device_Command:214:81)
      ! 22:29:36.835 [info] javascript.0 Start javascript script.js.Alexa_Device_Command
      ! 22:29:36.835 [info] javascript.0 script.js.Alexa_Device_Command: –- Alexa Kommandos - Skript gestartet ---
      ! 22:29:36.836 [info] javascript.0 script.js.Alexa_Device_Command: registered 0 subscriptions and 0 schedules
      ! 22:29:37.012 [error] Caught by controller[0]: at dpAbfrageAlexaAnlegen (script.js.Alexa_Device_Command:245:32)
      ! 22:29:37.012 [error] Caught by controller[0]: at IncomingMessage. (script.js.Alexa_Device_Command:214:81)
      MyMeyer
      >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
      >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
        terne
        #223
        Hallo zusammen
        funktioniert das Script noch bei jemanden?
        ich bekomme weder das automatische "Cookie-Script" noch das "Alexa-Steuerscript" zum Laufen.
        Bekomme den javascript.0 2018-06-14 12:13:29.200 info script.js.common.Skript3: STATUS: 500.
        ! host.terne-PC 2018-06-14 12:13:29.231 error instance system.adapter.javascript.0 terminated with code 0 (OK)
        ! javascript.0 2018-06-14 12:13:29.215 error at process._tickCallback (node.js:356:17)
        ! javascript.0 2018-06-14 12:13:29.215 error at nextTickCallbackWith2Args (node.js:442:9)
        ! javascript.0 2018-06-14 12:13:29.215 error at endReadableNT (_stream_readable.js:921:12)
        ! javascript.0 2018-06-14 12:13:29.215 error at IncomingMessage.emit (events.js:166:7)
        ! javascript.0 2018-06-14 12:13:29.215 error at emitNone (events.js:72:20)
        ! javascript.0 2018-06-14 12:13:29.215 error at IncomingMessage. (script.js.common.Skript3:199:81)
        ! javascript.0 2018-06-14 12:13:29.215 error at dpAbfrageAlexaAnlegen (script.js.common.Skript3:230:32)
        ! javascript.0 2018-06-14 12:13:29.215 error at Object.parse (native)
        ! javascript.0 2018-06-14 12:13:29.215 error SyntaxError: Unexpected token <
        ! javascript.0 2018-06-14 12:13:29.215 error uncaught exception: Unexpected token <
        irgendewas überseh ich doch :shock: :geek:
        Raspimatic und ioBroker auf ProxMox-Server
        ioBroker JS-Controler 3.3.18 redis/redis
        • haselchenH Offline
          haselchenH Offline
          haselchen
          #224
          Also bei mir geht es noch.
          Ab und zu muss ich es manuell anschubsen.
          Und das geht so:
          Ich habe 2 Javascript Instanzen 0 und 1.
          0 ist Alexa Commands
          1 ist das Log on Skript.
          Ich stoppe beide Instanzen.
          Dann ersetze ich im Commands Skript die Javascript1 Instanz auf 0 (beide Zeilen).
          Dann starte ich starte ich beide Instanzen wieder.
          Dann stoppe ich sie wieder und schreibe in das Commands Skript wieder die 1 für Javascript Instanz 1.
          Dann holt er sich den aktuellen Cookie wieder und alles ist schön.
          • E Offline
            Erti1337
            #225
            Du stoppst die Scripte oder ?
            Nicht die Javascript instanzen …
            Aber es macht null Sinn :) Du könntest auch einfach die Scripte neustarten ohne was zu ändern.... Ich glaube eher das dein Cookie noch gültig ist.
            Das Problem an dem Script ist, das duch den Layla.Amazon blabla kein CSRF Token mehr durchkommt irgendwie..
            Mr. Franke wäre hier wohl gefragt, der ist jedoch seit 2 Monaten nicht mehr aktiv gewesen :)
            cgs
            Erti
            • sigi234S Online
              sigi234S Online
              sigi234
              #226
              @Erti1337:
              Mr. Franke wäre hier wohl gefragt, der ist jedoch seit 2 Monaten nicht mehr aktiv gewesen :) `
              Ja, das sollte sich Hauke ansehen! Ich sende ihn mal eine PN.
              Immer Daten sichern!
                haselchenH Offline
                haselchen
                #227
                Ja, ich stoppe die Scripte :)
                Aber tatsächlich holt er erst einen neuen Key,wenn ich das so mache wie beschrieben.
