  4. [gelöst] kann nichts updaten
    6.0k
31 Beiträge 4 Kommentatoren 4.3k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    @skinni sagte in kann nichts updaten:
    Das hab ich auch immer brav gemacht,
    Sorry, habe nichts gesagt. Steht aber in keinem der vorherigen Post oder bin ich blind.!?
    skinni
    @wendy2702 nee hatte ich nicht erwähnt, alles gut. ich bin ja für alles dankbar.
      @skinni
      iobroker repo list
      iobroker update
      iobroker upgrade
      skinni
      @thomas-braun said in kann nichts updaten:
      @skinni
      iobroker repo list
      iobroker update
      iobroker upgrade
      Leider das gleich Ergebnis, läuft alles durch aber am Ende ist nichts passiert
      pi@iobroker:~ $ iobroker upgrade
      This upgrade of "shelly" will at least introduce the following changes:
      -> 5.3.2:
      Added cover position status for generation 2 devices
      Added cover power, voltage, current and energy for generation 2 devices
      Updated switch roles for material ui (switch.power to switch)
      -> 5.3.1:
      Don't ack new values directly after change
      -> 5.3.0:
      Added Shelly Plus I4
      Added more objects for power metering channels (current, voltage, limits, ...)
      Moved device temperature of generation 2 devices to relays (this is the official way)
      Added Sys channel (eco mode, timezone, ...) for generation 1 devices
      Fixed datatype error of Shelly 1/PM ext switch
      Added option to enable/disable WiFi access point (generation 2 devices)
      Added power limits and position control for covers (generation 2 devices)
      Removed colors for online state indication on device objects
      -> 5.2.0:
      Added Shelly Pro 1
      Added Shelly Pro 1 PM
      Added Shelly Pro 2
      Added Shelly Pro 2 PM
      Added Shelly Plus 2 PM
      Allow to change device and channel names of generation 2 devices
      Added auto on/off timers for generation 2 devices
      Added input mode, events and initial state for generation 2 devices
      Added support of covers / shutters for generation 2 devices
      Replaced node-fetch with axios (also for digest auth)
      -> 5.1.3:
      Changed common.states strings to objects
      Just perform firmware update if an available update was detected
      Extended logging for CoAP
      -> 5.1.2:
      Fixed Shelly UNI ADC voltage
      Fixed dimmer brightness values handling
      Logging improvements for offline devices
      -> 5.1.1:
      Fixed firmware auto update
      Updated timeouts
      Added command source for shelly 2.5
      Added color for device objects as online indicator
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade shelly from @4.1.2 to @5.3.2 now? [(y)es, (n)o]: n
      No upgrade of "shelly" desired.
      This upgrade of "javascript" will introduce the following changes:
      -> 5.3.3:
      Added async functions: createStateAsync, deleteStateAsync
      -> 5.3.2:
      fix problem that scripts were not starting when scriptsEnabled State was triggered (or startScript was used)
      Make sure callbacks on startScript/stopScript work and Async variants also resolve
      Make sure startScriptAsync, stopScriptAsync and runScriptAsync resolve in debug mode too
      Would you like to upgrade javascript from @5.3.1 to @5.3.3 now? [(y)es, (n)o]: y
      Update javascript from @5.3.1 to @5.3.3
      NPM version: 6.14.16
      Installing iobroker.javascript@5.3.3... (System call)
      upload [103] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
      upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
      upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
      upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png
      upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pt.js google-blockly/msg/js/pt.js application/javascript
      upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
      upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
      upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/plugins/bundle.js plugins/bundle.js application/javascript
      upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.367f9424.js static/js/runtime-main.367f9424.js application/javascript
      upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
      upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
      upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
      upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
      upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
      upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
      upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
      upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
      upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
      upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
      upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
      upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
      upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
      upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
      upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
      upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
      upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
      upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
      upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
      upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
      upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
      This upgrade of "iot" will introduce the following changes:
      -> 1.10.0:
      Respect min/max when calculating the value for byOn with % values
      Would you like to upgrade iot from @1.9.7 to @1.10.0 now? [(y)es, (n)o]: y
      Update iot from @1.9.7 to @1.10.0
      Installing iobroker.iot@1.10.0... (System call)
      upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
      upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
      upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
      upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
      upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
      upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
      upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
      upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
      upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
      upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
      upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
      upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.f1408482.chunk.js static/js/2.f1408482.chunk.js application/javascript
      upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.f1408482.chunk.js.LICENSE.txt static/js/2.f1408482.chunk.js.LICENSE.txt text/plain
      upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.f1408482.chunk.js.map static/js/2.f1408482.chunk.js.map application/json
      upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.eedf2471.chunk.js static/js/main.eedf2471.chunk.js application/javascript
      upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.eedf2471.chunk.js.map static/js/main.eedf2471.chunk.js.map application/json
      upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ef534f76.js static/js/runtime-main.ef534f76.js application/javascript
      upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ef534f76.js.map static/js/runtime-main.ef534f76.js.map application/json
      This upgrade of "influxdb" will introduce the following changes:
      -> 2.6.3:
      Fix potential crash cases (Sentry IOBROKER-INFLUXDB-4Q)
      Would you like to upgrade influxdb from @2.6.2 to @2.6.3 now? [(y)es, (n)o]: y
      Update influxdb from @2.6.2 to @2.6.3
      Installing iobroker.influxdb@2.6.3... (System call)
      Update "system.adapter.influxdb.0"
      upload [15] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/custom_m.html custom_m.html text/html
      upload [14] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [13] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [12] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [11] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [10] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [9] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [8] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [7] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [6] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [5] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [4] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/index_m.html index_m.html text/html
      upload [3] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/influxdb.png influxdb.png image/png
      upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonCustom.json jsonCustom.json application/json
      upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/javascript
      pi@iobroker:~ $ iobroker update
      Used repository: beta
      Adapter    "admin"        : 5.3.1    , installed 5.3.1
      Adapter    "alexa2"       : 3.12.0   , installed 3.12.0
      Adapter    "backitup"     : 2.3.5    , installed 2.3.5
      Adapter    "daikin"       : 1.3.3    , installed 1.3.3
      Adapter    "deconz"       : 1.3.20   , installed 1.3.20
      Adapter    "devices"      : 1.0.10   , installed 1.0.10
      Adapter    "discovery"    : 2.8.0    , installed 2.8.0
      Adapter    "fb-checkpresence": 1.1.13, installed 1.1.13
      Adapter    "flot"         : 1.10.7   , installed 1.10.7
      Adapter    "fronius"      : 1.1.3    , installed 1.1.3
      Adapter    "history"      : 1.11.0   , installed 1.11.0
      Adapter    "hm-rega"      : 3.0.37   , installed 3.0.37
      Adapter    "hm-rpc"       : 1.15.8   , installed 1.15.8
      Adapter    "influxdb"     : 2.6.3    , installed 2.6.2  [Updatable]
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.10.0   , installed 1.9.7  [Updatable]
      Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
      Adapter    "javascript"   : 5.3.3    , installed 5.3.1  [Updatable]
      Controller "js-controller": 4.0.19   , installed 4.0.18 [Updatable]
      Adapter    "luftdaten"    : 2.1.3    , installed 2.1.3
      Adapter    "mihome-vacuum": 3.3.3    , installed 3.3.3
      Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
      Adapter    "ph803w"       : 1.0.1    , installed 1.0.1
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      Adapter    "scenes"       : 2.3.9    , installed 2.3.9
      Adapter    "shelly"       : 5.3.2    , installed 4.1.2  [Updatable]
      Adapter    "simple-api"   : 2.6.3    , installed 2.6.3
      Adapter    "socketio"     : 4.1.4    , installed 4.1.4
      Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
      Adapter    "statistics"   : 1.0.10   , installed 1.0.10
      Adapter    "synology"     : 1.1.3    , installed 1.1.3
      Adapter    "telegram"     : 1.11.1   , installed 1.11.1
      Adapter    "text2command" : 2.2.1    , installed 2.2.1
      Adapter    "tr-064"       : 4.2.15   , installed 4.2.15
      Adapter    "web"          : 4.2.0    , installed 4.2.0
      Adapter    "ws"           : 1.2.0    , installed 1.2.0
      Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
      pi@iobroker:~ $
      • S skinni
        @skinni
        iobroker repo list
        iobroker update
        iobroker upgrade
        -> 5.3.2:
        -> 5.3.1:
        -> 5.3.0:
        -> 5.2.0:
        Added Shelly Pro 1
        Added Shelly Pro 2
        -> 5.1.3:
        -> 5.1.2:
        -> 5.1.1:
        Updated timeouts
        -> 5.3.3:
        -> 5.3.2:
        -> 1.10.0:
        -> 2.6.3:
        pi@iobroker:~ $
        @skinni
        dmesg -T | grep -i ext4
        Und bitte zieh alle Adapter nach oben.
