  4. Probleme mit Adapterupdate nach Update aud Nodejs 16
7 Beiträge 4 Kommentatoren 797 Aufrufe 4 Beobachtet
    andi2055
    ich habe nach Anleitung von Nodejs 14 auf 16 aktualisiert und nun Probleme beim Adapterupdate.
    Habe ich doch etwas falsch gemacht? etwas vergessen? Hat jemand eine Idee was ich tun kann?
    Danke!
    pi@raspberrypi:~ $ iobroker stop admin
    The adapter "admin.0" was stopped.
    pi@raspberrypi:~ $ iobroker upgrade admin --debug
    This upgrade of "admin" will introduce the following changes:
    -> 6.1.11:
    Fixed GUI issues
    Release candidate 1
    -> 6.1.10:
    Fixed issue with map
    Would you like to upgrade admin from @6.1.9 to @6.1.11 now? [(y)es, (n)o]: y
    Update admin from @6.1.9 to @6.1.11
    NPM version: 8.11.0
    Installing iobroker.admin@6.1.11... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/abbrev
    npm ERR! dest /opt/iobroker/node_modules/.abbrev-5eNud0FY
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abbrev' -> '/opt/iobroker/node_modules/.abbrev-5eNud0FY'
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-07T10_02_01_944Z-debug-0.log
    host.raspberrypi Cannot install iobroker.admin@6.1.11: 217
    pi@raspberrypi:~ $ nodejs -v && node -v && npm -v && which nodejs && which node && which npm                v16.15.1
    v16.15.1
    8.11.0
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    pi@raspberrypi:~ $ iobroker upgrade backitup --debug
    This upgrade of "backitup" will introduce the following changes:
    -> 2.4.10:
    Code cleaning
    dependencies updated
    Disclaimer added
    Travis Support removed
    Fix backup-download with ssl
    Would you like to upgrade backitup from @2.4.9 to @2.4.10 now? [(y)es, (n)o]: y
    Update backitup from @2.4.9 to @2.4.10
    NPM version: 8.11.0
    Installing iobroker.backitup@2.4.10... (System call)
    npm ERR! errno -39
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-07T10_17_36_587Z-debug-0.log
    host.raspberrypi Cannot install iobroker.backitup@2.4.10: 217
    • A andi2055
      Danke!
      -> 6.1.11:
      Fixed GUI issues
      Release candidate 1
      -> 6.1.10:
      NPM version: 8.11.0
      npm ERR! errno -39
      v16.15.1
      8.11.0
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      -> 2.4.10:
      Code cleaning
      Disclaimer added
      NPM version: 8.11.0
      npm ERR! errno -39
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @andi2055
      Warum ein Thread dazu ... du bist der 1000 dazu ... gibt das mal in der Suche ein , da stehen Lösungen dazu
      A 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        @andi2055
        andi2055
        @glasfaser
        naja, weil man nichts Vernünftiges schnell findet. Daher auch meine Frage.
        Keine Ahnung was du im Sinn hattest - hast du ja nicht verraten.
        Zu meinem Fehler "ENOTEMPTY" findet man spontan nur einen Thread. Da steht keine Lösung drin
        https://forum.iobroker.net/topic/45728/npm-err-code-enotempty-adapter-upgrade-nicht-mehr-m%C3%B6glich
        In anderen Threads wo es um npm geht, sind tausende Lösungsvorschläge genannt, ohne dass die sich auf mein Problem direkt beziehen. Diverse habe ich nun trotzdem einfach mal auf gut Glück ausprobiert.
        Vielleicht habe ich die schnelle Lösung auch nur nicht gefunden, wo diese auch immer steht....
        Letztendlich hat geholfen:
        pi@raspberrypi:/opt/iobroker $ npm cache clean --force
        • A andi2055
          @glasfaser
          Meister MopperM Offline
          Meister Mopper
          @andi2055
          Guck mal hier.
          Proxmox und HA ...
            @andi2055
            Guck mal hier.
            andi2055
            @meister-mopper
            Bin ich auch drüber gestolpert, mich dann aber für den anderen Befehl (siehe oben) entschieden...
            Danke.
            • A andi2055
              @meister-mopper
              Danke.
              @andi2055
              rm -rf /opt/iobroker/node_modules/.abbrev-5eNud0FY
              wäre es gewesen.
                @andi2055
                wäre es gewesen.
                andi2055
                tatsächlich war es auf meinem zweiten System nicht ganz so einfach wie beim ersten.
                Die Lösung dort war nun ca. 600 Folder nach dem Format /opt/iobroker/node_modules/.XXXX-yyyyy (siehe Beispiel oben) manuell zu löschen.
                Danach hat wieder alles funktioniert. Ob es dafür keinen Automatismus gibt...?
                Danke euch!
