  3. Einsteigerfragen
  4. ioBroker kaputt "gerettet"
    5.6k
66 Beiträge 7 Kommentatoren 7.8k Aufrufe 5 Beobachtet
    subman82
    ich habe wohl ähnliche Probleme wie mein Vorgänger aber leider wurden meine mit dem letzten Schritt nicht gelöst. Ich komme nicht auf die Adminseite meines iobroker.
    Ich versuche mal den Codetag hier anzuwenden,ich hoffe es funktioniert,ist mein erster Versuch....
    aktuell:
    Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
    The programs included with the Debian GNU/Linux system are free software;
    pi@raspberrypi:~ $ npm -v
    6.14.17
    pi@raspberrypi:~ $ node -v
    v14.20.0
    Ergebnis des letzten Schrittes deiner Anleitung:
    pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN checkPermissions Missing write access to /home/pi
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No license field.
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /home/pi
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/home/pi'
    npm ERR!  [Error: EACCES: permission denied, access '/home/pi'] {
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/home/pi'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-10T22_20_09_875Z-debug.log
    pi@raspberrypi:~ $ iobroker start
    pi@raspberrypi:~ $ iobroker status
    internal/modules/cjs/loader.js:905
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Es lief soweit alles stabil bis ich ein node update durchgeführt habe von v14 auf v16. npm war meine ich 8.1.5 als noch alles lief.
    Ich wollte eigentlich nur den Shellyadapter updaten aber dafür musste ich Updates vom System durchführen.
    Das hat auch ungefähr 10min funktioniert , alle Instanzen waren auch auch grün und dann wollte ich den Shellyadapter
    updaten und seit dem komme ich nicht mehr auf die Benutzeroberfläche.
    Wie oben dargestellt , habe ich aktuell node auf 14.20.0 und npm 6.14.17 zurückgestellt aber das half noch nicht.
    Ich sitz hier schon 5 Stunden dran und komm nicht weiter.Ich hoffe ihr könnt mir helfen,.
    Besten Dank vorab,Gruss Peter
    • S subman82
      aktuell:
      6.14.17
      v14.20.0
      npm ERR! errno -13
      npm ERR! }
      npm ERR!
      npm ERR!
        throw err;
        requireStack: []
      @subman82 sagte in ioBroker kaputt "gerettet":
      Du stehst im falschen Verzeichnis.
      cd /opt/iobroker
      Und wie bist du da nun grundsätzlich unterwegs?
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      anschauen.
        cd /opt/iobroker
        anschauen.
        subman82
        Moin und danke für die schnelle Rückmeldung.
        Ich glaub das mit dem falschem Verzeichnis liegt daran , wenn man keine Ahnung hat und aus allen Posts etwas versucht um es zu retten....Schande über mein Haupt. Ich könnte mir auch vorstellen, dass die Versionen von nodejs,node und npm nicht kompatibel sind. Ich habe immer regelmässig upgedatet aber diesmal ist was schief gelaufen:/
        pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.20.0
        v14.20.0
        6.14.17
        pi
        /home/pi
        Danke für deine Mühe!!
        • S subman82
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.20.0
          v14.20.0
          6.14.17
          pi
          /home/pi
          Vermutlich ewig keine Updates mehr eingespielt.
            subman82
            Ich schaue wirklich regelmässig nach Updates,ich würde sagen mindestens einmal im Monat.
            Ich habe in den Adaptern und unter der Benutzeroberfläche unter Info immer kontrolliert dass alles aktuell ist, vielleicht habe ich aus Unwissenheit etwas vergessen?Bisher hab ich immer node.js und js-controller über Putty upgedatet meine ich . Node ist ebefalls ein separates Programm habe ich jetzt festgestellt. Ich schau später nochmal nach einer Anleitung, wie ich es zukünftig richtig mache.
            pi@raspberrypi:~ $ sudo apt update && apt policy nodejs
            OK:3 https://deb.nodesource.com/node_14.x buster InRelease
            Aktualisierung für 9 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
            nodejs:
              Installiert:           14.20.0-deb-1nodesource1
              Installationskandidat: 14.20.0-deb-1nodesource1
              Versionstabelle:
             *** 14.20.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
            Thomas BraunT S 2 Antworten Letzte Antwort
            • S subman82
              nodejs:
                Versionstabelle:
              Aktualisier das System.
              Und wo klemmt es denn nun konkret?
