  4. Node-Red
  5. Unifi Adapter mac Adresse blockieren und wieder aktivieren?
    6.5k
2 Beiträge 2 Kommentatoren 472 Aufrufe 1 Beobachtet
    Ritschi
    Hallo
    Ich habe versucht mit Hilfe dieses alten Threads Geräte mit Angabe der Mac Adresse zu deaktivieren.
    Re: Node-Red-Contrib-Unifi Special Commands
    Leider klappt es nicht, dass das Gerät geblockt wird.
    Hier mein Flow:
            "id": "8a3e4967.edde68",
            "type": "inject",
            "z": "1225019d0289ffff",
            "name": "blockClient",
            "props": [
                    "p": "payload.command",
                    "v": "blockClient",
                    "vt": "str"
                    "p": "payload.mac",
                    "v": "Mein mac Gerät",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "x": 490,
            "y": 260,
            "wires": [
                    "9273c229c2a5d194"
            "id": "84112698.7006a8",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 930,
            "y": 280,
            "wires": []
            "id": "12f29a29.19bf96",
            "type": "inject",
            "name": "unblockClient",
            "props": [
                    "v": "unblockClient",
                    "vt": "str"
                    "p": "payload.mac",
                    "v": "Meine mac Adresse",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "x": 500,
            "y": 300,
            "wires": [
                    "9273c229c2a5d194"
            "id": "9273c229c2a5d194",
            "type": "Unifi",
            "name": "",
            "ip": "192.168.1.3",
            "port": 8443,
            "site": "default",
            "command": "20",
            "unifios": false,
            "credentials": {},
            "x": 730,
            "y": 280,
            "wires": [
                    "84112698.7006a8"
    Ich bin nicht sicher, ob das unifi Gerät richtig eingestellt ist.
    Hier mal ein Printscreen
    Wäre dankbar um Hilfe.
    • R Ritschi
      Hallo
      Hier mein Flow:
              "type": "inject",
              "props": [
                      "v": "blockClient",
                      "vt": "str"
                      "p": "payload.mac",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "x": 490,
              "y": 260,
              "wires": [
                      "9273c229c2a5d194"
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 930,
              "y": 280,
              "wires": []
              "type": "inject",
              "props": [
                      "vt": "str"
                      "p": "payload.mac",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "x": 500,
              "y": 300,
              "wires": [
                      "9273c229c2a5d194"
              "type": "Unifi",
              "name": "",
              "port": 8443,
              "site": "default",
              "command": "20",
              "unifios": false,
              "credentials": {},
              "x": 730,
              "y": 280,
              "wires": [
                      "84112698.7006a8"
      mickymM Offline
      mickymM Offline
      mickym
      @ritschi sagte in Unifi Adapter mac Adresse blockieren und wieder aktivieren?:
      Ich weiß nicht, ob ich Dir helfen kann, da ich diesen Switch nicht besitze.
      Ich habe aber gerade mal versucht diese Node zu installieren und da gab es erst einen Fehler. Schau mal in Deinem Palettenmanager, ob die Node richtig installiert ist.
      Ich hab dann manuell diese aws verzeichnis und noch ein modul aus node-modules gelöscht und nochmal installiert und da hat es dann funktioniert.
      Also check mal Deinen Palettenmanager und ggf. musst die Node installieren. Funktionieren denn die eingebauten Kommandos? - Wie gesagt ich kann hier nur trocken mal checken - und kann Dir ggf. nicht viel helfen.
      Zumindest solltest Du im Status sehen, wenn Du die Inject Nodes benutzt, dass der Status unter der Unifi Node angezeigt wird:
