  4. uv-protect Adapter - Warn Meldungen
    6.3k
8 Beiträge 3 Kommentatoren 316 Aufrufe 3 Beobachtet
  • rtwlR Offline
    rtwlR Offline
    rtwl
    @simatec
    ich bekomme beim uv-protect Adapter folgende Fehlermeldung:
    was ist denn hier der Fehler? Hab den Adapter schon mehrfach neu gestartet. Aber es gibt keine Besserung.
    2022-06-26 10:00:01.733 - warn: uv-protect.0 (27873) Object uv-protect.0.uv is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.736 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.755 - warn: uv-protect.0 (27873) Object uv-protect.0.uv_max is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.756 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.771 - warn: uv-protect.0 (27873) Object uv-protect.0.ozone is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.772 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.786 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st1 is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.786 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.795 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st2 is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.796 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.805 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st3 is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.806 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.815 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st4 is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.816 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.825 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st5 is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.825 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.835 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st6 is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.836 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.928 - warn: uv-protect.0 (27873) Object uv-protect.0.sun_info.sun_position.azimuth is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.928 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.936 - warn: uv-protect.0 (27873) Object uv-protect.0.sun_info.sun_position.altitude is invalid: Default value has to be type "number" but received type "string"
    2022-06-26 10:00:01.936 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.954 - warn: uv-protect.0 (27873) Object uv-protect.0.uv_alert is invalid: Default value has to be type "boolean" but received type "string"
    2022-06-26 10:00:01.955 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.962 - warn: uv-protect.0 (27873) Object uv-protect.0.uv_warn is invalid: Default value has to be type "boolean" but received type "string"
    2022-06-26 10:00:01.963 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
    2022-06-26 10:00:01.973 - info: uv-protect.0 (27873) starting. Version 0.3.4 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v14.19.0, js-controller: 4.0.23
    2022-06-26 10:00:04.171 - info: host.smarthome instance system.adapter.netatmo-crawler.0 started with pid 27892
    2022-06-26 10:00:10.448 - info: host.smarthome instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-06-26 10:00:19.627 - warn: uv-protect.0 (27873) Request error: Error: Request failed with status code 500
    2022-06-26 10:00:25.634 - info: uv-protect.0 (27873) Terminated (NO_ERROR): Without reason
    2022
    -Peter
    Thomas BraunT simatecS 2 Antworten Letzte Antwort
    • rtwlR rtwl
      @simatec
      2022
      @rtwl sagte in uv-protect Adapter - Warn Meldungen:
      Hast du das gemacht? Bzw. geschaut ob es nicht schon als Issue angelegt wurde?
      Siehe:
      https://github.com/simatec/ioBroker.uv-protect/issues/50
      • rtwlR rtwl
        @simatec
        2022
        simatecS Offline
        simatecS Offline
        simatec
        @rtwl Welche Version hast du installiert?
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • simatecS simatec
          @simatec
          Also würde sich hier die Beta-Version empfehlen, oder man wartet ab bis die 0.3.5 stable wird.
          rtwlR 1 Antwort Letzte Antwort
            @simatec
            rtwlR Offline
            rtwlR Offline
            rtwl
            @simatec ich hab die version 0.3.4 installiert (vor ca 7 Tagen)
            -Peter
            • rtwlR rtwl
              simatecS Offline
              simatecS Offline
              simatec
              @rtwl Installiere mal die 0.3.5 aus dem latest.
              Ich pushe die die nächsten Tage ins Stable
              • simatecS simatec
                rtwlR Offline
                rtwlR Offline
                rtwl
                @simatec
                okay dsnke
                ich warte vorerst mal auf die stabile Version.
                bräuchte eh dann noch die Info (Anleitung) wie ich diesen UV Wert in shuttercontrol integrieren kann.
                -Peter
                • rtwlR rtwl
                  @simatec
                  okay dsnke
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @rtwl Ich pushe die Version nachher ins Stable.