              • S subman82
                nodejs:
                  Versionstabelle:
                subman82
                @subman82 Die jetzt installierten Versionen habe ich nur installiert, weil ich gehofft hatte dass mit den alten Versionen es wieder laufen würde und ich könnte dann neu updaten.
                • S subman82
                  @subman82
                  Und konkret bedeutet das? Läuft der iobroker? Wenn nicht, mit welchen Meldungen?
                    subman82
                    ich suche gleich nochmal alle 3 aktuellen Versionen raus und installiere sie neu.
                    Aktuell komme ich nicht auf die Benützeroberfläche über die IP. Laut Fritzbox ist es aber die richtige IP.
                    Bringt es jetzt noch etwas aus dem Backup über Putty wiederherzustellen? Oder habe ich schon zu viel verändert?
                    Thomas BraunT J 2 Antworten Letzte Antwort
                    • S subman82
                      @subman82
                      Du verwirrst mich. Welche drei Versionen?
                      iobroker status
                      iobroker list instances
                      • S subman82
                        Jan1
                        Es ist wurscht was da geändert wurde, da man vor dem Restor am besten den gesamten IOBroker löscht und dann außer Linux eh nix mehr da ist ;)
                        Nur sollte man schon noch vorher per SSH auf die Kiste kommen.
                          @subman82
                          iobroker status
                          subman82
                          das hat sich hier unglücklich überschnitten.
                          Thomas:Du verwirrst mich. Welche drei Versionen?:
                          Ich meine die 3 aktuellen Versionen von node,nodejs und npm.
                          Meldung des Browser:
                          "Fehler: Verbindung fehlgeschlagen
                          Thomas:Und konkret bedeutet das? Läuft der iobroker? Wenn nicht, mit welchen Meldungen?
                          Firefox kann keine Verbindung zu dem Server unter 192.168.178.58:8081 aufbauen.
                          Die Website könnte vorübergehend nicht erreichbar sein, versuchen Sie es bitte später nochmals.
                          Wenn Sie auch keine andere Website aufrufen können, überprüfen Sie bitte die Netzwerk-/Internetverbindung.
                          Wenn Ihr Computer oder Netzwerk von einer Firewall oder einem Proxy geschützt wird, stellen Sie bitte sicher, dass Firefox auf das Internet zugreifen darf."
                          Iobroker scheint aber auch nicht im Hintergrund zu laufen, da es auf keine Befehle mehr über Siri reagiert.
                          Über Putty (SSH?) kann ich auf den Raspberry zugreifen aber Iobroker läuft nicht. Ich habe das System damals über Ebay fertig gekauft und dann nur die notwendigen Adaptern selber installiert, drum bin ich da nicht so fit drin, sorry:/
                          pi@raspberrypi:~ $ apt list --upgradable
                          Auflistung... Fertig
                          freetype2-doc/oldstable 2.9.1-3+deb10u3 all [aktualisierbar von: 2.9.1-3+deb10u2]
                          libfreetype6-dev/oldstable 2.9.1-3+deb10u3 armhf [aktualisierbar von: 2.9.1-3+deb10u2]
                          libfreetype6/oldstable 2.9.1-3+deb10u3 armhf [aktualisierbar von: 2.9.1-3+deb10u2]
                          libfribidi-dev/oldstable 1.0.5-3.1+deb10u2 armhf [aktualisierbar von: 1.0.5-3.1+deb10u1]
                          libfribidi0/oldstable 1.0.5-3.1+deb10u2 armhf [aktualisierbar von: 1.0.5-3.1+deb10u1]
                          libgssapi-krb5-2/oldstable 1.17-3+deb10u4 armhf [aktualisierbar von: 1.17-3+deb10u3]
                          libk5crypto3/oldstable 1.17-3+deb10u4 armhf [aktualisierbar von: 1.17-3+deb10u3]
                          libkrb5-3/oldstable 1.17-3+deb10u4 armhf [aktualisierbar von: 1.17-3+deb10u3]
                          libkrb5support0/oldstable 1.17-3+deb10u4 armhf [aktualisierbar von: 1.17-3+deb10u3]
                            throw err;
                            requireStack: []
                          pi@raspberrypi:~ $ iobroker list instances
                            throw err;
                            requireStack: []
                          Thomas BraunT Dr. BakteriusD 3 Antworten Letzte Antwort
                          • S subman82
                              throw err;
                              requireStack: []
                              throw err;
                              requireStack: []
                            Es gibt keine individuellen Versionen. Das ist alles richtig im Paket 'nodejs' drin. Frickel da nix herum.
