  4. Canvas Installation mit Node16 auf R4 nicht möglich
    1.0k
22 Beiträge 4 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • A anno171986
    @skb Hallo, ich habe ein ähnliches Problem:
    Cannot find required modules: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 72. This version of Node.js requires NODE_MODULE_VERSION 93. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
    und wenn ich es versuche neu zu installieren kommen auch Fehler:
    pi@raspberrypi:/opt/iobroker$ cd /opt/iobroker/node_modules
    pi@raspberrypi:/opt/iobroker/node_modules$ npm install canvas --build-from-source
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/canvas
    npm ERR! command failed
    npm ERR! command sh /tmp/install-ab819b46.sh
    npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
    npm ERR! node-pre-gyp info it worked if it ends with ok
    npm ERR! node-pre-gyp info using node-pre-gyp@1.0.10
    npm ERR! node-pre-gyp info using node@16.17.1 | linux | arm
    npm ERR! node-pre-gyp info build requesting source compile
    npm ERR! node:internal/modules/cjs/loader:959
    npm ERR!   throw err;
    npm ERR!   ^
    npm ERR!
    npm ERR! Error: Cannot find module 'object-assign'
    npm ERR! Require stack:
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
    npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
    npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)
    npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
    npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)
    npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1126:14)
    npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
    npm ERR!     at Module.load (node:internal/modules/cjs/loader:1004:32)
    npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:839:12)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19) {
    npm ERR!   code: 'MODULE_NOT_FOUND',
    npm ERR!   requireStack: [
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'
    npm ERR!   ]
    npm ERR! }
    npm ERR! node-pre-gyp ERR! build error
    npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
    npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
    npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
    npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1093:16)
    npm ERR! node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
    npm ERR! node-pre-gyp ERR! System Linux 5.10.103-v7l+
    npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
    npm ERR! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    npm ERR! node-pre-gyp ERR! node -v v16.17.1
    npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.10
    npm ERR! node-pre-gyp ERR! not ok
    npm ERR!     /home/pi/.npm/_logs/2022-11-17T21_24_58_078Z-debug-0.log
    Konntest du dein Problem lösen?
    MCU
    @anno171986
    https://github.com/Automattic/node-canvas/issues/1879
    A 1 Antwort Letzte Antwort
    • M MCU
      @anno171986
      anno171986
      @mcu HAbe ich auch schon gesehen. Weiß aber nicht wie ich das Modul löschen soll und was das für Auswirkungen haben kann