                Wenn ich die Scripte einfach so wieder starte, bekomme ich Fehlermeldungen.
                Ich kann das ja unten in dem Log File sehen.
                • H Offline
                  helfi9999
                  #228
                  habe seit 3 Tagen das gleiche Problem sobald ich das Script von Hauke laufen lasse, macht der Javascript Adapter Probleme und die Leuchte ist nur noch rot, stoppe ich das Script ist die Leuchte dauerhaft grün. Bin voll am verzweifeln.
                  host.ioBroker-RasPi	2018-06-17 08:20:27.783	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                  Caught	2018-06-17 08:20:27.782	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:180:9)
                  Caught	2018-06-17 08:20:27.782	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
                  Caught	2018-06-17 08:20:27.782	error	by controller[0]: at endReadableNT (_stream_readable.js:1064:12)
                  Caught	2018-06-17 08:20:27.782	error	by controller[0]: at IncomingMessage.emit (events.js:208:7)
                  Caught	2018-06-17 08:20:27.782	error	by controller[0]: at emitNone (events.js:111:20)
                  Caught	2018-06-17 08:20:27.782	error	by controller[0]: at IncomingMessage. <anonymous>(script.js.Alexa_Control_Cookie.AlexaControl:990:81)
                  Caught	2018-06-17 08:20:27.782	error	by controller[0]: at script.js.Alexa_Control_Cookie.AlexaControl:523:34
                  Caught	2018-06-17 08:20:27.781	error	by controller[0]: at JSON.parse (<anonymous>:null:null)
                  Caught	2018-06-17 08:20:27.781	error	by controller[0]: SyntaxError: Unexpected end of JSON input
                  javascript.0	2018-06-17 08:20:27.748	info	terminating
                  javascript.0	2018-06-17 08:20:27.740	error	at process._tickCallback (internal/process/next_tick.js:180:9)
                  javascript.0	2018-06-17 08:20:27.740	error	at _combinedTickCallback (internal/process/next_tick.js:138:11)
                  javascript.0	2018-06-17 08:20:27.740	error	at endReadableNT (_stream_readable.js:1064:12)
                  javascript.0	2018-06-17 08:20:27.740	error	at IncomingMessage.emit (events.js:208:7)
                  javascript.0	2018-06-17 08:20:27.740	error	at emitNone (events.js:111:20)
                  javascript.0	2018-06-17 08:20:27.740	error	at IncomingMessage. <anonymous>(script.js.Alexa_Control_Cookie.AlexaControl:990:81)
                  javascript.0	2018-06-17 08:20:27.740	error	at script.js.Alexa_Control_Cookie.AlexaControl:523:34
                  javascript.0	2018-06-17 08:20:27.740	error	at JSON.parse (<anonymous>:null:null)
                  javascript.0	2018-06-17 08:20:27.740	error	SyntaxError: Unexpected end of JSON input
                  javascript.0	2018-06-17 08:20:27.739	error	uncaught exception: Unexpected end of JSON input</anonymous></anonymous></anonymous></anonymous>
                  Kann Hauke helfen.
                  Intel NUC mit Iobroker
                  • E Offline
                    Erti1337
                    #229
                    Sind wohl nur wenige die das überhaupt nutzen, sonst wäre hier sicher mehr los ^^
                    Ist nur sehr schade, da hiermit auch die Rolladensteuerung mit normalen Ausdrücken realisierbar war.
                    Evtl. hören wir ja was von denen die das rausgefunden haben.
                    • O Offline
                      O Offline
                      ooooli
                      #230
                      Ja ist schade! Ich nutze das Ganze auch, um Alexa als Badradio zu starten, wenn das Licht an ist. Das funktionierte bis vor kurzem wirklich prima.
                      Leider kenne ich mich auch zu wenig aus, um zur Lösung beitragen zu können. Wäre toll, wenn sich einer der Entwickler draufstürzen könnte
                      ioBroker Neuling mit 4 Alexas, Sonoff, Netatmo, Lametric Time, Hue, Harmony Hub und einigen anderen Spielereien die es zu verknüpfen gilt
                        haselchenH Offline
                        haselchen
                        #231
                        @Erti1337
                        Hast Du denn meine "Anleitung" mal ausprobiert?
                        • ? Offline
                          #232
                          Warum schreibt Ihr den Cookie nicht manuell?