                            • S subman82
                                throw err;
                                requireStack: []
                                throw err;
                                requireStack: []
                              @subman82
                              cd /opt/iobroker
                              iobroker update -i
                              iobroker upgrade
                              iobroker start
                              iobroker status
                                @subman82
                                cd /opt/iobroker
                                iobroker update -i
                                iobroker upgrade
                                iobroker start
                                iobroker status
                                subman82
                                @thomas-braun said in ioBroker kaputt "gerettet":
                                iobroker status
                                npm ERR! errno -13
                                npm ERR! }
                                npm ERR!
                                npm ERR!
                                npm ERR!     /home/iobroker/.npm/_logs/2022-09-11T10_27_38_573Z-debug.log
                                pi@raspberrypi:~ $ iobroker update -i
                                  throw err;
                                  requireStack: []
                                pi@raspberrypi:~ $ iobroker upgrade
                                  throw err;
                                  requireStack: []
                                  throw err;
                                  requireStack: []
                                War das nicht das Problem mit dem falschen Verzeichnis? Aber wie ändere ich das?
                                • S subman82
                                  iobroker status
                                  npm ERR! errno -13
                                  npm ERR! }
                                  npm ERR!
                                  npm ERR!
                                    throw err;
                                    requireStack: []
                                    throw err;
                                    requireStack: []
                                    throw err;
                                    requireStack: []
                                  @subman82
                                  Du stehst immer noch im falschen Verzeichnis.
                                  Warum gibst du nicht alles ein, was ich vorgebe?
                                  Die Zeile mit dem cd drin steht da nicht zur Zierde.
                                    @subman82
                                    subman82
                                    Ooooh, ich dachte immer da sich bei Putty nach der Eingabe dieses Befehls nichts getan hat, wäre es nur eine Art Befehl um SSH bzw. Putty zu starten.Wieder was gelernt, werde es nicht mehr weglassen!! Das bestimmt was root zu tun oder? (Ich kann echt garnix am PC:/)
                                    Ich habe somit nochmal von oben angefangen und folgende Logs:
                                    pi@raspberrypi:~ $ cd /opt/iobroker
                                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                    > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                    > node lib/preinstallCheck.js
                                    NPM version: 6.14.17
                                    > usb@1.9.2 install /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo/node_modules/usb
                                    > node-gyp-build
                                    make: Verzeichnis „/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo/node_modules/usb/build“ wird betreten
                                      CC(target) Release/obj.target/libusb/libusb/libusb/core.o
                                      CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
                                      CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
                                      CC(target) Release/obj.target/libusb/libusb/libusb/io.o
                                      CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
                                      CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
                                      CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
                                      CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
                                      CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
                                      CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
                                      AR(target) Release/obj.target/usb.a
                                      COPY Release/usb.a
                                      CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
                                    ../src/node_usb.cc: In function ‘Napi::Value SetDebugLevel(const Napi::CallbackInfo&)’:
                                    ../src/node_usb.cc:118:71: warning: ‘void libusb_set_debug(libusb_context*, int)’ is deprecated: Use libusb_set_option instead [-Wdeprecated-declarations]
                                      libusb_set_debug(usb_context, info[0].As<Napi::Number>().Int32Value());
                                    In file included from ../src/node_usb.h:11,
                                                     from ../src/node_usb.cc:1:
                                    ../libusb/libusb/libusb.h:1325:18: note: declared here
                                     void LIBUSB_CALL libusb_set_debug(libusb_context *ctx, int level);
                                      CXX(target) Release/obj.target/usb_bindings/src/device.o
                                      CXX(target) Release/obj.target/usb_bindings/src/transfer.o
                                      SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
                                      COPY Release/usb_bindings.node
                                    make: Verzeichnis „/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo/node_modules/usb/build“ wird verlassen
                                    > usb@1.9.2 install /opt/iobroker/node_modules/@abandonware/.noble-UjddDcbH/node_modules/usb
                                    > node-gyp-build
                                    make: Verzeichnis „/opt/iobroker/node_modules/@abandonware/.noble-UjddDcbH/node_modules/usb/build“ wird betreten
                                      COPY Release/usb.a
                                    make: Verzeichnis „/opt/iobroker/node_modules/@abandonware/.noble-UjddDcbH/node_modules/usb/build“ wird verlassen