          @skinni
          @thomas-braun sagte in kann nichts updaten:
          kann er ja nicht
            kann er ja nicht
            Ich meinte damit, dass man angebotene Updates nicht verneint.
              skinni
              Der shelly Adapter ab 5 macht irgendwas kaputt, den hatte ich mal getestet und seitdem ignoriert, aber zum Test kann ich den natürlich auch mal nicht verneinen
              pi@iobroker:~ $ dmesg -T | grep -i ext4
              [Thu Mar 10 16:35:00 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:05:D6:B7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e52a9d10-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
              [Thu Mar 10 16:35:00 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [Thu Mar 10 16:35:00 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Thu Mar 10 16:35:02 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              pi@iobroker:~ $
              • S skinni
                pi@iobroker:~ $
                skinni
                das hab ich in nem log gefunden mit upgrade --debug
                314 silly resolveWithNewModule minimist@1.2.5 checking installable status
                315 verbose stack Error: Invalid tag name "node_modules\tr-O64": Tags may not have any characters that encodeURIComponent encodes.
                315 verbose stack     at invalidTagName (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:91:15)
                315 verbose stack     at fromRegistry (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:296:13)
                315 verbose stack     at resolve (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:81:12)
                315 verbose stack     at npa (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:52:10)
                315 verbose stack     at doesChildVersionMatch (/usr/lib/node_modules/npm/lib/install/deps.js:91:21)
                315 verbose stack     at isDep (/usr/lib/node_modules/npm/lib/install/deps.js:163:27)
                315 verbose stack     at addRequiredDep (/usr/lib/node_modules/npm/lib/install/deps.js:175:13)
                315 verbose stack     at resolveWithExistingModule (/usr/lib/node_modules/npm/lib/install/deps.js:630:3)
                315 verbose stack     at /usr/lib/node_modules/npm/lib/install/deps.js:566:5
                315 verbose stack     at /usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:35
                315 verbose stack     at Array.forEach (<anonymous>)
                315 verbose stack     at /usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:11
                315 verbose stack     at asyncMap (/usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:51:8)
                315 verbose stack     at exports.loadExtraneous.andResolveDeps (/usr/lib/node_modules/npm/lib/install/deps.js:565:3)
                315 verbose stack     at Array.<anonymous> (/usr/lib/node_modules/npm/node_modules/slide/lib/bind-actor.js:15:8)
                316 verbose cwd /opt/iobroker
                317 verbose Linux 5.10.103-v7l+
                318 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "--save-exact" "iobroker.javascript@5.3.3"
                319 verbose node v14.19.0
                320 verbose npm  v6.14.16
                321 error code EINVALIDTAGNAME
                322 error Invalid tag name "node_modules\tr-O64": Tags may not have any characters that encodeURIComponent encodes.
                323 verbose exit [ 1, true ]
                • S skinni
                  Der Fehler ist 'uralt'. Ich weiß nur nicht mehr aus dem Stehgreif wie man den umschifft.
                  Der tr-064 Adapter ist (oder war) installiert?
                    über Suche und 4 Verlinkungen bin ich hierhin gekommen:
                    https://forum.iobroker.net/topic/46210/npm-problem/2?_=1646932290891
                    Bin auch über das O statt der 0 in TR-064 gestolpert
                    Scheint sich um den veralteten TR64 zu handeln.
                      skinni
                      @homoran der ist installiert, aber war deaktiviert, ich versuche ihn gerade loszuwerden
                      • S skinni
                        skinni
                        die Deinstallation des Adapters hat gefühlt ewig gedauert, aber jetzt funktioniert wieder alles.
                        Merkwürdig, dass der ausgerechnet jetzt Probleme gemacht hat, den hatte ich schon seit ziemlich vielen Monaten, vermutlich Jahren, deaktiviert mit rumgeschleppt
                        Vielen Dank an alle die geholfen haben!