                          Keine Probleme hier.
                          • sigi234S Online
                            sigi234S Online
                            sigi234
                            #233
                            bekomme diese Meldung:
                            Wrong type of javascript.0.productive.alexalogon.cookievalid: "string". Please fix, while deprecated and will not work in next versions.
                            • E Offline
                              Erti1337
                              #234
                              Manuell ist quasi kein Problem allerdings halt sone Arbeit, welche wenn sie sich vermeiden lässt, die nicht so spannend ist :)
                              Auto war da schon angenehmer :D
                              Und @haeselchen,
                              das geht bei mir nicht.
                              Erti
                              • liv-in-skyL Offline
                                liv-in-skyL Offline
                                liv-in-sky
                                #235
                                sehr frustrierend dieses thema - bei mir lief es wieder ein oder 2 wochen und nun geht wieder nichts. habe mal von hand cookie und csrf eingetragen und damit geht es wieder (thanx to @pocky) siehe: https://www.gehrig.info/alexa/Alexa.html - ist aber sehr umständlich!
                                für linux user: habe eine exec()-script lösung mit https://github.com/thorsten-gehrig/alexa-remote-control gebastelt - damit kann ich wenigstens radio ein aus und bluetooth verbindung momentan benutzen - einen langzeit test habe ich leider noch nicht. für die, die das script kennen - es ist eine neue version auf github! die alte funktionierte auch nicht mehr.
                                mal sehen was in ein oder 2 wochen passiert.
                                leider bin ich kein programmierer - aber vielleicht kann ja jemand mit dem github file etwas anfangen und in das javascript (iobroker) integrieren. in dem github file werden die ganzen curl-abfragen benutzt - vielleicht kann man die in ein javascript verwandeln und ein neues loginscript erstellen, welches csrf und cookie setzt? ich selbst habe ein wenig herumprobiert - aber ohne kenntnisse komme ich da nicht weit!
                                • H Offline
                                  helfi9999
                                  #236
                                  #live-in-sky,
                                  kannst du mal einen Newbie zeigen wie es per Hand gemacht wird mit dem Script habe da absolute Probleme. Habe meine Vis mit dem AlexaLogon gemacht und jetzt geht es nicht mehr.
                                  Grüße helfi9999
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    #237
                                    hi helfi,
                                    1- momentan funktioniert das script (bei mir seit 4 tagen)- aber mal abwarten, was in 2 wochen ist - vielleicht gibt es dann auch probleme
                                    2 - alles zu erklären ist etwas viel - ich weiß nicht welches level du hast? kannst du auf ein terminal zugreifen und auf der linux-console arbeiten - das ist nötig um das script einzurichten und zu testen (das script ist für linux programmiert- erst im zweiten teil wird es in iobroker selbst aufgerufen - wobei brauchst du hilfe?
                                    siehe mal unter: viewtopic.php?f=37&t=15024&p=157153#p157153 nach - dabei geht es zwar um "Alexa redet eigenen text" aber das benutzt das selbe script. dort wird zumindest mal erklärt, wie man das script unter linux installiert (2te seite 4.ter eintrag)
                                    3. ob das script mit 2fa funktioniert weiß ich nicht
                                      MyMeyer
                                      #238
                                      Hi…ich habe immer das Problem das sobald ich das Script startet "JavaScript" abstürzt !
                                      Warum auch immer. Es werden keine Datenpunkte unter Objekte angelegt.
