  3. Cloud Dienste
  4. kann Google Home nicht mehr (re)connecten!
    6.4k
9 Beiträge 4 Kommentatoren 1.2k Aufrufe 4 Beobachtet
  • frankjokeF Offline
    frankjokeF Offline
    frankjoke
    schrieb am zuletzt editiert von frankjoke
    Ich kann seit gestern mein Google home nicht mehr (re)connecten!
    Kriege in IOT solche Fehlermeldungen:
    2022-03-29 17:23:24.344	error	[GHOME] devices are unknown to google home
    iot.0
    2022-03-29 17:23:14.552	warn	[GHOME] Missing name, type or treat for: alias.0.Keller.BewegungKellerUnten. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.552	warn	[GHOME] Missing name, type or treat for: alias.0.Keller.BewegungKellerOben. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.551	warn	[GHOME] Missing name, type or treat for: alias.0.Keller.BewegungAbstellraum. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.549	warn	[GHOME] Missing name, type or treat for: alias.0.EG.Wassermelder. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.549	warn	[GHOME] Missing name, type or treat for: alias.0.EG.WCEingang. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.548	warn	[GHOME] Missing name, type or treat for: alias.0.EG.WCAusgang. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.547	warn	[GHOME] Missing name, type or treat for: alias.0.EG.VorzimmerBewegung. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.547	warn	[GHOME] Missing name, type or treat for: alias.0.EG.TorSchalter. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.545	warn	[GHOME] Missing name, type or treat for: alias.0.EG.BewegungWC. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.545	warn	[GHOME] Missing name, type or treat for: alias.0.AZF.BewegungInnen. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.544	warn	[GHOME] Missing name, type or treat for: alias.0.AZF.BewegungAZFS. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.544	warn	[GHOME] Missing name, type or treat for: alias.0.AZF.BewegungAZF2. Not added to GoogleHome
    iot.0
    2022-03-29 17:23:14.542	warn	[GHOME] Missing name, type or treat for: alias.0.1Stock.Klimaanlage. Not added to GoogleHome
    iot.0
    2022-03-29 17:22:55.222	error	[GHOME] device alias.0.1Stock.TemperaturFZ.ACTUAL is unknown to google home
    iot.0
    2022-03-29 17:20:05.565	error	[GHOME] device alias.0.EG.TerassenTemperatur.SECOND is unknown to google home
    iot.0
    2022-03-29 17:18:49.809	error	[GHOME] device alias.0.GartenPool.GartenTemperatur.ACTUAL is unknown to google home
    iot.0
    2022-03-29 17:18:49.805	error	[GHOME] device alias.0.WZ.TempWZ1.SECOND is unknown to google home
    iot.0
    2022-03-29 17:18:11.200	error	[GHOME] device alias.0.1Stock.TemperaturFZ.SECOND is unknown to google home
    iot.0
    2022-03-29 17:15:56.519	error	[GHOME] device alias.0.EG.TerassenTemperatur.ACTUAL is unknown to google home
    iot.0
    2022-03-29 17:14:18.660	error	[GHOME] device alias.0.EG.Tado.SECOND is unknown to google home
    iot.0
    2022-03-29 17:14:18.658	error	[GHOME] device alias.0.EG.Tado.ACTUAL is unknown to google home
    iot.0
    2022-03-29 17:14:01.909	error	[GHOME] device alias.0.Zentrale.GPUtemp.ACTUAL is unknown to google home
    iot.0
    2022-03-29 17:14:01.846	error	[GHOME] device alias.0.Zentrale.CPUtemp.ACTUAL is unknown to google home
    iot.0
    2022-03-29 17:12:40.791	error	[GHOME] device alias.0.GartenPool.GartenTemperatur.SECOND is unknown to google home
    iot.0
    2022-03-29 17:12:40.607	error	[GHOME] device alias.0.WZ.TempWZ1.ACTUAL is unknown to google home
    iot.0
    2022-03-29 17:09:28.112	error	[GHOME] device alias.0.1Stock.TemperaturSZ.ACTUAL is unknown to google home
    Bis gestern hat's funktioniert, nur mit warnings.
    Übrigens: Wie kann ich geräte aus dem Google-interface ausblenden? Wenn ich das Gerät in der Liste mit dem Mistkübel lösche taucht es immer wieder auf!
    Ich will nur 5-6 meiner Geräte für Google assistant nutzbar machen aber nicht alles (z.B. den Teil der oben Fehler macht)!
    Frank,
    H 1 Antwort Letzte Antwort
    • frankjokeF frankjoke
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      holofury
      @frankjoke
      Gibt es hierfür jetzt eine Lösung?
      Habe das gleiche Problem - ioBroker aus Google Home entfernt, neu verbinden funktioniert nicht, ebenfalls mit u.a. dieser Meldung im Log:
      • crunchipC Abwesend
        crunchipC Abwesend
        Info:
        Habe gestern ein Update der Google Home App gemacht, seither wurden alle Geräte entfernt, keine Verbindung mehr zu iobroker möglich.
          crunchipC Abwesend
          Gibt es bezüglich google home Update noch andere mit diesem Problem?
          Marius SchäferM 1 Antwort Letzte Antwort
            Marius SchäferM Offline
            Marius Schäfer
            Habe heute upgedated und meine Geräte sind auch alle weg.
            • Marius SchäferM Marius Schäfer
              crunchipC Abwesend
              crunchipC Abwesend
              @marius-schäfer dann bin ich schon mal nicht alleine, wundert mich allerdings das aktuell nicht noch mehr von diesem Problem zu lesen ist, nutzen ja doch einige google/iobroker
                Marius Schäfer
                @crunchip Ja..
                [GHOME] No devices defined. Did you add no sensors or indicate states to rooms and enums?
                  @crunchip Ja..
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @marius-schäfer ich habe jetzt im iot google ausgeschaltet und gespeichert, anschliessend google wieder aktiviert, jetzt konnte ich iobroker wieder in der home App zufügen
                    Marius Schäfer
                    @crunchip Ich habe ein downgrade auf 1.11.5 gemacht und es geht.