                                    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/@iobroker/.db-base-ab09iRFq/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-base-ab09iRFq/node_modules/unix-dgram/build“ wird betreten
                                      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                                    In file included from ../../nan/nan.h:60,
                                                     from ../src/unix_dgram.cc:5:
                                    /home/iobroker/.cache/node-gyp/14.20.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                           (node::addon_register_func) (regfunc),                          \
                                    /home/iobroker/.cache/node-gyp/14.20.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                                       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                                     NODE_MODULE(unix_dgram, Initialize)
                                      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                                      COPY Release/unix_dgram.node
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-base-ab09iRFq/node_modules/unix-dgram/build“ wird verlassen
                                    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/@iobroker/.db-objects-file-ubICTaYK/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-objects-file-ubICTaYK/node_modules/unix-dgram/build“ wird betreten
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-objects-file-ubICTaYK/node_modules/unix-dgram/build“ wird verlassen
                                    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/@iobroker/.db-objects-jsonl-G7SarE7O/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-objects-jsonl-G7SarE7O/node_modules/unix-dgram/build“ wird betreten
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-objects-jsonl-G7SarE7O/node_modules/unix-dgram/build“ wird verlassen
                                    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/@iobroker/.db-objects-redis-c2gJ2uk7/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-objects-redis-c2gJ2uk7/node_modules/unix-dgram/build“ wird betreten
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-objects-redis-c2gJ2uk7/node_modules/unix-dgram/build“ wird verlassen
                                    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/@iobroker/.db-states-file-b4IMGS2U/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-states-file-b4IMGS2U/node_modules/unix-dgram/build“ wird betreten
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-states-file-b4IMGS2U/node_modules/unix-dgram/build“ wird verlassen
                                    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/@iobroker/.db-states-jsonl-u7i57pvw/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-states-jsonl-u7i57pvw/node_modules/unix-dgram/build“ wird betreten
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-states-jsonl-u7i57pvw/node_modules/unix-dgram/build“ wird verlassen
                                    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/@iobroker/.db-states-redis-GzenCYAo/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-states-redis-GzenCYAo/node_modules/unix-dgram/build“ wird betreten
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.db-states-redis-GzenCYAo/node_modules/unix-dgram/build“ wird verlassen
                                    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/@iobroker/.js-controller-adapter-KzcGIgOj/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    make: Verzeichnis „/opt/iobroker/node_modules/@iobroker/.js-controller-adapter-KzcGIgOj/node_modules/unix-dgram/build“ wird betreten
                                    + iobroker.js-controller@4.0.23
                                    added 1112 packages from 283 contributors, removed 9 packages and updated 245 packages in 758.546s
                                    50 packages are looking for funding
                                      run `npm fund` for details
                                    pi@raspberrypi:/opt/iobroker $ iobroker status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    pi@raspberrypi:/opt/iobroker $ iobroker list instances
                                     Cannot determine Set feature status: Connection is closed.
                                     Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                                     Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                                    Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                                    Musste Log abkürzen ,da eine Fehlermeldung beim Absenden auftrat (Payload too large) Ich hoffe du kannst trotzdem etwas damit anfangen.
                                    Es hat sich durch hinzufügen des ersten Schrittes (1. cd /opt/iobroker) auf jedenfall etwas geändert...ich komme wieder auf die Benutzeroberfläche:))
                                    Die Instanzen sind noch alle da aber auf rot.
                                    J 1 Antwort Letzte Antwort
                                    • S subman82
                                      > node-gyp-build
                                        COPY Release/usb.a
                                      > node-gyp-build
                                        COPY Release/usb.a
                                      > node-gyp rebuild
                                      > node-gyp rebuild
                                      > node-gyp rebuild
                                      > node-gyp rebuild
                                      > node-gyp rebuild
                                      > node-gyp rebuild
                                      > node-gyp rebuild
                                      > node-gyp rebuild
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Jan1
                                      Wieder was gelernt
                                      Dann gleich noch was, Putty ist lediglich ein Tool um z.B. eine Konsole für ein SSH Verbindung zu öffnen, nicht mehr und nicht weniger ;)
                                      • J Jan1
                                        Wieder was gelernt
                                        subman82
                                        @jan1 Viel lernen ich noch muss 😕
                                        Ich danke euch auf jeden Fall, insbesondere für die Geduld 🙄
                                        • S subman82
                                          @subman82
                                          cd = Change Directory
                                          Starte die Kiste mal komplett durch.
                                          iobroker stop
                                          sudo reboot
