  4. iobroker Benutzer Error in GUI!
    6.3k
32 Beiträge 7 Kommentatoren 3.5k Aufrufe 5 Beobachtet
    Mika 0
    Dank euch innerhalb von Sekunden über Putty: ;-)
    pi@iobroker:~ $ which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/node
    v14.19.1
    /usr/bin/npm
    6.14.16
    nodejs:
    Installed: 14.19.1-deb-1nodesource1
    Candidate: 14.19.1-deb-1nodesource1
    Version table:
    *** 14.19.1-deb-1nodesource1 500
    500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
    100 /var/lib/dpkg/status
    12.22.5~dfsg-2~11u1 500
    500 http://deb.debian.org/debian bullseye/main arm64 Packages
    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    pi@iobroker:~ $
    Hoffe das passt alles?
    • M Mika 0
      /usr/bin/node
      v14.19.1
      /usr/bin/npm
      6.14.16
      nodejs:
      Version table:
      pi@iobroker:~ $
      @mika-0
      which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        Mika 0
        schrieb am zuletzt editiert von Mika 0
        Tadaa:
        pi@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        pi@iobroker:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.1
        v14.19.1
        6.14.16
        pi
        /home/pi
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
        Reading package lists... Done
        Building dependency tree... Done
        2 packages can be upgraded. Run 'apt list --upgradable' to see them.
        nodejs:
        Version table:
        pi@iobroker:~ $
        Also das habe ich gemacht und den Pi jetzt noch neu gestartet.
        Der Error ist weiterhin vorhanden.
        • M Mika 0
          Tadaa:
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.19.1
          v14.19.1
          6.14.16
          pi
          /home/pi
          nodejs:
          Version table:
          pi@iobroker:~ $
          @mika-0
          Kannst du bitteText in CodeTags einbetten?
          iobroker update -i
          sagt?
            Mika 0
            @thomas-braun sagte in iobroker Benutzer Error in GUI!:
            iobroker update -i
            Hallo Thomas. Aber ich habe deinen Befehl mal im Putty eingegeben und folgend das Ergebnis:
            pi@iobroker:~ $ iobroker update -i
            Used repository: stable
            Adapter    "admin"        : 5.3.1    , installed 5.3.1
            Adapter    "backitup"     : 2.3.3    , installed 2.3.3
            Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
            Adapter    "discovery"    : 2.7.5    , installed 2.7.5
            Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
            Adapter    "history"      : 1.10.5   , installed 1.10.5
            Adapter    "ical"         : 1.11.4   , installed 1.11.4
            Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
            Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
            Adapter    "javascript"   : 5.2.21   , installed 5.2.21
            Controller "js-controller": 4.0.21   , installed 4.0.21
            Adapter    "mihome-vacuum": 3.3.1    , installed 3.3.1
            Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
            Adapter    "ping"         : 1.5.0    , installed 1.5.0
            Adapter    "s7"           : 1.3.10   , installed 1.3.10
            Adapter    "simple-api"   : 2.6.2    , installed 2.6.4
            Adapter    "smappee"      : 0.2.6    , installed 0.2.6
            Adapter    "socketio"     : 4.1.4    , installed 4.1.5
            Adapter    "tr-064"       : 4.2.15   , installed 4.2.15
            Adapter    "trashschedule": 1.4.1    , installed 1.4.1
            Adapter    "vis"          : 1.4.5    , installed 1.4.5
            Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
            Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
            Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
            Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
            Adapter    "web"          : 4.2.0    , installed 4.2.0
            Adapter    "ws"           : 1.2.0    , installed 1.2.0
            pi@iobroker:~ $
            Korrektur durchgeführt...
            • M Mika 0
              iobroker update -i
              pi@iobroker:~ $
              @mika-0
              CodeTags:
              Text markieren, </> Icon anklicken, fertig.
              • M Mika 0
                iobroker update -i
                pi@iobroker:~ $
                @mika-0
                Und was ist jetzt aktuell das Problem? Mit welchen Meldungen?
                  @mika-0
                  Mika 0
                  Wenn ich auf Users im ioBroker drücke kommt immer noch Error.
                  Auszug vom Error:
                  Error: Minified React error #31; visit https://reactjs.org/docs/error-decoder.html?invariant=31&args[]=object%20with%20keys%20%7Ben%2C%20de%2C%20ru%2C%20pt%2C%20nl%2C%20fr%2C%20it%2C%20es%2C%20pl%2C%20zh-cn%7D for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
                      at Ec (6.501acaca.chunk.js:2:5595786)
                      at 6.501acaca.chunk.js:2:5600621
                      at Po (6.501acaca.chunk.js:2:5611663)
                      at Zi (6.501acaca.chunk.js:2:5657695)
                      at jl (6.501acaca.chunk.js:2:5643113)
                      at Sl (6.501acaca.chunk.js:2:5643041)
                      at Cl (6.501acaca.chunk.js:2:5642904)
                      at zl (6.501acaca.chunk.js:2:5639870)
                      at 6.501acaca.chunk.js:2:5589364
                      at t.unstable_runWithPriority (6.501acaca.chunk.js:2:5672574)
                      at Ga (6.501acaca.chunk.js:2:5589141)
                      at Ka (6.501acaca.chunk.js:2:5589309)
                      at Za (6.501acaca.chunk.js:2:5589244)
                      at pl (6.501acaca.chunk.js:2:5637247)
                      at Object.enqueueSetState (6.501acaca.chunk.js:2:5593262)
                      at s.m.setState (6.501acaca.chunk.js:2:5664084)
                      at :8081/static/js/9.a078e0d6.chunk.js:1:27236
                  • M Mika 0
                    Auszug vom Error:
                    @mika-0 sagte in iobroker Benutzer Error in GUI!:
                    Muss sich jemand mit Kenn vom Admin-GUI anschauen, denke ich.
                    Log ein Issue.
                      Log ein Issue.
                      TT-Tom
                      @mika-0
                      Log ein Issue.
                      Es ist immer noch offen 1337
                      Mika wird warten müssen.
                      Gruß Tom
                      Public Transport
                      NSPanel Adapter Wiki
                      • T TT-Tom
                        @mika-0
                        Log ein Issue.
                        Mika 0
                        @tt-tom Danke der Info. Dann schließe ich erstmal das Thema.
                        • ElzersharkE Offline
                          ElzersharkE Offline
                          Elzershark
                          schrieb am zuletzt editiert von Elzershark
                          Ganz oben auf den Schraubenschlüssel klicken. (Systemeinstellung)
                          Repositories
                          Dort die 2 anklicken (Beta) und speichern.
                          (Eventuell auf Experte einstellen (Oben der Kopf) und Version 5.3.4. installieren. ab 5.3.4. ist es gefixt)
                          Admin Adapter updaten.
                          Repositories wieder auf stable stellen. (1 anklicken)
                          Fertig
                          https://www.youtube.com/c/Elzershark
                          https://t.me/joinchat/BD87n3xMU0QzYmUy
                          https://www.facebook.com/elzershark