                                      Mit diesem Script:
                                      ! // Alexa mit Javaskript in ioBroker steuern
                                      ! // Skript arbeitet unabhängig vom Cloud Adapter
                                      ! // Version: v0.3.3
                                      ! // Author: ruhr70
                                      ! // Skript im ioBroker Forum: http://forum.iobroker.net/viewtopic.php … and#p62006
                                      ! // alexaCommand("küche","volume",70); // Alle Anwendungen
                                      ! // alexaCommand("küche","pause"); // Radio, Spotify, Hörbücher
                                      ! // alexaCommand("küche","play"); // Radio, Spotify, Hörbücher
                                      ! // alexaCommand("küche","next"); // z.B. Spotify: nächstes Lied
                                      ! // alexaCommand("küche","previous"); // z.B. Spotify: vorheriges Lied
                                      ! // alexaCommand("küche","forward"); // z.B. Hörbücher: 30 Sekunden vor
                                      ! // alexaCommand("küche","rewind"); // z.B. Hörbücher: 30 Sekunden zurück
                                      ! // alexaCommand("küche","shuffle",true); // z.B Amazon Music, Shuffle ein in der aktuellen Playlist
                                      ! // alexaCommand("küche","shuffle",false); // z.B Amazon Music, Shuffle aus in der aktuellen Playlist
                                      ! // alexaCommand("küche","radio",true); // schaltet den Default tunein Radiosender an
                                      ! // alexaCommand("küche","radio",false); // setzt Radio auf Pause
                                      ! // alexaCommand("küche","tunein","s100198"); // setzt tunein Radio auf "s100198" (Einslive)
                                      ! // Die Steuerung kann über die für jedes Gerät angelegten Datenpunkte erfolgen, z.B. über VIS
                                      Log:
                                      ! 22:25:32.526 [info] javascript.0 Start javascript script.js.Alexa_Device_Command
                                      ! 22:25:32.526 [info] javascript.0 script.js.Alexa_Device_Command: –- Alexa Kommandos - Skript gestartet ---
                                      ! 22:25:32.526 [warn] javascript.0 script.js.Alexa_Device_Command: Forcecreation ist eingeschaltet. Wenn nicht mehr benötigt, bitte im Skript auf false setzen
                                      ! 22:25:32.526 [info] javascript.0 script.js.Alexa_Device_Command: registered 0 subscriptions and 0 schedules
                                      ! 22:25:32.709 [error] Caught by controller[0]: at dpAbfrageAlexaAnlegen (script.js.Alexa_Device_Command:245:32)
                                      ! 22:25:32.709 [error] Caught by controller[0]: at IncomingMessage. (script.js.Alexa_Device_Command:214:81)
                                      MyMeyer
                                        MyMeyer
                                        #239
                                        Hi…da hier scheinbar NIEMAND helfen kann sondern man nur ließt "Bei mir läuft es noch..." und " Bei mir läuft es nicht..." lohnt es sich nicht weiter zu hoffen das es ja vernünftig läuft. Der Entwickler hat sich ja bisher auch nicht zu den JAVA Problemen gemeldet.
                                        Entwerder kein Interesse oder er ist einfach raus aus dem Thema !
                                        Ich lösche die Scripts jetzt einfach und such nach etwas neuen...
                                        S C H A D E !!!
                                        MyMeyer
                                        • ? Offline
                                          #240
                                          Der `Entwickler´ wird sich dieses Skript für seine privaten Zwecke geschrieben haben.
                                          Er hat es dann Euch zur Verfügung gestellt. Ohne Verpflichtungen.
                                          Wahrscheinlich haben sich seine Prioritäten bezüglich dieses Skriptes geändert. Aus welchen Gründen auch immer.
                                          Ob Du nun dieses Skript löscht oder sonstwas damit anstellst, interessiert den `Entwickler´ und auch der
                                          Mehrzahl der hier lesenden User wohl gar nichts.
                                          Lasst das Jammern sein und zeigt selbst Initiative.
                                          Alles immer auf einem Silbertablett gereicht zu bekommen hilft einem , wie Du siehst, nicht immer weiter
                                          Es gibt eine Lösung für das Logon.
                                          Cookie selber schreiben.
                                          Wichtig ist ein Browser der Entwicklertools anbietet.
                                          Firefox und Chrome bietet das.
                                          Lies hier https://www.gehrig.info/alexa/Alexa.html wie Du den Cookie manuell schreibst.
                                          Der Cookie fängt mit "session-id=" an und endet HINTER =" und VOR ; sst-acbde (So habe ich das zumindest bei mir so geschrieben.)
                                          Kann im ganzen Stück so kopiert werden.
                                          Selbst das CSRF befindet sich in der ersten Zeile schon im ausgelesenen Cookie.
                                          Diesen kopierst Du auch noch raus aus dem Cookie raus und trägst ihn im csrf ein.
                                          Überschreibe den alten Cookie mit dem neuen.
                                          Voilà, Skript läuft wieder ohne Fehler.
                                          ~~![](</s><URL url=)https://united-websites.org/Cookie.png" />
                                          Übrigens, das eigentliche Skript vom Threadersteller läuft von Anfang an vorzüglich.
                                          Lediglich das Cookie Skript hier viewtopic.php?f=37&t=9237&p=98626&hilit … gOn#p98493
                                          ist das Problem.~~
